I'm curious as to the difference in the Program push button and the Reset pad on the bottom of the 3.2 unit. Are these explained in any documentation? Searching the Forum doesn't turn up much useful info.
For example, if I were to use the Program pin as a Reset line for other circuits, would it also restart the code on the Teensy? --as the Reset pin on an Arduino would. I'm going to put this Teensy into a closed case and will be unable to push the button. So I'm going to run a wire from the Program pin to an external accessible switch. Do I need to also connect to the Reset pad with another switch?
Thanks.
Thanks.
