Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 98 of 98
Thread: Discussion about a simple way to change the sample-rate
  1. #76
    Jan 2019
    11
    I just tried the code out in message #44 and received the following error message when. compiling.
    'clkArr' was not declared in this scope
    Any ideas?
  2. #77
    17,137
    Looking at the code its definition is based on the value of the F_PLL.
    What Teensy and clock speed is in use?
    Write a short sketch using the same compile params and speed and Serial.print( F_PLL ) and Serial.print( F_CPU )
  3. #78
    Jan 2019
    11
    Thanks for replying so quick!
    I'm using T3.5 running at 168MHz. I just changed it to 120MHz and it compiled OK!!
  4. #79
    Hi Frank,
    I wanted to tryout your sample rate changing code for the Teensy 4, which I pulled from CorBee's Bat Detector repo on github. It seems that it's not perhaps compatible with the Teensy 4 as I2S0_MCR & I2S_MCR_DUF are showing up as undefined during compilation. On a more recent thread Paul mentioned that the 3.6 and 4 have different ways of using the MCLK as seen here. What changes should be needed for the Teensy 4? Any resources I should look into?
    -Akshay
  5. #80
    Good day,
    I encounter the same issue as mentioned in the last post. How can we adapt the code for the Teensy 4.1?
    Thank you,
    Jaco
  6. #81
    Aug 2020
    1
    Hi all
    This is my first post on this forum and it touches on a subject that I am having difficulty getting my head around. I know this thread is now somewhat ancient history but it turned up when I was searching for a way of resolving my particular problem
    Unlike some I am not interested in a high audio sample rate but in a relatively low one. The reason is that I want to play a simple WAV file that has been stored on the flash memory of an Adafruit Feather M4 Express. The 2MB of space available allows the storage of about 2 minutes an 8 bit mono audio with sample rate of 16000 Hz. I wish to play this over one of the internal DACs on the SAMD51.
    I have used an updated version of the SamdAudio library to get it working on Feather M0 Express ( https://github.com/Gambalunga/Audio_FeatherM0 ) but that will not compile for the M4.
    I have tried using the Adafruit fork of the Teensy Audio library and managed to get the example sketch WavFilePlayer.ino (with a tiny mod) to compile and load. Clearly, however, 2MB of on board flash is not going give any useful period of sound at stereo 44117 Hz. and I can get it playing about 11 seconds of music.
    I noted the section of code below but I am not sure if it is relevant to my problem or even how to implement it in the sketch.
    Here's the same for the internal DACs :
    void setDACFreq(int freq) {
    const unsigned config = PDB_SC_TRGSEL(15) | PDB_SC_PDBEN | PDB_SC_CONT | PDB_SC_PDBIE | PDB_SC_DMAEN;
        PDB0_SC = 0;
        PDB0_IDLY = 1;
        PDB0_MOD = round((float)F_BUS / freq ) - 1;
        PDB0_SC = config | PDB_SC_LDOK;
        PDB0_SC = config | PDB_SC_SWTRIG;
        PDB0_CH0C1 = 0x0101;
    edit: Added one line
    I noticed the following section of code in AudioStream.h and wondered if it could be modified to give me the 16000 sample rate that I require.
    #ifndef AUDIO_SAMPLE_RATE_EXACT
    #if defined(__MK20DX128__) || defined(__MK20DX256__) || defined(__MK64FX512__) || defined(__MK66FX1M0__)
    #define AUDIO_SAMPLE_RATE_EXACT 44117.64706 // 48 MHz / 1088, or 96 MHz * 2 / 17 / 256
    #elif defined(__MKL26Z64__)
    #define AUDIO_SAMPLE_RATE_EXACT 22058.82353 // 48 MHz / 2176, or 96 MHz * 1 / 17 / 256
    #elif defined(__SAMD51__)
    //#define AUDIO_CLKRATE (SystemCoreClock >> 6)
    //#define AUDIO_PRESCALER TC_CTRLA_PRESCALER_DIV64
    //#define AUDIO_SAMPLE_RATE_EXACT 22058.82353 // 120 MHz / 64 / 85
    //#define AUDIO_TC_FREQ 22000
    #define AUDIO_CLKRATE (VARIANT_GCLK2_FREQ >> 4)
    #define AUDIO_PRESCALER TC_CTRLA_PRESCALER_DIV16
    #define AUDIO_SAMPLE_RATE_EXACT 44014.085 // 100 MHz / 16 / 142
    #define AUDIO_TC_FREQ 44100
    #endif // SAMD51
    #endif // AUDIO_SAMPLE_RATE_EXACT
    It seems to me that if the following were defined with different values I may be able to get the 16000 Hz that I require:
    AUDIO_TC_FREQ 44100
    Does anyone have any idea of how this may be made to function?
