Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 151 to 175 of 194
Thread: Bat detector
  1. #151
    Nov 2018
    5
    there must be some missing includes
    Can you tell me the program you are compiling?
    which system are you using Arduino IDE or other?
    I am using the code from here: https://github.com/CorBer/teensy_batdetector
    I've added the uSDFS to my library from here: https://github.com/WMXZ-EU/uSDFS
    Compiling in Arduino 1.8.7
    I've added a blank .ino to make it compile, apart from that it is all as downloaded
    I tried adding #include <stddef.h> just before #include "ff.h" but it didn't make any difference
    I don't think it is related to the Time.h discussion above as that include is commented out in this code but maybe I'm misunderstanding that bit.
  2. #152
    Nov 2018
    Netherlands
    28
    Hi nickjb,
    I guess you are using Arduino 1.8.7 in windows just like me.
    The code by corber should have an #include "Time.h"
    I now have replaced that with TimeAlt.h, if you add this TimeAlt library and use the code as below I guess it should compile.
    Your error output looked exactly like mine. I know this is not bet best way to fix but at least it should allow you to compile.
    TimeAlt to be added to C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ :
    https://drive.google.com/open?id=1V4...1j_Bbh78NpooRB
    I hope someone will be able to fix this properly without the TimeAlt library which actually is just a renamed Time library.
     *  TEENSY 3.6 BAT DETECTOR V0.1 20180814
     *  Copyright (c) 2018, Cor Berrevoets, registax@gmail.com
     *  TODO: use selectable presets
     *  HARDWARE USED:
     *     TEENSY 3.6
     *     TEENSY audio board
     *     Ultrasonic microphone with seperate preamplifier connected to mic/gnd on audioboard
     *       eg. Knowles MEMS SPU0410LR5H-QB
     *     TFT based on ILI9341
     *     2 rotary encoders with pushbutton
     *     2 pushbuttons
     *     SDCard
    *   IMPORTANT: uses the SD card slot of the Teensy, NOT the SD card slot of the audio board
     *  4 operational modes: Heterodyne.
     *                       Frequency divider
     *                       Automatic heterodyne (1/10 implemented)
     *                       Automatic TimeExpansion (live)
     *  Sample rates up to 352k
     *  User controlled parameters:
     *     Volume
     *     Gain
     *     Frequency
     *     Display (none, spectrum, waterfall)
     *     Samplerate
     *  Record raw data
     *  Play raw data (user selectable) on the SDcard using time_expansion (8, 11, 16,22,32,44k samplerate )
     *  Fixes compared to original base:
     *    - issue during recording due to not refilling part of the buffer (was repeating the original first 256 samples )
     *    - filenames have samplerate stored
     *    - RTC added (based on hardware)
     *   Based on code by DD4WH
     *   https://forum.pjrc.com/threads/38988-Bat-detector
     *   https://github.com/DD4WH/Teensy-Bat-Detector
     *   made possible by the samplerate code by Frank Boesing, thanks Frank!
     *   Audio sample rate code - function setI2SFreq
     *   Copyright (c) 2016, Frank Bösing, f.boesing@gmx.de
     * THE SOFTWARE.
    /* CORBEE */
    /* TEENSY 3.6 PINSETUP (20180814)
                      GND                  Vin  - PREAMP V+
                       0                   Analog GND
                       1                   3.3V - MEMS MIC
                       2                   23 AUDIO -LRCLK
                       3                   22 AUDIO -TX
                       4                   21 TFT CS
                       5                   20 TFT DC
           AUDIO MEMCS 6                   19 AUDIO - SCL
           AUDIO MOSI  7                   18 AUDIO - SDA
                       8                   17
           AUDIO BCLK  9                   16
           AUDIO SDCS 10                  15 AUDIO -VOL
           AUDIO MCLK 11                  14 AUDIO -SCLK
           AUDIO MISO 12                  13 AUDIO -RX
                      3.3V                GND
                      24                  A22
                      25                  A21
                      26                  39  TFT MISO
            TFT SCLK  27                  38  MICROPUSH_L
            TFT MOSI  28                  37  MICROPUSH_R
         ENC_L-BUTTON 29                  36  ENC_R-BUTTON
         ENC_L A      30                  35  ENC_R A
         ENC_L B      31                  34  ENC_R B
                      32                  33
    //#define DEBUG
    #define USETFT
    //SD1 uses default SDcard Fat, TODO !! SD2 uses faster SDIO library
    #define USESD1
    #ifdef USESD1
      #define USESD
      #include "ff.h"       // uSDFS lib
      #include "ff_utils.h" // uSDFS lib
      File root;
      FRESULT rc;        /* Result code */
      FATFS fatfs;      /* File system object */
      FIL fil;        /* File object */
    // TODO: try and see if using the SdFs library is able to write faster
    // started setup and included several #ifdefs inside the audio-library SDrelated files (play_raw play_wav)
    #ifdef USESD2
    #define USESD
    //#include "SdFs.h"
    #include "logger_setup.h"
    //default SD related
    #ifdef USESD
      #define MAX_FILES    50
      #define MAX_FILE_LENGTH  13   // 8 chars plus 4 for.RAW plus NULL
      char filelist[ MAX_FILES ][ MAX_FILE_LENGTH ];
      int filecounter=0;
      int fileselect=0;
      int referencefile=0;
      //File frec; // audio is recorded to this file first
      int file_number = 0;
    #include <TimeAlt.h>
    #include "Audio.h"
    //#include <Wire.h>
    #include <Bounce.h>
    //#include <Metro.h>
    boolean SD_ACTIVE=false;
    boolean continousPlay=false;
    boolean batTrigger=false;//triggers when an ultrasonic signalpeak is found during FFT
    boolean TE_ready=true; //when a TEcall is played this signals the end of the call
    time_t getTeensy3Time()
      return Teensy3Clock.get();
    int helpmin; // definitions for time and date adjust - Menu
    int helphour;
    int helpday;
    int helpmonth;
    int helpyear;
    int helpsec;
    uint8_t hour10_old;
    uint8_t hour1_old;
    uint8_t minute10_old;
    uint8_t minute1_old;
    uint8_t second10_old;
    uint8_t second1_old;
    bool timeflag = 0;
    uint32_t lastmillis;
    #ifdef USETFT
     #define ILI9341
     #ifdef ILI9341
      #include "ILI9341_t3.h"
      #include "font_Arial.h"
      #define BACKLIGHT_PIN 255
      #define TOP_OFFSET 90
      #define BOTTOM_OFFSET 20
      #define TFT_DC      20
      #define TFT_CS      21
      #define TFT_RST     255  // 255 = unused. connect to 3.3V
      #define TFT_MOSI    28
      #define TFT_SCLK    27
      #define TFT_MISO    39
      //#define Touch_CS    8
      ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
      //XPT2046_Touchscreen ts = XPT2046_Touchscreen(Touch_CS);
    //predefine menu background etc colors
      #define ENC_MENU_COLOR COLOR_YELLOW
      #define ENC_VALUE_COLOR COLOR_LIGHTGREY
      #define MENU_BCK_COLOR COLOR_DARKRED
    // this audio comes from the codec by I2S2
    AudioInputI2S                    i2s_in; // MIC input
    AudioRecordQueue                 recorder;
    AudioSynthWaveformSineHires      sine1; // local oscillator
    //AudioSynthWaveformSineHires      sine2; // local oscillator
    AudioEffectMultiply              heterodyne_multiplier; // multiply = mix
    //AudioEffectMultiply              mult2; // multiply = mix
    //AudioAnalyzeFFT1024         fft1024_1; // for waterfall display
    AudioAnalyzeFFT256               myFFT; // for spectrum display
    AudioPlaySdRaw                   player;
    AudioEffectGranular              granular1;
    AudioMixer4                      mixFFT;
    AudioMixer4                      outputMixer; //selective output
    AudioMixer4                      inputMixer; //selective input
    AudioOutputI2S                   i2s_out; // headphone output
    AudioConnection mic_toinput         (i2s_in, 0, inputMixer, 0); //microphone signal
    AudioConnection mic_torecorder      (i2s_in, 0, recorder, 0); //microphone signal
    //AudioConnection mic_topeak (i2s_in, peakRMS);
    //AudioConnection mic_topeak1 (i2s_in, peakVal);
    AudioConnection player_toinput      (player, 0, inputMixer, 1); //player signal
    AudioConnection input_toswitch      (inputMixer,0,  mixFFT,0);
    AudioConnection input_todelay       (inputMixer,0, granular1, 0);
    AudioConnection switch_toFFT        (mixFFT,0, myFFT,0 ); //raw recording channel
    AudioConnection input_toheterodyne1 (inputMixer, 0, heterodyne_multiplier, 0); //heterodyne 1 signal
    AudioConnection sineheterodyne1    (sine1, 0, heterodyne_multiplier, 1);//heterodyne 1 mixerfreq
    AudioConnection granular_toout (granular1,0, outputMixer,1);
    //AudioConnection input_toheterodyne2 (granular1, 0, mult2, 0); //heterodyne 2
    //AudioConnection sineheterodyne2     (sine2, 0, mult2, 1);//heterodyne 2 mixerfreq
    AudioConnection heterodyne1_toout      (heterodyne_multiplier, 0, outputMixer, 0);  //heterodyne 1 output to outputmixer
    //AudioConnection heterodyne2_toout      (mult2, 0, outputMixer, 1);  //heterodyne 2 output to outputmixer
    AudioConnection player_toout           (inputMixer,0, outputMixer, 2);    //direct signal (use with player) to outputmixer
    AudioConnection output_toheadphoneleft      (outputMixer, 0, i2s_out, 0); // output to headphone
    AudioConnection output_toheadphoneright     (outputMixer, 0, i2s_out, 1);
    //AudioConnection granular_toheadphone        (granular1,0,i2s_out,1);
    AudioControlSGTL5000        sgtl5000;
    //const int myInput = AUDIO_INPUT_LINEIN;
    const int myInput = AUDIO_INPUT_MIC;
    #define GRANULAR_MEMORY_SIZE 30000  // enough for 100 ms at 281kHz
    int16_t granularMemory[GRANULAR_MEMORY_SIZE];
    // forward declaration Stop recording with message
    #ifdef DEBUGSERIAL
       void die(char *str, FRESULT rc);
    extern "C" uint32_t usd_getError(void);
    struct tm seconds2tm(uint32_t tt);
    //continous timers
    elapsedMillis since_bat_detection1; //start timing directly after FFT detects an ultrasound
    elapsedMillis since_bat_detection2; //start timing directly after FFT detects the end of the ultrasound
    elapsedMillis since_heterodyne=1000; //timing interval for auto_heterodyne frequency adjustments
    uint16_t callLength=0;
    //uint16_t clicker=0;
    /************** RECORDING PLAYING SETTINGS *****************/
    const int8_t    MODE_DETECT = 0;
    const int8_t    MODE_REC = 1;
    const int8_t    MODE_PLAY = 2;
    int mode = MODE_DETECT;
    #if defined(__MK20DX256__)
      #define BUFFSIZE (8*1024) // size of buffer to be written
    #elif defined(__MK66FX1M0__)
      #define BUFF 64
      #define BUFFSIZE (BUFF*1024) // size of buffer to be written
    // buffer to store audiosamples during recording
    uint8_t buffern[BUFFSIZE] __attribute__( ( aligned ( 16 ) ) );
    //uint8_t buffern2[BUFFSIZE] __attribute__( ( aligned ( 16 ) ) );
    uint wr;
    uint32_t nj = 0;
    #define waterfallgraph 1
    #define spectrumgraph 2
    int idx_t = 0;
    int idx = 0;
    int64_t sum;
    float32_t mean;
    int16_t FFT_bin [128];
    int16_t FFT_max1 = 0;
    uint32_t FFT_max_bin1 = 0;
    int16_t FFT_mean1 = 0;
    int16_t FFT_max2 = 0;
    uint32_t FFT_max_bin2 = 0;
    int16_t FFT_mean2 = 0;
    //int16_t FFT_threshold = 0;
    int16_t FFT_bat [3]; // max of 3 frequencies are being displayed
    int16_t index_FFT;
    int l_limit;
    int u_limit;
    int index_l_limit;
    int index_u_limit;
    //const uint16_t FFT_points = 1024;
    const uint16_t FFT_points = 256;
    int barm [512];
    #define SAMPLE_RATE_MIN               0
    #define SAMPLE_RATE_8K                0
    #define SAMPLE_RATE_11K               1
    #define SAMPLE_RATE_16K               2
    #define SAMPLE_RATE_22K               3
    #define SAMPLE_RATE_32K               4
    #define SAMPLE_RATE_44K               5
    #define SAMPLE_RATE_48K               6
    #define SAMPLE_RATE_88K               7
    #define SAMPLE_RATE_96K               8
    #define SAMPLE_RATE_176K              9
    #define SAMPLE_RATE_192K              10
    #define SAMPLE_RATE_234K              11
    #define SAMPLE_RATE_281K              12
    #define SAMPLE_RATE_352K              13
    #define SAMPLE_RATE_MAX               13
    typedef struct SR_Descriptor
        const int SR_n;
        const char* const txt; //display
    } SR_Desc;
    // SRtext and position for the FFT spectrum display scale
    const SR_Descriptor SR [SAMPLE_RATE_MAX + 1] =
        //   SR_n ,  f1
        {  SAMPLE_RATE_8K,  "8"},
        {  SAMPLE_RATE_11K,  "11"},
        {  SAMPLE_RATE_16K,  "16"},
        {  SAMPLE_RATE_22K,  "22"},
        {  SAMPLE_RATE_32K,  "32"},
        {  SAMPLE_RATE_44K,  "44"},
        {  SAMPLE_RATE_48K,  "48"},
        {  SAMPLE_RATE_88K,  "88"},
        {  SAMPLE_RATE_96K,  "96"},
        {  SAMPLE_RATE_176K,  "176"},
        {  SAMPLE_RATE_192K,  "192"},
        {  SAMPLE_RATE_234K,  "234"},
        {  SAMPLE_RATE_281K,  "281"},
        {  SAMPLE_RATE_352K,  "352"}
    // setup for FFTgraph denoising
    uint32_t FFTcount=0; //count the # of FFTs done
    uint16_t powerspectrumCounter=0;
    float FFTavg[128];
    float FFTpowerspectrum[128];
    float powerspectrum_Max=0;
    // defaults at startup functions
    int displaychoice=waterfallgraph; //default display
    int8_t mic_gain = 35; // start detecting with this MIC_GAIN in dB
    int8_t volume=50;
    int freq_real = 45000; // start heterodyne detecting at this frequency
    int freq_real_backup=freq_real; //used to return to proper settingafter using the play_function
    // initial sampling setup
    int sample_rate = SAMPLE_RATE_281K;
    int sample_rate_real = 281000;
    char * SRtext="281";
    int last_sample_rate=sample_rate;
    float freq_Oscillator =50000;
    /************************************************* MENU ********************************/
    typedef struct Menu_Descriptor
        const char* name;
        // ********preset variables below NOT USED YET
        const int len; // length of string to allow right-alignment
        const int def; //default settings
        const int low; // low threshold
        const int high; //high threshold
    } Menu_Desc;
    const int Leftchoices=10; //can have any value
    const int Rightchoices=10;
    const Menu_Descriptor MenuEntry [Leftchoices] =
    {  {"Volume",6,60,0,100}, //divide by 100
       {"Gain",4,30,0,63},
       {"Frequency",9,45,20,90}, //multiply 1000
       {"Display",7,0,0,0},
       {"Denoise",7,0,0,0},
       {"SampleR",6,0,0,0},
       {"Record",6,0,0,0}, //functions where the LeftEncoder
       {"Play",4,0,0,0},
       {"PlayD",5,0,0,0},
    //TODO constants should be part of the menuentry, a single structure to hold the info
    const int8_t  MENU_VOL = 0; //volume
    const int8_t  MENU_MIC = 1; //mic_gain
    const int8_t  MENU_FRQ = 2; //frequency
    const int8_t  MENU_DSP = 3; //display
    const int8_t  MENU_DNS = 4; //denoise
    const int8_t  MENU_SR  = 5; //sample rate
    const int8_t  MENU_REC = 6; //record
    const int8_t  MENU_PLY = 7; //play
    const int8_t  MENU_PLD = 8; //play at original rate
    //available modes
    const int detector_heterodyne=0;
    const int detector_divider=1;
    const int detector_Auto_heterodyne=2;
    const int detector_Auto_TE=3;
    const int detector_passive=4;
    //default
    int detector_mode=detector_heterodyne;
    //************************* ENCODER variables/constants
    const int8_t enc_menu=0; //changing encoder sets menuchoice
    const int8_t enc_value=1; //changing encoder sets value for a menuchoice
    const int8_t enc_leftside=0; //encoder
    const int8_t enc_rightside=1; //encoder
    const int8_t enc_up=1; //encoder goes up
    const int8_t enc_nc=0;
    const int8_t enc_dn=-1; //encoder goes down
    int EncLeft_menu_idx=0;
    int EncRight_menu_idx=0;
    int EncLeft_function=0;
    int EncRight_function=0;
    // ******** LEFT AND RIGHT ENCODER CONNECTIONS/BUTTONS
    #include <Encoder.h>
    //try to avoid interrupts as they can (possibly ?) interfere during recording
    #define ENCODER_DO_NOT_USE_INTERRUPTS
    #define MICROPUSH_RIGHT  37
    Bounce micropushButton_R = Bounce(MICROPUSH_RIGHT, 50);
    #define encoderButton_RIGHT      36
    Bounce encoderButton_R = Bounce(encoderButton_RIGHT, 50);
    Encoder EncRight(34,35);
    int EncRightPos=0;
    int EncRightchange=0;
    #define MICROPUSH_LEFT  38
    Bounce micropushButton_L = Bounce(MICROPUSH_LEFT, 50);
    #define encoderButton_LEFT       29
    Bounce encoderButton_L = Bounce(encoderButton_LEFT, 50);
    Encoder EncLeft(30,31);
    int EncLeftPos=0;
    int EncLeftchange=0;
    // **END************ LEFT AND RIGHT ENCODER DEFINITIONS
    #ifdef USESD1
       #ifdef DEBUGSERIAL
       Serial.printf("%s: Failed with rc=%u.\n", str, rc); for (;;) delay(100);
    #ifdef USESD1
    //uint32_t count=0;
    uint32_t ifn=0;
    uint32_t isFileOpen=0;
    TCHAR wfilename[80];
    uint32_t t0=0;
    uint32_t t1=0;
    char filename[80];
    void display_settings() {
      #ifdef USETFT
        tft.setTextColor(ENC_MENU_COLOR);
        tft.setFont(Arial_16);
        tft.fillRect(0,0,240,TOP_OFFSET-50,MENU_BCK_COLOR);
        tft.fillRect(0,TOP_OFFSET-10,240,10,COLOR_BLACK);
        tft.fillRect(0,ILI9341_TFTHEIGHT-BOTTOM_OFFSET,240,BOTTOM_OFFSET,MENU_BCK_COLOR);
        tft.setCursor(0,0);
        tft.print("g:"); tft.print(mic_gain);
        tft.print(" f:"); tft.print(freq_real);
        tft.print(" v:"); tft.print(volume);
        tft.print(" SR"); tft.print(SRtext);
        tft.setCursor(0,20);
        switch (detector_mode) {
           case detector_heterodyne:
             tft.print("HTD"); //
           case detector_divider:
             tft.print("FD");
           case detector_Auto_heterodyne:
             tft.print("Auto_HTD");
           case detector_Auto_TE:
            tft.print("Auto_TE");
           case detector_passive:
            tft.print("PASS");
           default:
            tft.print("error");
         // push the cursor to the lower part of the screen
         tft.setCursor(0,ILI9341_TFTHEIGHT-BOTTOM_OFFSET);
         /****************** SHOW ENCODER SETTING ***********************/
         // set the colors according to the function of the encoders
         if (mode==MODE_DETECT )
         // show menu selection as menu-active of value-active
           if (EncLeft_function==enc_value)
            { tft.setTextColor(ENC_MENU_COLOR);
            { tft.setTextColor(ENC_VALUE_COLOR);}
           tft.print(MenuEntry[EncLeft_menu_idx].name);
           tft.print(" ");
           if (EncRight_function==enc_value)
             { tft.setTextColor(ENC_MENU_COLOR);} //value is active
             { tft.setTextColor(ENC_VALUE_COLOR);} //menu is active
           //if MENU on the left-side is PLAY and selected than show the filename
            if ((EncLeft_menu_idx==MENU_PLY) and (EncLeft_function==enc_value))
               { //tft.print(fileselect);
                 tft.print(filelist[fileselect]);
             if (EncLeft_menu_idx==MENU_REC)
              // show the filename that will be used for the next recording
               {  sprintf(filename, "B%u_%s.raw", file_number+1,SRtext);
                  tft.print(filename );
             if (EncLeft_menu_idx==MENU_SR)
              { tft.print(SR[sample_rate].txt);
              { //tft.print(EncRightchange);
                tft.setCursor(ILI9341_TFTWIDTH/2  ,ILI9341_TFTHEIGHT-BOTTOM_OFFSET);
                tft.print(MenuEntry[EncRight_menu_idx].name);
            if (mode==MODE_REC)
                tft.print("REC:");
                tft.print(filename);
            if (mode==MODE_PLAY)
             {if (EncLeft_menu_idx==MENU_PLY)
                tft.print("PLAY:");
               {tft.setTextColor(ENC_VALUE_COLOR);
                tft.print(" ");
        //scale every 10kHz
        float x_factor=10000/(0.5*(sample_rate_real / FFT_points));
        int curF=2*int(freq_real/(sample_rate_real / FFT_points));
        int maxScale=int(sample_rate_real/20000);
        for (int i=1; i<maxScale; i++)
         { tft.drawFastVLine(i*x_factor, TOP_OFFSET-10, 9, ENC_MENU_COLOR);
        tft.fillCircle(curF,TOP_OFFSET-4,3,ENC_MENU_COLOR);
    void       set_mic_gain(int8_t gain) {
        AudioNoInterrupts();
        //sgtl5000.micGainNew (24);
        sgtl5000.micGain (gain);
        //sgtl5000.lineInLevel(gain/4);
        AudioInterrupts();
        display_settings();
        powerspectrum_Max=0; // change the powerspectrum_Max for the FFTpowerspectrum
    } // end function set_mic_gain
    void       set_freq_Oscillator(int freq) {
        // audio lib thinks we are still in 44118sps sample rate
        // therefore we have to scale the frequency of the local oscillator
        // in accordance with the REAL sample rate
        freq_Oscillator = (freq) * (AUDIO_SAMPLE_RATE_EXACT / sample_rate_real);
        //float F_LO2= (freq+5000) * (AUDIO_SAMPLE_RATE_EXACT / sample_rate_real);
        // if we switch to LOWER samples rates, make sure the running LO
        // frequency is allowed ( < 22k) ! If not, adjust consequently, so that
        // LO freq never goes up 22k, also adjust the variable freq_real
        if(freq_Oscillator > 22000) {
          freq_Oscillator = 22000;
          freq_real = freq_Oscillator * (sample_rate_real / AUDIO_SAMPLE_RATE_EXACT) + 9;
        //setup multiplier SINE
        sine1.frequency(freq_Oscillator);
        //sine2.frequency(freq_Oscillator);
        AudioInterrupts();
        display_settings();
    } // END of function set_freq_Oscillator
    // set samplerate code by Frank Boesing
    void setI2SFreq(int freq) {
      typedef struct {
        uint8_t mult;
        uint16_t div;
      } tmclk;
    //MCLD Divide sets the MCLK divide ratio such that: MCLK output = MCLK input * ( (FRACT + 1) / (DIVIDE + 1) ).
