Excellent results with Floating Point FFT/IFFT Processing and Teensy 3.6
thanks duff!
I ran your fastFFT and it had 12-15% CPU usage on the Teensy 3.5 @120MHz. That is not much difference to the Teensy 3.2 with 18%.
I was wondering whether it would be wise in the audio lib objects to convert the input samples to floating point, implement the FFT in floating point and then convert the output to 16 bit fixed point again (for Teensy 3.5/3.6)? Has anybody experience with that and would it be faster? Chip showed that the floating point calculations in Teensy 3.5/3.6 are so much faster, so maybe it could help speed up the whole FFT.
Frank
Chip, I got your AudioEffectFreqDomain working with the new arm_cfft functions:
#ifndef effect_freqDomain_h_
#define effect_freqDomain_h_
#include "Arduino.h"
#include "AudioStream.h"
#include "arm_math.h"
#include <arm_const_structs.h>
#include "utility/dspinst.h"  //copied from analyze_fft256.cpp.  Do we need this?
//// windows.c
//extern "C" {
//  extern const int16_t AudioWindowHanning256[];
//  extern const int16_t AudioWindowBartlett256[];
//  extern const int16_t AudioWindowBlackman256[];
//  extern const int16_t AudioWindowFlattop256[];
//  extern const int16_t AudioWindowBlackmanHarris256[];
//  extern const int16_t AudioWindowNuttall256[];
//  extern const int16_t AudioWindowBlackmanNuttall256[];
//  extern const int16_t AudioWindowWelch256[];
//  extern const int16_t AudioWindowHamming256[];
//  extern const int16_t AudioWindowCosine256[];
//  extern const int16_t AudioWindowTukey256[];
//assumes ADUIO_BLOCK_SAMPLES is 64 or 128.  Assumes 50% overlap
#define N_FFT 256
//#define N_FFT 1024
#define N_POS_BINS (N_FFT/2+1)
//define FFT_DATA_TYPE 16
#define FFT_DATA_TYPE 32
#if AUDIO_BLOCK_SAMPLES == 128
#define N_BUFF_BLOCKS (2)
#elif AUDIO_BLOCK_SAMPLES == 64
#define N_BUFF_BLOCKS (4)
#if FFT_DATA_TYPE == 16
  typedef q15_t fft_data_t;
#elif FFT_DATA_TYPE == 32
  typedef q31_t fft_data_t;
typedef struct complex_t {
  fft_data_t re;
  fft_data_t im;
} complex_t;
class AudioEffectFreqDomain : public AudioStream
  public:
    AudioEffectFreqDomain(void) : AudioStream(1, inputQueueArray), freqShift_bins(0) { }
    void setup(void) {
      Serial.println("AudioEffectFreqDomain: setup...");
      Serial.print("    : N_FFT = "); Serial.println(N_FFT);
      Serial.print("    : N_BUFF_BLOCKS = "); Serial.println(N_BUFF_BLOCKS);
      //initialize FFT and IFFT functions
 //       arm_cfft_radix4_init_q15(&fft_inst, N_FFT, 0, 1); //FFT
 //       arm_cfft_radix4_init_q15(&ifft_inst, N_FFT, 1, 1); //IFFT
//        arm_cfft_radix4_init_q31(&fft_inst, N_FFT, 0, 1); //FFT
//        arm_cfft_radix4_init_q31(&ifft_inst, N_FFT, 1, 1); //IFFT
      //define the default window
      //setWindowRectangular();
      setWindowHanning();
      //initialize the blocks for holding the previous data
      for (int i = 0; i < N_BUFF_BLOCKS; i++) {
        input_buff_blocks[i] = allocate();
        clear_audio_block(input_buff_blocks[i]);
        output_buff_blocks[i] = allocate();
        clear_audio_block(output_buff_blocks[i]);
    //void windowFunction(const int16_t *w) {
    //  window = w;
    void setWindowRectangular(void) {
      //flag__useWindow = 1;
      for (int i=0; i < N_FFT; i++) window[i] = (fft_data_t)(32767.0); //cast it to the right type
    void setWindowHanning(void) {
      for (int i=0; i < N_FFT; i++) window[i] = (fft_data_t)(32767.0*(-0.5*cos(2.0*PI*i/N_FFT) + 0.5)); //cast it to the right type
    virtual void update(void);
    ~AudioEffectFreqDomain(void) {
      //release allcoated memory
        if (input_buff_blocks[i] != NULL) release(input_buff_blocks[i]);
        if (output_buff_blocks[i] != NULL) release(output_buff_blocks[i]);
