thank you sir , for a bit look at me. ..No problem if you don't know about FL Studio.My FL Studio has not a special setting for midi interface.There is not a special
midi contoller made for only FL studio. Every Generic controller is working. I had use three words(tempo,pitch,target) to tell you only just three parameter.
We can also use words (Parameter1,Parameter2,Parameter3). My FL Studio does not assign any slider or knob to particular parameter automaticaly. when we
connect any(plug & play)midi contoller to PC. we will enable it in midi menu by name.it will be ready to use. Any activity of midi controller like as moving slider,knob or pressing any button will be show in midi meter(midi meter show us that our midi controller in working or not) in this soft ware.we can assign any parameter to be control from any knob or slider by setup of that parameter manualy .I am using my( Roland xp 30 synthesizer) as midi controller [you are seeing in picture].I enabled it as
generic controller in FL Studio once. Now every time FL studio establish link to it automaticaly if it is connected.No matter if we connect it after opening software
.it begin working like as(usb optical mouse or typing keyboard). I also did not intall any driver for it.It is working as plug&play Device. ,,,,,,,,,,,,,,,,,,,,,,
Now please attention to troubleshooting. ....
Please Note two main problem
(1): this board is also not doing any activity in serial monitor of Arduino .(2) My FL studio is not be open if teensy is connected .if i connect it after opening
FL Studio,it does not responding.I mean teensy is disturbing to my software.
,,,,,you made code to control 3 Parameters. I am going to explain
again that i want to use it in music software as midi controller.it should be only input device. It should control parameter value like( as knob or slider are control value in generic controller )through push buttons.please careful, first parameter(mention as "tempo" in sketch) should be highest by pressing increase button 512 times if we start from lowest .second & third parameter should be lowest to highest by pressing incease button 24 times.highest to lowest should be same way.
you already know which custom code should be upload to teensy for this purpose.I don't know about fuctions of sketch .so if there is need to make fuction
change in sketch, please edit it. and post it .i will copy whole text and paste to arduino New Sketch. ,,,,,,,,,,,,,,,should i re-upload sketch ?
,,,,,,,,,,,,,,,,i have done it without intalling serial drivers(following a tutorial from internet). am i right?
,,,,,,,,,,,,,,,,,,,,,,,,,,,A lot of THANKS you,in advance,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