    perhaps defining
    AUDIO_SAMPLE_RATE_EXACT 16025.641 // 100 MHz / 16 / 390
    and
    AUDIO_TC_FREQ 16000
    It seems too easy and I am not sure if that "390" has to be specified somewhere else or even if it can be used.
  7. #82
    27,982
    This forum is for Teensy. If you're using Adafruit's hardware (and their modified copies of Teensy's software), ask for support on Adafruit's forum.
  8. #83
    @FrankB, I am having a hard time understanding how to change the sampling frequency of the PT8211 using your routines...
    When I try to use your routines I2S_MDR_DIVIDE and I2S_MDR_FRACT are not defined.
    These are my #include
    #include <Arduino.h>
    #include <AudioStream.h>
    #include <DMAChannel.h>
    What am I missing?
    Thank you so much!
  9. #84
    9,735
    On a Teensy4?
    Try this:
    #include <utility/imxrt_hw.h>
    void setI2SFreq(int freq) { //Teensy 4
      // PLL between 27*24 = 648MHz und 54*24=1296MHz
      int n1 = 4; //SAI prescaler 4 => (n1*n2) = multiple of 4
      int n2 = 1 + (24000000 * 27) / (freq * 256 * n1);
      double C = ((double)freq * 256 * n1 * n2) / 24000000;
      int c0 = C;
      int c2 = 10000;
      int c1 = C * c2 - (c0 * c2);
      set_audioClock(c0, c1, c2, true);
      CCM_CS1CDR = (CCM_CS1CDR & ~(CCM_CS1CDR_SAI1_CLK_PRED_MASK | CCM_CS1CDR_SAI1_CLK_PODF_MASK))
           | CCM_CS1CDR_SAI1_CLK_PRED(n1-1) // &0x07
           | CCM_CS1CDR_SAI1_CLK_PODF(n2-1); // &0x3f
  10. #85
    Thank you for all your great contributions to the Forum, @frankB
  11. #86
    Sep 2019
    Sevilla, Spain
    101
    This works pretty good! thanks Frank B,
    I'm getting some issues with abrupt changes to lower values, sound turns off if I switch from 44100 to 22050, but it works fine with other values ...and I have no idea why,
    45100 -> 22550 ok
    44100 -> 22050 no sound
    43100 -> 21550 ok
  12. #87
    9,735
    I don't know, why. Maybe try to disable the interrupts when switching the rate. I have never tried that - But I know of an application that sets 176khZ in one step, without problems.
  13. #88
    Sep 2019
    Sevilla, Spain
    101
    that's the first thing I tried, with no luck. Indeed I can change the frequency from 44100 to 88200 with no problem, the 'no sound' issue occurs when jumping below 44100, anyway what I did is to disable 1 octave changes below 44k1,
  14. #89
    May 2021
    2
    Thanks Frank B. This is my first post. I want Teensy 4.0 to be the I2S master and to generate MCLK =12.288Mhz, BCLK=1.024Mhz (64xLRCLK) and LRCLK = 16khz to TI PCM5242 DAC. I used your code and I was able to generate the clocks.
    Unfortunately, MCLK frequency is always fix ratio of 256 to LRCLK. Is there a simpler way to setup I2S clocks. I am guessing set_audioClock() sets the PLL frequency. I still do not understand where MCLK is selected and how BClk and LRClk are generated.
