I'd like to control the LED of my touchscreen with IO pins from my Teensy 3.2.
My screen is the touchscreen sold by PJRC.
Currently its LED pin is hooked to VIN with 110 Ohm in series. The Teensy is powered by USB. VCC/VIN is 4.93V. The current to the LED is 19 mA.
I'd like to remove the hardwire from VIN to an IO pin on the Teensy so I can turn the screen on/off programmatically (I don't need values in between for now, but I guess I could PWM to control brightness more granularly).
The question is: can I hook up an IO pin to the resistor to the LED? Will the current drawn be "OK" for the teensy to take on? If not, can I combine multiple IO pins to provide "more current" while staying in range of a safe "per pin current rating"?
Thanks in advance!
Thanks in advance!