    // FRACT must be set equal or less than the value in the DIVIDE field.
    //(double)F_PLL * (double)clkArr[iFreq].mult / (256.0 * (double)clkArr[iFreq].div);
    //ex 180000000* 1 /(256* 3 )=234375Hz  setting   {1,3} at 180Mhz
    #if (F_PLL==16000000)
      const tmclk clkArr[numfreqs] = {{16, 125}, {148, 839}, {32, 125}, {145, 411}, {64, 125}, {151, 214}, {12, 17}, {96, 125}, {151, 107}, {24, 17}, {192, 125}, {127, 45}, {48, 17}, {255, 83} };
    #elif (F_PLL==72000000)
      const tmclk clkArr[numfreqs] = {{32, 1125}, {49, 1250}, {64, 1125}, {49, 625}, {128, 1125}, {98, 625}, {8, 51}, {64, 375}, {196, 625}, {16, 51}, {128, 375}, {249, 397}, {32, 51}, {185, 271} };
    #elif (F_PLL==96000000)
      const tmclk clkArr[numfreqs] = {{8, 375}, {73, 2483}, {16, 375}, {147, 2500}, {32, 375}, {147, 1250}, {2, 17}, {16, 125}, {147, 625}, {4, 17}, {32, 125}, {151, 321}, {8, 17}, {64, 125} };
    #elif (F_PLL==120000000)
      const tmclk clkArr[numfreqs] = {{32, 1875}, {89, 3784}, {64, 1875}, {147, 3125}, {128, 1875}, {205, 2179}, {8, 85}, {64, 625}, {89, 473}, {16, 85}, {128, 625}, {178, 473}, {32, 85}, {145, 354} };
    #elif (F_PLL==144000000)
      const tmclk clkArr[numfreqs] = {{16, 1125}, {49, 2500}, {32, 1125}, {49, 1250}, {64, 1125}, {49, 625}, {4, 51}, {32, 375}, {98, 625}, {8, 51}, {64, 375}, {196, 625}, {16, 51}, {128, 375} };
    #elif (F_PLL==168000000)
      const tmclk clkArr[numfreqs] = {{32, 2625}, {21, 1250}, {64, 2625}, {21, 625}, {128, 2625}, {42, 625}, {8, 119}, {64, 875}, {84, 625}, {16, 119}, {128, 875}, {168, 625}, {32, 119}, {189, 646} };
    #elif (F_PLL==180000000)
      const int numfreqs = 17;
      const int samplefreqs[numfreqs] = {  8000,      11025,      16000,      22050,       32000,       44100, (int)44117.64706 , 48000,      88200, (int)44117.64706 * 2,   96000, 176400, (int)44117.64706 * 4, 192000,  234000, 281000, 352800};
      const tmclk clkArr[numfreqs] = {{46, 4043}, {49, 3125}, {73, 3208}, {98, 3125}, {183, 4021}, {196, 3125}, {16, 255},   {128, 1875}, {107, 853},     {32, 255},   {219, 1604}, {1, 4},      {64, 255},     {219,802}, { 1,3 },  {2,5} , {1,2} };  //last value 219 802
    #elif (F_PLL==192000000)
      const tmclk clkArr[numfreqs] = {{4, 375}, {37, 2517}, {8, 375}, {73, 2483}, {16, 375}, {147, 2500}, {1, 17}, {8, 125}, {147, 1250}, {2, 17}, {16, 125}, {147, 625}, {4, 17}, {32, 125} };
    #elif (F_PLL==216000000)
      const tmclk clkArr[numfreqs] = {{32, 3375}, {49, 3750}, {64, 3375}, {49, 1875}, {128, 3375}, {98, 1875}, {8, 153}, {64, 1125}, {196, 1875}, {16, 153}, {128, 1125}, {226, 1081}, {32, 153}, {147, 646} };
    #elif (F_PLL==240000000)
      const tmclk clkArr[numfreqs] = {{16, 1875}, {29, 2466}, {32, 1875}, {89, 3784}, {64, 1875}, {147, 3125}, {4, 85}, {32, 625}, {205, 2179}, {8, 85}, {64, 625}, {89, 473}, {16, 85}, {128, 625} };
      for (int f = 0; f < numfreqs; f++) {
        if ( freq == samplefreqs[f] ) {
          while (I2S0_MCR & I2S_MCR_DUF) ;
          I2S0_MDR = I2S_MDR_FRACT((clkArr[f].mult - 1)) | I2S_MDR_DIVIDE((clkArr[f].div - 1));
          return;
    void      set_sample_rate (int sr) {
      switch (sr) {
        case SAMPLE_RATE_8K:
        sample_rate_real = 8000;
        SRtext = " 8";
        case SAMPLE_RATE_11K:
        sample_rate_real = 11025;
        SRtext = "11";
        case SAMPLE_RATE_16K:
        sample_rate_real = 16000;
        SRtext = "16";
        case SAMPLE_RATE_22K:
        sample_rate_real = 22050;
        SRtext = "22";
        case SAMPLE_RATE_32K:
        sample_rate_real = 32000;
        SRtext = "32";
        case SAMPLE_RATE_44K:
        sample_rate_real = 44100;
        SRtext = "44";
        case SAMPLE_RATE_48K:
        sample_rate_real = 48000;
        SRtext = "48";
        case SAMPLE_RATE_88K:
        sample_rate_real = 88200;
        SRtext = "88";
        case SAMPLE_RATE_96K:
        sample_rate_real = 96000;
        SRtext = "96";
        case SAMPLE_RATE_176K:
        sample_rate_real = 176400;
        SRtext = "176";
        case SAMPLE_RATE_192K:
        sample_rate_real = 192000;
        SRtext = "192";
        case SAMPLE_RATE_234K:
        sample_rate_real = 234000;
        SRtext = "234";
        case SAMPLE_RATE_281K:
        SRtext = "281";
        case SAMPLE_RATE_352K:
        sample_rate_real = 352800;
        SRtext = "352";
        setI2SFreq (sample_rate_real);
        delay(200); // this delay seems to be very essential !
        set_freq_Oscillator (freq_real);
        AudioInterrupts();
        delay(20);
        display_settings();
    } // END function set_sample_rate
    void spectrum() { // spectrum analyser code by rheslip - modified
         #ifdef USETFT
         if (myFFT.available()) {
    //     if (fft1024_1.available()) {
        int16_t peak=0; uint16_t avgF=0;
        // find the BIN corresponding to the current frequency-setting
        int curF=int(freq_real/(sample_rate_real / FFT_points));
    //    for (int i = 0; i < 240; i++) {
        //startup sequence to denoise the FFT
        FFTcount++;
        if (FFTcount==1)
         {for (int16_t i = 0; i < 128; i++) {
             FFTavg[i]=0;
        if (FFTcount<1000)
           for (int i = 0; i < 128; i++) {
             FFTavg[i]=FFTavg[i]+abs(myFFT.output[i])*0.001; //0.1% of total values
    for (int16_t x = 2; x < 128; x++) {
       avgF=avgF+FFT_bin[x];
       if (FFT_bin[x]>peak)
            peak=FFT_bin[x];
    avgF=avgF/128;
    //check if the peak is at least 2x higher than the average otherwise set the indicator low
    if ((peak-avgF)<(avgF/3))
      { maxF=2;}
    //  for (uint16_t x = 8; x < 512; x+=4) {
         FFT_bin[x] = (myFFT.output[x]);//-FFTavg[x]*0.9;
         int colF=ENC_VALUE_COLOR;
    //     FFT_bin[x/4] = abs(fft1024_1.output[x]);
         int barnew = (FFT_bin[x])/2 ;
         // this is a very simple first order IIR filter to smooth the reaction of the bars
         int bar = 0.05 * barnew + 0.95 * barm[x];
         if (bar >(ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET))
            { bar=(ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET);
         if (bar <0) bar=0;
         if (barnew >(ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET))
            { barnew=(ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET);
         int g_x=x*2;
         int spectrumline=barm[x];
         int spectrumline_new=barnew;
         //tft.drawFastVLine(g_x,TOP_OFFSET,ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET, COLOR_BLACK);
         tft.drawFastVLine(g_x,TOP_OFFSET,spectrumline_new, COLOR_GREEN);
         //tft.drawFastVLine(g_x,TOP_OFFSET,spectrumline, COLOR_RED);
         tft.drawFastVLine(g_x,TOP_OFFSET+spectrumline_new,ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET-spectrumline_new, COLOR_BLACK);
         tft.drawFastVLine(g_x+1,TOP_OFFSET,spectrumline, COLOR_DARKGREEN);
         tft.drawFastVLine(g_x+1,TOP_OFFSET+spectrumline,ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET-spectrumline, COLOR_BLACK);
        /* if (x==maxF)
           { colF=COLOR_ORANGE;
             tft.drawFastVLine(g_x,TOP_OFFSET,240-bar, colF);
         //tft.drawPixel(g_x,ILI9341_TFTHEIGHT-BOTTOM_OFFSET-bar,colF);
         barm[x] = bar;
        // if (mode == MODE_DETECT)  search_bats();
      } //end if
        {//float ww=( player.positionMillis()/player.lengthMillis()*240.0);
         tft.drawFastHLine(0,320-BOTTOM_OFFSET-5,240*player.positionMillis()/player.lengthMillis()-10,COLOR_BLACK);
         tft.drawFastHLine(240*player.positionMillis()/player.lengthMillis()-9,320-BOTTOM_OFFSET-5,5,ENC_MENU_COLOR);
         tft.drawFastHLine(0,320-BOTTOM_OFFSET-4,240*player.positionMillis()/player.lengthMillis()-10,COLOR_BLACK);
         tft.drawFastHLine(240*player.positionMillis()/player.lengthMillis()-9,320-BOTTOM_OFFSET-4,5,ENC_MENU_COLOR);
    #ifdef DEBUGSERIAL
    /*void check_processor() {
          if (second.check() == 1) {
          Serial.print("Proc = ");
          Serial.print(AudioProcessorUsage());
          Serial.print(" (");
          Serial.print(AudioProcessorUsageMax());
          Serial.print("),  Mem = ");
          Serial.print(AudioMemoryUsage());
          Serial.print(" (");
          Serial.print(AudioMemoryUsageMax());
          Serial.println(")");
          AudioProcessorUsageMaxReset();
          AudioMemoryUsageMaxReset();
    */ // END function check_processor
    void waterfall(void) // thanks to Frank B !
