Results 1 to 3 of 3
Thread: TJCTM24028-SPI screen+touch+sd?
    Oct 2016
    2
    I have recently purchased a cheap tft screen for use with arduino projects and have been struggling to get all of the features working correctly.
    The arduino/adafruit examples seem to work well with the tft and touch both working correctly, but I can't get the SD to work at all. The closest I have came, was getting the SD to load a file when the tft pins were configured incorrectly.
    Following the instructions in this thread haven't got me much further than I was before as the working code that people have posted is long gone.
    Can someone help me out getting the SD reader to work at the same time as tft and touch?
    Thanks.
    For reference, the following version of touchpaint works on my setup.
    TouchPaint.ino
      This is our touchscreen painting example for the Adafruit ILI9341 Shield
      ----> http://www.adafruit.com/products/1651
      Check out the links above for our tutorials and wiring diagrams
      These displays use SPI to communicate, 4 or 5 pins are required to
      interface (RST is optional)
      products from Adafruit!
      MIT license, all text above must be included in any redistribution
    #include <Wire.h>      // this is needed even tho we aren't using it
    #include "Adafruit_ILI9341.h"
    #include <XPT2046_Touchscreen.h>
    // This is calibration data for the raw touch data to the screen coordinates
    #define TS_MINX 150
    #define TS_MINY 130
    #define TS_MAXX 3800
    #define TS_MAXY 4000
    // The XPT2046 uses hardware SPI on the shield, and #8
    #define CS_PIN  8
    XPT2046_Touchscreen ts(CS_PIN);
    // The display also uses hardware SPI, plus #9 & #10
    #define TFT_DC 6 //9
    #define TFT_CS 5 //10
    #define TFT_RST 7 //8
    #define TFT_LED 9
    Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
    // Size of the color selection boxes and the paintbrush size
    #define BOXSIZE 40
    #define PENRADIUS 3
    int oldcolor, currentcolor;
    void setup(void) {
     // while (!Serial);     // used for leonardo debugging
      pinMode(TFT_LED, OUTPUT);
      digitalWrite(TFT_LED, HIGH);
      Serial.println(F("Touch Paint!"));
      tft.begin();
        ts.begin();
        tft.setRotation(3);
      // make the color selection boxes
      tft.fillRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_RED);
      tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_YELLOW);
      tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9341_GREEN);
      tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9341_CYAN);
      tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9341_BLUE);
      tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_MAGENTA);
      // select the current color 'red'
      tft.drawRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
      currentcolor = ILI9341_RED;
      // See if there's any  touch data for us
      if (ts.bufferEmpty()) {
        return;
      // You can also wait for a touch
      if (! ts.touched()) {
        return;
      // Retrieve a point
      TS_Point p = ts.getPoint();
      Serial.print("X = "); Serial.print(p.x);
      Serial.print("\tY = "); Serial.print(p.y);
      Serial.print("\tPressure = "); Serial.println(p.z);
      // Scale from ~0->4000 to tft.width using the calibration #'s
      p.x = 320 - map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
      p.y = 240 - map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
     // int tx = p.x;
     // p.x = p.y;
     // p.y = 240-tx;
     if(p.z > 0){
      Serial.print("("); Serial.print(p.x);
      Serial.print(", "); Serial.print(p.y);
      Serial.println(")");
      if (p.y < BOXSIZE) {
         oldcolor = currentcolor;
         if (p.x < BOXSIZE) {
         } else if (p.x < BOXSIZE*2) {
           currentcolor = ILI9341_YELLOW;
           tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
         } else if (p.x < BOXSIZE*3) {
           currentcolor = ILI9341_GREEN;
           tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
         } else if (p.x < BOXSIZE*4) {
           currentcolor = ILI9341_CYAN;
           tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
         } else if (p.x < BOXSIZE*5) {
           currentcolor = ILI9341_BLUE;
           tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
         } else if (p.x < BOXSIZE*6) {
           currentcolor = ILI9341_MAGENTA;
           tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
         if (oldcolor != currentcolor) {
            if (oldcolor == ILI9341_RED)
            if (oldcolor == ILI9341_YELLOW)
            if (oldcolor == ILI9341_GREEN)
            if (oldcolor == ILI9341_CYAN)
            if (oldcolor == ILI9341_BLUE)
            if (oldcolor == ILI9341_MAGENTA)
      if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
        tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
    Nov 2015
    Cold hollow VT
    188
    It sounds like you are experiencing bus conflicts. Each device on the SPI bus is controlled by a chip select. Only ONE chip select may be active at any time or there will be two or more devices fighting signal levels on the bus. Sometimes the driver files handle control of the chip selects other times the program must handle them, sometimes the devices them selves are faulty in design and do not act as intended making it necessary to add additional logic to control their level states.
    I suggest you scrutinize your code to be certain only the device that should be active has chip select. Hang the code in a loop for each device and check the level on the CS line.
    Sumotoy had a similar problem with the RA8875 controller and this is an example of how he fixed it.
    Oct 2016
    2
    You know what? I've been looking so hard at the tft code, for a moment, I completely forgot that even when not using the touch screen, it's still connected. Simple remembering that, was enough to remind me to set the T_CS high and wollop! it's working correctly.
    Thinks Lightning!