    I tried to modify n1 and n2 and C in your code to make it work. But without understanding what the numbers mean, I was not able to make it work.
  15. #90
    3,497
    maybe this snippet helps
        //PLL:
            int fs = fsamp;
            int ovr = 2*(NCHAN_I2S*32);
            int n0 = 26; // targeted PLL frequency (n0*24 MHz) n0>=27 && n0<54
            int n1, n2;
            do
            {   n0++;
                n1=0;
                do
                {   n1++;
                    n2 = 1 + (24'000'000 * n0) / (fs * ovr * n1);
                } while ((n2>64) && (n1<=8));
            } while ((n2>64 && n0<54));
            Serial.printf("fs=%d, n1=%d, n2=%d, %d (>=27 && <54) ", fs, n1,n2,n1*n2*(fs/1000)*ovr/24000);
            double C = ((double)fs * ovr * n1 * n2) / (24000000.0f);
            Serial.printf(" C=%f\r\n",C);
            int c0 = C;
            int c2 = 10'000;
    this relates the MCLK to the sampling frequency by specifying the number of channels (NCHAN_I2S) and word size (32).
    obviously, the allowed ratio MCLK / Fs is given in ADC datasheet
    relating sampling frequency(framesync) and Bitclock must also be done in SAI configuration
  16. #91
    May 2021
    2
        //PLL:
            int fs = fsamp;
            int n1, n2;
            do
            {   n0++;
                n1=0;
                do
                {   n1++;
            int c0 = C;
            int c2 = 10'000;
    I modified Frank B's original code with the above snippet. NCHAN_I2S=2 and fs=16khz
    I got MCLK=2Mhz, BCLK=510Khz and LRCLK=7.998Khz.
    The sampling frequency went from 16khz to 8Khz. The BCLK to LRCLK ratio is the same at 64. MCLK to LRCLK ratio changed to 250 from 256.
    There are only 5 parameters. c0, c1=0 (fix), c2=10,000, n1 and n2. c0 to c2 are used to set PLL frequency; n1 and n2 are dividers. I just could not figure out how these 5 parameters are used to setup the MCLK or where MCLK frequency is configured. There is no example in the ref manual. I know how the PLL frequency is setup by set_audioClock, but I do not understand how MCLK, BCLK and LRCLK are produced. Any help would be appreciated.
  17. #92
    3,497
    You can use the following example to adapt your program
    //MCLK =12.288Mhz, BCLK=1.024Mhz (64xLRCLK) and LRCLK = 16khz (2 Bytes/word)
    #define FSAMP 16000
    #define NCHAN_I2S 2
    #define N_BYTES 2
    #define N_BITS (8*N_BYTES)
    #if N_BITS==16
      typedef uint16_t data_t;
    #elif N_BITS==32
      typedef uint32_t data_t;
    #define RCR2_DIV 12
    #define MCLK_OVR (RCR2_DIV*2*(NCHAN_I2S*N_BITS))
    //Bitclock = MasterClock/(2*RCR2_DIV)
    //Framclock = Bitclock/(NCHAN_I2S*NBITS)
    float mclk,fclk,bclk;
    #define NSAMP 128
    #define NBUF_I2S (NCHAN_I2S*NSAMP)
    DMAMEM data_t tdm_rx_buffer[2*NBUF_I2S] __attribute__((aligned(32)));
    //int32_t acq_rx_buffer[NBUF_I2S];
    volatile uint32_t acq_count=0;
    static void acq_isr(void);
    #ifndef I2S_DMA_PRIO
    //  #define I2S_SAI_PRIO 4*16
      #define I2S_DMA_PRIO 5*16
    // ACQ setup functions
