I just updated the library with an increased delayNanoseconds time, should hopefully be a little more robust now.
Hi Brian
Taking a break from my other distractions and just gave you latest library changes a try with one of those generic mpu-9250 boards and I am having problems. Haven't had a chance to debug yet but this is all I am getting with the Basic_SPI example:
Code:IMU initialization unsuccessful
Now if I use the last version of the library I was using it works without an issue even at 600Mhz. I am attaching the version I have that works. As time permits will do some debugging.
@ora_jago you are free to give the version I just attached to see if it works - might help with the debugging.
hi mjs513 thanks for your sharing....it's work for me....
Hi @brtaylor
Strange that its not working for me with my breakouts - what breakouts are you using?
The old emsensor boards modified to work with SPI.
Tested that board ("The old emsensor boards modified to work with SPI.") this morning and its working for me with your current lib. But if I use one of the ebay/amazon mpu-9250's thats when I run into problems.
