Hi, I am new in the world of Teensy.
I would like to give a Piano the Midi ability and use therefore a Teensy.
I have 3 questions.
1: The Piano should have two MIDI-Out jacks: One as a normal Midi-Din jack and one as a USB-Midi jack.
Is it possible to do this, if yes, how do I have to do it?
2: Is it possible to do Midi and audio process with the same Teensy and in the same sketch?
That means, I would like to scan the Piano keys, produce Midi data, send it out and simultaneously I would like to read a wave file (e.g. a drum pattern) from SDD card and send it as an audio data. If that works fine, do I need a seperate thread? I would like to write the source code with arduino studio, not in C or C++.
3: Which power supply do you recommend for Teensy and wich pins do I have to use therefore, if I should use the USB for Midi out and not for power supply.
Thank you.
I have 3 questions.
Thank you.