    #ifdef USETFT
    // code for 256 point FFT
      const uint16_t Y_OFFSET = TOP_OFFSET;
      static int count = TOP_OFFSET;
      //int curF=int(freq_real/(sample_rate_real / FFT_points));
      // lowest frequencybin to detect as a batcall
      int batCall_LoF_bin= int(30000/(sample_rate_real / FFT_points));
      int batCall_HiF_bin= int(80000/(sample_rate_real / FFT_points));
      uint16_t FFT_pixels[240]; // maximum of 240 pixels, each one is the result of one FFT
      FFT_pixels[0]=0; FFT_pixels[1]=0;  FFT_pixels[2]=0; FFT_pixels[3]=0;
        FFTcount++;
        //requested to start with a clean FFTavg array to denoise
        if (FFTcount==1)
              FFTavg[i]=0;
        // collect 1000 FFT samples for the denoise array
        if (FFTcount<100)
         { for (int i = 2; i < 128; i++) {
             //FFTavg[i]=FFTavg[i]+myFFT.read(i)*65536.0*5*0.001; //0.1% of total values
             FFTavg[i]=FFTavg[i]+myFFT.output[i]*10*0.001; //0.1% of total values
        int FFT_peakF_bin=0;
        int peak=512;
        int avgFFTbin=0;
        // there are 128 FFT different bins only 120 are shown on the graphs
        for (int i = 2; i < 120; i++) {
          int val = myFFT.output[i]*10 -FFTavg[i]*0.9 + 10; //v1
          avgFFTbin+=val;
          //detect the peakfrequency
          if (val>peak)
           { peak=val;
             FFT_peakF_bin=i;
           if (val<5)
               {val=5;}
           FFT_pixels[i*2] = tft.color565(
                  min(255, val/2),
                  (val/6>255)? 255 : val/6,
                  //(val/4>255)? 255 : val/4
                                0
                  //((255-val)>>1) <0? 0: (255-val)>>1
          FFT_pixels[i*2+1]=FFT_pixels[i*2];
        avgFFTbin=avgFFTbin/120;
        //mark the peak
        //FFT_pixels[FFT_peakF_bin*2]=COLOR_RED;
        //FFT_pixels[FFT_peakF_bin*2+1]=COLOR_RED;
       if ((peak/avgFFTbin)<1.2) //very low peakvalue so probably noise
         { FFT_peakF_bin=0;
      int powerSpectrum_Maxbin=0;
      // detected a peak in the bat frequencies
      if ((FFT_peakF_bin>batCall_LoF_bin) and (FFT_peakF_bin<batCall_HiF_bin))
        //collect data for the powerspectrum
            //add new samples
            FFTpowerspectrum[i]+=myFFT.output[i];
            //keep track of the maximum
            if (FFTpowerspectrum[i]>powerspectrum_Max)
               { powerspectrum_Max=FFTpowerspectrum[i];
                 powerSpectrum_Maxbin=i;
         //keep track of the no of samples with bat-activity
         powerspectrumCounter++;
        // update display after every 100th FFT sample with bat-activity
        if ((powerspectrumCounter>50)  )
           { powerspectrumCounter=0;
             //clear powerspectrumbox
             tft.fillRect(0,TOP_OFFSET-50,240,45, COLOR_BLACK);
             // keep a minimum maximumvalue to the powerspectrum
             int binLo=2; int binHi=0;
             for (int i=2; i<120; i++)
                int ypos=FFTpowerspectrum[i]/powerspectrum_Max*45;
                // first encounter of 1/20 of maximum
                if (i<powerSpectrum_Maxbin)
                  {if (FFTpowerspectrum[i]<(powerspectrum_Max*0.1))
                        {binLo=i;}}
                  {if (FFTpowerspectrum[i]>(powerspectrum_Max*0.1))
                        {binHi=i;}
                tft.drawFastVLine(i*2,TOP_OFFSET-ypos-6,ypos,COLOR_RED);
                if (i==powerSpectrum_Maxbin)
                  { tft.drawFastVLine(i*2,TOP_OFFSET-ypos-6,ypos,ENC_MENU_COLOR);
                //tft.drawFastVLine(i*2+1,TOP_OFFSET-ypos-6,ypos,COLOR_RED);
                FFTpowerspectrum[i]=0;
             //tft.setCursor(0,TOP_OFFSET-45);
             //tft.print(powerspectrum_Max);
             if (powerspectrum_Max==20000)
              {binLo=0; binHi=0;
             float multiplier=(sample_rate_real / FFT_points)*0.001;
             powerspectrum_Max=powerspectrum_Max*0.5; //lower the max after a graphupdate
             tft.setCursor(140,TOP_OFFSET-45);
             tft.print(int(binLo*multiplier) );
             tft.print(" ");
             tft.print(int(powerSpectrum_Maxbin*multiplier) );
             tft.print(" ");
             tft.print(int(binHi*multiplier) );
        if ((FFT_peakF_bin>batCall_LoF_bin) and (FFT_peakF_bin<batCall_HiF_bin)) // we got a high-frequent signal peak
            // when a batcall is first discovered
            if (not batTrigger)
              { since_bat_detection1=0; //start of the call mark
                //clicker=0;
                FFT_pixels[5]=ENC_VALUE_COLOR; // mark the start on the screen
                FFT_pixels[6]=ENC_VALUE_COLOR;
                FFT_pixels[7]=ENC_VALUE_COLOR;
                if (detector_mode==detector_Auto_heterodyne)
                   if (since_heterodyne>1000) //update the most every second
                    {freq_real=int((FFT_peakF_bin*(sample_rate_real / FFT_points)/500))*500; //round to nearest 500hz
                     set_freq_Oscillator(freq_real);
                     since_heterodyne=0;
                     //granular1.stop();
                //restart the TimeExpansion only if the previous call was played
                if ((detector_mode==detector_Auto_TE) and (TE_ready) )
                 { granular1.stop();
                   granular1.beginTimeExpansion(GRANULAR_MEMORY_SIZE);
                   granular1.setSpeed(0.05);
                   TE_ready=false;
             //clicker++;
             batTrigger=true;
       else // FFT_peakF_bin does not show a battcall
              if (batTrigger) //previous sample was still a call
               { callLength=since_bat_detection1; // got a pause so store the time since the start of the call
                 /*if (callLength>20) //call is too long
                  { TE_ready=true; // break the TE replay
                  since_bat_detection2=0; //start timing the length of the replay
              batTrigger=false;
        // restart TimeExpansion recording a bit after the call has finished completely
        if ((!TE_ready) and (since_bat_detection2>(callLength*10)))
          { //stop the time expansion
            TE_ready=true;
            granular1.stopTimeExpansion();
        if (since_bat_detection2<50) //keep scrolling 100ms after the last bat-call
          {  tft.writeRect( 0,count, ILI9341_TFTWIDTH,1, (uint16_t*) &FFT_pixels); //show a line with spectrumdata
             tft.setScroll(count);
            count++;
        if (count >= ILI9341_TFTHEIGHT-BOTTOM_OFFSET) count = Y_OFFSET;
    void startRecording() {
      mode = MODE_REC;
      #ifdef USESD1
        #ifdef DEBUGSERIAL
          Serial.print("startRecording");
        // close file
        if(isFileOpen)
          //close file
          rc = f_close(&fil);
          if (rc) die("close", rc);
          isFileOpen=0;
      if(!isFileOpen)
      file_number++;
      //automated filename BA_S.raw where A=file_number and S shows samplerate. Has to fit 8 chars
      // so max is B999_192.raw
      sprintf(filename, "B%u_%s.raw", file_number, SRtext);
        #ifdef DEBUGSERIAL
        Serial.println(filename);
      char2tchar(filename, 13, wfilename);
      filecounter++;
      strcpy(filelist[filecounter],filename );
      rc = f_stat (wfilename, 0);
      #ifdef DEBUGSERIAL
        Serial.printf("stat %d %x\n",rc,fil.obj.sclust);
      rc = f_open (&fil, wfilename, FA_WRITE | FA_CREATE_ALWAYS);
    #ifdef DEBUGSERIAL
        Serial.printf(" opened %d %x\n\r",rc,fil.obj.sclust);
        // check if file has errors
        if(rc == FR_INT_ERR)
        { // only option then is to close file
            rc = f_close(&fil);
            if(rc == FR_INVALID_OBJECT)
              #ifdef DEBUGSERIAL
              Serial.println("unlinking file");
              rc = f_unlink(wfilename);
              if (rc) {
                die("unlink", rc);
              die("close", rc);
        // retry open file
        rc = f_open(&fil, wfilename, FA_WRITE | FA_CREATE_ALWAYS);
        if(rc) {
          die("open", rc);
        isFileOpen=1;
      //clear the screen completely
      tft.fillRect(0,0,ILI9341_TFTWIDTH,ILI9341_TFTHEIGHT,COLOR_BLACK);
      tft.setFont(Arial_28);
      tft.setCursor(0,100);
      tft.print("RECORDING");
      display_settings();
      granular1.stop(); //stop granular
      //switch off several circuits
      mixFFT.gain(0,0);
      outputMixer.gain(1,0);  //shutdown granular output
      outputMixer.gain(0,1);
      nj=0;
      recorder.begin();
    void continueRecording() {
      #ifdef USESD1
      const uint32_t N_BUFFER = 2;
      const uint32_t N_LOOPS = BUFF*N_BUFFER; // !!! NLOOPS and BUFFSIZE ARE DEPENDENT !!! NLOOPS = BUFFSIZE/N_BUFFER
      // buffer size total = 256 * n_buffer * n_loops
      // queue: write n_buffer blocks * 256 bytes to buffer at a time; free queue buffer;
      // repeat n_loops times ( * n_buffer * 256 = total amount to write at one time)
      // then write to SD card
      if (recorder.available() >= N_BUFFER  )
      {// one buffer = 256 (8bit)-bytes = block of 128 16-bit samples
        //read N_BUFFER sample-blocks into memory
        for (int i = 0; i < N_BUFFER; i++) {
           //copy a new bufferblock from the audiorecorder into memory
           memcpy(buffern + i*256 + nj * 256 * N_BUFFER, recorder.readBuffer(), 256);
           //free the last buffer that was read
           recorder.freeBuffer();
        nj++;
        if (nj >  (N_LOOPS-1))
          nj = 0;
          //old code used to copy into a 2nd buffer, not needed since the writing to SD of the buffer seems faster than the filling
          //this allows larger buffers to be used
          //memcpy(buffern2,buffern,BUFFSIZE);
          //push to SDcard
          rc =  f_write (&fil, buffern, N_BUFFER * 256 * N_LOOPS, &wr);
    void stopRecording() {
    #ifdef USESD1
      #ifdef DEBUGSERIAL
        Serial.print("stopRecording");
        recorder.end();
        if (mode == MODE_REC) {
          while (recorder.available() > 0) {
          rc = f_write (&fil, (byte*)recorder.readBuffer(), 256, &wr);
      //      frec.write((byte*)recorder.readBuffer(), 256);
            //close file
            rc = f_close(&fil);
            isFileOpen=0;
      //    frec.close();
      //    playfile = recfile;
        mode = MODE_DETECT;
      //  clearname();
      #ifdef DEBUGSERIAL
        Serial.println (" Recording stopped!");
      //switch on FFT
      tft.fillScreen(COLOR_BLACK);
      mixFFT.gain(0,1);
    void startPlaying(int SR) {
    //      String NAME = "Bat_"+String(file_number)+".raw";
    //      char fi[15];
    //      NAME.toCharArray(fi, sizeof(NAME));
    inputMixer.gain(0,0); //switch off the mic-line as input
    inputMixer.gain(1,1); //switch on the playerline as input
          outputMixer.gain(2,1);  //player to output
          outputMixer.gain(0,0);  //shutdown heterodyne output
          EncRight_menu_idx=MENU_SR;
          EncRight_function=enc_value;
          freq_real_backup=freq_real; //keep track of heterodyne setting
      //direct play is used to test functionalty based on previous recorded data
      //this will play a previous recorded raw file through the system as if it were live data coming from the microphone
    if (EncLeft_menu_idx==MENU_PLD)
          outputMixer.gain(2,0);  //shutdown direct audio from player to output
          outputMixer.gain(0,1);  //default mode will be heterodyne based output
          if (detector_mode==detector_Auto_TE)
             { outputMixer.gain(1,1);  //start granular output processing
    //allow settling
      //keep track of the sample_rate
      SR=constrain(SR,SAMPLE_RATE_MIN,SAMPLE_RATE_MAX);
      set_sample_rate(SR);
      fileselect=constrain(fileselect,0,filecounter);
      strncpy(filename, filelist[fileselect],  13);
      //default display is waterfall
      display_settings();
      player.play(filename);
      mode = MODE_PLAY;
    void stopPlaying() {
    #ifdef DEBUGSERIAL
      Serial.print("stopPlaying");
      if (mode == MODE_PLAY) player.stop();
      mode = MODE_DETECT;
    #ifdef DEBUGSERIAL
      Serial.println (" Playing stopped");
      //restore last sample_rate setting
      set_sample_rate(last_sample_rate);
      freq_real=freq_real_backup;
      //restore heterodyne frequency
      outputMixer.gain(2,0); //stop the direct line output
      outputMixer.gain(1,1); // open granular output
      outputMixer.gain(0,1); // open heterodyne output
      inputMixer.gain(0,1); //switch on the mic-line
      inputMixer.gain(1,0); //switch off the playerline
    void continuePlaying() {
      //the end of file was reached
      if (!player.isPlaying()) {
        stopPlaying();
        if (continousPlay) //keep playing until stopped by the user
          { startPlaying(SAMPLE_RATE_176K);
    void changeDetector_mode()
      if (detector_mode==detector_heterodyne)
             { granular1.stop(); //stop other detecting routines
               outputMixer.gain(1,0);  //stop granular output
               outputMixer.gain(0,1);  //start heterodyne output
              //switch menu to volume/frequency
               EncLeft_menu_idx=MENU_VOL;
               EncLeft_function=enc_value;
               EncRight_menu_idx=MENU_FRQ;
          if (detector_mode==detector_divider)
             { granular1.beginDivider(GRANULAR_MEMORY_SIZE);
               //switch menu to volume/gain
               EncRight_menu_idx=MENU_MIC;
             { granular1.beginTimeExpansion(GRANULAR_MEMORY_SIZE);
               granular1.setSpeed(0.06); //default TE is 1/0.06 ~ 1/16 :TODO, switch from 1/x floats to divider value x
             { granular1.stop();
          if (detector_mode==detector_passive)
             { granular1.stop(); //stop all other detecting routines
               outputMixer.gain(2,1);  //direct line to output
           else //all other options use the heterodyne and granular output line
            {  outputMixer.gain(2,0);  //shut down direct line to output
               //outputMixer.gain(1,1);  //granular   output
               //outputMixer.gain(0,1);  //heterodyne output
    //*****************************************************update encoders
    void updateEncoder(uint8_t Encoderside )
      /************************setup vars*************************/
       int encodermode=-1; // menu=0 value =1;
       int change=0;
       int menu_idx=0;
       int choices=0;
        //get encodermode
       if (Encoderside==enc_leftside)
        { encodermode=EncLeft_function;
          change=EncLeftchange;
          menu_idx=EncLeft_menu_idx;
          choices=Leftchoices; //available menu options
       if (Encoderside==enc_rightside)
        { encodermode=EncRight_function;
          change=EncRightchange;
          menu_idx=EncRight_menu_idx;
          choices=Rightchoices; //available menu options
      /************************proces changes*************************/
      //encoder is in menumode
      if (encodermode==enc_menu)
        { menu_idx=menu_idx+change;
          //allow revolving choices
          if (menu_idx<0)
            {menu_idx=choices-1;}
          if (menu_idx>=choices)
            {menu_idx=0;}
          //remove functionality when SD is not active, so no SDCARD mounted or SDCARD is unreadable
          if (!SD_ACTIVE)
            { if ((menu_idx==MENU_PLD) or (menu_idx==MENU_PLY) or (menu_idx==MENU_REC))
               { // move menu to volume
                 menu_idx=MENU_VOL;
              { EncLeft_menu_idx=menu_idx; //limit the menu
         //limit the changes of the rightside encoder for specific functions
          if ((EncLeft_menu_idx!=MENU_SR) )
              { EncRight_menu_idx=menu_idx; //limit the menu
      //encoder is in valuemode and has changed position
      if ((encodermode==enc_value) and (change!=0))
          /******************************VOLUME  ***************/
          if (menu_idx==MENU_VOL)
            { volume+=change;
              volume=constrain(volume,0,90);
              float V=volume*0.01;
              sgtl5000.volume(V);
              AudioInterrupts();
          /******************************MIC_GAIN  ***************/
          if (menu_idx==MENU_MIC)
             mic_gain+=change;
             mic_gain=constrain(mic_gain,0,63);
             set_mic_gain(mic_gain);
             FFTcount=0; //start denoise after changing gain
             //reset FFTdenoise array
               FFTavg[i]=0;
          /******************************FREQUENCY  ***************/
          if (menu_idx==MENU_FRQ)
             { int delta=500;
               uint32_t currentmillis=millis();
               //when turning the encoder fast make the change larger
               if ((currentmillis-lastmillis)<500)
                  { delta=1000;}
               if ((currentmillis-lastmillis)<250)
                  { delta=2000;}
               if ((currentmillis-lastmillis)<100)
                  { delta=5000;}
              freq_real=freq_real+delta*change;
              // limit the frequencies to 500hz steps
              freq_real=constrain(freq_real,7000,int(sample_rate_real/2000)*1000-1000);
              lastmillis=millis();
          /******************************DENOISE  ***************/
          if (menu_idx==MENU_DNS)
            { // setting FFTcount to 0 activates a 1000 sample denoise
              FFTcount=0;
          /******************************DISPLAY  ***************/
          if (menu_idx==MENU_DSP)
               displaychoice+=change;
               displaychoice=displaychoice%3; //limit to 0(none),1(spectrum),2(waterfall)
               if (displaychoice==waterfallgraph)
                   tft.setRotation( 0 );
               if (displaychoice==spectrumgraph)
                tft.setScroll(0);
    /************** SPECIAL MODES WHERE THE LEFTENCODER SETS A FUNCTION AND THE RIGHT ENCODER SELECTS */
          /******************************SAMPLE_RATE  ***************/
          if (EncLeft_menu_idx==MENU_SR)  //only selects a possible sample_rate, user needs to press a button to SET sample_rate
            { sample_rate+=EncRightchange;
              sample_rate=constrain(sample_rate,SAMPLE_RATE_MIN,SAMPLE_RATE_MAX);
          /******************************SELECT A FILE  ***************/
          if ((EncLeft_menu_idx==MENU_PLY) and (EncRight_menu_idx==MENU_PLY) and (EncRight_function==enc_value))//menu play selected on the left and right
               if (mode!=MODE_PLAY)
                 fileselect+=EncRightchange;
                 fileselect=constrain(fileselect,0,filecounter-1);
          /******************************CHANGE SR during PLAY  ***************/
          if ((EncLeft_menu_idx==MENU_PLY) and (EncRight_menu_idx==MENU_SR) and (EncRight_function==enc_value))//menu play selected on the left and right
                     sample_rate=constrain(sample_rate,SAMPLE_RATE_8K,SAMPLE_RATE_44K);
                     set_sample_rate(sample_rate);
    void updateEncoders()
    //only react to changes large enough (depending on the steps of the encoder for one rotation)
     long EncRightnewPos = EncRight.read()/4;
     if (EncRightnewPos>EncRightPos)
       { EncRightchange=enc_up; }
       if (EncRightnewPos<EncRightPos)
       { EncRightchange=enc_dn; }
       { EncRightchange=enc_nc; }
     if (EncRightchange!=0)
        {updateEncoder(enc_rightside);
     EncRightPos=EncRightnewPos;
     long EncLeftnewPos = EncLeft.read()/4;
     if (EncLeftnewPos>EncLeftPos)
       { EncLeftchange=enc_up; }
       if (EncLeftnewPos<EncLeftPos)
       { EncLeftchange=enc_dn; }
       { EncLeftchange=enc_nc; }
     if (EncLeftchange!=0)
        {updateEncoder(enc_leftside);
     EncLeftPos=EncLeftnewPos;
     //update display only if a change has happened
     if ((EncRightchange!=0) or (EncLeftchange!=0))
          display_settings();
    void updateButtons()
     // Respond to button presses
     // try to make the interrupts as short as possible when recording
     if (mode==MODE_REC)
         encoderButton_L.update(); //check the left encoderbutton
          if ((encoderButton_L.risingEdge())  )
           { stopRecording();
              EncLeft_function=enc_menu; //force into active-menu
              display_settings();
     else // not MODE_REC
      encoderButton_R.update();
      micropushButton_L.update();
      micropushButton_R.update();
       /*RIGHT MICROPUSH */
      if (micropushButton_R.risingEdge()) {
            detector_mode++;
            if (detector_mode>detector_passive)
              {detector_mode=0;}
            changeDetector_mode();
            display_settings();
    /*LEFT MICROPUSH */
      if (micropushButton_L.risingEdge()) {
          //no function yet
      /************  LEFT ENCODER BUTTON *******************/
      if (encoderButton_L.risingEdge()) {
          EncLeft_function=!EncLeft_function;
          //*SPECIAL MODES that change rightside Encoder based on leftside Encoder menusetting
          //****************************************SAMPLERATE
          if ((EncLeft_menu_idx==MENU_SR) and (EncLeft_function==enc_value))
           { EncRight_menu_idx=MENU_SR;
             EncRight_function=enc_value; // set the rightcontroller to select
         if (SD_ACTIVE)
            /*if (mode==MODE_REC)
                     { stopRecording();
            if ((mode==MODE_PLAY) and ((EncLeft_menu_idx==MENU_PLY) or (EncLeft_menu_idx==MENU_PLD)))
                     { stopPlaying();
                       EncLeft_menu_idx=MENU_PLY;
            //Direct play menu got choosen, now change the rightencoder to choose a file
            if ((EncLeft_menu_idx==MENU_PLD) and (EncLeft_function==enc_value))
               EncRight_menu_idx=MENU_FRQ ;
            //play menu got choosen, now change the rightencoder to choose a file
               EncRight_menu_idx=MENU_PLY ;
         } //END SD_ACTIVE
         display_settings();
    /************  RIGHT ENCODER BUTTON *******************/
     if (encoderButton_R.risingEdge()) {
        EncRight_function=!EncRight_function; //switch between menu/value control
        //when EncLeftoder is SR menu than EncRightoder can directly be setting the samplerate at a press
        //the press should be a transfer from enc_value to enc_menu before it gets activated
        if ( (EncLeft_menu_idx==MENU_SR) and (EncRight_menu_idx==MENU_SR) and (EncRight_function==enc_menu))
        { set_sample_rate(sample_rate);
        //recording and playing are only possible with an active SD card
        if (SD_ACTIVE)
                 { stopRecording();
                   EncRight_function=enc_menu; //force into active-menu
              else*/
                     startRecording();
                  if (not continousPlay)
                    { stopPlaying();
          if (mode==MODE_DETECT)
           { if (EncLeft_menu_idx==MENU_PLY)
                { last_sample_rate=sample_rate;
                  startPlaying(SAMPLE_RATE_8K);
                  {  fileselect=referencefile;
                     continousPlay=true;
          display_settings();
     #ifdef DEBUGSERIAL
      delay(200);
    //setup Encoder Buttonpins with pullups
      pinMode(encoderButton_RIGHT,INPUT_PULLUP);
      pinMode(encoderButton_LEFT,INPUT_PULLUP);
      pinMode(MICROPUSH_RIGHT,INPUT_PULLUP);
      pinMode(MICROPUSH_LEFT,INPUT_PULLUP);
     // EncLeft.write(10000); //set default far away from 0 to avoid negative transitions
      //EncRight.write(10000); //set default far away from 0 to avoid negative transitions
    //startup menu
      // Audio connections require memory.