        #include "DMAChannel.h"
        DMAChannel dma;
        #define IMXRT_CACHE_ENABLED 2 // 0=disabled, 1=WT, 2= WB
        PROGMEM
        void set_audioClock(int nfact, int32_t nmult, uint32_t ndiv, bool force) // sets PLL4
            if (!force && (CCM_ANALOG_PLL_AUDIO & CCM_ANALOG_PLL_AUDIO_ENABLE)) return;
            CCM_ANALOG_PLL_AUDIO = CCM_ANALOG_PLL_AUDIO_BYPASS | CCM_ANALOG_PLL_AUDIO_ENABLE
                        | CCM_ANALOG_PLL_AUDIO_POST_DIV_SELECT(2) // 0: 1/4; 1: 1/2; 2: 1/1
                        | CCM_ANALOG_PLL_AUDIO_DIV_SELECT(nfact);
            CCM_ANALOG_PLL_AUDIO_NUM   = nmult & CCM_ANALOG_PLL_AUDIO_NUM_MASK;
            CCM_ANALOG_PLL_AUDIO_DENOM = ndiv & CCM_ANALOG_PLL_AUDIO_DENOM_MASK;
            CCM_ANALOG_PLL_AUDIO &= ~CCM_ANALOG_PLL_AUDIO_POWERDOWN;//Switch on PLL
            while (!(CCM_ANALOG_PLL_AUDIO & CCM_ANALOG_PLL_AUDIO_LOCK)) {}; //Wait for pll-lock
            const int div_post_pll = 1; // other values: 2,4
            CCM_ANALOG_MISC2 &= ~(CCM_ANALOG_MISC2_DIV_MSB | CCM_ANALOG_MISC2_DIV_LSB);
            if(div_post_pll>1) CCM_ANALOG_MISC2 |= CCM_ANALOG_MISC2_DIV_LSB;
            if(div_post_pll>3) CCM_ANALOG_MISC2 |= CCM_ANALOG_MISC2_DIV_MSB;
            CCM_ANALOG_PLL_AUDIO &= ~CCM_ANALOG_PLL_AUDIO_BYPASS;   //Disable Bypass
            Serial.printf("PLL %f\r\n",24.0f*((float)nfact+(float)nmult/(float)ndiv));
        void acq_init(int fsamp)
            CCM_CCGR5 |= CCM_CCGR5_SAI1(CCM_CCGR_ON);
            // if either transmitter or receiver is enabled, do nothing
            if (I2S1_RCSR & I2S_RCSR_RE) return;
            //PLL:
            int fs = fsamp;
            int ovr = MCLK_OVR;
            int n1, n2;
            do
            {   n0++;
                n1=0;
                do
                {   n1++;
            int c0 = C;
            int c2 = 10'000;
            mclk=C*24000000.0/n1/n2;
            // clear SAI1_CLK register locations
            CCM_CSCMR1 = (CCM_CSCMR1 & ~(CCM_CSCMR1_SAI1_CLK_SEL_MASK))
                | CCM_CSCMR1_SAI1_CLK_SEL(2); // &0x03 // (0,1,2): PLL3PFD0, PLL5, PLL4
                | CCM_CS1CDR_SAI1_CLK_PRED((n1-1)) // &0x07  // <8
                | CCM_CS1CDR_SAI1_CLK_PODF((n2-1)); // &0x3f // <64
            IOMUXC_GPR_GPR1 = (IOMUXC_GPR_GPR1 & ~(IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL_MASK))
                    | (IOMUXC_GPR_GPR1_SAI1_MCLK_DIR | IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL(0));  //Select MCLK
      //configure I2S
            I2S1_RMR = 0;
            I2S1_RCR1 = I2S_RCR1_RFW(4);
            I2S1_RCR2 = I2S_RCR2_SYNC(0) | I2S_TCR2_BCP | I2S_RCR2_MSEL(1)
                | I2S_RCR2_BCD | I2S_RCR2_DIV((RCR2_DIV-1));
            I2S1_RCR3 = I2S_RCR3_RCE;
            I2S1_RCR4 = I2S_RCR4_FRSZ((NCHAN_I2S-1)) | I2S_RCR4_SYWD((NCHAN_I2S-1)) | I2S_RCR4_MF
                | I2S_RCR4_FSE | I2S_RCR4_FSD;
            I2S1_RCR5 = I2S_RCR5_WNW((N_BITS-1)) | I2S_RCR5_W0W((N_BITS-1)) | I2S_RCR5_FBT((N_BITS-1));
            // I2S pins
            CORE_PIN23_CONFIG = 3;  //1:MCLK
            CORE_PIN21_CONFIG = 3;  //1:RX_BCLK
