Page 11 of 22 FirstFirst ... 9 10 11 12 13 21 ... LastLast
Results 251 to 275 of 528
Thread: Bat detector
  1. #251
    Jun 2019
    France
    40
    I understand that recording data required some processing. Thus what parameters did you recommend before record?
  2. #252
    Senior Member CorBee's Avatar
    Jun 2018
    Netherlands
    257
    Nothing special, just use any setting you wish. Recording is ment to save raw data for later analysis. And like stated using 44Khz SR is not at all effective for bats. You should use at least 96Khz (for bats that dont produce sounds with frequencies higher than 45Khz) and anything higher will allow recording of higher-frequencies.
  3. #253
    Jun 2019
    France
    40
    SD card
    Ok, thanks for details. To lowering processing issue I force Sample rate at 8Khz, in PASS mode : But I try and writing freeze..even with SDhc not low cost.
    I could be an issue with the code modification...
    Some time I can read name files on the card. And start reading file. Need to found good SR also..or some *.raw file sample.
    Long work for investigation...
  4. #254
    Jun 2018
    Netherlands
    257
    Which SD card are you using ? Do you have the same problems with the original sketch from DD4WH ?
    Cor
  5. #255
    Nov 2018
    Netherlands
    83
    Hi folks,
    It's been i while since I have been here. It seems I have to do some reading.
    I did run into some problems with uSDFS, the seems 13 days ago changes were made that makes the old corber code fail. Maybe it does work with newer code.
    I hope to find me some time to test the latest on Github.
    I allso have been playing with the ICS microphone I used it singele ended but did ty -out to GND using a capacitor. The signals seemed to be just about the same as on the SPU microphone. just a tiny bit lower signal on some frequencies. Ik kind of looks like someone suggested the unused output should be floating. I have to check that.
    Anyway, glad to see the activity here.
    Kind regards,
    Edwin
  6. #256
    Jun 2018
    Netherlands
    257
    Hi Edwin,
    Good to see you are also able to attend the thread again.
    regards
    Cor
  7. #257
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    453
    Hi Edwin,
    I feel that there are several people having problems to understand how to use the ICS40730 in single ended mode for maximum performance ;-).
    Here is the <magic> with that MIC:
    GND --> connect to GND
    VDD --> connect to 1.5-3.6V power supply
    OUTPUT- --> DO NOT CONNECT ANYTHING, EVEN A WIRE IS NOT ALLOWED, LEAVE THIS PAD ABSOLUTELY UNTOUCHED [this is also stated in the data sheet]
    OUTPUT+ --> this is the microphone audio output, which you can connect to a standard audio OP-Amp as usual.
    So, its much easier than you might have thought!? :-)
    With that setup, I am able to obtain an SNR of about 64dB [including MIC, preamp, wires, using the standard 3V3 regulator on the Teensy board, using the ADC of the Teensy in 12bit mode] and a superb high frequency response up to 160kHz (see post https://forum.pjrc.com/threads/38988...l=1#post208496). However, if you manage to build a superduper audio amp you might be able to use the full 74dBA SNR range of the ICS40730.
    Good luck!
    Frank DD4WH
    P.S.: your result of not seeing a difference to the SPU mic might be related to the fact that you connected OUT- OR that the SGTL5000 analog preamp is not really good in amplifying frequencies in the high ultrasound range.
  8. #258
    Nov 2018
    Netherlands
    83
    The microphones work fine Frank, even with out- tied to ground with a capacitor.... It was clearly stated in the last lines of the datasheet.
    Well, I only soldered about 10 of my mics with extra capacitors. Nor ready for testing (again) together with a bunch of other freshly soldered mics.
    Man, this ICS40730 realy is a huge one :-)
    I also had been playing with Cor's code. Not with the latest but just to see why people are complaining it does not work, even when I thought i made good instructions.
    I found two "problems" uSDFS has been updated tan this gives error of missing ff_utils.h, I used the older library I had stored and it worked right away.
    The other problem was an exitstatus 1 error when compiling almost is finished. This did not appear with Arduino 1.8.7 with Teensyduino 1.44 but now that we have the 1.8.9 and 1.46 version I can not get the code from post 159 to compile.
    Switching back again to the older uSDFS and Arduino 1.8.7 with Teensyduino 1.44 fixed the errors.
    Edwin
  9. #259
    Nov 2018
    Netherlands
    83
    For the people struggling to find the older versions the Arduino 1.8.7 windows installer
    Here the Teensyduino 1.44 Windows installer
    The old uSDFS library
    If everything fails, use the precompiled hex v0.84 with the code by Corber as found on github today.
    Or this older hex file (082?) I had on my computer.
    Open Teensy.exe in C:\Program Files (x86)\Arduino\hardware\tools
    Select open hex file, and press the button on the Teensy to load the file.
    The time and date will notbe correct I guess but at leas it could save you with struggling to get things compiled.