      AudioMemory(300);
    // Enable the audio shield. select input. and enable output
      sgtl5000.enable();
      sgtl5000.inputSelect(myInput);
      sgtl5000.volume(0.45);
      sgtl5000.micGain (mic_gain);
      //sgtl5000.adcHighPassFilterDisable(); // does not help too much!
      sgtl5000.lineInLevel(0);
      mixFFT.gain(0,1);
    // Init TFT display
    #ifdef USETFT
      tft.begin();
      //ts.begin();
      tft.setCursor(0, 0);
      tft.setScrollarea(TOP_OFFSET,BOTTOM_OFFSET);
      display_settings();
      tft.setCursor(80,50);
      tft.setFont(Arial_24);
      char tstr[9];
      snprintf(tstr,9, "%02d:%02d:%02d",  hour(), minute(), second() );
      tft.print(tstr);
      delay(2000); //wait a second to clearly show the time
       //Init SD card use
    // uses the SD card slot of the Teensy, NOT that of the audio boards
    // this init only for playback
    #ifdef USESD1
      if(!(SD.begin(BUILTIN_SDCARD)))
          #ifdef DEBUGSERIAL
        SD_ACTIVE=false;
        tft.fillCircle(70,50,5,COLOR_RED);
        SD_ACTIVE=true;
        tft.fillCircle(70,50,5,COLOR_GREEN);
        filecounter=0;
        root = SD.open("/");
        //TODO: check if file is a RAW file and also read the SAMPLERATE
        while (true) {
            File entry =  root.openNextFile();
            if (! entry) {
              // no more files
              tft.setCursor(0,50);
              tft.print(filecounter);
            if (entry.isDirectory()) {
              // do nothing, only look for raw files in the root
            } else
            strcpy(filelist[filecounter],entry.name() );
            if (String(entry.name())=="TEST_176.RAW")
               {referencefile=filecounter;
            filecounter++;
            entry.close();
    if (SD_ACTIVE)
    // Recording on SD card by uSDFS library
      {f_mount (&fatfs, (TCHAR *)_T("0:/"), 0);      /* Mount/Unmount a logical drive */
       for (int i=0; i<filecounter; i++)
           #ifdef DEBUGSERIAL
              #ifdef USETFT
                tft.setCursor(0,50+i*20);
                tft.print(filelist[i]);
         file_number=filecounter+1;
    #ifdef USESD2
     uSD.init();
    set_sample_rate (sample_rate);
    inputMixer.gain(0,1); //microphone active
    inputMixer.gain(1,0); //player off
    outputMixer.gain(0,1); // heterodyne1 to output
    outputMixer.gain(1,0); // granular to output off
    outputMixer.gain(2,0); // player to output off
    // the Granular effect requires memory to operate
    granular1.begin(granularMemory, GRANULAR_MEMORY_SIZE);
    // reset the FFT denoising array at startup
      FFTavg[i]=0;
    } // END SETUP
    // If we're playing or recording, carry on...
        continueRecording();
      if (mode == MODE_PLAY) {
        continuePlaying();
    updateButtons();
    // during recording only the left encoders button is used and screens are not updated
    if (mode!=MODE_REC)
     updateEncoders();
     #ifdef USETFT
        { waterfall();
        {  spectrum();
    Nov 2018
    5
    OK, that code seems to compile "better". Thanks. It still doesn't complete but I'm not really sure why. The only things in red are the first line, c:\\user... etc and the very last line
    Arduino: 1.8.7 (Windows 10), TD: 1.44, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
    C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\sketch\effect_granular.cpp: In member function 'void AudioEffectGranular::begin(int16_t*, int16_t)':
    effect_granular.cpp:39: warning: unused variable 'subsample'
      int subsample=0;
    main.cpp:398: warning: ISO C++ forbids converting a string constant to 'char*'
    main.cpp: In function 'void set_sample_rate(int)':
    main.cpp:725: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = " 8";
    main.cpp:729: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "11";
    main.cpp:733: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "16";
    main.cpp:737: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "22";
    main.cpp:741: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "32";
    main.cpp:745: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "44";
    main.cpp:749: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "48";
    main.cpp:753: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "88";
    main.cpp:757: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "96";
    main.cpp:761: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "176";
    main.cpp:765: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "192";
    main.cpp:769: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "234";
    main.cpp:773: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "281";
    main.cpp:777: warning: ISO C++ forbids converting a string constant to 'char*'
         SRtext = "352";
    main.cpp: In function 'void spectrum()':
    main.cpp:835: warning: unused variable 'colF'
    main.cpp:800: warning: unused variable 'curF'
    main.cpp: In function 'void startRecording()':
    main.cpp:1129: warning: ISO C++ forbids converting a string constant to 'char*'
    main.cpp:1165: warning: ISO C++ forbids converting a string constant to 'char*'
                 die("unlink", rc);
    main.cpp:1170: warning: ISO C++ forbids converting a string constant to 'char*'
               die("close", rc);
    main.cpp:1176: warning: ISO C++ forbids converting a string constant to 'char*'
           die("open", rc);
    main.cpp: In function 'void continueRecording()':
    main.cpp:1218: warning: comparison between signed and unsigned integer expressions
    main.cpp:1221: warning: comparison between signed and unsigned integer expressions
    main.cpp: In function 'void stopRecording()':
    main.cpp:1257: warning: ISO C++ forbids converting a string constant to 'char*'
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdio.c: In function 'SDHC_InitCard':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdio.c:194:12: warning: variable 'd' set but not used [-Wunused-but-set-variable]
      { uint8_t d[16];
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdio.c: At top level:
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdio.c:523:16: warning: 'sdhc_ReadBlock' defined but not used [-Wunused-function]
     static DRESULT sdhc_ReadBlock(LWord* pData, LWord Count, LWord Size)
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdio.c:554:16: warning: 'sdhc_WriteBlock' defined but not used [-Wunused-function]
     static DRESULT sdhc_WriteBlock(const LWord* pData, LWord Count, LWord Size)
    In file included from C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdio.c:56:0:
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdio_prv.h:223:17: warning: 'sdhc_WaitStatus' declared 'static' but never defined [-Wunused-function]
     static uint16_t sdhc_WaitStatus(LWord mask);
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c: In function 'SDReadBlock':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c:382:11: warning: pointer targets in passing argument 1 of 'xferBulk' differ in signedness [-Wpointer-sign]
      xferBulk(buff,0,512);
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c:382:11: note: expected 'char *' but argument is of type 'uint8_t * {aka unsigned char *}'
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c: In function 'SDWriteBlock':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c:563:13: warning: pointer targets in passing argument 2 of 'xferBulk' differ in signedness [-Wpointer-sign]
      xferBulk(0,buff,512);
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c:563:13: note: expected 'char *' but argument is of type 'uint8_t * {aka unsigned char *}'
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c: In function 'usd_readData':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c:859:11: warning: pointer targets in passing argument 1 of 'xferBulk' differ in signedness [-Wpointer-sign]
      xferBulk(dst, 0, count);
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdcard.c:859:11: note: expected 'char *' but argument is of type 'uint8_t * {aka unsigned char *}'
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdspi.c: In function 'SPIInit':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\sdspi.c:98:12: warning: unused variable 'brscaler' [-Wunused-variable]
      uint32_t  brscaler;
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\uSD.cpp: In member function 'TCHAR* uSDClass::char2tchar(const char*, size_t, TCHAR*)':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\uSD.cpp:37:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       for(ii = 0; ii<nn; ii++) tcharString[ii] = (TCHAR) charString[ii];
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\uSD.cpp: In member function 'char* uSDClass::tchar2char(TCHAR*, size_t, char*)':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\uSD.cpp:43:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       for(ii = 0; ii<nn; ii++) charString[ii] = (char) tcharString[ii];
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\uSD.cpp: In member function 'boolean uSDClass::exists(const char*)':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\uSD.cpp:77:8: warning: unused variable 'drive' [-Wunused-variable]
      TCHAR drive[80]; //(TCHAR *)_T("0:/")
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\uSDif.cpp: In function 'void sdspi_setup(uint16_t)':
    C:\Program Files (x86)\Arduino\libraries\uSDFS-master\src\uSDif.cpp:76:19: warning: variable 'finalclk' set but not used [-Wunused-but-set-variable]
       uint32_t        finalclk;
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_granular.cpp: In member function 'void AudioEffectGranular::begin(int16_t*, int16_t)':
      int subsample=0;
    C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\libraries\Audio\effect_granular.cpp.o: In function `AudioEffectGranular::update()':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/effect_granular.cpp:119: multiple definition of `AudioEffectGranular::update()'
    C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\sketch\effect_granular.cpp.o:C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\sketch/effect_granular.cpp:119: first defined here
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/effect_granular.cpp:119: multiple definition of `AudioEffectGranular::begin(short*, short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/effect_granular.cpp:119: multiple definition of `AudioEffectGranular::beginFreeze_int(int)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/effect_granular.cpp:119: multiple definition of `AudioEffectGranular::beginPitchShift_int(int)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/effect_granular.cpp:119: multiple definition of `AudioEffectGranular::beginTimeExpansion_int(int)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/effect_granular.cpp:119: multiple definition of `AudioEffectGranular::beginDivider_int(int)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/effect_granular.cpp:119: multiple definition of `AudioEffectGranular::stop()'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/effect_granular.cpp:119: multiple definition of `vtable for AudioEffectGranular'
    C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\libraries\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::ILI9341_t3(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:63: multiple definition of `ILI9341_t3::ILI9341_t3(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)'
    C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\sketch\ILI9341_t3.cpp.o:C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\sketch/ILI9341_t3.cpp:63: first defined here
    C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\libraries\ILI9341_t3\ILI9341_t3.cpp.o: In function `SPIClass::port()':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::ILI9341_t3(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)'
    C:\Users\NICKUS~1\AppData\Local\Temp\arduino_build_756457\sketch\ILI9341_t3.cpp.o:C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/Print.h:61: first defined here
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::setAddrWindow(unsigned short, unsigned short, unsigned short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::pushColor(unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawPixel(short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawFastVLine(short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawFastHLine(short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillRect(short, short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillScreen(unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillRectVGradient(short, short, short, short, unsigned short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillRectHGradient(short, short, short, short, unsigned short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillScreenVGradient(unsigned short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillScreenHGradient(unsigned short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::setRotation(unsigned char)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::setScroll(unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::invertDisplay(bool)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::readcommand8(unsigned char, unsigned char)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::readPixel(short, short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::readRect(short, short, short, short, unsigned short*)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::writeRect(short, short, short, short, unsigned short const*)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::writeRect8BPP(short, short, short, short, unsigned char const*, unsigned short const*)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::writeRect4BPP(short, short, short, short, unsigned char const*, unsigned short const*)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::writeRect2BPP(short, short, short, short, unsigned char const*, unsigned short const*)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::writeRect1BPP(short, short, short, short, unsigned char const*, unsigned short const*)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::begin()'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawCircle(short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawCircleHelper(short, short, short, unsigned char, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillCircleHelper(short, short, short, unsigned char, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillCircle(short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawLine(short, short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawRect(short, short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawRoundRect(short, short, short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillRoundRect(short, short, short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawTriangle(short, short, short, short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::fillTriangle(short, short, short, short, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawBitmap(short, short, unsigned char const*, short, short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawChar(short, short, unsigned char, unsigned short, unsigned short, unsigned char)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawFontChar(unsigned int)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::write(unsigned char)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::strPixelLen(char*)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::drawFontBits(unsigned long, unsigned long, unsigned long, unsigned long, unsigned long)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::setCursor(short, short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::getCursor(short*, short*)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::setTextSize(unsigned char)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::getTextSize()'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::setTextColor(unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::setTextColor(unsigned short, unsigned short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::setTextWrap(bool)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::getTextWrap()'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::getRotation()'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `ILI9341_t3::sleep(bool)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `Adafruit_GFX_Button::initButton(ILI9341_t3*, short, short, unsigned char, unsigned char, unsigned short, unsigned short, unsigned short, char const*, unsigned char)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `Adafruit_GFX_Button::drawButton(bool)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `Adafruit_GFX_Button::contains(short, short)'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:488: multiple definition of `vtable for ILI9341_t3'
    Error compiling for board Teensy 3.6.
  4. #154
    2,028
    Quote Originally Posted by pe1pwf View Post
    I hope someone will be able to fix this properly without the TimeAlt library which actually is just a renamed Time library.
    pe1pwf: could you please comment the include of TimeAlt.h and all known time function until it compiles
    which lines do you have to comment?
    If it is only the two function, then solution is easy
  5. #155
    Nov 2018
    Netherlands
    28
    These seem to be the only lines that seem to be related....
    Ihe number is the line number in the code (+/- 3 lines)
    147 //#include <Time.h>
    1812 // setSyncProvider(getTeensy3Time);
    1837 // snprintf(tstr,9, "%02d:%02d:%02d", hour(), minute(), second() );
  6. #156
    2,028
    let the line commented (to be able to go back)
    comment also lines 160 to 163 (function time_t getTeensy3Time())
    after (commented) line 1837 add
    struct tm tx = seconds2tm(RTC_TSR);
    snprintf(tstr,9, "%02d:%02d:%02d", tx.tm_hour, tx.tm_min, tx.tm_sec);
  7. #157
    Nov 2018
    Netherlands
    28
    Thanks WMXZ
    It compiles just fine. I have not checked how well everything works.
    I just got my PCB's so I will mount the parts first on one of these new PCB's.
    My experimental PCB does not have a RTC battery mounted yet.
  8. #158
    Nov 2018
    Netherlands
    28
    Just threw some parts together on the board.
    I know I did not gave the right transistors for the microphone amplifier, but compiled and uploaded the sketch.
    I just made some silent recordings and the right timestamp is used, the RTC seems to function just fine.
    Thanks a lot WMXZ, this functions without the struggle with Time.h.
    I hope I will get the enclosure and some transistors quickly so I can finish this project and do a full and complete test.
    Kind regards,
    Edwin
  9. #159
    Nov 2018
    Netherlands
    28
    I just had some experiments with the detector with the code alterations as suggested by WMXZ. As far as I can tel thinks look good without Time.h
    I pasted the code below for the people that missed the lines that needed to be altered.
    I hope Cor also find the time to check this after all this is his baby, well together with Frank DD4WH that is....
    I hope nickjb get things compiled and maybe misterixx could try as well. As i understand he also was struggling to het things working in windows and used some virtual machine running linux to compile.
    The PCB's you have seen pictures off work well enough, I did not even hear the updating of the display as I did with my forst experimental board. Apparently the shielding works well enough and decoupling of noises is enough, the only modifiction needed is the seperate 3.3V for the audioboard and microphone amplifier.
    I had some boards made and I only need one myself so if anyone would like to try one.... It can change owner for about $5 usd and shipping takes about $2 usd WW.
    Kind regards,
    Edwin
     *  TEENSY 3.6 BAT DETECTOR V0.1 20180814
     *  Copyright (c) 2018, Cor Berrevoets, registax@gmail.com
     *  TODO: use selectable presets
     *  HARDWARE USED:
     *     TEENSY 3.6
     *     TEENSY audio board
     *     Ultrasonic microphone with seperate preamplifier connected to mic/gnd on audioboard
     *       eg. Knowles MEMS SPU0410LR5H-QB
     *     TFT based on ILI9341
     *     2 rotary encoders with pushbutton
     *     2 pushbuttons
     *     SDCard
    *   IMPORTANT: uses the SD card slot of the Teensy, NOT the SD card slot of the audio board
     *  4 operational modes: Heterodyne.
     *                       Frequency divider
     *                       Automatic heterodyne (1/10 implemented)
     *                       Automatic TimeExpansion (live)
     *  Sample rates up to 352k
     *  User controlled parameters:
     *     Volume
     *     Gain
     *     Frequency
     *     Display (none, spectrum, waterfall)
     *     Samplerate
     *  Record raw data
     *  Play raw data (user selectable) on the SDcard using time_expansion (8, 11, 16,22,32,44k samplerate )
     *  Fixes compared to original base:
     *    - issue during recording due to not refilling part of the buffer (was repeating the original first 256 samples )
     *    - filenames have samplerate stored
     *    - RTC added (based on hardware)
     *   Based on code by DD4WH
     *   https://forum.pjrc.com/threads/38988-Bat-detector
     *   https://github.com/DD4WH/Teensy-Bat-Detector
     *   made possible by the samplerate code by Frank Boesing, thanks Frank!