    void setFreqShiftBins(int value) {
      freqShift_bins = min(max(0,value),N_POS_BINS);
  private:
    int freqShift_bins;
    //int printFFTtoSerial = 4;  //how many FFT results to print before stopping
    int flipSignOddBins = 1;
    audio_block_t *inputQueueArray[1];
    audio_block_t *input_buff_blocks[N_BUFF_BLOCKS];
    audio_block_t *output_buff_blocks[N_BUFF_BLOCKS];
    //const int16_t *window;
    //q31_t buffer[N_FFT] __attribute__ ((aligned (4)));
    //q31_t second_buffer[N_FFT] __attribute__ ((aligned(4)));
    complex_t buffer[N_FFT];
    complex_t second_buffer[N_FFT];
    fft_data_t window[N_FFT];
//      arm_cfft_radix4_instance_q15 fft_inst;
//      arm_cfft_radix4_instance_q15 ifft_inst;
//      arm_cfft_radix4_instance_q31 fft_inst;
//      arm_cfft_radix4_instance_q31 ifft_inst;
    void clear_audio_block(audio_block_t *block) {
      for (int i = 0; i < AUDIO_BLOCK_SAMPLES; i++) block->data[i] = 0;
//static void apply_window_to_fft_q15_buffer(complex_t buff[], int16_t win[])
//  for (int i = 0; i < N_FFT; i++) {
//    //int32_t val = buff[i].re * win[i];
//    int32_t val = ((int32_t)buff[i].re) * ((int32_t)win[i]);
//    //*buf = signed_saturate_rshift(val, 16, 15);
//    buff[i].re = val >> 15;
static int adjustPhaseOfBins( complex_t second_buffer[], const int freqShift_bins, const int n_overlap, int call_count) {
  fft_data_t foo_val;
  switch (n_overlap) {
    case 1:   //0% overlap.  No phase shifting needed.
    case 2:  //50% overlap.  Every other bin gets shifted by 180 deg on every other call
      if (call_count==1) {
        if ((freqShift_bins % 2) == 1) {
          for (int i=0; i < N_POS_BINS; i++) {
            second_buffer[i].re = -second_buffer[i].re;  //shift by 180 deg
            second_buffer[i].im = -second_buffer[i].im ;    //shift by 180 deg
      call_count = !call_count;
   case 4:     //75% overlap.  Four call cycle
    int phase_shift_pi_2 = (freqShift_bins*call_count) % 4;  //multiples of pi/2
    switch (phase_shift_pi_2) {
      case 0:
        //no phase correction needed
      case 1:
          foo_val = second_buffer[i].re;
          second_buffer[i].re = -second_buffer[i].im;  //shift by 90 deg
          second_buffer[i].im = foo_val;    //shift by 90 deg
      case 2:
      case 3:
          second_buffer[i].re = second_buffer[i].im;  //shift by 270 deg
          second_buffer[i].im = -foo_val;    //shift by 270 deg
    call_count++;  if (call_count == 4) call_count=0;
  return call_count;
static int shiftByIntegerNumberOfBins(complex_t buffer[], complex_t second_buffer[], const int freqShift_bins, const int n_overlap, int call_count) {
  //shift the bins
  int targ_ind = 0;
  for (int source_ind = 0; source_ind < N_POS_BINS; source_ind++) {
    targ_ind = source_ind + freqShift_bins;
    if ((targ_ind > -1) && (targ_ind < N_POS_BINS)) {
      second_buffer[targ_ind].re = buffer[source_ind].re;  //copy both the real and imaginary parts
      second_buffer[targ_ind].im = buffer[source_ind].im;
  //adjust the phase of the bins
  call_count = adjustPhaseOfBins(second_buffer, freqShift_bins, n_overlap, call_count);
  return call_count;
void AudioEffectFreqDomain::update(void)
  int targ_ind, source_ind;
  //get a pointer to the latest data
  audio_block_t *block;
  block = receiveReadOnly();
  if (!block) return;
  //shuffle all of input data blocks in preperation for this latest processing
  release(input_buff_blocks[0]);  //release the oldest one
  for (int i = 1; i < N_BUFF_BLOCKS; i++) input_buff_blocks[i - 1] = input_buff_blocks[i];
  input_buff_blocks[N_BUFF_BLOCKS - 1] = block; //append the newest input data to the buffer blocks
  //clear the buffer?
