Actually, both buttons pushed will happen very frequently for super short intervals on the x-axis of the left stick. There is a technique in Super Smash Bros. Melee called Dash Dancing, where you can run back and forth very quickly, and it is done a lot to trick out your opponent. The way this circuit works, I will have to let go of the other button for it to work, but there will most likely be very short periods of time where I am holding both down.
When I removed the joystick from the GC board, I tested it and saw that both pots on it had a resistance of about 36k ohms. If I increased the values of all resistors, it would make the circuit safer right? It is actually beneficial for me to do it because it puts the modifier resistors in a better selection range for my trimpots.
Here is a version with high resistances:
$ 1 0.000005 19.867427341514983 61 5 43
r 752 384 864 384 0 47000
r 864 384 976 384 0 47000
r 624 336 720 336 0 2200
r 1008 336 1104 336 0 2200
s 752 352 864 352 0 1 false
s 864 352 976 352 0 1 false
R 1104 336 1136 336 0 0 40 5 0 0 0.5
g 624 336 608 336 0
r 864 320 976 320 0 3500
s 752 320 864 320 0 1 false
s 752 288 864 288 0 1 false
r 864 288 976 288 0 1000
w 752 288 720 336 0
w 752 320 720 336 0
w 752 352 720 336 0
w 720 336 752 384 0
w 1008 336 976 384 0
w 1008 336 976 352 0
w 1008 336 976 320 0
w 1008 336 976 288 0
w 864 352 864 384 0
w 864 416 864 384 0