     *   Audio sample rate code - function setI2SFreq
     *   Copyright (c) 2016, Frank Bösing, f.boesing@gmx.de
     * THE SOFTWARE.
    /* CORBEE */
    /* TEENSY 3.6 PINSETUP (20180814)
                      GND                  Vin  - PREAMP V+
                       0                   Analog GND
                       1                   3.3V - MEMS MIC
                       2                   23 AUDIO -LRCLK
                       3                   22 AUDIO -TX
                       4                   21 TFT CS
                       5                   20 TFT DC
           AUDIO MEMCS 6                   19 AUDIO - SCL
           AUDIO MOSI  7                   18 AUDIO - SDA
                       8                   17
           AUDIO BCLK  9                   16
           AUDIO SDCS 10                  15 AUDIO -VOL
           AUDIO MCLK 11                  14 AUDIO -SCLK
           AUDIO MISO 12                  13 AUDIO -RX
                      3.3V                GND
                      24                  A22
                      25                  A21
                      26                  39  TFT MISO
            TFT SCLK  27                  38  MICROPUSH_L
            TFT MOSI  28                  37  MICROPUSH_R
         ENC_L-BUTTON 29                  36  ENC_R-BUTTON
         ENC_L A      30                  35  ENC_R A
         ENC_L B      31                  34  ENC_R B
                      32                  33
    //#define DEBUG
    #define USETFT
    //SD1 uses default SDcard Fat, TODO !! SD2 uses faster SDIO library
    #define USESD1
    #ifdef USESD1
      #define USESD
      #include "ff.h"       // uSDFS lib
      #include "ff_utils.h" // uSDFS lib
      File root;
      FRESULT rc;        /* Result code */
      FATFS fatfs;      /* File system object */
      FIL fil;        /* File object */
    // TODO: try and see if using the SdFs library is able to write faster
    // started setup and included several #ifdefs inside the audio-library SDrelated files (play_raw play_wav)
    #ifdef USESD2
    #define USESD
    //#include "SdFs.h"
    #include "logger_setup.h"
    //default SD related
    #ifdef USESD
      #define MAX_FILES    50
      #define MAX_FILE_LENGTH  13   // 8 chars plus 4 for.RAW plus NULL
      char filelist[ MAX_FILES ][ MAX_FILE_LENGTH ];
      int filecounter=0;
      int fileselect=0;
      int referencefile=0;
      //File frec; // audio is recorded to this file first
      int file_number = 0;
    //#include "Time.h"
    #include "Audio.h"
    //#include <Wire.h>
    #include <Bounce.h>
    #include <Metro.h>
    boolean SD_ACTIVE=false;
    boolean continousPlay=false;
    boolean batTrigger=false;//triggers when an ultrasonic signalpeak is found during FFT
    boolean TE_ready=true; //when a TEcall is played this signals the end of the call
    //time_t getTeensy3Time()
    //  return Teensy3Clock.get();
    int helpmin; // definitions for time and date adjust - Menu
    int helphour;
    int helpday;
    int helpmonth;
    int helpyear;
    int helpsec;
    uint8_t hour10_old;
    uint8_t hour1_old;
    uint8_t minute10_old;
    uint8_t minute1_old;
    uint8_t second10_old;
    uint8_t second1_old;
    bool timeflag = 0;
    uint32_t lastmillis;
    #ifdef USETFT
     #define ILI9341
     #ifdef ILI9341
      #include "ILI9341_t3.h"
      #include "font_Arial.h"
      #define BACKLIGHT_PIN 255
      #define TOP_OFFSET 90
      #define BOTTOM_OFFSET 20
      #define TFT_DC      20
      #define TFT_CS      21
      #define TFT_RST     255  // 255 = unused. connect to 3.3V
      #define TFT_MOSI    28
      #define TFT_SCLK    27
      #define TFT_MISO    39
      //#define Touch_CS    8
      ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
      //XPT2046_Touchscreen ts = XPT2046_Touchscreen(Touch_CS);
    //predefine menu background etc colors
      #define ENC_MENU_COLOR COLOR_YELLOW
      #define ENC_VALUE_COLOR COLOR_LIGHTGREY
      #define MENU_BCK_COLOR COLOR_DARKRED
    // this audio comes from the codec by I2S2
    AudioInputI2S                    i2s_in; // MIC input
    AudioRecordQueue                 recorder;
    AudioSynthWaveformSineHires      sine1; // local oscillator
    //AudioSynthWaveformSineHires      sine2; // local oscillator
    AudioEffectMultiply              heterodyne_multiplier; // multiply = mix
    //AudioEffectMultiply              mult2; // multiply = mix
    //AudioAnalyzeFFT1024         fft1024_1; // for waterfall display
    AudioAnalyzeFFT256               myFFT; // for spectrum display
    AudioPlaySdRaw                   player;
    AudioEffectGranular              granular1;
    AudioMixer4                      mixFFT;
    AudioMixer4                      outputMixer; //selective output
    AudioMixer4                      inputMixer; //selective input
    AudioOutputI2S                   i2s_out; // headphone output
    AudioConnection mic_toinput         (i2s_in, 0, inputMixer, 0); //microphone signal
    AudioConnection mic_torecorder      (i2s_in, 0, recorder, 0); //microphone signal
    //AudioConnection mic_topeak (i2s_in, peakRMS);
    //AudioConnection mic_topeak1 (i2s_in, peakVal);
    AudioConnection player_toinput      (player, 0, inputMixer, 1); //player signal
    AudioConnection input_toswitch      (inputMixer,0,  mixFFT,0);
    AudioConnection input_todelay       (inputMixer,0, granular1, 0);
    AudioConnection switch_toFFT        (mixFFT,0, myFFT,0 ); //raw recording channel
    AudioConnection input_toheterodyne1 (inputMixer, 0, heterodyne_multiplier, 0); //heterodyne 1 signal
    AudioConnection sineheterodyne1    (sine1, 0, heterodyne_multiplier, 1);//heterodyne 1 mixerfreq
    AudioConnection granular_toout (granular1,0, outputMixer,1);
    //AudioConnection input_toheterodyne2 (granular1, 0, mult2, 0); //heterodyne 2
    //AudioConnection sineheterodyne2     (sine2, 0, mult2, 1);//heterodyne 2 mixerfreq
    AudioConnection heterodyne1_toout      (heterodyne_multiplier, 0, outputMixer, 0);  //heterodyne 1 output to outputmixer
    //AudioConnection heterodyne2_toout      (mult2, 0, outputMixer, 1);  //heterodyne 2 output to outputmixer
    AudioConnection player_toout           (inputMixer,0, outputMixer, 2);    //direct signal (use with player) to outputmixer
    AudioConnection output_toheadphoneleft      (outputMixer, 0, i2s_out, 0); // output to headphone
    AudioConnection output_toheadphoneright     (outputMixer, 0, i2s_out, 1);
    //AudioConnection granular_toheadphone        (granular1,0,i2s_out,1);
    AudioControlSGTL5000        sgtl5000;
    //const int myInput = AUDIO_INPUT_LINEIN;
    const int myInput = AUDIO_INPUT_MIC;
    #define GRANULAR_MEMORY_SIZE 30000  // enough for 100 ms at 281kHz
    int16_t granularMemory[GRANULAR_MEMORY_SIZE];
    // forward declaration Stop recording with message
    #ifdef DEBUGSERIAL
       void die(char *str, FRESULT rc);
    extern "C" uint32_t usd_getError(void);
    struct tm seconds2tm(uint32_t tt);
    //continous timers
    elapsedMillis since_bat_detection1; //start timing directly after FFT detects an ultrasound
    elapsedMillis since_bat_detection2; //start timing directly after FFT detects the end of the ultrasound
    elapsedMillis since_heterodyne=1000; //timing interval for auto_heterodyne frequency adjustments
    uint16_t callLength=0;
    //uint16_t clicker=0;
    /************** RECORDING PLAYING SETTINGS *****************/
    const int8_t    MODE_DETECT = 0;
    const int8_t    MODE_REC = 1;
    const int8_t    MODE_PLAY = 2;
    int mode = MODE_DETECT;
    #if defined(__MK20DX256__)
      #define BUFFSIZE (8*1024) // size of buffer to be written
    #elif defined(__MK66FX1M0__)
      #define BUFF 64
      #define BUFFSIZE (BUFF*1024) // size of buffer to be written
    // buffer to store audiosamples during recording
    uint8_t buffern[BUFFSIZE] __attribute__( ( aligned ( 16 ) ) );
    //uint8_t buffern2[BUFFSIZE] __attribute__( ( aligned ( 16 ) ) );
    uint wr;
    uint32_t nj = 0;
    #define waterfallgraph 1
    #define spectrumgraph 2
    int idx_t = 0;
    int idx = 0;
    int64_t sum;
    float32_t mean;
    int16_t FFT_bin [128];
    int16_t FFT_max1 = 0;
    uint32_t FFT_max_bin1 = 0;
    int16_t FFT_mean1 = 0;
    int16_t FFT_max2 = 0;
    uint32_t FFT_max_bin2 = 0;
    int16_t FFT_mean2 = 0;
    //int16_t FFT_threshold = 0;
    int16_t FFT_bat [3]; // max of 3 frequencies are being displayed
    int16_t index_FFT;
    int l_limit;
    int u_limit;
    int index_l_limit;
    int index_u_limit;
    //const uint16_t FFT_points = 1024;
    const uint16_t FFT_points = 256;
    int barm [512];
    #define SAMPLE_RATE_MIN               0
    #define SAMPLE_RATE_8K                0
    #define SAMPLE_RATE_11K               1
    #define SAMPLE_RATE_16K               2
    #define SAMPLE_RATE_22K               3
    #define SAMPLE_RATE_32K               4
    #define SAMPLE_RATE_44K               5
    #define SAMPLE_RATE_48K               6
    #define SAMPLE_RATE_88K               7
    #define SAMPLE_RATE_96K               8
    #define SAMPLE_RATE_176K              9
    #define SAMPLE_RATE_192K              10
    #define SAMPLE_RATE_234K              11
    #define SAMPLE_RATE_281K              12
    #define SAMPLE_RATE_352K              13
    #define SAMPLE_RATE_MAX               13
    typedef struct SR_Descriptor
        const int SR_n;
        const char* const txt; //display
    } SR_Desc;
    // SRtext and position for the FFT spectrum display scale
    const SR_Descriptor SR [SAMPLE_RATE_MAX + 1] =
        //   SR_n ,  f1
        {  SAMPLE_RATE_8K,  "8"},
        {  SAMPLE_RATE_11K,  "11"},
        {  SAMPLE_RATE_16K,  "16"},
        {  SAMPLE_RATE_22K,  "22"},
        {  SAMPLE_RATE_32K,  "32"},
        {  SAMPLE_RATE_44K,  "44"},
        {  SAMPLE_RATE_48K,  "48"},
        {  SAMPLE_RATE_88K,  "88"},
        {  SAMPLE_RATE_96K,  "96"},
        {  SAMPLE_RATE_176K,  "176"},
        {  SAMPLE_RATE_192K,  "192"},
        {  SAMPLE_RATE_234K,  "234"},
        {  SAMPLE_RATE_281K,  "281"},
        {  SAMPLE_RATE_352K,  "352"}
    // setup for FFTgraph denoising
    uint32_t FFTcount=0; //count the # of FFTs done
    uint16_t powerspectrumCounter=0;
    float FFTavg[128];
    float FFTpowerspectrum[128];
    float powerspectrum_Max=0;
    // defaults at startup functions
    int displaychoice=waterfallgraph; //default display
    int8_t mic_gain = 35; // start detecting with this MIC_GAIN in dB
    int8_t volume=50;
    int freq_real = 45000; // start heterodyne detecting at this frequency
    int freq_real_backup=freq_real; //used to return to proper settingafter using the play_function
    // initial sampling setup
    int sample_rate = SAMPLE_RATE_281K;
    int sample_rate_real = 281000;
    char * SRtext="281";
    int last_sample_rate=sample_rate;
    float freq_Oscillator =50000;
    /************************************************* MENU ********************************/
    typedef struct Menu_Descriptor
        const char* name;
        // ********preset variables below NOT USED YET
        const int len; // length of string to allow right-alignment
        const int def; //default settings
        const int low; // low threshold
        const int high; //high threshold
    } Menu_Desc;
    const int Leftchoices=10; //can have any value
    const int Rightchoices=10;
    const Menu_Descriptor MenuEntry [Leftchoices] =
    {  {"Volume",6,60,0,100}, //divide by 100
       {"Gain",4,30,0,63},
       {"Frequency",9,45,20,90}, //multiply 1000
       {"Display",7,0,0,0},
       {"Denoise",7,0,0,0},
       {"SampleR",6,0,0,0},
       {"Record",6,0,0,0}, //functions where the LeftEncoder
       {"Play",4,0,0,0},
       {"PlayD",5,0,0,0},
    //TODO constants should be part of the menuentry, a single structure to hold the info
    const int8_t  MENU_VOL = 0; //volume
    const int8_t  MENU_MIC = 1; //mic_gain
    const int8_t  MENU_FRQ = 2; //frequency
    const int8_t  MENU_DSP = 3; //display
    const int8_t  MENU_DNS = 4; //denoise
    const int8_t  MENU_SR  = 5; //sample rate
    const int8_t  MENU_REC = 6; //record
    const int8_t  MENU_PLY = 7; //play
    const int8_t  MENU_PLD = 8; //play at original rate
    //available modes
    const int detector_heterodyne=0;
    const int detector_divider=1;
    const int detector_Auto_heterodyne=2;
    const int detector_Auto_TE=3;
    const int detector_passive=4;
    //default
    int detector_mode=detector_heterodyne;
    //************************* ENCODER variables/constants
    const int8_t enc_menu=0; //changing encoder sets menuchoice
    const int8_t enc_value=1; //changing encoder sets value for a menuchoice
    const int8_t enc_leftside=0; //encoder
    const int8_t enc_rightside=1; //encoder
    const int8_t enc_up=1; //encoder goes up
    const int8_t enc_nc=0;
    const int8_t enc_dn=-1; //encoder goes down
    int EncLeft_menu_idx=0;
    int EncRight_menu_idx=0;
    int EncLeft_function=0;
    int EncRight_function=0;
    // ******** LEFT AND RIGHT ENCODER CONNECTIONS/BUTTONS
    #include <Encoder.h>
    //try to avoid interrupts as they can (possibly ?) interfere during recording
    #define ENCODER_DO_NOT_USE_INTERRUPTS
    #define MICROPUSH_RIGHT  37
    Bounce micropushButton_R = Bounce(MICROPUSH_RIGHT, 50);
    #define encoderButton_RIGHT      36
    Bounce encoderButton_R = Bounce(encoderButton_RIGHT, 50);
    Encoder EncRight(34,35);
    int EncRightPos=0;
    int EncRightchange=0;
    #define MICROPUSH_LEFT  38
    Bounce micropushButton_L = Bounce(MICROPUSH_LEFT, 50);
    #define encoderButton_LEFT       29
    Bounce encoderButton_L = Bounce(encoderButton_LEFT, 50);
    Encoder EncLeft(30,31);
    int EncLeftPos=0;
    int EncLeftchange=0;
    // **END************ LEFT AND RIGHT ENCODER DEFINITIONS
    #ifdef USESD1
       #ifdef DEBUGSERIAL
       Serial.printf("%s: Failed with rc=%u.\n", str, rc); for (;;) delay(100);
    #ifdef USESD1
    //uint32_t count=0;
    uint32_t ifn=0;
    uint32_t isFileOpen=0;
    TCHAR wfilename[80];
    uint32_t t0=0;
    uint32_t t1=0;
    char filename[80];
    void display_settings() {
      #ifdef USETFT
        tft.setTextColor(ENC_MENU_COLOR);
        tft.setFont(Arial_16);
        tft.fillRect(0,0,240,TOP_OFFSET-50,MENU_BCK_COLOR);
        tft.fillRect(0,TOP_OFFSET-10,240,10,COLOR_BLACK);
        tft.fillRect(0,ILI9341_TFTHEIGHT-BOTTOM_OFFSET,240,BOTTOM_OFFSET,MENU_BCK_COLOR);
        tft.setCursor(0,0);
        tft.print("g:"); tft.print(mic_gain);
        tft.print(" f:"); tft.print(freq_real);
        tft.print(" v:"); tft.print(volume);
        tft.print(" SR"); tft.print(SRtext);
        tft.setCursor(0,20);
        switch (detector_mode) {
           case detector_heterodyne:
             tft.print("HTD"); //
           case detector_divider:
             tft.print("FD");
           case detector_Auto_heterodyne:
             tft.print("Auto_HTD");
           case detector_Auto_TE:
            tft.print("Auto_TE");
           case detector_passive:
            tft.print("PASS");
           default:
            tft.print("error");
         // push the cursor to the lower part of the screen
         tft.setCursor(0,ILI9341_TFTHEIGHT-BOTTOM_OFFSET);
         /****************** SHOW ENCODER SETTING ***********************/
         // set the colors according to the function of the encoders
         if (mode==MODE_DETECT )
         // show menu selection as menu-active of value-active
           if (EncLeft_function==enc_value)
            { tft.setTextColor(ENC_MENU_COLOR);
            { tft.setTextColor(ENC_VALUE_COLOR);}
           tft.print(MenuEntry[EncLeft_menu_idx].name);
           tft.print(" ");
           if (EncRight_function==enc_value)
             { tft.setTextColor(ENC_MENU_COLOR);} //value is active
             { tft.setTextColor(ENC_VALUE_COLOR);} //menu is active
           //if MENU on the left-side is PLAY and selected than show the filename
            if ((EncLeft_menu_idx==MENU_PLY) and (EncLeft_function==enc_value))
               { //tft.print(fileselect);
                 tft.print(filelist[fileselect]);
             if (EncLeft_menu_idx==MENU_REC)
              // show the filename that will be used for the next recording
               {  sprintf(filename, "B%u_%s.raw", file_number+1,SRtext);
                  tft.print(filename );
              { tft.print(SR[sample_rate].txt);
              { //tft.print(EncRightchange);
                tft.setCursor(ILI9341_TFTWIDTH/2  ,ILI9341_TFTHEIGHT-BOTTOM_OFFSET);
                tft.print(MenuEntry[EncRight_menu_idx].name);
            if (mode==MODE_REC)
                tft.print("REC:");
                tft.print(filename);
            if (mode==MODE_PLAY)
             {if (EncLeft_menu_idx==MENU_PLY)
                tft.print("PLAY:");
               {tft.setTextColor(ENC_VALUE_COLOR);
                tft.print(" ");
        //scale every 10kHz
        float x_factor=10000/(0.5*(sample_rate_real / FFT_points));
        int curF=2*int(freq_real/(sample_rate_real / FFT_points));
        int maxScale=int(sample_rate_real/20000);
        for (int i=1; i<maxScale; i++)
         { tft.drawFastVLine(i*x_factor, TOP_OFFSET-10, 9, ENC_MENU_COLOR);
        tft.fillCircle(curF,TOP_OFFSET-4,3,ENC_MENU_COLOR);
    void       set_mic_gain(int8_t gain) {
        AudioNoInterrupts();
        //sgtl5000.micGainNew (24);
        sgtl5000.micGain (gain);
        //sgtl5000.lineInLevel(gain/4);
        AudioInterrupts();
        display_settings();
        powerspectrum_Max=0; // change the powerspectrum_Max for the FFTpowerspectrum
    } // end function set_mic_gain
    void       set_freq_Oscillator(int freq) {
        // audio lib thinks we are still in 44118sps sample rate
        // therefore we have to scale the frequency of the local oscillator
        // in accordance with the REAL sample rate
        freq_Oscillator = (freq) * (AUDIO_SAMPLE_RATE_EXACT / sample_rate_real);
        //float F_LO2= (freq+5000) * (AUDIO_SAMPLE_RATE_EXACT / sample_rate_real);
        // if we switch to LOWER samples rates, make sure the running LO
        // frequency is allowed ( < 22k) ! If not, adjust consequently, so that
        // LO freq never goes up 22k, also adjust the variable freq_real
        if(freq_Oscillator > 22000) {
          freq_Oscillator = 22000;
          freq_real = freq_Oscillator * (sample_rate_real / AUDIO_SAMPLE_RATE_EXACT) + 9;
        //setup multiplier SINE
        sine1.frequency(freq_Oscillator);
        //sine2.frequency(freq_Oscillator);
        AudioInterrupts();
        display_settings();
    } // END of function set_freq_Oscillator
    // set samplerate code by Frank Boesing
    void setI2SFreq(int freq) {
      typedef struct {
        uint8_t mult;
        uint16_t div;
      } tmclk;
    //MCLD Divide sets the MCLK divide ratio such that: MCLK output = MCLK input * ( (FRACT + 1) / (DIVIDE + 1) ).
