Pin Name Default ALT0 ALT1 ALT2 ALT3 ALT4 ALT5 ALT6 ALT7
0 PTB16 TSI0_CH9 TSI0_CH9 PTB16 SPI1_SOUT UART0_RX FTM_CLKIN0 FB_AD17/SDRAM_D17 EWM_IN TPM_CLKIN0
1 PTB17 TSI0_CH10 TSI0_CH10 PTB17 SPI1_SIN UART0_TX FTM_CLKIN1 FB_AD16/SDRAM_D16 EWM_OUT_b TPM_CLKIN1
2 PTD0/LLWU_P12 DISABLED PTD0/LLWU_P12 SPI0_PCS0 UART2_RTS_b FTM3_CH0 FB_ALE/FB_CS1_b/FB_TS_b
3 PTA12 CMP2_IN0 CMP2_IN0 PTA12 CAN0_TX FTM1_CH0 RMII0_RXD1/MII0_RXD1 I2C2_SCL I2S0_TXD0 FTM1_QD_PHA/TPM1_CH0
4 PTA13/LLWU_P4 CMP2_IN1 CMP2_IN1 PTA13/LLWU_P4 CAN0_RX FTM1_CH1 RMII0_RXD0/MII0_RXD0 I2C2_SDA I2S0_TX_FS FTM1_QD_PHB/TPM1_CH1
5 PTD7 DISABLED PTD7 CMT_IRO UART0_TX FTM0_CH7 SDRAM_CKE FTM0_FLT1 SPI1_SIN
6 PTD4/LLWU_P14 DISABLED PTD4/LLWU_P14 SPI0_PCS1 UART0_RTS_b FTM0_CH4 FB_AD2/SDRAM_A10 EWM_IN SPI1_PCS0
7 PTD2/LLWU_P13 DISABLED PTD2/LLWU_P13 SPI0_SOUT UART2_RX FTM3_CH2 FB_AD4/SDRAM_A12 I2C0_SCL
8 PTD3 DISABLED PTD3 SPI0_SIN UART2_TX FTM3_CH3 FB_AD3/SDRAM_A11 I2C0_SDA
9 PTC3/LLWU_P7 CMP1_IN1 CMP1_IN1 PTC3/LLWU_P7 SPI0_PCS1 UART1_RX FTM0_CH2 CLKOUT I2S0_TX_BCLK
10 PTC4/LLWU_P8 DISABLED PTC4/LLWU_P8 SPI0_PCS0 UART1_TX FTM0_CH3 FB_AD11/SDRAM_A19 CMP1_OUT
11 PTC6/LLWU_P10 CMP0_IN0 CMP0_IN0 PTC6/LLWU_P10 SPI0_SOUT PDB0_EXTRG I2S0_RX_BCLK FB_AD9/SDRAM_A17 I2S0_MCLK
12 PTC7 CMP0_IN1 CMP0_IN1 PTC7 SPI0_SIN USB0_SOF_OUT I2S0_RX_FS FB_AD8/SDRAM_A16
13 PTC5/LLWU_P9 DISABLED PTC5/LLWU_P9 SPI0_SCK LPTMR0_ALT2 I2S0_RXD0 FB_AD10/SDRAM_A18 CMP0_OUT FTM0_CH2
14 PTD1 ADC0_SE5b ADC0_SE5b PTD1 SPI0_SCK UART2_CTS_b FTM3_CH1 FB_CS0_b
15 PTC0 ADC0_SE14/TSI0_CH13 ADC0_SE14/TSI0_CH13 PTC0 SPI0_PCS4 PDB0_EXTRG USB0_SOF_OUT FB_AD14/SDRAM_A22 I2S0_TXD1
16 PTB0/LLWU_P5 ADC0_SE8/ADC1_SE8/TSI0_CH0 ADC0_SE8/ADC1_SE8/TSI0_CH0 PTB0/LLWU_P5 I2C0_SCL FTM1_CH0 RMII0_MDIO/MII0_MDIO SDRAM_CAS_b FTM1_QD_PHA/TPM1_CH0
17 PTB1 ADC0_SE9/ADC1_SE9/TSI0_CH6 ADC0_SE9/ADC1_SE9/TSI0_CH6 PTB1 I2C0_SDA FTM1_CH1 RMII0_MDC/MII0_MDC SDRAM_RAS_b FTM1_QD_PHB/TPM1_CH1