  //for (int i=0; i < 2*N_FFT; i++) buffer[i]=0;
  //copy all input data blocks into one big block
  targ_ind = 0;
    for (int j = 0; j < AUDIO_BLOCK_SAMPLES; j++) {
        buffer[targ_ind].re = input_buff_blocks[i]->data[j];  //real
        buffer[targ_ind].re = ((q31_t)(input_buff_blocks[i]->data[j]));  //the 16-bit shift will occur naturally in the windowing
      buffer[targ_ind].im = 0;  //imaginary
      targ_ind++;
  //apply window to the data
  //if (flag__useWindow) {
    //#if FFT_DATA_TYPE == 16
    //  apply_window_to_fft_q15_buffer(buffer, window);
    //#else
      for (source_ind = 0; source_ind < N_FFT; source_ind++) {
        buffer[source_ind].re = buffer[source_ind].re * window[source_ind];
    //#endif
  //} else {
    //#if FFT_DATA_TYPE == 32
    //  for (source_ind = 0; source_ind < N_FFT; source_ind++) {
    //    buffer[source_ind].re = buffer[source_ind].re * 32767;  //max window value is 32767, which is same as a 15 bit shift
    //#endif
  //call the FFT
//    arm_cfft_radix4_q15(&fft_inst, (q15_t *)buffer);
    arm_cfft_q15(&arm_cfft_sR_q15_len256, (q15_t *)buffer, 0,1);
//    arm_cfft_radix4_q31(&fft_inst, (q31_t *)buffer);
    arm_cfft_q31(&arm_cfft_sR_q31_len256, (q31_t *)buffer,0,1);
  //Clear the target bins.  Is this necessary in all cases?