    // FRACT must be set equal or less than the value in the DIVIDE field.
    //(double)F_PLL * (double)clkArr[iFreq].mult / (256.0 * (double)clkArr[iFreq].div);
    //ex 180000000* 1 /(256* 3 )=234375Hz  setting   {1,3} at 180Mhz
    #if (F_PLL==16000000)
      const tmclk clkArr[numfreqs] = {{16, 125}, {148, 839}, {32, 125}, {145, 411}, {64, 125}, {151, 214}, {12, 17}, {96, 125}, {151, 107}, {24, 17}, {192, 125}, {127, 45}, {48, 17}, {255, 83} };
    #elif (F_PLL==72000000)
      const tmclk clkArr[numfreqs] = {{32, 1125}, {49, 1250}, {64, 1125}, {49, 625}, {128, 1125}, {98, 625}, {8, 51}, {64, 375}, {196, 625}, {16, 51}, {128, 375}, {249, 397}, {32, 51}, {185, 271} };
    #elif (F_PLL==96000000)
      const tmclk clkArr[numfreqs] = {{8, 375}, {73, 2483}, {16, 375}, {147, 2500}, {32, 375}, {147, 1250}, {2, 17}, {16, 125}, {147, 625}, {4, 17}, {32, 125}, {151, 321}, {8, 17}, {64, 125} };
    #elif (F_PLL==120000000)
      const tmclk clkArr[numfreqs] = {{32, 1875}, {89, 3784}, {64, 1875}, {147, 3125}, {128, 1875}, {205, 2179}, {8, 85}, {64, 625}, {89, 473}, {16, 85}, {128, 625}, {178, 473}, {32, 85}, {145, 354} };
    #elif (F_PLL==144000000)
      const tmclk clkArr[numfreqs] = {{16, 1125}, {49, 2500}, {32, 1125}, {49, 1250}, {64, 1125}, {49, 625}, {4, 51}, {32, 375}, {98, 625}, {8, 51}, {64, 375}, {196, 625}, {16, 51}, {128, 375} };
    #elif (F_PLL==168000000)
      const tmclk clkArr[numfreqs] = {{32, 2625}, {21, 1250}, {64, 2625}, {21, 625}, {128, 2625}, {42, 625}, {8, 119}, {64, 875}, {84, 625}, {16, 119}, {128, 875}, {168, 625}, {32, 119}, {189, 646} };
    #elif (F_PLL==180000000)
      const int numfreqs = 17;
      const int samplefreqs[numfreqs] = {  8000,      11025,      16000,      22050,       32000,       44100, (int)44117.64706 , 48000,      88200, (int)44117.64706 * 2,   96000, 176400, (int)44117.64706 * 4, 192000,  234000, 281000, 352800};
      const tmclk clkArr[numfreqs] = {{46, 4043}, {49, 3125}, {73, 3208}, {98, 3125}, {183, 4021}, {196, 3125}, {16, 255},   {128, 1875}, {107, 853},     {32, 255},   {219, 1604}, {1, 4},      {64, 255},     {219,802}, { 1,3 },  {2,5} , {1,2} };  //last value 219 802
    #elif (F_PLL==192000000)
      const tmclk clkArr[numfreqs] = {{4, 375}, {37, 2517}, {8, 375}, {73, 2483}, {16, 375}, {147, 2500}, {1, 17}, {8, 125}, {147, 1250}, {2, 17}, {16, 125}, {147, 625}, {4, 17}, {32, 125} };
    #elif (F_PLL==216000000)
      const tmclk clkArr[numfreqs] = {{32, 3375}, {49, 3750}, {64, 3375}, {49, 1875}, {128, 3375}, {98, 1875}, {8, 153}, {64, 1125}, {196, 1875}, {16, 153}, {128, 1125}, {226, 1081}, {32, 153}, {147, 646} };
    #elif (F_PLL==240000000)
      const tmclk clkArr[numfreqs] = {{16, 1875}, {29, 2466}, {32, 1875}, {89, 3784}, {64, 1875}, {147, 3125}, {4, 85}, {32, 625}, {205, 2179}, {8, 85}, {64, 625}, {89, 473}, {16, 85}, {128, 625} };
      for (int f = 0; f < numfreqs; f++) {
        if ( freq == samplefreqs[f] ) {
          while (I2S0_MCR & I2S_MCR_DUF) ;
          I2S0_MDR = I2S_MDR_FRACT((clkArr[f].mult - 1)) | I2S_MDR_DIVIDE((clkArr[f].div - 1));
          return;
    void      set_sample_rate (int sr) {
      switch (sr) {
        case SAMPLE_RATE_8K:
        sample_rate_real = 8000;
        SRtext = " 8";
        case SAMPLE_RATE_11K:
        sample_rate_real = 11025;
        SRtext = "11";
        case SAMPLE_RATE_16K:
        sample_rate_real = 16000;
        SRtext = "16";
        case SAMPLE_RATE_22K:
        sample_rate_real = 22050;
        SRtext = "22";
        case SAMPLE_RATE_32K:
        sample_rate_real = 32000;
        SRtext = "32";
        case SAMPLE_RATE_44K:
        sample_rate_real = 44100;
        SRtext = "44";
        case SAMPLE_RATE_48K:
        sample_rate_real = 48000;
        SRtext = "48";
        case SAMPLE_RATE_88K:
        sample_rate_real = 88200;
        SRtext = "88";
        case SAMPLE_RATE_96K:
        sample_rate_real = 96000;
        SRtext = "96";
        case SAMPLE_RATE_176K:
        sample_rate_real = 176400;
        SRtext = "176";
        case SAMPLE_RATE_192K:
        sample_rate_real = 192000;
        SRtext = "192";
        case SAMPLE_RATE_234K:
        sample_rate_real = 234000;
        SRtext = "234";
        case SAMPLE_RATE_281K:
        SRtext = "281";
        case SAMPLE_RATE_352K:
        sample_rate_real = 352800;
        SRtext = "352";
        setI2SFreq (sample_rate_real);
        delay(200); // this delay seems to be very essential !
        set_freq_Oscillator (freq_real);
        AudioInterrupts();
        delay(20);
        display_settings();
    } // END function set_sample_rate
    void spectrum() { // spectrum analyser code by rheslip - modified
         #ifdef USETFT
         if (myFFT.available()) {
    //     if (fft1024_1.available()) {
        int16_t peak=0; uint16_t avgF=0;
        // find the BIN corresponding to the current frequency-setting
        int curF=int(freq_real/(sample_rate_real / FFT_points));
    //    for (int i = 0; i < 240; i++) {
        //startup sequence to denoise the FFT
        FFTcount++;
        if (FFTcount==1)
         {for (int16_t i = 0; i < 128; i++) {
             FFTavg[i]=0;
        if (FFTcount<1000)
           for (int i = 0; i < 128; i++) {
             FFTavg[i]=FFTavg[i]+abs(myFFT.output[i])*0.001; //0.1% of total values
    for (int16_t x = 2; x < 128; x++) {
       avgF=avgF+FFT_bin[x];
       if (FFT_bin[x]>peak)
            peak=FFT_bin[x];
    avgF=avgF/128;
    //check if the peak is at least 2x higher than the average otherwise set the indicator low
    if ((peak-avgF)<(avgF/3))
      { maxF=2;}
    //  for (uint16_t x = 8; x < 512; x+=4) {
         FFT_bin[x] = (myFFT.output[x]);//-FFTavg[x]*0.9;
         int colF=ENC_VALUE_COLOR;
    //     FFT_bin[x/4] = abs(fft1024_1.output[x]);
         int barnew = (FFT_bin[x])/2 ;
         // this is a very simple first order IIR filter to smooth the reaction of the bars
         int bar = 0.05 * barnew + 0.95 * barm[x];
         if (bar >(ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET))
            { bar=(ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET);
         if (bar <0) bar=0;
         if (barnew >(ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET))
            { barnew=(ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET);
         int g_x=x*2;
         int spectrumline=barm[x];
         int spectrumline_new=barnew;
         //tft.drawFastVLine(g_x,TOP_OFFSET,ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET, COLOR_BLACK);
         tft.drawFastVLine(g_x,TOP_OFFSET,spectrumline_new, COLOR_GREEN);
         //tft.drawFastVLine(g_x,TOP_OFFSET,spectrumline, COLOR_RED);
         tft.drawFastVLine(g_x,TOP_OFFSET+spectrumline_new,ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET-spectrumline_new, COLOR_BLACK);
         tft.drawFastVLine(g_x+1,TOP_OFFSET,spectrumline, COLOR_DARKGREEN);
         tft.drawFastVLine(g_x+1,TOP_OFFSET+spectrumline,ILI9341_TFTHEIGHT-BOTTOM_OFFSET-TOP_OFFSET-spectrumline, COLOR_BLACK);
        /* if (x==maxF)
           { colF=COLOR_ORANGE;
             tft.drawFastVLine(g_x,TOP_OFFSET,240-bar, colF);
         //tft.drawPixel(g_x,ILI9341_TFTHEIGHT-BOTTOM_OFFSET-bar,colF);
         barm[x] = bar;
        // if (mode == MODE_DETECT)  search_bats();
      } //end if
        {//float ww=( player.positionMillis()/player.lengthMillis()*240.0);
         tft.drawFastHLine(0,320-BOTTOM_OFFSET-5,240*player.positionMillis()/player.lengthMillis()-10,COLOR_BLACK);
         tft.drawFastHLine(240*player.positionMillis()/player.lengthMillis()-9,320-BOTTOM_OFFSET-5,5,ENC_MENU_COLOR);
         tft.drawFastHLine(0,320-BOTTOM_OFFSET-4,240*player.positionMillis()/player.lengthMillis()-10,COLOR_BLACK);
         tft.drawFastHLine(240*player.positionMillis()/player.lengthMillis()-9,320-BOTTOM_OFFSET-4,5,ENC_MENU_COLOR);
    #ifdef DEBUGSERIAL
    /*void check_processor() {
          if (second.check() == 1) {
          Serial.print("Proc = ");
          Serial.print(AudioProcessorUsage());
          Serial.print(" (");
          Serial.print(AudioProcessorUsageMax());
          Serial.print("),  Mem = ");
          Serial.print(AudioMemoryUsage());
          Serial.print(" (");
          Serial.print(AudioMemoryUsageMax());
          Serial.println(")");
          AudioProcessorUsageMaxReset();
          AudioMemoryUsageMaxReset();
    */ // END function check_processor
    void waterfall(void) // thanks to Frank B !