18 PTB3 ADC0_SE13/TSI0_CH8 ADC0_SE13/TSI0_CH8 PTB3 I2C0_SDA UART0_CTS_b/UART0_COL_b ENET0_1588_TMR1 SDRAM_CS0_b FTM0_FLT0
19 PTB2 ADC0_SE12/TSI0_CH7 ADC0_SE12/TSI0_CH7 PTB2 I2C0_SCL UART0_RTS_b ENET0_1588_TMR0 SDRAM_WE FTM0_FLT3
20 PTD5 ADC0_SE6b ADC0_SE6b PTD5 UART0_CTS_b/UART0_COL_b FTM0_CH5 FB_AD1/SDRAM_A9 EWM_OUT_b SPI1_SCK
21 PTD6/LLWU_P15 ADC0_SE7b ADC0_SE7b PTD6/LLWU_P15 SPI0_PCS3 UART0_RX FTM0_CH6 FB_AD0 FTM0_FLT0 SPI1_SOUT
22 PTC1/LLWU_P6 ADC0_SE15/TSI0_CH14 ADC0_SE15/TSI0_CH14 PTC1/LLWU_P6 SPI0_PCS3 UART1_RTS_b FTM0_CH0 FB_AD13/SDRAM_A21 I2S0_TXD0
23 PTC2 ADC0_SE4b/CMP1_IN0/TSI0_CH15 ADC0_SE4b/CMP1_IN0/TSI0_CH15 PTC2 SPI0_PCS2 UART1_CTS_b FTM0_CH1 FB_AD12/SDRAM_A20 I2S0_TX_FS
24 PTE26 DISABLED PTE26 ENET_1588_CLKIN UART4_CTS_b RTC_CLKOUT USB0_CLKIN
25 PTA5 DISABLED PTA5 USB0_CLKIN FTM0_CH2 RMII0_RXER/MII0_RXER CMP2_OUT I2S0_TX_BCLK JTAG_TRST_b
26 PTA14 DISABLED PTA14 SPI0_PCS0 UART0_TX RMII0_CRS_DV/MII0_RXDV I2C2_SCL I2S0_RX_BCLK I2S0_TXD1
27 PTA15 CMP3_IN1 CMP3_IN1 PTA15 SPI0_SCK UART0_RX RMII0_TXEN/MII0_TXEN I2S0_RXD0
28 PTA16 CMP3_IN2 CMP3_IN2 PTA16 SPI0_SOUT UART0_CTS_b/UART0_COL_b RMII0_TXD0/MII0_TXD0 I2S0_RX_FS I2S0_RXD1
29 PTB18 TSI0_CH11 TSI0_CH11 PTB18 CAN0_TX FTM2_CH0 I2S0_TX_BCLK FB_AD15/SDRAM_A23 FTM2_QD_PHA/TPM2_CH0
30 PTB19 TSI0-CH12 TSI0_CH12 PTB19 CANO_RX FTM2_CH1 I2S0_TX_FS FB_OE_b FTM2_QD_PHB/TPM2_CH1
31 PTB10 ADC1_SE14 ADC1_SE14 PTB10 SPI1_PCS0 UART3_RX FB_AD19/SDRAM_D19 FTM0_FLT1
32 PTB11 ADC1_SE15 ADC1_SE15 PTB11 SPI1_SCK UART3_TX FB_AD18/SDRAM_D18 FTM0_FLT2
33 PTE24 ADC0_SE17 ADC0_SE17 PTE24 CAN1_TX UART4_TX I2C0_SCL EWM_OUT_b
34 PTE25/LLWU_P21 ADC0_SE18 ADC0_SE18 PTE25/LLWU_P21 CAN1_RX UART4_RX I2C0_SDA EWM_IN
35 PTC8 ADC1_SE4b/CMP0_IN2 ADC1_SE4b/CMP0_IN2 PTC8 FTM3_CH4 I2S0_MCLK FB_AD7/SDRAM_A15
36 PTC9 ADC1_SE5b/CMP0_IN3 ADC1_SE5b/CMP0_IN3 PTC9 FTM3_CH5 I2S0_RX_BCLK FB_AD6/SDRAM_A14 FTM2_FLT0