            CORE_PIN20_CONFIG = 3;  //1:RX_SYNC
            // I2S data pins
            CORE_PIN8_CONFIG = 3;   //RX_DATA0
            IOMUXC_SAI1_RX_DATA0_SELECT_INPUT = 2; // GPIO_B1_00_ALT3, pg 873
      // configure DMA
            dma.TCD->ATTR = DMA_TCD_ATTR_SSIZE((N_BYTES/2)) | DMA_TCD_ATTR_DSIZE((N_BYTES/2));
            dma.TCD->SADDR = &I2S1_RDR0;
            dma.TCD->SOFF = 0;
            dma.TCD->SLAST = 0;
            dma.TCD->NBYTES_MLOFFNO = N_BYTES;
            dma.TCD->DADDR = tdm_rx_buffer;
            dma.TCD->DOFF = N_BYTES;
            dma.TCD->CITER_ELINKNO = 2*NBUF_I2S;
            dma.TCD->BITER_ELINKNO = dma.TCD->CITER_ELINKNO;
            dma.TCD->DLASTSGA = -sizeof(tdm_rx_buffer);
            dma.TCD->CSR = DMA_TCD_CSR_INTHALF | DMA_TCD_CSR_INTMAJOR;
            dma.triggerAtHardwareEvent(DMAMUX_SOURCE_SAI1_RX);
    //        NVIC_SET_PRIORITY(DMAMUX_SOURCE_SAI1_RX,I2S_SAI_PRIO);
            dma.enable();
            //DMA_SERQ = dma.channel;
            I2S1_RCSR =  I2S_RCSR_FRDE | I2S_RCSR_FR;
            dma.attachInterrupt(acq_isr, I2S_DMA_PRIO);
        void acq_start(void)
            I2S1_RCSR |= (I2S_RCSR_RE | I2S_RCSR_BCE);
        void acq_stop(void)
            I2S1_RCSR &= ~(I2S_RCSR_RE | I2S_RCSR_BCE);
            //DMA_CERQ = dma.channel;
        void acq_isr(void)
            uint32_t daddr;
            data_t *src;
            dma.clearInterrupt();
            asm volatile("dsb");
            daddr = (uint32_t) dma.destinationAddress();
            if (daddr < ((uint32_t)tdm_rx_buffer + sizeof(tdm_rx_buffer) / 2)) {
                // DMA is receiving to the first half of the buffer
                // need to remove data from the second half
                src = (data_t*)&tdm_rx_buffer[NBUF_I2S];
                // DMA is receiving to the second half of the buffer
                // need to remove data from the first half
                src = &tdm_rx_buffer[0];
            #if IMXRT_CACHE_ENABLED >=1
                arm_dcache_delete((void*)src, sizeof(tdm_rx_buffer) / 2);
            //memcpy(acq_rx_buffer,src,sizeof(acq_rx_buffer));
            // process data in acq_rx_buffer
            acq_count++;
      while(!Serial);
      acq_init(FSAMP);
      bclk=mclk/(2*RCR2_DIV);
      fclk=bclk/(NCHAN_I2S*N_BITS);
      Serial.printf("MCLK = %.1f\n",mclk);
      Serial.printf("FCLK = %.1f\n",fclk);
      Serial.printf("BCLK = %.1f\n",bclk);
      acq_start();
      static uint32_t ic=0;
      static uint32_t t0=0;
      if(millis()-t0>1000)
      { t0=millis();
        Serial.printf("%d %d \n",ic++,acq_count);
        acq_count=0;
    It configures an ADC, but you should be able to modify for a DAC
    If you use the audio library, you should compare, understand the differences and modify accordingly.
  18. #93
    Oct 2021
    Australia
    20
    I am looking to change the sample rate of ADC1 to 96khz to speed up the 256bin FFT. I am looking for a ~1ms turn around for knock sensor circuit.
    I am running a 4 pole, 16Khz low pass MFB on a Teensy 3.6 with a broadband knock sensor.