    #ifdef USETFT
    // code for 256 point FFT
      const uint16_t Y_OFFSET = TOP_OFFSET;
      static int count = TOP_OFFSET;
      //int curF=int(freq_real/(sample_rate_real / FFT_points));
      // lowest frequencybin to detect as a batcall
      int batCall_LoF_bin= int(30000/(sample_rate_real / FFT_points));
      int batCall_HiF_bin= int(80000/(sample_rate_real / FFT_points));
      uint16_t FFT_pixels[240]; // maximum of 240 pixels, each one is the result of one FFT
      FFT_pixels[0]=0; FFT_pixels[1]=0;  FFT_pixels[2]=0; FFT_pixels[3]=0;
        FFTcount++;
        //requested to start with a clean FFTavg array to denoise
        if (FFTcount==1)
              FFTavg[i]=0;
        // collect 1000 FFT samples for the denoise array
        if (FFTcount<100)
         { for (int i = 2; i < 128; i++) {
             //FFTavg[i]=FFTavg[i]+myFFT.read(i)*65536.0*5*0.001; //0.1% of total values
             FFTavg[i]=FFTavg[i]+myFFT.output[i]*10*0.001; //0.1% of total values
        int FFT_peakF_bin=0;
        int peak=512;
        int avgFFTbin=0;
        // there are 128 FFT different bins only 120 are shown on the graphs
        for (int i = 2; i < 120; i++) {
          int val = myFFT.output[i]*10 -FFTavg[i]*0.9 + 10; //v1
          avgFFTbin+=val;
          //detect the peakfrequency
          if (val>peak)
           { peak=val;
             FFT_peakF_bin=i;
           if (val<5)
               {val=5;}
           FFT_pixels[i*2] = tft.color565(
                  min(255, val/2),
                  (val/6>255)? 255 : val/6,
                  //(val/4>255)? 255 : val/4
                                0
                  //((255-val)>>1) <0? 0: (255-val)>>1
          FFT_pixels[i*2+1]=FFT_pixels[i*2];
        avgFFTbin=avgFFTbin/120;
        //mark the peak
        //FFT_pixels[FFT_peakF_bin*2]=COLOR_RED;
        //FFT_pixels[FFT_peakF_bin*2+1]=COLOR_RED;
       if ((peak/avgFFTbin)<1.2) //very low peakvalue so probably noise
         { FFT_peakF_bin=0;
      int powerSpectrum_Maxbin=0;
      // detected a peak in the bat frequencies
      if ((FFT_peakF_bin>batCall_LoF_bin) and (FFT_peakF_bin<batCall_HiF_bin))
        //collect data for the powerspectrum
            //add new samples
            FFTpowerspectrum[i]+=myFFT.output[i];
            //keep track of the maximum
            if (FFTpowerspectrum[i]>powerspectrum_Max)
               { powerspectrum_Max=FFTpowerspectrum[i];
                 powerSpectrum_Maxbin=i;
         //keep track of the no of samples with bat-activity
         powerspectrumCounter++;
        // update display after every 100th FFT sample with bat-activity
        if ((powerspectrumCounter>50)  )
           { powerspectrumCounter=0;
             //clear powerspectrumbox
             tft.fillRect(0,TOP_OFFSET-50,240,45, COLOR_BLACK);
             // keep a minimum maximumvalue to the powerspectrum
             int binLo=2; int binHi=0;
             for (int i=2; i<120; i++)
                int ypos=FFTpowerspectrum[i]/powerspectrum_Max*45;
                // first encounter of 1/20 of maximum
                if (i<powerSpectrum_Maxbin)
                  {if (FFTpowerspectrum[i]<(powerspectrum_Max*0.1))
                        {binLo=i;}}
                  {if (FFTpowerspectrum[i]>(powerspectrum_Max*0.1))
                        {binHi=i;}
                tft.drawFastVLine(i*2,TOP_OFFSET-ypos-6,ypos,COLOR_RED);
                if (i==powerSpectrum_Maxbin)
                  { tft.drawFastVLine(i*2,TOP_OFFSET-ypos-6,ypos,ENC_MENU_COLOR);
                //tft.drawFastVLine(i*2+1,TOP_OFFSET-ypos-6,ypos,COLOR_RED);
                FFTpowerspectrum[i]=0;
             //tft.setCursor(0,TOP_OFFSET-45);
             //tft.print(powerspectrum_Max);
             if (powerspectrum_Max==20000)
              {binLo=0; binHi=0;
             float multiplier=(sample_rate_real / FFT_points)*0.001;
             powerspectrum_Max=powerspectrum_Max*0.5; //lower the max after a graphupdate
             tft.setCursor(140,TOP_OFFSET-45);
             tft.print(int(binLo*multiplier) );
             tft.print(" ");
             tft.print(int(powerSpectrum_Maxbin*multiplier) );
             tft.print(" ");
             tft.print(int(binHi*multiplier) );
        if ((FFT_peakF_bin>batCall_LoF_bin) and (FFT_peakF_bin<batCall_HiF_bin)) // we got a high-frequent signal peak
            // when a batcall is first discovered
            if (not batTrigger)
              { since_bat_detection1=0; //start of the call mark
                //clicker=0;
                FFT_pixels[5]=ENC_VALUE_COLOR; // mark the start on the screen
                FFT_pixels[6]=ENC_VALUE_COLOR;
                FFT_pixels[7]=ENC_VALUE_COLOR;
                if (detector_mode==detector_Auto_heterodyne)
                   if (since_heterodyne>1000) //update the most every second
                    {freq_real=int((FFT_peakF_bin*(sample_rate_real / FFT_points)/500))*500; //round to nearest 500hz
                     set_freq_Oscillator(freq_real);
                     since_heterodyne=0;
                     //granular1.stop();
                //restart the TimeExpansion only if the previous call was played
                if ((detector_mode==detector_Auto_TE) and (TE_ready) )
                 { granular1.stop();
                   granular1.setSpeed(0.05);
                   TE_ready=false;
             //clicker++;
             batTrigger=true;
       else // FFT_peakF_bin does not show a battcall
              if (batTrigger) //previous sample was still a call
               { callLength=since_bat_detection1; // got a pause so store the time since the start of the call
                 /*if (callLength>20) //call is too long
                  { TE_ready=true; // break the TE replay
                  since_bat_detection2=0; //start timing the length of the replay
              batTrigger=false;
        // restart TimeExpansion recording a bit after the call has finished completely
        if ((!TE_ready) and (since_bat_detection2>(callLength*10)))
          { //stop the time expansion
            TE_ready=true;
            granular1.stopTimeExpansion();
        if (since_bat_detection2<50) //keep scrolling 100ms after the last bat-call
          {  tft.writeRect( 0,count, ILI9341_TFTWIDTH,1, (uint16_t*) &FFT_pixels); //show a line with spectrumdata
             tft.setScroll(count);
            count++;
        if (count >= ILI9341_TFTHEIGHT-BOTTOM_OFFSET) count = Y_OFFSET;
    void startRecording() {
      mode = MODE_REC;
      #ifdef USESD1
        #ifdef DEBUGSERIAL
          Serial.print("startRecording");
        // close file
        if(isFileOpen)
          //close file
          rc = f_close(&fil);
          if (rc) die("close", rc);
          isFileOpen=0;
      if(!isFileOpen)
      file_number++;
      //automated filename BA_S.raw where A=file_number and S shows samplerate. Has to fit 8 chars
      // so max is B999_192.raw
      sprintf(filename, "B%u_%s.raw", file_number, SRtext);
        #ifdef DEBUGSERIAL
        Serial.println(filename);
      char2tchar(filename, 13, wfilename);
      filecounter++;
      strcpy(filelist[filecounter],filename );
      rc = f_stat (wfilename, 0);
      #ifdef DEBUGSERIAL
        Serial.printf("stat %d %x\n",rc,fil.obj.sclust);
      rc = f_open (&fil, wfilename, FA_WRITE | FA_CREATE_ALWAYS);
    #ifdef DEBUGSERIAL
        Serial.printf(" opened %d %x\n\r",rc,fil.obj.sclust);
        // check if file has errors
        if(rc == FR_INT_ERR)
        { // only option then is to close file
            rc = f_close(&fil);
            if(rc == FR_INVALID_OBJECT)
              #ifdef DEBUGSERIAL
              Serial.println("unlinking file");
              rc = f_unlink(wfilename);
              if (rc) {
                die("unlink", rc);
              die("close", rc);
        // retry open file
        rc = f_open(&fil, wfilename, FA_WRITE | FA_CREATE_ALWAYS);
        if(rc) {
          die("open", rc);
        isFileOpen=1;
      //clear the screen completely
      tft.fillRect(0,0,ILI9341_TFTWIDTH,ILI9341_TFTHEIGHT,COLOR_BLACK);
      tft.setFont(Arial_28);
      tft.setCursor(0,100);
      tft.print("RECORDING");
      display_settings();
      granular1.stop(); //stop granular
      //switch off several circuits
      mixFFT.gain(0,0);
      outputMixer.gain(1,0);  //shutdown granular output
      nj=0;
      recorder.begin();
    void continueRecording() {
      #ifdef USESD1
      const uint32_t N_BUFFER = 2;
      const uint32_t N_LOOPS = BUFF*N_BUFFER; // !!! NLOOPS and BUFFSIZE ARE DEPENDENT !!! NLOOPS = BUFFSIZE/N_BUFFER
      // buffer size total = 256 * n_buffer * n_loops
      // queue: write n_buffer blocks * 256 bytes to buffer at a time; free queue buffer;
      // repeat n_loops times ( * n_buffer * 256 = total amount to write at one time)
      // then write to SD card
      if (recorder.available() >= N_BUFFER  )
      {// one buffer = 256 (8bit)-bytes = block of 128 16-bit samples
        //read N_BUFFER sample-blocks into memory
        for (int i = 0; i < N_BUFFER; i++) {
           //copy a new bufferblock from the audiorecorder into memory
           memcpy(buffern + i*256 + nj * 256 * N_BUFFER, recorder.readBuffer(), 256);
           //free the last buffer that was read
           recorder.freeBuffer();
        nj++;
        if (nj >  (N_LOOPS-1))
          nj = 0;
          //old code used to copy into a 2nd buffer, not needed since the writing to SD of the buffer seems faster than the filling
          //this allows larger buffers to be used
          //memcpy(buffern2,buffern,BUFFSIZE);
          //push to SDcard
          rc =  f_write (&fil, buffern, N_BUFFER * 256 * N_LOOPS, &wr);
    void stopRecording() {
    #ifdef USESD1
      #ifdef DEBUGSERIAL
        Serial.print("stopRecording");
        recorder.end();
        if (mode == MODE_REC) {
          while (recorder.available() > 0) {
          rc = f_write (&fil, (byte*)recorder.readBuffer(), 256, &wr);
      //      frec.write((byte*)recorder.readBuffer(), 256);
            //close file
            rc = f_close(&fil);
            isFileOpen=0;
      //    frec.close();
      //    playfile = recfile;
        mode = MODE_DETECT;
      //  clearname();
      #ifdef DEBUGSERIAL
        Serial.println (" Recording stopped!");
      //switch on FFT
      tft.fillScreen(COLOR_BLACK);
      mixFFT.gain(0,1);
    void startPlaying(int SR) {
    //      String NAME = "Bat_"+String(file_number)+".raw";
    //      char fi[15];
    //      NAME.toCharArray(fi, sizeof(NAME));
    inputMixer.gain(0,0); //switch off the mic-line as input
    inputMixer.gain(1,1); //switch on the playerline as input
          outputMixer.gain(2,1);  //player to output
          outputMixer.gain(0,0);  //shutdown heterodyne output
          freq_real_backup=freq_real; //keep track of heterodyne setting
      //direct play is used to test functionalty based on previous recorded data
      //this will play a previous recorded raw file through the system as if it were live data coming from the microphone
    if (EncLeft_menu_idx==MENU_PLD)
          outputMixer.gain(2,0);  //shutdown direct audio from player to output
          outputMixer.gain(0,1);  //default mode will be heterodyne based output
          if (detector_mode==detector_Auto_TE)
             { outputMixer.gain(1,1);  //start granular output processing
    //allow settling
      //keep track of the sample_rate
      SR=constrain(SR,SAMPLE_RATE_MIN,SAMPLE_RATE_MAX);
      set_sample_rate(SR);
      fileselect=constrain(fileselect,0,filecounter);
      strncpy(filename, filelist[fileselect],  13);
      //default display is waterfall
      display_settings();
      player.play(filename);
      mode = MODE_PLAY;
    void stopPlaying() {
    #ifdef DEBUGSERIAL
      Serial.print("stopPlaying");
      if (mode == MODE_PLAY) player.stop();
      mode = MODE_DETECT;
    #ifdef DEBUGSERIAL
      Serial.println (" Playing stopped");
      //restore last sample_rate setting
      set_sample_rate(last_sample_rate);
      freq_real=freq_real_backup;
      //restore heterodyne frequency
      outputMixer.gain(2,0); //stop the direct line output
      outputMixer.gain(1,1); // open granular output
      outputMixer.gain(0,1); // open heterodyne output
      inputMixer.gain(0,1); //switch on the mic-line
      inputMixer.gain(1,0); //switch off the playerline
    void continuePlaying() {
      //the end of file was reached
      if (!player.isPlaying()) {
        stopPlaying();
        if (continousPlay) //keep playing until stopped by the user
          { startPlaying(SAMPLE_RATE_176K);
    void changeDetector_mode()
      if (detector_mode==detector_heterodyne)
             { granular1.stop(); //stop other detecting routines
               outputMixer.gain(1,0);  //stop granular output
               outputMixer.gain(0,1);  //start heterodyne output
              //switch menu to volume/frequency
               EncLeft_menu_idx=MENU_VOL;
               EncLeft_function=enc_value;
               EncRight_menu_idx=MENU_FRQ;
          if (detector_mode==detector_divider)
             { granular1.beginDivider(GRANULAR_MEMORY_SIZE);
               //switch menu to volume/gain
               EncRight_menu_idx=MENU_MIC;
             { granular1.beginTimeExpansion(GRANULAR_MEMORY_SIZE);
               granular1.setSpeed(0.06); //default TE is 1/0.06 ~ 1/16 :TODO, switch from 1/x floats to divider value x
             { granular1.stop();
          if (detector_mode==detector_passive)
             { granular1.stop(); //stop all other detecting routines
               outputMixer.gain(2,1);  //direct line to output
               EncRight_function=enc_value;
           else //all other options use the heterodyne and granular output line
            {  outputMixer.gain(2,0);  //shut down direct line to output
               //outputMixer.gain(1,1);  //granular   output
               //outputMixer.gain(0,1);  //heterodyne output
    //*****************************************************update encoders
    void updateEncoder(uint8_t Encoderside )
      /************************setup vars*************************/
       int encodermode=-1; // menu=0 value =1;
       int change=0;
       int menu_idx=0;
       int choices=0;
        //get encodermode
       if (Encoderside==enc_leftside)
        { encodermode=EncLeft_function;
          change=EncLeftchange;
          menu_idx=EncLeft_menu_idx;
          choices=Leftchoices; //available menu options
       if (Encoderside==enc_rightside)
        { encodermode=EncRight_function;
          change=EncRightchange;
          menu_idx=EncRight_menu_idx;
          choices=Rightchoices; //available menu options
      /************************proces changes*************************/
      //encoder is in menumode
      if (encodermode==enc_menu)
        { menu_idx=menu_idx+change;
          //allow revolving choices
          if (menu_idx<0)
            {menu_idx=choices-1;}
          if (menu_idx>=choices)
            {menu_idx=0;}
          //remove functionality when SD is not active, so no SDCARD mounted or SDCARD is unreadable
          if (!SD_ACTIVE)
            { if ((menu_idx==MENU_PLD) or (menu_idx==MENU_PLY) or (menu_idx==MENU_REC))
               { // move menu to volume
                 menu_idx=MENU_VOL;
              { EncLeft_menu_idx=menu_idx; //limit the menu
         //limit the changes of the rightside encoder for specific functions
          if ((EncLeft_menu_idx!=MENU_SR) )
              { EncRight_menu_idx=menu_idx; //limit the menu
      //encoder is in valuemode and has changed position
      if ((encodermode==enc_value) and (change!=0))
          /******************************VOLUME  ***************/
          if (menu_idx==MENU_VOL)
            { volume+=change;
              volume=constrain(volume,0,90);
              float V=volume*0.01;
              sgtl5000.volume(V);
              AudioInterrupts();
          /******************************MIC_GAIN  ***************/
          if (menu_idx==MENU_MIC)
             mic_gain+=change;
             mic_gain=constrain(mic_gain,0,63);
             set_mic_gain(mic_gain);
             FFTcount=0; //start denoise after changing gain
             //reset FFTdenoise array
               FFTavg[i]=0;
          /******************************FREQUENCY  ***************/
          if (menu_idx==MENU_FRQ)
             { int delta=500;
               uint32_t currentmillis=millis();
               //when turning the encoder fast make the change larger
               if ((currentmillis-lastmillis)<500)
                  { delta=1000;}
               if ((currentmillis-lastmillis)<250)
                  { delta=2000;}
               if ((currentmillis-lastmillis)<100)
                  { delta=5000;}
              freq_real=freq_real+delta*change;
              // limit the frequencies to 500hz steps
              freq_real=constrain(freq_real,7000,int(sample_rate_real/2000)*1000-1000);
              lastmillis=millis();
          /******************************DENOISE  ***************/
          if (menu_idx==MENU_DNS)
            { // setting FFTcount to 0 activates a 1000 sample denoise
              FFTcount=0;
          /******************************DISPLAY  ***************/
          if (menu_idx==MENU_DSP)
               displaychoice+=change;
               displaychoice=displaychoice%3; //limit to 0(none),1(spectrum),2(waterfall)
               if (displaychoice==waterfallgraph)
                   tft.setRotation( 0 );
               if (displaychoice==spectrumgraph)
                tft.setScroll(0);
    /************** SPECIAL MODES WHERE THE LEFTENCODER SETS A FUNCTION AND THE RIGHT ENCODER SELECTS */
          /******************************SAMPLE_RATE  ***************/
          if (EncLeft_menu_idx==MENU_SR)  //only selects a possible sample_rate, user needs to press a button to SET sample_rate
            { sample_rate+=EncRightchange;
              sample_rate=constrain(sample_rate,SAMPLE_RATE_MIN,SAMPLE_RATE_MAX);
          /******************************SELECT A FILE  ***************/
          if ((EncLeft_menu_idx==MENU_PLY) and (EncRight_menu_idx==MENU_PLY) and (EncRight_function==enc_value))//menu play selected on the left and right
               if (mode!=MODE_PLAY)
                 fileselect+=EncRightchange;
                 fileselect=constrain(fileselect,0,filecounter-1);
          /******************************CHANGE SR during PLAY  ***************/
          if ((EncLeft_menu_idx==MENU_PLY) and (EncRight_menu_idx==MENU_SR) and (EncRight_function==enc_value))//menu play selected on the left and right
                     sample_rate=constrain(sample_rate,SAMPLE_RATE_8K,SAMPLE_RATE_44K);
                     set_sample_rate(sample_rate);
    void updateEncoders()
    //only react to changes large enough (depending on the steps of the encoder for one rotation)
     long EncRightnewPos = EncRight.read()/4;
     if (EncRightnewPos>EncRightPos)
       { EncRightchange=enc_up; }
       if (EncRightnewPos<EncRightPos)
       { EncRightchange=enc_dn; }
       { EncRightchange=enc_nc; }
     if (EncRightchange!=0)
        {updateEncoder(enc_rightside);
     EncRightPos=EncRightnewPos;
     long EncLeftnewPos = EncLeft.read()/4;
     if (EncLeftnewPos>EncLeftPos)
       { EncLeftchange=enc_up; }
       if (EncLeftnewPos<EncLeftPos)
       { EncLeftchange=enc_dn; }
       { EncLeftchange=enc_nc; }
     if (EncLeftchange!=0)
        {updateEncoder(enc_leftside);
     EncLeftPos=EncLeftnewPos;
     //update display only if a change has happened
     if ((EncRightchange!=0) or (EncLeftchange!=0))
          display_settings();
    void updateButtons()
     // Respond to button presses
     // try to make the interrupts as short as possible when recording
     if (mode==MODE_REC)
         encoderButton_L.update(); //check the left encoderbutton
          if ((encoderButton_L.risingEdge())  )
           { stopRecording();
              EncLeft_function=enc_menu; //force into active-menu
              display_settings();
     else // not MODE_REC
      encoderButton_R.update();
      micropushButton_L.update();
      micropushButton_R.update();
       /*RIGHT MICROPUSH */
      if (micropushButton_R.risingEdge()) {
            detector_mode++;
            if (detector_mode>detector_passive)
              {detector_mode=0;}
            changeDetector_mode();
            display_settings();
    /*LEFT MICROPUSH */
      if (micropushButton_L.risingEdge()) {
          //no function yet
      /************  LEFT ENCODER BUTTON *******************/
      if (encoderButton_L.risingEdge()) {
          EncLeft_function=!EncLeft_function;
          //*SPECIAL MODES that change rightside Encoder based on leftside Encoder menusetting
          //****************************************SAMPLERATE
          if ((EncLeft_menu_idx==MENU_SR) and (EncLeft_function==enc_value))
           { EncRight_menu_idx=MENU_SR;
             EncRight_function=enc_value; // set the rightcontroller to select
         if (SD_ACTIVE)
            /*if (mode==MODE_REC)
                     { stopRecording();
            if ((mode==MODE_PLAY) and ((EncLeft_menu_idx==MENU_PLY) or (EncLeft_menu_idx==MENU_PLD)))
                     { stopPlaying();
                       EncLeft_menu_idx=MENU_PLY;
            //Direct play menu got choosen, now change the rightencoder to choose a file
            if ((EncLeft_menu_idx==MENU_PLD) and (EncLeft_function==enc_value))
               EncRight_menu_idx=MENU_FRQ ;
            //play menu got choosen, now change the rightencoder to choose a file
               EncRight_menu_idx=MENU_PLY ;
         } //END SD_ACTIVE
         display_settings();
    /************  RIGHT ENCODER BUTTON *******************/
     if (encoderButton_R.risingEdge()) {
        EncRight_function=!EncRight_function; //switch between menu/value control
        //when EncLeftoder is SR menu than EncRightoder can directly be setting the samplerate at a press
        //the press should be a transfer from enc_value to enc_menu before it gets activated
        if ( (EncLeft_menu_idx==MENU_SR) and (EncRight_menu_idx==MENU_SR) and (EncRight_function==enc_menu))
        { set_sample_rate(sample_rate);
        //recording and playing are only possible with an active SD card
        if (SD_ACTIVE)
                 { stopRecording();
                   EncRight_function=enc_menu; //force into active-menu
              else*/
                     startRecording();
                  if (not continousPlay)
                    { stopPlaying();
          if (mode==MODE_DETECT)
           { if (EncLeft_menu_idx==MENU_PLY)
                { last_sample_rate=sample_rate;
                  startPlaying(SAMPLE_RATE_8K);
                  {  fileselect=referencefile;
                     continousPlay=true;
          display_settings();
     #ifdef DEBUGSERIAL
      delay(200);
    //setup Encoder Buttonpins with pullups
      pinMode(encoderButton_RIGHT,INPUT_PULLUP);
      pinMode(encoderButton_LEFT,INPUT_PULLUP);
      pinMode(MICROPUSH_RIGHT,INPUT_PULLUP);
      pinMode(MICROPUSH_LEFT,INPUT_PULLUP);
     // EncLeft.write(10000); //set default far away from 0 to avoid negative transitions
      //EncRight.write(10000); //set default far away from 0 to avoid negative transitions
    //startup menu
      // Audio connections require memory.
