Page 18 of 22 FirstFirst ... 8 16 17 18 19 20 ... LastLast
Results 426 to 450 of 540
Thread: Bat detector
  1. #426
    Senior Member CorBee's Avatar
    Jun 2018
    Netherlands
    260
    Well the Mic is PCB mounted and thus that central pad is not something I can or will try to fiddle with ... its way to small for programmers I am used to buttons instead of a microscope
  2. #427
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    506
    well, then we will never know or solve the problem with the noise that you have . . .
  3. #428
    Jun 2018
    Netherlands
    260
    Well we have Edwin who assembles these modules and he might have a go at trying one without the central pad connected. So never ... say never
  4. #429
    Nov 2018
    Netherlands
    87
    In single ended output the -out pad is floating.
    I do have to mention the codec gain used is quite high,
    This is what I see with codec gain on 10
    I also made a few noises....
    The spectrum of the silent part looks like this.
    When I have codec gain set to 20 I see this
    Sorry for the different scales....
    Somehow the peak near 23Khz seems a lot larger than the rest of the noise.....
  5. #430
    Nov 2018
    Netherlands
    87
    Frank,
    Maybe you could use a SD-card extender like this to be able to seperate the SD powersupply from the Teensy. On the teensy it is very hard to do that but here you can easily cut a track.
    There are also versions with white plastic ribbon cable but I think those could be a bit more difficult to solder on to.
    Edwin
  6. #431
    Oct 2015
    Central Europe
    506
    Hi Edwin,
    thanks a lot! I will think more about that!
    However, adding additional hardware for features already implemented (built-in SD card) is a bit annyoing, and I think I read that the built-in SD card is much faster, which could be important for high speed ultrasound logging.
    All the best,
    Frank
  7. #432
    Nov 2018
    Netherlands
    87
    The externder was just an idea to be able to cut a power supply track and put a separate 3v3 source on the SD card to try and get the writing noise out of the teensy.
    I did some experiments again with the SGTL gain settings microphones and amplifiers. We already knew that using high gains settings on the SGTL adds a lot of noise.
    Both the ICS and SPU microphines seem to have some noise around 23Khz, with the SPU it is presented as a wider lower hump but the ICS presents a larger spike.
    The amplifiers help to suppress the low frequency sounds and enhance the high frequency sounds.
    Using these, or connecting the microphones directly seem to show the same raised levels on or around 23Khz.
    Although it seemed the noise is coming form the microphone the SGTL5000 also seems to have a big part in it.
    Of course this is not a huge problem but I just wanted to get rid of the vertical bar on the waterfall screen when I am searching for bats on high gain.
    Once one has located bats and they are closer one can reduce the gain and the bar becomes barely noticeable.
    The main problem is introduced by the user I guess, when there is no bat around, one tends to turn up the gain in the hope and hear some bats.
    If one wants great signal to noise level I guess the SGTL is not the best thing to use.
    Your stationary bat recorder is probably a lot better at recording but for running around the field using the detection modes and de graphical presentation dit approach is just great.
    Edwin
  8. #433
    Nov 2018
    Netherlands
    87
    I just updated some documentation.
    I don't quite remember if I shared the link to these files before but any eBay buyer of the V0.2 board als got the link form the item description.
    The link now holds the new files.
    Anyway, if you still have to start working on the V0.2 board here are the updated files.
    The most important changes:
    Display update noise is reduced by quite a bit. (100 ohm resistors in all data lines)
    Added instructions on how to build a transistor amp on this board if you like that better.
    Beside that there was some minor parts optimization.
    The V0.2 version was designed to use a low noise rail-to-rail opamp that would give us a bigger dynamic range and less noise.
    Unfortunately the opamp als picked up some display update noise. This noise is nearly gone by using the resistors in the datalines the opamp version now is just slightly better than te transistor version. No huge differences so if you have the transistor board version keep it. The biggest improvement is in reducing the data noise, of course one can also use the resistors in the data lines with the transistor version.
    If one wants to use standard headers, it is better to use a transistor amplifier.
