Hi again
I'd like to ask one question. Is possible to program the teensy 3.2 / LC with a bluetooth module in order to work with it as a joystick usb (serial/joystick/keyboard) for using buttons without usb cable?
And PC can detect the joystick by bluetooth? Or only is possible with emulation keys of keyboard?
I'd like to use this example sketch by bluetooth.
Thanks in advance
/* Complete USB Joystick Example
Teensy becomes a USB joystick with 16 or 32 buttons and 6 axis input
You must select Joystick from the "Tools > USB Type" menu
Pushbuttons should be connected between the digital pins and ground.
Potentiometers should be connected to analog inputs 0 to 5.
// Configure the number of buttons. Be careful not
// to use a pin for both a digital button and analog
// axis. The pullup resistor will interfere with
// the analog voltage.
const int numButtons = 16; // 16 for Teensy, 32 for Teensy++
// you can print to the serial monitor while the joystick is active!
// configure the joystick to manual send mode. This gives precise
// control over when the computer receives updates, but it does
// require you to manually call Joystick.send_now().
Joystick.useManualSend(true);
for (int i=0; i<numButtons; i++) {
pinMode(i, INPUT_PULLUP);
Serial.println("Begin Complete Joystick Test");
byte allButtons[numButtons];
byte prevButtons[numButtons];
int angle=0;
// read 6 analog inputs and use them for the joystick axis
Joystick.X(analogRead(0));
Joystick.Y(analogRead(1));
Joystick.Z(analogRead(2));
Joystick.Zrotate(analogRead(3));
Joystick.sliderLeft(analogRead(4));
Joystick.sliderRight(analogRead(5));
// read digital pins and use them for the buttons
if (digitalRead(i)) {
// when a pin reads high, the button is not pressed
// the pullup resistor creates the "on" signal
allButtons[i] = 0;
// when a pin reads low, the button is connecting to ground.
allButtons[i] = 1;
Joystick.button(i + 1, allButtons[i]);
// make the hat switch automatically move in a circle
angle = angle + 1;
if (angle >= 360) angle = 0;
Joystick.hat(angle);
// Because setup configured the Joystick manual send,
// the computer does not see any of the changes yet.
// This send_now() transmits everything all at once.
Joystick.send_now();
// check to see if any button changed since last time
boolean anyChange = false;
if (allButtons[i] != prevButtons[i]) anyChange = true;
prevButtons[i] = allButtons[i];
// if any button changed, print them to the serial monitor
if (anyChange) {
Serial.print("Buttons: ");
Serial.print(allButtons[i], DEC);
// a brief delay, so this runs "only" 200 times per second
delay(5);
Thanks in advance
