Thought I would mention that the Stino plug is having a major rework done to it.
https://github.com/Robot-Will/Stino
The new main branch is Stino2017 - I received github email about my earlier Pull Request to make it work on Teensy. So after seeing update message about passing for Teensy. I gave it a try.
I decided I did not want to have my older version interfere with the new stuff, so I deleted my old configuration stuff: That is I got rid of:
C:\Users\kurte\AppData\Roaming\Sublime Text 3
I then reinstalled the few additions I mainly use. Sublime Merge, and some code that allows by default the sidebar (directory list) to be hidden, but if you hover over the line number area it shows up...
I then followed the instructions in the readme to install. You need to setup your path to the Arduino IDE that has Teensy installed in it. I ran into a couple of problems like my Sketch folder was too big to load, so he fixed it. There was an issue on searching for libraries, which he fixed...
So this morning I was able to build for T3.6 and I build and downloaded (using TyCommander) the test program I am doing for testing out adding DMA to the ili9341_t3n library...
And I did not have to edit the platform.txt file like I was doing before.
He did run into an issue last night building the graphictest program... Not sure if my version or not, but from the message he saw:
But the example graphicstest did not pass the build. The error message is:
graphicstest" -larm_cortexM4lf_math -lm
d:/arduino-1.8.1/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-sbrkr.o): In function `_sbrk_r':
sbrkr.c:(.text._sbrk_r+0xc): undefined reference to `_sbrk'
But again if you are using Sublimetext 3, you might give this new version of the plugin a try!