37 PTC10 ADC1_SE6b ADC1_SE6b PTC10 I2C1_SCL FTM3_CH6 I2S0_RX_FS FB_AD5/SDRAM_A13
38 PTC11/LLWU_P11 ADC1_SE7b ADC1_SE7b PTC11/LLWU_P11 I2C1_SDA FTM3_CH7 I2S0_RXD1 FB_RW_b
39 PTA17 ADC1_SE17 ADC1_SE17 PTA17 SPI0_SIN UART0_RTS_b RMII0_TXD1/MII0_TXD1 I2S0_MCLK
Updates in Core Pins.h
40 A28 DISABLED PTA28 MII0_TXER FB_A25
41 A29 DISABLED PTA29 MII0_COL FB_A24
42 A26 DISABLED PTA26 MII0_TXD3 FB_A27
43 B20 DISABLED PTB20 SPI2_PCS0 FB_AD31/SDRAM_D31 CMP0_OUT
44 B22 DISABLED PTB22 SPI2_SOUT FB_AD29/SDRAM_D29 CMP2_OUT
45 B23 DISABLED PTB23 SPI2_SIN SPI0_PCS5 FB_AD28/SDRAM_D28 CMP3_OUT
46 B21 DISABLED PTB21 SPI2_SCK FB_AD30/SDRAM_D30 CMP1_OUT
47 D8 DISABLED PTD8/LLWU_P24 I2C0_SCL LPUART0_RX FB_A16
48 D9 DISABLED PTD9 I2C0_SDA LPUART0_TX FB_A17
49 B4 ADC1_SE10 ADC1_SE10 PTB4 ENET0_1588_TMR2 SDRAM_CS1-b FTM1_FLT0
50 B5 ADC1_SE11 ADC1_SE11 PTB5 ENET0_1588_TMR3 FTM2_FLT0
51 D14 DISABLED PTD14 SPI2_SIN SDHC0_D6 FB_A22
52 D13 DISABLED PTD13 SPI2_SOUT SDHC0_D5 FB_A21
53 D12 DISABLED PTD12 SPI2_SCK FTM3_FLT0 SDHC0_D4 FB_A20
54 D15 DISABLED PTD15 SPI2_PCS1 SDHC0_D7 FB_A23
55 D11 DISABLED PTD11/LLWU_P25 SPI2_PCS0 SDHC0_CLKIN LPUART0_CTS_b FB_A19
56 E10 DISABLED PTE10/LLWU_P18 I2C3_SDA I2S0_TXD0 LPUART0_CTS_b FTM3_CH5 USB1_ID
57 E11 DISABLED PTE11 I2C3_SCL I2S0_TX_FS LPUART0_RTS_b FTM3_CH6
A10 ADC1_DP0/ADC0_DP3 ADC1_DP0/ADC0_DP3
A11 ADC1_DM0/ADC0_DM3 ADC1_DM0/ADC0_DM3
Aref
5 PIN USB HOST
G
G
D+ J1
D- K1
5V
On-board SD card (dedicated 4-bit SDIO)
58 PTE0 ADC1_SE4a ADC1_SE4a PTE0 SPI1_PCS1 UART1_TX SDHC1_D1 TRACE_CLKOUT I2C1_SDA RTC_CLKOUT
59 PTE1 ADC1_SE5a ADC1_SE5a PTE1/LLWU_P0 SPI1_SOUT UART1_RX SDHC0_D0 TRACE_D3 I2C1_SCL SPI1_SIN
60 PTE2 PTE2/LLWU_P1 ADC1_SE6a PTE2/LLWU_P1 SPI1_SCK UART1_CTS_b SDHC0_DCLK TRACE_D2
61 PTE3 ADC1_SE7a ADC1_SE7a PTE3 SPI1_SIN UART1_RTS_b SDHC0_CMD TRACE_D1 SPI1_SOUT
62 PTE4 DISABLED PTE4/LLWU_P2 SPI1_PCS0 UART3_TX SDHC0_D3 TRACE_D0
63 PTE5 DISABLED PTE5 SPI1_PCS2 UART3_RX SDHC0_D2 FTM3_CH0
