defragster
Senior Member+
Did another update to Tset - the NEW command had two lines out of order and caused a silly warning creating the file then saying it already existed.
Also updated the readme to include notes as KurtE used to get the BUILD setup for sublime. There are added notes about T4 Beta - those can be ignored of course when using a prior shipping Teensy.
I found the sublimetext "F4" key works to walk through Multiple Errors - even across files! { just like it does for Global Search Ctrl+Shift+F } Sometimes it takes a click in the console window - a double click on the file/error line to get started when an error isn't in the open file. Then F4 will walk through any other errors with red annotation box (Shift+F4 walks the list backwards). Very handy and much nicer than the IDE - especially when it goes into Core Teensy files.
This morning I programmed 5 connected Teensy's of three types from within Sublime with two sketches using TyComm and it worked well. Just remember if the Tset option to make a Teensy specific directory is chosen - that subfolder Compile.cmd has to be open when the Build System is started as it uses that Current Directory to execute the command. If not using the subdirectory - then any file in the skwtch directory can be the current file and the build will work to build the sketch - Thanks yet again to FrankB.
And when using the SublimeAStyleFormatter package it is Ctrl+Alt+F to format the code where the IDE uses Ctrl+T. That and the BUILD info is noted in SublimeText.txt
