BasicTest on Teensy 3.2
BuffaloFan32
I am running the BasicTest Script from the example code of the Octo library on a strip of 179 WS2812 LEDs. By my calculations, the strip should be consuming about 10amps when it gets to full white. I am using a clamp meter to verify that but it says the strip is only pulling 5 amps. Any idea what the difference could be? Also, is there a way to use RGB instead of hex colors with the octo library?
I have not used the OctoWS2811 library, but assuming same library,
they do have a setPixel method which allows you call it with: setPixel(pixel, red, green, blue);
Or you can also do it by: setPixel(pixel, color(red, green, blue));
Which is what the first one actually calls...
Thanks Kurt, that should work. Any idea why it's pulling such little amperage when the color is set to 0xFFFFFF?
You are welcome, as for the amperage, hopefully one of the EE type people up here can answer that part.