    How much of this can I apply?
  19. #94
    Has anyone got this to work on a Teensy 4 with the Audio Shield?
    I tried the code below and it compiled, but AUDIO_SAMPLE_RATE_EXACT is still showing up as 44100. I'm calling setI2SFreq(22050) in setup() after enabling the audio shield.
    On a Teensy4?
    Try this:
      int c0 = C;
      int c2 = 10000;
  20. #95
    3,497
    Quote Originally Posted by gatheround View Post
    As you can see from the code, it does NOT change AUDIO_SAMPLE_RATE_EXACT and in fact it cannot change this as it is a '#define' symbol.
    You can change this symbol in 'hardware/teensy/avr/ boards.txt' by replacing
    teensy41.build.flags.defs=-D__IMXRT1062__ -DTEENSYDUINO=158
    with
    teensy41.build.flags.defs=-D__IMXRT1062__ -DTEENSYDUINO=158 -DAUDIO_SAMPLE_RATE_EXACT=22050
    and recompiling all.
    NOTE: the usb-audio is hard-coded for 44100
  21. #96
    Dec 2013
    East Stroudsburg PA.
    339
    I need simple way to change the sample rate and master clock at runtime
    Slowly going through the IMXRT1062 Teensy 4.x data sheets.
    For 44,100kHz I need:
    MCLK-22,579,200Mhz
    BCLK---5,644,800Mhz -8ch-16b.
    LRCLK-----44,100kHz -4ch stereo
    ___________________________________________ CCM ANALOG _________________________________________________________________________________________
    >CCM_CLK1_(P+N)  NOTE:Teensy 4.1 NC        Alt+0175¯
    | >OSC_24000000Mhz (XTAL-n)
    | |  PLL4_BYPASS_CLK_SCR
    | |  |¯\            Audio PPL4                              PLL4_POST_DIV                   PLL4_BYPASS
    | |->|<\\     |--------------------|                       |--------------|                 |¯\                 PLL4_AUDIO_DIV
    | |  |  \|--->|24000000*(47+(2/50)=|-- 1,128,960,000Mhz -->|      /2     =|--564,480,000--->|<\\    |-------|  |--------------|   PPL4_MAIN_CLK
    |-|->|  /  |  |--------------------|                       |--------------|                 |  \|-->|PLL4_EN|->|     /1       |--564,480,000-->|
    | |  |_/   |        /-->|  /    |-------|  |--------------|                |
    | |        |---------------------------------------------------------------------------/    |_/                                                |
    ______________________________________________________________________________________________________________________________________________ | __
    ______________________________________________ CCM ___________________________________________________________________________________________ | __
    |<-------564,480,000Mhz-----------------------------------------------------------------------------------------------------------------------<|
    |                    SAI1_CLK_SEL
    |                    |  \                 SAI1_CLK_PRED                  SAI1_CLK_PODF                             LRCLK-----44,100kHz -4ch stereo
    |  --PLL3_PFD2_CLK-->|   |               |--------------|               |--------------|  SAI1_CLK_ROOT            BCLK---5,644,800Mhz -8ch-16b.