    Edwin
  10. #260
    Jun 2019
    France
    40
    Many thanks for your help....I dont have old sd micro. I continu with my SD HC in fat32. I download corberjune.ino.hex with old tools teensy duino : it works :
    I can see the message of Sd recording, Button stop work. I can read the file into audacity. I check only with noise.
    The other hex file is to big for teensy tools
    I was not able to compile with A1.8.7 , T 1.44 and this old uSDFS. First I need to rename the function SDHC_isr wich is into two librairy ( uSDFS and SD)...like yet discribe in my first post here. Some other compilation problems.
    Under last version of Arduino and Teensy I have try someexample in SD and uSDFS. Most of them are working.
    Remi
  11. #261
    Jun 2018
    Netherlands
    257
    Quote Originally Posted by remis View Post
    Remi
    You mention a corberjune.ino.hex ... that you download ... I guess that is a compiled version of my code that I upload at https://github.com/CorBer/teensy_batdetector ? When sharing your work (and problems) try to be accurate in describing what you are doing as this might lead very easy to confusing remarks.
    regards
    Cor
  12. #262
    Jun 2018
    Netherlands
    257
    I have just added the hex files that Edwin mentioned in message#259, they are available on github from https://github.com/CorBer/teensy_bat...e_compiled_hex
    kind regards
    Cor
  13. #263
    Oct 2015
    Central Europe
    453
    Hi Edwin,
    what an impressive amount of microphones!!! Looks like a lot of soldering fun ;-).
    This is wrong for single ended mode and is not stated in the datasheet, that is what my posts in the last days were about.
    As you can see on page 9 of the manual, the codec in figure 7 has a differential input. Only for differential output connect OUT- of the mic to IN- of the codec (IN- is not the same as GND in a differential input codec).
    For a single-ended MIC output leave OUT- unconnected. --> see page 8 of the datasheet:
    "The unused output pin should be left disconnected when the mic is used in single-ended mode; do not connect the unused pin to ground."
    But maybe we are talking about different microphones and different datasheets ???
    This is the one I am using:
    http://www.invensense.com/wp-content...40730-v1.0.pdf
    I think it would be good to contact Walter, WMXZ, the author of the uSDFS lib in order to resolve the problem with the lib. I do not think it is wise to directly delete / alter the uSDFS files or other files in the Teensyduino installation.
  14. #264
    Oct 2015
    Central Europe
    453
    deleted due to browser error.
  15. #265
    2,344
    Quote Originally Posted by pe1pwf View Post
    I repeat, what I said earlier, do NOT use uSDFS together with SD and if you only need the tm2seconds or seconds2tm functions it is better to copy the function from ff_utils.h
  16. #266
    Jun 2018
    Netherlands
    257
    I do not think that the original source of Frank DD4WH was only using tm2seconds from uSDFS. That error raised when people where trying to ommit using the SD for recording, but that is not really the functionality we are building towards. From what I understand (based on a mail from Edwin), the 1.0.6 version was working fine and things went wrong with the latest version(s). Its a bit unclear - I looked at the commits - what can cause this behaviour from uSDFS.
    This is probably also a pure windows/arduino problem. The sourcecode in my github uses seconds2tm from your ff_utils.h library and I have (programming in visual code under linux) no problems. I think the arduino uses libraries different. Question is where the link to uSDFS comes into the play and how to prevent it. This is the codepart that sets up the initial interaction with SD and additional libraries. As you see no reference to uSDFS.
    #ifdef USESD1
      //#define USESD
      #include "ff.h"       // uSDFS lib
      #include "ff_utils.h" // uSDFS lib
      File root;
      FRESULT rc;        /* Result code */
      FATFS fatfs;      /* File system object */
      FIL fil;        /* File object */
    regards
    Cor
  17. #267
    Nov 2018
    Netherlands
    83
    When compile the #159 post with Arduino 1.8.7 and Teensyduino 1.44 and the latest uSDFS library I get this error.
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Toshiba\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -ide-version=10807 -build-path C:\Users\Toshiba\AppData\Local\Temp\arduino_build_671532 -warnings=all -build-cache C:\Users\Toshiba\AppData\Local\Temp\arduino_cache_784013 -verbose C:\Users\Toshiba\Documents\Arduino\teensybatpost159\teensybatpost159.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Toshiba\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -ide-version=10807 -build-path C:\Users\Toshiba\AppData\Local\Temp\arduino_build_671532 -warnings=all -build-cache C:\Users\Toshiba\AppData\Local\Temp\arduino_cache_784013 -verbose C:\Users\Toshiba\Documents\Arduino\teensybatpost159\teensybatpost159.ino
    Using board 'teensy36' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Detecting libraries used...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=144 -DARDUINO=10807 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Toshiba\\AppData\\Local\\Temp\\arduino_build_671532\\sketch\\teensybatpost159.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=144 -DARDUINO=10807 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "C:\\Users\\Toshiba\\AppData\\Local\\Temp\\arduino_build_671532\\sketch\\teensybatpost159.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=144 -DARDUINO=10807 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\uSDFS-master\\src" "C:\\Users\\Toshiba\\AppData\\Local\\Temp\\arduino_build_671532\\sketch\\teensybatpost159.ino.cpp" -o nul
    C:\Users\Toshiba\Documents\Arduino\teensybatpost159\teensybatpost159.ino:115:37: fatal error: ff_utils.h: No such file or directory
    compilation terminated.