  for (targ_ind = 0; targ_ind < N_POS_BINS; targ_ind++) {
    second_buffer[targ_ind].re = 0; //real
    second_buffer[targ_ind].im = 0; //imaginary
  //apply the frequency domain processing algorithm that you care about
  switch (0) {
    case 0:
      //Simplest.  Copy input buffer to output buffer.  No change to audio
      for (source_ind=0; source_ind < N_POS_BINS; source_ind++) second_buffer[source_ind] = buffer[source_ind]; //copies both real and imaginary parts
    case 1:
      //Do a frequency shift by a fixed number of bins
      flipSignOddBins = shiftByIntegerNumberOfBins(buffer, second_buffer, freqShift_bins, N_BUFF_BLOCKS, flipSignOddBins);
    case 10:
      //Pure synthesis
      second_buffer[freqShift_bins].re = 33552631;
      second_buffer[freqShift_bins].im = 0;
      if (flipSignOddBins) {
        if ((freqShift_bins % 2) == 1) {  //only for 50% overlap
          second_buffer[freqShift_bins].re = -1*second_buffer[freqShift_bins].re;
          second_buffer[freqShift_bins].im = -1*second_buffer[freqShift_bins].im;
      flipSignOddBins = !flipSignOddBins;
  //create the negative frequency space via complex conjugate of the positive frequency space
  int ind_nyquist_bin = N_POS_BINS-1;
  targ_ind = ind_nyquist_bin+1;
  for (source_ind = ind_nyquist_bin-1; source_ind > 0; source_ind--) {
    second_buffer[targ_ind].re = second_buffer[source_ind].re; //real
    second_buffer[targ_ind].im = -second_buffer[source_ind].im; //imaginary.  negative makes it the complex conjugate, which is what we want for the neg freq space
    targ_ind++;
//   if (printFFTtoSerial) {
//    int printThisOne=0;
//    for (int i=0; i < N_FFT; i++) {
//      if (abs(buffer[i].re) > 0) {
//        printThisOne = 1;
//    if (printThisOne > 0) {
//      Serial.print("FFT: ");
//      Serial.print(printFFTtoSerial);
//      Serial.print(".  Shifted ");
//      Serial.print(freqShift_bins);
//      Serial.println();
//        Serial.print(i);
//        Serial.print(": ");
//        Serial.print(buffer[i].re);
//        Serial.print(", ");
//        Serial.print(buffer[i].im);
//        Serial.print(second_buffer[i].re);
//        Serial.print(second_buffer[i].im);
//      printFFTtoSerial--;
  //call the IFFT
//    arm_cfft_radix4_q15(&ifft_inst, (q15_t *)second_buffer);
    arm_cfft_q15(&arm_cfft_sR_q15_len256, (q15_t *)second_buffer,1,1);
//    arm_cfft_radix4_q31(&ifft_inst, (q31_t *)second_buffer);
    arm_cfft_q31(&arm_cfft_sR_q31_len256, (q31_t *)second_buffer,1,1);
//  //apply window to the data
//  //if (flag__useWindow) {
//    //#if FFT_DATA_TYPE == 16
//    //  apply_window_to_fft_q15_buffer(second_buffer, window);
//    //#else
//        second_buffer[source_ind].re = second_buffer[source_ind].re * window[source_ind];
//    //#endif
//  //} else {
//    //#if FFT_DATA_TYPE == 32
//    //  for (source_ind = 0; source_ind < N_FFT; source_ind++) {
//    //    second_buffer[source_ind].re = second_buffer[source_ind].re * 32767;  //max window value is 32767, which is same as a 15 bit shift
//    //#endif
  //prepare for the overlap-and-add for the output
  audio_block_t *temp_buff = output_buff_blocks[0]; //hold onto this one for a moment
  for (int i = 1; i < N_BUFF_BLOCKS; i++) output_buff_blocks[i - 1] = output_buff_blocks[i]; //shuffle the output data blocks
  output_buff_blocks[N_BUFF_BLOCKS - 1] = temp_buff; //put the oldest output buffer back in the list
  //clear_audio_block(output_buff_blocks[N_BUFF_BLOCKS-1]); //not needed because we'll simply overwrite with the newest data
  //do overlap and add with previously computed data
  int output_count = 0;
  for (int i = 0; i < N_BUFF_BLOCKS - 1; i++) { //Notice that this loop does NOT do the last block.  That's a special case after.
        output_buff_blocks[i]->data[j] +=  second_buffer[output_count].re; //get just the real component
        output_buff_blocks[i]->data[j] +=  (q15_t)(second_buffer[output_count].re >> (15-8)); //get the real and down shift to q15_t
      output_count++;  //buffer is [real, imaginary, real, imaginary,...] and we only want the reals.  so inrement by 2.
