I'm getting a ton of distortion/noise from what seems to be spi. Here is a audio file from the headphone jack on the audio shield. https://dl.dropboxusercontent.com/u/32253157/Noisey.wma
The wiring is a 3.5mm plug wired to the audio input l/r on the audio shield. The teensy 3.1/3.2 is powered by battery 4.2v. The lights aren't connected for trouble shooting.
original source: https://github.com/2xAA/Audio-Light-Tube
I've edited the code from above to work with the audio shield.
I've done the following:
remove the leds
different teensy and audio shield
different pins for the led data
#include <Adafruit_NeoPixel.h>
#define NEOPIN 0
#define NUMPIXELS 144
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, NEOPIN, NEO_GRB + NEO_KHZ400);
// const int myInput = AUDIO_INPUT_MIC;
AudioInputI2S i2s1; //xy=290,327
AudioMixer4 mixer1; //xy=510,359
AudioOutputI2S i2s2; //xy=701,459
AudioAnalyzeRMS rms1; //xy=735,363
AudioAnalyzePeak peak1; //xy=739,294
AudioAnalyzeFFT256 fft256_1; //xy=742,329
AudioConnection patchCord1(i2s1, 0, mixer1, 0);
AudioConnection patchCord2(i2s1, 1, mixer1, 1);
AudioConnection patchCord3(mixer1, rms1);
AudioConnection patchCord4(mixer1, peak1);
AudioConnection patchCord5(mixer1, 0, i2s2, 0);
AudioConnection patchCord6(mixer1, fft256_1);
int rgbColour[3];
int mode = 0; //default mode
int modes = 6; //num modes
const int buttonPin = 2; // button pin
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
bool pressed = false;
int MAXBRIGHTNESS = 25;
AudioMemory(6);
audioShield.enable();
audioShield.inputSelect(myInput);
audioShield.volume(10);
pinMode(buttonPin, INPUT);
AudioMemory(16);
pixels.begin();
pixels.setBrightness(255); // 0-255
// Start off with red.
rgbColour[0] = 150;
rgbColour[1] = 75;
rgbColour[2] = 25;
elapsedMillis fps;
float floatPeak = 0;
int monoPeak = 0;
int maxPeak = 0;
bool initialised = false;
float rmsValue = 0.0;
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max) {
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH && pressed == false) {
// if the current state is HIGH then the button
// wend from off to on:
if(mode+1 < modes) mode++;
else mode = 0;
pressed = true;
// clear the strip
for(int i = 0; i < NUMPIXELS; i++) {
pixels.setPixelColor(i, pixels.Color(0, 0, 0));
pixels.show();
if(buttonState == LOW) {
pressed = false;
if (fps > 24 || initialised) {
if (peak1.available()) {
initialised = true;
floatPeak = peak1.read() * 30.0;
monoPeak = floatPeak;
if(maxPeak < monoPeak) maxPeak = monoPeak;
if(mode == 0) vuMeter();
if(rms1.available()) {
rmsValue = rms1.read();
if(mode == 1) fftBlink();
if(mode == 2) rms();
if(mode == 3) chaseStrobe();
if(mode == 4) strobe();
if(mode == 5) multiStrobe();
remove the leds
