I'm trying to compile a sketch using the teensy i2c library and mpr121 and I get a bunch of errors. To eliminate any extraneous causes, I've netted down the sketch to this
#include <i2c_t3.h> //teency i2c library
#include "mpr121.h" //MPR121 register definitions
that generates the following errors which may be caused by the inclusion of the i2c.h inside the MPR121Q library. I want to use the SparkFun mpr121 breakout board due to the physical layout. The wires to the touch sensors need to terminate on a board such as this and then communicate with the teensy over I2C. Has anyone gotten this to work on a teensy 3.2? If so, how did you get pas the errors.
In file included from C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:27:0:
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cInit':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:102:6: error: 'TWCR' undeclared (first use in this function)
sbi(TWCR, TWEN); // Enable TWI
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:53:28: note: in definition of macro 'sbi'
#define sbi(var, mask) ((var) |= (uint8_t)(1 << mask))
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:102:6: note: each undeclared identifier is reported only once for each function it appears in
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:102:12: error: 'TWEN' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:53:51: note: in definition of macro 'sbi'
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cSetBitrate':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:110:6: error: 'TWSR' undeclared (first use in this function)
cbi(TWSR, TWPS0);
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:54:28: note: in definition of macro 'cbi'
#define cbi(var, mask) ((var) &= (uint8_t)~(1 << mask))
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:110:12: error: 'TWPS0' undeclared (first use in this function)
cbi(TWSR, TWPS0);
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:54:52: note: in definition of macro 'cbi'
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:111:12: error: 'TWPS1' undeclared (first use in this function)
cbi(TWSR, TWPS1);
In file included from C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:26:0:
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:117:7: error: 'TWBR' undeclared (first use in this function)
outb(TWBR, bitrate_div);
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\defs.h:31:27: note: in definition of macro 'outb'
#define outb(addr, data) addr = (data)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cSendStart':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:56:21: error: 'DDRC' undeclared (first use in this function)
#define WRITE_sda() DDRC = DDRC | 0b00010000 //SDA must be output when writing
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:122:2: note: in expansion of macro 'WRITE_sda'
WRITE_sda();
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:124:2: error: 'TWCR' undeclared (first use in this function)
TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:124:13: error: 'TWINT' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:124:24: error: 'TWSTA' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:124:35: error: 'TWEN' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cSendStop':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:130:9: error: 'TWCR' undeclared (first use in this function)
TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:130:20: error: 'TWINT' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:130:31: error: 'TWEN' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:130:41: error: 'TWSTO' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cWaitForComplete':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:138:15: error: 'TWCR' undeclared (first use in this function)
while ((!(TWCR & (1<<TWINT))) && (i < 90))
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:138:26: error: 'TWINT' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cSendByte':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:146:2: note: in expansion of macro 'WRITE_sda'
WRITE_sda();
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:148:2: error: 'TWDR' undeclared (first use in this function)
TWDR = data;
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:150:2: error: 'TWCR' undeclared (first use in this function)
TWCR = (1<<TWINT)|(1<<TWEN);
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:150:13: error: 'TWINT' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:150:24: error: 'TWEN' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cReceiveByte':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:159:8: error: 'TWCR' undeclared (first use in this function)
outb(TWCR, (inb(TWCR)&TWCR_CMD_MASK)|BV(TWINT)|BV(TWEA));
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:159:43: error: 'TWINT' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\defs.h:31:35: note: in definition of macro 'outb'
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:159:40: note: in expansion of macro 'BV'
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:159:53: error: 'TWEA' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:159:50: note: in expansion of macro 'BV'
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cGetReceivedByte':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:171:14: error: 'TWDR' undeclared (first use in this function)
return( inb(TWDR) );
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\defs.h:34:23: note: in definition of macro 'inb'
#define inb(addr) (addr)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h: In function 'i2cGetStatus':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:177:14: error: 'TWSR' undeclared (first use in this function)
return( inb(TWSR) );
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c: In function 'main':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:69:2: error: 'for' loop initial declarations are only allowed in C99 mode
for (int i = 0; i < 5; i++)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:69:2: note: use option -std=c99 or -std=gnu99 to compile your code
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c: In function 'mpr121Read':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:112:6: error: 'TWCR' undeclared (first use in this function)
cbi(TWCR, TWEN); // Disable TWI
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:35:28: note: in definition of macro 'cbi'
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:112:12: error: 'TWEN' undeclared (first use in this function)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:35:52: note: in definition of macro 'cbi'
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c: In function 'checkInterrupt':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:204:7: error: 'PIND' undeclared (first use in this function)
if ((PIND & (1<<2)) == 0)
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c: In function 'ioinit':
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:217:2: error: 'DDRB' undeclared (first use in this function)
DDRB = 0b01100000; //PORTB4, B5 output
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:218:5: error: 'DDRC' undeclared (first use in this function)
DDRC = 0b00010011; //PORTC4 (SDA), PORTC5 (SCL), PORTC all others are inputs
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:219:5: error: 'DDRD' undeclared (first use in this function)
DDRD = 0b11111010; //PORTD (RX on PD0), IRQ on PD2
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:220:2: error: 'PORTC' undeclared (first use in this function)
PORTC = 0b00110000; //pullups on the I2C bus
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:172:1: warning: control reaches end of non-void function [-Wreturn-type]
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\i2c.h:178:1: warning: control reaches end of non-void function [-Wreturn-type]
C:\Users\jrdarrah\Documents\Arduino\libraries\MPR121Q\main.c:208:1: warning: control reaches end of non-void function [-Wreturn-type]
Error compiling for board Teensy 3.2 / 3.1.
cbi(TWSR, TWPS0);
cbi(TWSR, TWPS0);
cbi(TWSR, TWPS1);
WRITE_sda();
WRITE_sda();
TWDR = data;