    |>---PLL4_MAIN_CLK-->|<--|--564,480,000->|      /5     =|--112,896,000->|      /5     =|--22,579,200MHz--> ,       MCLK--22,579,200Mhz
       --PLL5_MAIN_CLK-->|   |               |--------------|               |--------------|
          Video PLL5     |  /
                         |_/
    ___________________________________________________________________________________________________________________________________________________
    // Selector for sai1 clock multiplexer
    CCM_CSCMR1 = (CCM_CSCMR1 & ~(CCM_CSCMR1_SAI1_CLK_SEL_MASK)) | CCM_CSCMR1_SAI1_CLK_SEL(2); // (0,1,2): PLL3_PFD2, PLL5, PLL4
    EDIT 48,000kHz
    ___________________________________________ CCM ANALOG ________48,000kHz___________________________________________________________________________
    | |  PLL4_BYPASS_CLK_SCR
    | |->|<\\     |---------------------|                       |--------------|                 |¯\                 PLL4_AUDIO_DIV
    | |  |  \|--->|24000000*(51+(10/50)=|-- 1,228,800,000Mhz -->|      /2     =|--614,400,000--->|<\\    |-------|  |--------------|   PPL4_MAIN_CLK
    |-|->|  /  |  |---------------------|                       |--------------|                 |  \|-->|PLL4_EN|->|     /1       |--614,400,000-->|
    | |  |_/   |        /--->|  /    |-------|  |--------------|                |
    _______________________________________________________________________________________________________________________________________________ | __
    ______________________________________________ CCM ____________________________________________________________________________________________ | __
    |<-------614,400,000Mhz------------------------------------------------------------------------------------------------------------------------<|
    |                    SAI1_CLK_SEL
    |                    |  \                 SAI1_CLK_PRED                  SAI1_CLK_PODF                             LRCLK-----48,000kHz -4ch stereo
    |  --PLL3_PFD2_CLK-->|   |               |--------------|               |--------------|  SAI1_CLK_ROOT            BCLK---6,144,000Mhz -8ch-16b.
    |>---PLL4_MAIN_CLK-->|<--|--614,400,000->|      /5     =|--122,880,000->|      /5     =|--24,576,000MHz--> ,       MCLK--24,576,000Mhz
          Video PLL5     |  /
                         |_/
  22. #97
    3,497
    Quote Originally Posted by Chris O. View Post
    I do it as follows
    stop I2S (I assume you are using I2S)
    modify frequency
    restart frequency
    code: e.g.: https://github.com/WMXZ-EU/record_sg...ter/i2s_mods.h
  23. #98
    Dec 2013
    339
    Thanks.
    All this is new to me.
    I will look at the code when I have a bit more time, basically I'm trying to recreate this device for my classic 1992 Atari falcon 030 with the Motorola DSP 56001 @ 32 MHz.
Name:	Falcon soundpool SPDIF.jpg
    Edit: Added for complete example.
    | |  PLL4_BYPASS_CLK_SCR
    |                    SAI1_CLK_SEL
    |>---PLL4_MAIN_CLK-->|<--|--614,400,000->|      /5     =|--122,880,000->|      /5     =|--24,576,000MHz-->|,       MCLK--24,576,000Mhz
       --PLL5_MAIN_CLK-->|   |               |--------------|               |--------------|                  |
          Video PLL5     |  /        |
                         |_/        |
    _________________________________________________________________________________________________________ | _______________________________________
    ___________________________________________ IOMUXC_GPR __________________________________________________ | _______________________________________
    |<-------SAI1_CLK_ROOT-----------------------------------------------------------------------------------<|
    |                       SAI1_MCLK1_SEL
    |>------SAI1_CLK_ROOT-->|<\\
       -----SAI2_CLK_ROOT-->|  \\
       -----SAI3_CLK_ROOT-->|   \|
    en/ds --SAI1_MCLK-----|>|    |------------------SAI1_MCLK1---------------------------------------> , MCLK1-- 24,576,000Mhz for 48,000kHz -4ch stereo
    en/ds --SAI2_MCLK---|-->|    |
    en/ds --SAI3_MCLK-|---->|   /
                      | | | |_/
                      TO SAI1_MCLK2_SEL & SAI1_MCLK3_SEL + SAI2_MCLK3_SEL + SAI3_MCLK3_SEL
    // 11.4.2 GPR1 General Purpose Register (IOMUXC_GPR_GPR1)
    // SAI1_MCLK_DIR field descriptions 19
    // 0 sai1.MCLK is input signal
    // 1 sai1.MCLK is output signal
    // SAI1_MCLK1_SEL field descriptions 3-0
    // 000 ccm.ssi1_clk_root
    // 001 ccm.ssi2_clk_root
    // 010 ccm.ssi3_clk_root
    // 011 iomux.sai1_ipg_clk_sai_mclk
    // 100 iomux.sai2_ipg_clk_sai_mclk
    // 101 iomux.sai3_ipg_clk_sai_mclk
    // 110 Reserved
    // 111 Reserved
