Page 10 of 10 FirstFirst ... 8 9 10
Results 226 to 242 of 242
Thread: MPU-9250 Teensy Library
  1. #226
    12,380
    My TD 1.44 download dated 9/19/2018 give a splash of just 1.44 - not beta?
    As for the Amazon 9250's - minor name change on the silkscreen between the two - but all else looks the same on pin labels and parts location and type. Let me know when you get your hooked up Mike and I'll give mine try if possible. The ASYNC/DMA SPI seems like it would be helpful when getting 100-1000 updates a second! SPI faster and if the DMA engine does the work ASYNC then no wait when the INT arrives … then the data arrives … repeat.
    It has been some time - and not used or updated - but I was getting 1 Mhz or faster on i2c - though there was some anomaly I noted with leaving the update speed set I never resolved … maybe that was a side effect of the HIGH speed.
  2. #227
    5,596
    Never mind I know what I did. Better let Mr S. know.
    I remember, I was too but now I seem to be having a problem. Not sure what happened. Would like to track it down though. Just very strange because it seemed to be working in prior versions.
    I do remember we use to see spikes in the data periodically, don't know if that is related or not. What really got me was the temperature spikes dropping like that when I ran the filters.
  3. #228
    Mar 2016
    Portland, OR
    580
    Whoa, this is bizarre. Works great for me on Arduino 1.8.5 with Teensyduino 1.44, but not with 1.8.7...
  4. #229
    12,380
    Quote Originally Posted by brtaylor View Post
    Odd - they went to the parallel core building? What else I'm not sure. Maybe try a different compile Optimize and rebuild?
  5. #230
    Mar 2016
    Portland, OR
    580
    NEVERMIND...forgot that I had de-soldered some resistors and had to jumper a few more things than normal. Works fine on a fresh 1.8.7 with Teensyduino 1.44 install on Windows 10.
  6. #231
    5,596
    Ok, but not sure what that means when I am dealing with a normal breakout board. Are you using your board or a breakout board? Just curious I am not having a problem with Wire when using Kris Winer's library.
  7. #232
    Mar 2016
    Portland, OR
    580
    I'm using the breakout board from Embedded Masters:
    https://octopart.com/emsensr-mpu9250...sters-75645249
    To get SPI to work on that breakout there are a couple 0 Ohm resistors that need to be de-soldered, which I did. The thing is that then, you need to remember to tie nCS to power for I2C to work properly.
    If you can send some photos of your setup that might help diagnose what's going on.
  8. #233
    5,596
    Oh, ok now I understand what you were talking about. I have that board as well and modified it to use SPI. Didn't know all I had to do to I2C to work again was to tie nCS to power. Glad I asked.
    Still have to figure out why I am having issues with other breakout boards.
    TEMP CALC WRONG IN LIBRARY. By the way when I was working with the temp calc noticed you had the calculation wrong:
    IS:
    _t = ((((float) _tcounts) - _tempOffset)/_tempScale) + _tempOffset;
    SHOULD BE:
     _t = ((float) _tcounts / _tempScale) + _tempOffset)
  9. #234
    5,596
    Hi Brian - on the embedded masters 9250 breakout board I seem to remember you also had to connect vdio to vdd and FSYNC to ground is that correct?
    EDIT: THANKS FOR THE FAST RESPONSE
  10. #235
    Mar 2016
    Portland, OR
    580
    Yes, correct.
  11. #236
    May 2020
    15
    Hello everybody,
    I want to read the BMI160 with teensy3.6.
    I get the code from hanyazou and get the following error: Wire.endTransmission() failed.
    How can it set the sda, scl pin configuration in the BMI160Gen.cpp oder .h?
    Do you have an idea?
  12. #237
    Mar 2016
    Portland, OR
    580
    Quote Originally Posted by Siggi88 View Post
    Hello everybody,
    Seems like this deserves its own thread.