  //now write in the newest data into the last block, overwriting any garbage that might have existed there
      output_buff_blocks[N_BUFF_BLOCKS - 1]->data[j] =  second_buffer[output_count].re; //overwrite with the newest data
      output_buff_blocks[N_BUFF_BLOCKS - 1]->data[j] =  (q15_t)(second_buffer[output_count].re >> (15-8)); //the 8 is to recover the 8bits lost through IFFt
  //scale the IFFT to make up for the Q15 IFFT gain loss (8 bits?)
  //const int bits_to_shift=8;
  //arm_scale_q15(output_buff_blocks[0],1,bits_to_shift,output_buff_blocks[0],AUDIO_BLOCK_SAMPLES);
    for (int j=0; j < AUDIO_BLOCK_SAMPLES; j++) output_buff_blocks[0]->data[j] <<= 7;  //only needed to account for loss in Q15 IFFT?
  //send the oldest data.  Don't issue the release command here because we will release it the next time through this routine
  transmit(output_buff_blocks[0]); //don't release this buffer because we re-use it every time this is called
  //transmit(input_buff_blocks[0]); //don't release this buffer because we re-use it every time this is called
  return;
To make it work on Teensy 3.5, you have to get the new lib --> see this post by Duff: HERE
AND copy the libarm_cortexM4lf_math.a into your folder AND set #define __FPU_USED 1
in arm_math.h
However, audio that is put through this effect is still heavily distorted when using a 256-FFT and 256-IFFT (also with a 512-FFT and IFFT, yes, I tried 512 and it worked, but still distorted ;-)), even with 32bit fixed point. Therefore, I would like to use the floating point FFT functions, because my interpretation would be that the distortion is produced by the use of fixed point math vs. floating point.
Would that mean to gather the audio samples in 16bit fixed point, convert them to float32_t, run the FFT and IFFT and then convert back to 16bit fixed point? Or do you have another idea how to deal with that?
Final goal is to use the FFT and IFFT in real time for a software defined radio (on the Teensy 3.5) and implement all the filtering in between the FFTs . . .
Frank
Ray, I just realized that you used floating point FFTs for your measurements with a queue object, would you be willing to share your code?
Frank
I was getting around 15% with the Teensy 3.2 @ 120MHz.
Probably not, 16bit fixed point calculations are still faster.
I'm going to start a new thread for the speed up of the Audio library FFT, since this thread has been hijacked a couple of times already.
Yes, but 16-bit FFT/IFFT sounds horrible for audio processing. If you're just doing analysis (ie, making a graph, detecting tones, etc), 16-bit FFT is often fine enough. For, for Audio, ick! Int32 / Float32 sounds so much better.
Thanks for starting a new thread. That's probably a good idea.
Chip
This is great news. I've been developing a neural network based synth, it works but I'm experimenting with a new structure to have an output neuron for each frequency bin of an FFT and use IFFT to create the audio. I don't have the formal maths training for understanding FFT/IFFT but I have implemented some demos from the CMSIS docs and was surprised at the speed.
I didn't realize that I would need to run the FFT higher than 16 bit to avoid distorted audio, any idea how many bits are lost on FFT/IFFT conversion? Also there are so many different types of FFT in the CMSIS docs, any suggestions on what I should be using?
Here's a copy of the arm_math.h library, with a makefile that compiles the code.
https://github.com/PaulStoffregen/arm_math
So far, this hasn't really been tested much. My long-term intention was (and still is) to replace the .a files we use now with the result of compiling from this source. Eventually, I want to bring in the newer features, and also make some fairly simple modifications like using separate lookup tables, so using a 1024 point FFT doesn't import the huge 4096 point table.
somehow "core_cmFunc.h" disappeared from both the core and the arm_math repository, but is called from core_arm4.h. (I may have some defines wrong)
Only to try, I just got CMSIS_5 compiled (in Makefile project, not Arduino)
for this I had to remove arm_math.h from Teensy3/core to use the CMIS/core version (core_cmFunc.h missing). This resulted in the need to declare the enable/disable_irq macros (from kinetis.h) as undefined in cmsis_gcc.h, where they are also defined as inline functions.
