Results 1 to 4 of 4
Thread: MKL26Z64VLH4 64 pin LQFP IC with teensy LC
    Oct 2016
    2
    Hi All,
    I am using MKL26Z64VLH4 64 pin LQFP IC for my project. I need to know whether I can use MINI 54 pre programmed IC for teensy LC to program.
    If yes how to enable pins which are not defined in teensy LC schematics such as PTB18 PTB19 etc. Can I also use the 4 ADC available in the IC to configure in a differential mode as in teensy 3.1. Please suggest.
    Im going to bump this thread instead of making a new one.
    Can the MKL26Z64VLH4 be used in place of the QFN version? And there will be no issue with the MKL04Z32 Bootloader?
    21,346
    I do not know. It might work. In fact, odds are pretty good it'll work. But that chip isn't officially supported and hasn't been tested, so it might not work. If it doesn't work, I can tell you 1 thing with certainty: PJRC will not alter the bootloader to support it.
    If you do try this, I recommend building just 1 or 2 test prototypes to confirm whether it works.
    Well not without a generous donation right?
    Ok ill give it a shot. Ideally I would hope it works exactly the same since i want to prototype with LQFP and production will be QFN.
    Excellent community support as always Paul!