    Kind regards,
    Edwin
    Almost forgot, there is some extra information on LCD revisions, some versions use direct LED drive, others have a transistor on the LED pin. One can determine the difference if there is a Q1 part next to the U1. It makes a huge difference in the resistor used on the LED pin.
  9. #434
    Dec 2016
    101
    Quote Originally Posted by pe1pwf View Post
    Edwin
    Edwin
    Have you tried to use the tl972 with a higher gain and using the SGTL at a lower gain?
    Alain
  10. #435
    Nov 2018
    Netherlands
    87
    Quote Originally Posted by AlainD View Post
    Edwin
    Alain
    Yes I did, somehow it seems I did not post my reply yesterday.
    I set the amplification close to 40dB on the TL972, these are the results i got in a quit room with SGTL gain set to 0
    I also did the same with SGTL gain set to 10
    With the ICS microphone I still get that peek although it is very low when using 0dB on the SGTL the SPU microphone also gives me a bit of signal near this frequency but it is much wider and a lot lower.
    I would still like to gave some control over the gain, If i do set the gain on the opamp very high I have only little control over the total gain.
    An extra control could be an option but I do not really want an extra switch or pot.
    Other experiments showed the amplification in the SGTL adds quite a bit of noise when it is at a high level. This 23Khz signal also proves we should better have more old fashioned analog amplification.
    For that reason I already changed the resistors a bit in the last builds.
    Since the SPU microphone has a wider and lower hump than the ICS, I still choose that in combination with this bat detector. Maybe I do not have the lowest noise level microphone but I think with the rest of the hardware one will hardly notice the difference.
    Kind regards,
    Edwin
  11. #436
    Jun 2019
    15
    Query regarding resistors in documents for build 0.2a
    Kind regards,
    Edwin
    Hi Edwin
    Can you clarify where the 100 ohm resistor bodies go between teensy and audio board please. Do the main resistor bodies go between the teensy and the audio board or under the audio board and the main pcb with just a wire link between the teensy and the audio board. Photo is not too clear. Many thanks.
  12. #437
    Nov 2018
    Netherlands
    87
    Quote Originally Posted by seriesman71 View Post
    Hi Edwin
    The resistors are all soldered on the teensy so these are between the teensy and audioboard.
    I hope this helps.
    On the last boards I soldered I cut the pins like this so that mounting was easier.
    Yes I know, the second picture are not 100 ohm resistors, I ran out of 100 ohm and used 150 which also work.
    Edwin
  13. #438
    Jun 2019
    15
    THanks Edwin, yes that helps.
    Regards
    Barry
  14. #439
    Jun 2018
    Netherlands
    260
    next software update: requests ??
    Behind the screens I am working on a rather large change/update of the current sourcecode. If anybody has specific wishes/ideas/bugs I would like to hear them to consider adding them to the sourcecode. For me this is more or less the last week that I can spend more than average time on this project. From next week on my daytime job will be more demanding than in the past weeks and that means the progress will slow down.
    regards
    Cor
  15. #440
    Jun 2019
    15
    Quote Originally Posted by CorBee View Post
    regards
    Cor
    Hi
    Is it possible include an option to reverse the direction of the encoders? I have two teensybats with encoders that work in opposite directions - very confusing. I know you posted v0.90 in two versions with opposite direction encoders but later hex files have all been one direction only. It would save having to have two hex versions of the same release. Thanks
  16. #441
    Jun 2018
    Netherlands
    260
    Hi Seriesman71,
    Thats allready part of the new setup, you can save the encoder direction-setting now inside a new "settings" menu. As soon as that works as planned I will inform overhere
    regards
    Cor
  17. #442
    Jun 2019
    15
    Tried out the latest version
    Hi Seriesman71,
    regards
    Cor
    Hi. Downloaded the second version of 095 as tried by Edwin. Its working well on my transistor amplifier model. The revised menu layout is a big improvement, gets a lot of material irelevant to using the device in the field out of the way. Its simpler to use by far. Thanks for all your hard work, its obviously taken a great deal of effort.