    Using library SD at version 1.2.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
    Using library uSDFS-master at version 1.1.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\uSDFS-master
    Error compiling for board Teensy 3.6.
    It seems the file ff_utils.h is missing, but maybe that is not the real issue here.
    I see a lot of files are moved from the src folder. I tried to put the old ff_utils.h back into the src folder but end up with a new missing file.
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\uSDFS-master\src\utility\sd_msc.cpp:41:18: fatal error: msc.h: No such file or directory
    When the #include ff_utils.h is commented out I get this error:
    I did not yet see what calls for msc.h but it is late enough here already so I get some sleep first.
    Edwin
  18. #268
    Jun 2018
    Netherlands
    257
    I an attempt to solve the problems in the windows environment I have split the function seconds2tm away from dependencies related to uSDFS. To do this I have copied/changed the ff_utils(.c/.h) file and renamed the function to seconds2time and removed other functions from the ff_utils library. This is all available on the github repository, you need to download the new main.cpp and ff_utils_copy(.c/.h). I hope this clears the problems with the uSDFS library for windows users. Since I dont have a working setup to test the windows environment I cannot guarantee this will work. In my linux setup this did compile and work,
    regards
    Cor
  19. #269
    2,344
    Quote Originally Posted by CorBee View Post
    I an attempt to solve the problems in the windows environment I have split the function seconds2tm away from dependencies related to uSDFS. To do this I have copied/changed the ff_utils(.c/.h) file and renamed the function to seconds2time. This is all available on the github repository, you need to download the new main.cpp and ff_utils_copy(.c/.h). I hope this clears the problems with the uSDFS library for windows users. Since I dont have a working setup to test the windows environment I cannot guarantee this will work. In my linux setup this did compile and work,
    regards
    Cor
    it should, obviously you remove all includes ff.h and ff_itils.h
    OK, I see you did not.
    I wiil later suggest mods to use bat detector with uSDFS (USESD1)
  20. #270
    Jun 2018
    Netherlands
    257
    Did I miss one then ? In the ff_utils_copy library I have no references to ff_utils or ff anymore ... and also not in the main code. A reference to ff is needed for other functions
  21. #271
    Jun 2018
    Netherlands
    257
    Just saw that Edwin (pe1wf) has tried to use the new code (0.85) but still got compilation errors using a windows setup. It seems the whole structure of reading/writing to SDcards needs to be reconstructed to untangle dependencies that have to do with the SD and uSDFS libraries. Not sure how easy that is ...
    Cor
  22. #272
    2,344
    I made some changes to the code teensy_batdetector.zip
    I combined the SD routines together
    I also changes the granular effect class to coexist with stock library
    The ff_utils files are not used and should be removed
    Have no HW to test it, but it compiled under Arduino/TD
    edit: uSDFS/utility/sd_conf.h must ne edited to remove msc (if not installed as library)
  23. #273
    Jun 2018
    Netherlands
    257
    Thanks very much for trying to get this working, I will wait until people that have the hardware and the windows-setup report back without compiler issues. In the mean time I will set this up in my environment also.
    regards
    Cor
  24. #274
    Jun 2018
    Netherlands
    257
    In my setup I got errors with the new way to call granular, could easy switch back by commenting line 275 #include "effect_granular.h" and then renaming
    mAudioEffectGranular granular1;
    back to AudioEffectGranular granular1;
    Then got the expected error for msc, saw in message 273 that something needs to change in utility/sd_config.h ... but what ?
    Simply changing #define USE_MSC 1 to #define USE_MSC 0
    did not work and resulted in series of alike errors:
    .pioenvs/teensy36/lib54f/libuSDFS_ID2957.a(ff.c.o): In function `f_mount':
    ff.c:(.text.f_mount+0x0): multiple definition of `f_mount'
    Could it be due to an older version of the uSDFS library, I installed it directly using platformio and on the top of uSDFS.h I see
    #define uSDFS_VER "03_Jun_19_21_40"
  25. #275
    Nov 2018
    Netherlands
    83
    I just commented out this line in sd_config.h
    #define USE_MSC 1 // will be used in sd_msc.cpp
    Now the output looks like this...
    C:\Users\Toshiba\AppData\Local\Temp\arduino_build_330571\sketch\effect_granular.cpp: In member function 'void mAudioEffectGranular::begin(int16_t*, int16_t)':
    effect_granular.cpp:39: warning: unused variable 'subsample'
      int subsample=0;
    teensy_batdetectorwmxz:1085: error: 'FRESULT' has not been declared
       void die(char *str, FRESULT rc)
    Using library Time at version 1.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Time
    Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
    Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
    Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash
    Using library Bounce in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce (legacy)
    Using library ILI9341_t3 at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ILI9341_t3
    Using library Encoder at version 1.4.1 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder
    Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