  13. #238
    Aug 2019
    10
    I try to use the brian taylor library for the mpu9250 (the library have been downloaded using the arduino library manager)
    I try to use the library with a basic blue mpu9250 board like this one : https://www.robot-maker.com/shop/cap...0-spi-217.html on a teensy 4.0 board.
    I connect :
    MPU9250 TO Teensy 4.0
    VCC 5V ( the mpu board have a 3.3V converter integrated)
    GND GND
    SCL/SCLK 13
    SDA/SDI 11
    AD0/SDO 12
    NCS 10
    FSYNC GND
    Other MPU9250 pins are left unconnected.
    I use the Basic SPI code to make a simple test.
    Basic_SPI.ino
    Brian R Taylor
    brian.taylor@bolderflight.com
    Copyright (c) 2017 Bolder Flight Systems
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software
    and associated documentation files (the "Software"), to deal in the Software without restriction,
    including without limitation the rights to use, copy, modify, merge, publish, distribute,
    sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is
    furnished to do so, subject to the following conditions:
    The above copyright notice and this permission notice shall be included in all copies or
    substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING
    BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
    NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM,
    DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
    OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    #include "MPU9250.h"
    // an MPU9250 object with the MPU-9250 sensor on SPI bus 0 and chip select pin 10
    MPU9250 IMU(SPI,10);
    int status;
      // serial to display data
      while(!Serial) {}
      // start communication with IMU
      status = IMU.begin();
      if (status < 0) {
        Serial.println("IMU initialization unsuccessful");
        Serial.println("Check IMU wiring or try cycling power");
        Serial.print("Status: ");
        Serial.println(status);
        while(1) {}
      // read the sensor
      IMU.readSensor();
      // display the data
      Serial.print(IMU.getAccelX_mss(),6);
      Serial.print("\t");
      Serial.print(IMU.getAccelY_mss(),6);
      Serial.print("\t");
      Serial.print(IMU.getAccelZ_mss(),6);
      Serial.print("\t");
      Serial.print(IMU.getGyroX_rads(),6);
      Serial.print("\t");
      Serial.print(IMU.getGyroY_rads(),6);
      Serial.print("\t");
      Serial.print(IMU.getGyroZ_rads(),6);
      Serial.print("\t");
      Serial.print(IMU.getMagX_uT(),6);
      Serial.print("\t");
      Serial.print(IMU.getMagY_uT(),6);
      Serial.print("\t");
      Serial.print(IMU.getMagZ_uT(),6);
      Serial.print("\t");
      Serial.println(IMU.getTemperature_C(),6);
    The output I have on the serial monitor is :
    Status: -2
    Can someone confirm me that the librarie I try to use can be used on a teensy4.0?
    I read in another thread that status = - 2 was a " spi problem "... Does I need to rewrite some code to make it working?
    Can someone help me to figure what step is wrong in my experiment?
    Thank you in advance
    Best regards.
  14. #239
    Mar 2016
    Portland, OR
    580
    The library has not been updated for Teensy 4.x. There has been a fork and a PR to incorporate the necessary updates, but I haven't managed to test it yet (still haven't taken my Teensy 4 out of the package...). The PR is here, if you would like to give it a go:
    https://github.com/bolderflight/MPU9250/pull/64
  15. #240
    Aug 2019
    10
    Thank you for this fast reply.
    I will give it a try and come back with my result.
  16. #241
    Aug 2019
    10
    With the modification made, now the status is 1 as expected and basic spi as well as interrupt spi seems to work well.
    Thank you!
    Note : I only added the
    #if defined(__IMXRT1062__)
    #else
    part in the .cpp file.
    I don't know what is the "int readSensorCounts(int16_t* rawValues);" modification in the .h file ...
    Best regards.
  17. #242
    Mar 2016
    Portland, OR
    580
    Quote Originally Posted by Mike118 View Post
    IIRC, some people wanted access to the raw counts from the sensor data instead of the float values.