  18. #443
    Jun 2018
    Netherlands
    260
    Thanks to @Seriesman71 and @pe1pwf for testing, I will try today to wrap up the work on 0.95 and release the sourcecode and an updated hex. The current hex will be removed as it still contains some issues.
    regards
    Cor
  19. #444
    Jun 2018
    Netherlands
    260
    v096 major update
    I have just uploaded both the source and the compiled hex for V096. As mentioned before this contains a large amount of changes. Edwin (pe1pwf) and Seriesman71 have been testing this also and I hope this works for everybody as planned.
    The biggest change is the way the menu now works, with more and more settings entering the main menu it started to become a cluttered system. Now most settings have been moved to a separate settings page and the main menu only contains necessary options to control/use the detector.
    Have fun,
    Cor
    * v0.95 MAJOR CHANGES !!!
    - compacted the main menu to have all less often changed settings in a separate SETTINGS page
    - setting of both time and date can be done from the new settings page
    - updated startup from EEprom stored settings (more settings stored (see settings page))
    - improved spectrum-graph functionality (peak-hold now visibible, was present for many versions but invisible)
    - made as many as possible user-changeable options cyclic (if the user tries to rotate the encoder above the highest value automatically go to the lowest value)
    - time was updating still on screen every minute during recording, now has been removed
    - added a routine to monitor VIN (or anything else) voltage on A3 (pin17)
    - read unique SN (allows identifying different detectors, one for testing with additional functions)
  20. #445
    Jun 2018
    Netherlands
    260
    V096 ... has a problem
    Without me realizing V096 suddenly had a problem when used. So currently I have pulled off both the source and hex from the site until the repair is done ...
    regards
    Cor
  21. #446
    Jun 2019
    Öckerö, Sweden
    7
    I have used Teensy Bat Detector a couple of times and heard some bats.
    To night I was out again and I did not hear any bats but my friend with a Pettersson D200 did.
    How is the sensitivity of Teensy Bat Detector compared with example D200?
    I am using microphone ICS-40730, do I need to do any changes on the mic amplifier then using ICS-40730?
    Regards Bengt
  22. #447
    Jun 2018
    Netherlands
    260
    Comparing detectors is not a very simple thing unless it is done in a controlled environment. Can you tell which pre-amplifier you used ? How is your microphone constructed ?
    Frank (DD4WH) has posted some tests of microphones on this forum earlier (I dont have the exact message# at hand), it was showing that these microphones do work well.
    regards
    Cor
  23. #448
    Jun 2018
    Netherlands
    260
    regards
    Cor
    I have just uploaded a proper working hex and also updated the sourcecode. In the lib subdirectory I have added the most recent setup of the libraries I am using for those that are compiling the sourcecode themselves.
    This version can be recognized at startup as v0.96 20190824.
    regards
    Cor
  24. #449
    Jun 2019
    Öckerö, Sweden
    7
    Sensitivity
    regards
    Cor
    It is with one transistor, ICS-40730 mounted at the connector on the PCB front and a 3 mm hole in the enclosure.
    I shall do some measurement on the mic amplifier, which amplitud can I expect when I do some noise with a key ring?
    And maybe test without the enclosure.
    Regards Bengt
  25. #450
    Jun 2018
    Netherlands
    260
    Quote Originally Posted by benlenkar View Post
    Regards Bengt
    The amplitude will be depending on the distance from the key-ring to your detector, the loudness of your ring (intensity), the gain for the one-transistor amplifier (which design ?) and the mic_gain setting of the teensy_batdetector .
    One thing you can try to get a bit better understanding of the sensitivity is listening to for instance a constant high frequent signal coming from many devices with clocks inside. I have for instance an audio-player that emits this signal and I can pick it up about a meter away or so ... depending on the gain I use. Or a programmable timer (to switch appliances) will also. When you have a good and reliable source you can start recording/testing your device settings against that.
    Cor
    EDIT: this is my current 1-transistor amplifier (BC547=BC550c)
Name:	Screenshot from 2019-08-24 10-16-17.png