      AudioMemory(300);
    // Enable the audio shield. select input. and enable output
      sgtl5000.enable();
      sgtl5000.inputSelect(myInput);
      sgtl5000.volume(0.45);
      sgtl5000.micGain (mic_gain);
      //sgtl5000.adcHighPassFilterDisable(); // does not help too much!
      sgtl5000.lineInLevel(0);
      mixFFT.gain(0,1);
    // Init TFT display
    #ifdef USETFT
      tft.begin();
      //ts.begin();
      tft.setCursor(0, 0);
      tft.setScrollarea(TOP_OFFSET,BOTTOM_OFFSET);
      display_settings();
      tft.setCursor(80,50);
      tft.setFont(Arial_24);
      char tstr[9];
    tft.print(tstr);
      delay(2000); //wait a second to clearly show the time
       //Init SD card use
    // uses the SD card slot of the Teensy, NOT that of the audio boards
    // this init only for playback
    #ifdef USESD1
      if(!(SD.begin(BUILTIN_SDCARD)))
          #ifdef DEBUGSERIAL
        SD_ACTIVE=false;
        tft.fillCircle(70,50,5,COLOR_RED);
        SD_ACTIVE=true;
        tft.fillCircle(70,50,5,COLOR_GREEN);
        filecounter=0;
        root = SD.open("/");
        //TODO: check if file is a RAW file and also read the SAMPLERATE
        while (true) {
            File entry =  root.openNextFile();
            if (! entry) {
              // no more files
              tft.setCursor(0,50);
              tft.print(filecounter);
            if (entry.isDirectory()) {
              // do nothing, only look for raw files in the root
            } else
            strcpy(filelist[filecounter],entry.name() );
            if (String(entry.name())=="TEST_176.RAW")
               {referencefile=filecounter;
            filecounter++;
            entry.close();
    if (SD_ACTIVE)
    // Recording on SD card by uSDFS library
      {f_mount (&fatfs, (TCHAR *)_T("0:/"), 0);      /* Mount/Unmount a logical drive */
       for (int i=0; i<filecounter; i++)
           #ifdef DEBUGSERIAL
              #ifdef USETFT
                tft.setCursor(0,50+i*20);
                tft.print(filelist[i]);
         file_number=filecounter+1;
    #ifdef USESD2
     uSD.init();
    set_sample_rate (sample_rate);
    inputMixer.gain(0,1); //microphone active
    inputMixer.gain(1,0); //player off
    outputMixer.gain(0,1); // heterodyne1 to output
    outputMixer.gain(1,0); // granular to output off
    outputMixer.gain(2,0); // player to output off
    // the Granular effect requires memory to operate
    granular1.begin(granularMemory, GRANULAR_MEMORY_SIZE);
    // reset the FFT denoising array at startup
      FFTavg[i]=0;
    } // END SETUP
    // If we're playing or recording, carry on...
        continueRecording();
      if (mode == MODE_PLAY) {
        continuePlaying();
    updateButtons();
    // during recording only the left encoders button is used and screens are not updated
    if (mode!=MODE_REC)
     updateEncoders();
     #ifdef USETFT
        { waterfall();
        {  spectrum();
    Senior Member CorBee's Avatar
    Jun 2018
    Netherlands
    112
    Just tested the changes WMXZ has proposed, code compiles OK on my side too. Have not updated the detector itself (just check the code) but I am not doubting that this is a good change, the advantage is that this makes the code less dependent on particular libraries. Especially the differences between coding environments (windows, linux, platformIO, arduinoIDE ...) are sometimes causing issues that are difficult to assess.
    Thanks to WMXZ for chiming in and improving the code !
    Thanks to Edwin for persisting to work on both this issue with the code and your work on decreasing the backgroud-noise causes. I will try to see if I can also change the way my current setup is powered in the way you have suggested.
    Furthermore, I am currently not actively developing the code. Its winter and the bats overhere are allready at rest, but I do have some ideas to improve/extend the code further especially the AUTO_TE mode which is according to me the most attractive mode to listen to ultrasound. Sure its not scientifically as sound since it can skip parts of the incoming signal. But to wander around in a garden and hear different crickets/grasshoppers and at the same time hear bats all having distinct calls (like birds) is in my view very entertaining.
    regards
    Cor
  11. #161
    Nov 2018
    8
    hello I could not get the screen ili9341 that you use with this program code, I already buy different screens but I could not get the spectrum analysis visualized, could you advise me how do I make the connections with any of these screens or is it necessary get the same one that you use
    The screens that I got are the following:
    https://www.itead.cc/itdb02-3-2s-v1.html
    https://www.lionchipmexico.com/produ...ry-pi-b-2-3-to
  12. #162
    Nov 2018
    Netherlands
    28
    Quote Originally Posted by CandelaRDZ View Post
    Do you get any image at all?
    As long as the screen uses the right river it should work, I use this display 2.8" 240x320 SPI TFT LCD ILI9341 5V/3.3V (red pcb, 14+4pin on ebay)
    In post 147 you can see the schematic I use, reset is tied high with a delay 10k/100nF
    Pleas keep in mind the code by DD4WH and Corber do not use the exact same pins!
    Edwin
  13. #163
  14. #164
    Nov 2018
    Netherlands
    28
    For the first link I can not se what chip it uses, the screen resolution seem the same, the second one, raspberry pi display will almost cirtainly use and other chip.
    Be sure your display uses the ili9341 otherwise it will not work without changing the code to the right display driver chip.
    Edwin
  15. #165
    Nov 2018
    8
    already verify the first screen and have the ili9341 mention this in the product description:
    ITDB02-3.2S V2 display module is a 3.2 "TFT LCD with 65K color 320 x 240 resolutions for Arduino The controller of this Arduino LCD module is ILI9341.It supports 16bit data interface with control interface of four wires.
    https://www.itead.cc/itdb02-3-2s-v2.html
  16. #166
    Nov 2018
    Netherlands
    28
    CandelaRDZ
    Did you get anything usefull on your display?
    Do you use the Corber code and do you use the pins as described in the code?
    Did you connect the reset pin to the powersupply? (or like I did with a 10k resistor and 100nF capacitor)
    Edwin
  17. #167
    Jun 2018
    Netherlands
    112
    Looking at the pinout of this module I think it will be using SPI for touch and the SDcard and a 16bit databus instead of SPI for the screen itself. I could be wrong but the sheer number of pins on the module look like its a 16bit bus. And the current code is made to work with SPI, also I dont see how a 16bit bus could be controlled by a Teensy, I have no experience with them.
  18. #168
    Nov 2018
    Netherlands
    28
    CandelaRDZ, I just took some time to look at the datasheet of the ili chip and your display.
    As it seem the ili chip can be configured for ome of 12 different interface modes. One of these is SPI, the display you have does not use SPI for the display interface. (the choice of interface mode is set in the hardware by the manufacturer)
    It looks like you will have to use these displays for some other project and buy the right one for this project.
    Edwin
    Last edited by pe1pwf; 11-25-2018 at 08:15 AM. Reason: Answer was not clear enough.
  19. #169
    Nov 2018
    5
    Well I've tried Edwin's code in ArduinoIDE and it still won't compile. No clue as to why from the error message. I've now installed PlatformIO on windows. After failing to compile again as it couldn't find include files I put the full path in for the includes which helped but it still won't compile. To be honest the error message look much the same to me and I still can't see what the issue is. Only the last two lines are red. Everything else is yellow, which I'm taking as meaning not ideal but ok
    here is my code:
     *  HARDWARE USED:
     *     TEENSY 3.6
     *     2 pushbuttons
     *     SDCard
     *                       Frequency divider
     *     Volume
     *     Gain
     *     Frequency
     *     Samplerate
     *  Record raw data
     * THE SOFTWARE.
    /* CORBEE */
                      GND                  Vin  - PREAMP V+
                       0                   Analog GND
                       1                   3.3V - MEMS MIC
                       2                   23 AUDIO -LRCLK
                       3                   22 AUDIO -TX
                       4                   21 TFT CS
                       5                   20 TFT DC
                       8                   17
           AUDIO BCLK  9                   16
                      3.3V                GND
                      24                  A22
                      25                  A21
                      26                  39  TFT MISO
                      32                  33
    //#include "C:/Program Files (x86)/Arduino/hardware/tools/avr/avr/include/stdlib.h"
    //#define DEBUG
    #define USETFT
    #define USESD1
    #ifdef USESD1
      #define USESD
      #include "C:/Program Files (x86)/Arduino/hardware/teensy/avr/libraries/SD/SD.h"
      #include "C:/Program Files (x86)/Arduino/libraries/uSDFS-master/src/ff.h"       // uSDFS lib
      #include "C:/Program Files (x86)/Arduino/libraries/uSDFS-master/src/ff_utils.h" // uSDFS lib
      File root;
    #ifdef USESD2
    #define USESD
    //#include "SdFs.h"
    #ifdef USESD
      int filecounter=0;
      int fileselect=0;
    //#include "Time.h"
    #include "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\Audio.h"
    //#include <Wire.h>
    #include "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI\SPI.h"
    #include <Bounce.h>
    #include <Metro.h>
    int helphour;
    int helpday;
    int helpmonth;
    int helpyear;
    int helpsec;
    uint8_t hour10_old;
    uint8_t hour1_old;
    bool timeflag = 0;
    #ifdef USETFT
     #define ILI9341
     #ifdef ILI9341
      #include "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ILI9341_t3\ILI9341_t3.h"
      #define TFT_DC      20
      #define TFT_CS      21
      #define TFT_MOSI    7
      #define TFT_SCLK    14
      #define TFT_MISO    12
    AudioMixer4                      mixFFT;
    #ifdef DEBUGSERIAL
    //continous timers
      #define BUFF 64
    uint wr;
    uint32_t nj = 0;
    int idx_t = 0;
    int idx = 0;
    int64_t sum;
    float32_t mean;
    int16_t index_FFT;
    int l_limit;
    int u_limit;
    int index_l_limit;
    int index_u_limit;
    int barm [512];
        const int SR_n;
    } SR_Desc;
        //   SR_n ,  f1
    float FFTavg[128];
    int8_t volume=50;
        const char* name;
    } Menu_Desc;
       {"Gain",4,30,0,63},
       {"Play",4,0,0,0},
       {"PlayD",5,0,0,0},
    //available modes
    //default
    int EncRightPos=0;
    int EncLeftPos=0;
    #ifdef USESD1
       #ifdef DEBUGSERIAL
    #ifdef USESD1
    //uint32_t count=0;
    uint32_t ifn=0;
    uint32_t t0=0;
    uint32_t t1=0;
    char filename[80];
      #ifdef USETFT
        tft.setCursor(0,0);
             tft.print("FD");
            tft.print("PASS");
           default:
            tft.print("error");
           tft.print(" ");
            if (mode==MODE_REC)
                tft.print("REC:");
                tft.print("PLAY:");
                tft.print(" ");
        //scale every 10kHz
        AudioInterrupts();
        display_settings();
        AudioInterrupts();
        display_settings();
      typedef struct {
        uint8_t mult;
        uint16_t div;
      } tmclk;
          return;
      switch (sr) {
        SRtext = " 8";
        SRtext = "11";
        SRtext = "16";
        SRtext = "22";
        SRtext = "32";
        SRtext = "44";
        SRtext = "48";
        SRtext = "88";
        SRtext = "96";
        SRtext = "176";
        SRtext = "192";
        SRtext = "234";
        SRtext = "281";
        SRtext = "352";
        AudioInterrupts();
        delay(20);
        display_settings();
         #ifdef USETFT
        FFTcount++;
        if (FFTcount==1)
             FFTavg[i]=0;
        if (FFTcount<1000)
            peak=FFT_bin[x];
    avgF=avgF/128;
      { maxF=2;}
         if (bar <0) bar=0;
         int g_x=x*2;
        /* if (x==maxF)
         barm[x] = bar;
      } //end if
    #ifdef DEBUGSERIAL
          Serial.print(" (");
          Serial.print(" (");
    #ifdef USETFT
        FFTcount++;
        if (FFTcount==1)
              FFTavg[i]=0;
        if (FFTcount<100)
        int peak=512;
        int avgFFTbin=0;
          avgFFTbin+=val;
          if (val>peak)
           { peak=val;
             FFT_peakF_bin=i;
           if (val<5)
               {val=5;}
                  min(255, val/2),
                                0
        //mark the peak
         { FFT_peakF_bin=0;
            //add new samples
                        {binLo=i;}}
                        {binHi=i;}
              {binLo=0; binHi=0;
             tft.print(" ");
             tft.print(" ");
            if (not batTrigger)
                //clicker=0;
                     since_heterodyne=0;
                     //granular1.stop();
                 { granular1.stop();
                   TE_ready=false;
             //clicker++;
             batTrigger=true;
              batTrigger=false;
            TE_ready=true;
            count++;
      mode = MODE_REC;
      #ifdef USESD1
        #ifdef DEBUGSERIAL
        // close file
        if(isFileOpen)
          //close file
          rc = f_close(&fil);
          isFileOpen=0;
      if(!isFileOpen)
      file_number++;
        #ifdef DEBUGSERIAL
      filecounter++;
      #ifdef DEBUGSERIAL
    #ifdef DEBUGSERIAL
            rc = f_close(&fil);
              #ifdef DEBUGSERIAL
              if (rc) {
                die("unlink", rc);
              die("close", rc);
        // retry open file
        if(rc) {
          die("open", rc);
        isFileOpen=1;
      display_settings();
      mixFFT.gain(0,0);
      nj=0;
      recorder.begin();
      #ifdef USESD1
        nj++;
          nj = 0;
          //push to SDcard
    #ifdef USESD1
      #ifdef DEBUGSERIAL
        recorder.end();
            //close file
            rc = f_close(&fil);
            isFileOpen=0;
      //    frec.close();
        mode = MODE_DETECT;
      //  clearname();
      #ifdef DEBUGSERIAL
      //switch on FFT
      mixFFT.gain(0,1);
    //      char fi[15];
    //allow settling
      display_settings();
      mode = MODE_PLAY;
    #ifdef DEBUGSERIAL
      mode = MODE_DETECT;
    #ifdef DEBUGSERIAL
        stopPlaying();
             { granular1.stop();
       int change=0;
       int menu_idx=0;
       int choices=0;
        //get encodermode
          if (menu_idx<0)
            {menu_idx=0;}
          if (!SD_ACTIVE)
                 menu_idx=MENU_VOL;
            { volume+=change;
              sgtl5000.volume(V);
              AudioInterrupts();
             mic_gain+=change;
               FFTavg[i]=0;
             { int delta=500;
                  { delta=1000;}
                  { delta=2000;}
                  { delta=5000;}
              FFTcount=0;
                tft.setScroll(0);
          display_settings();
     if (mode==MODE_REC)
           { stopRecording();
              display_settings();
            detector_mode++;
              {detector_mode=0;}
            display_settings();
    /*LEFT MICROPUSH */
          //no function yet
         if (SD_ACTIVE)
                     { stopRecording();
                     { stopPlaying();
         } //END SD_ACTIVE
         display_settings();
        if (SD_ACTIVE)
                 { stopRecording();
              else*/
                     startRecording();
                    { stopPlaying();
                     continousPlay=true;
          display_settings();
     #ifdef DEBUGSERIAL
      delay(200);
    //startup menu
      AudioMemory(300);
      sgtl5000.enable();
      mixFFT.gain(0,1);
    // Init TFT display
    #ifdef USETFT
      tft.begin();
      //ts.begin();
      display_settings();
      char tstr[9];
    tft.print(tstr);
       //Init SD card use
    #ifdef USESD1
          #ifdef DEBUGSERIAL
        SD_ACTIVE=false;
        SD_ACTIVE=true;
        filecounter=0;
        while (true) {
            if (! entry) {
              // no more files
            } else
            filecounter++;
            entry.close();
    if (SD_ACTIVE)
           #ifdef DEBUGSERIAL
              #ifdef USETFT
    #ifdef USESD2
     uSD.init();
      FFTavg[i]=0;
    } // END SETUP
        continuePlaying();
    updateButtons();
    if (mode!=MODE_REC)
     updateEncoders();
     #ifdef USETFT
        { waterfall();
        {  spectrum();
    and the error message:
    > Executing task: C:\Users\nick user\.platformio\penv\Scripts\platformio.exe run --verbose <
    Processing teensy36 (platform: teensy; board: teensy36; framework: arduino)
    CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy36.html
    PLATFORM: Teensy > Teensy 3.6
    HARDWARE: MK66FX1M0 180MHz 256KB RAM (1MB Flash)
    DEBUG: CURRENT(jlink) EXTERNAL(jlink)
    Library Dependency Finder -> http://bit.ly/configure-pio-ldf
    LDF MODES: FINDER(chain) COMPATIBILITY(soft)
    Collected 93 compatible libraries
    Scanning dependencies...
    Dependency Graph
    |-- <Metro> (C:\Users\nick user\.platformio\packages\framework-arduinoteensy\libraries\Metro)
    |-- <SPI> 1.0 (C:\Users\nick user\.platformio\packages\framework-arduinoteensy\libraries\SPI)
    |-- <ILI9341_t3> (C:\Users\nick user\.platformio\packages\framework-arduinoteensy\libraries\ILI9341_t3)
    |-- <Encoder> (C:\Users\nick user\.platformio\packages\framework-arduinoteensy\libraries\Encoder)
    arm-none-eabi-g++ -o .pioenvs\teensy36\firmware.elf -T mk66fx1m0.ld -Os -Wl,--gc-sections,--relax -mthumb -mcpu=cortex-m4 -Wl,--defsym=__rtc_localtime=1543263450 -fsingle-precision-constant -mfloat-abi=hard -mfpu=fpv4-sp-d16 .pioenvs\teensy36\src\ILI9341_t3.cpp.o .pioenvs\teensy36\src\effect_granular.cpp.o .pioenvs\teensy36\src\main.cpp.o "-LC:\Users\nick user\.platformio\packages\framework-arduinoteensy\cores\teensy3" -L.pioenvs\teensy36 -Wl,--start-group .pioenvs\teensy36\lib332\libMetro.a .pioenvs\teensy36\liba54\libSPI.a .pioenvs\teensy36\lib038\libILI9341_t3.a .pioenvs\teensy36\lib2eb\libEncoder.a .pioenvs\teensy36\libFrameworkArduino.a -larm_cortexM4lf_math -lm -lstdc++ -Wl,--end-group
    .pioenvs\teensy36\src\main.cpp.o: In function `AudioPlaySdRaw::~AudioPlaySdRaw()':
    main.cpp:(.text._ZN14AudioPlaySdRawD2Ev[_ZN14AudioPlaySdRawD5Ev]+0xa): undefined reference to `File::~File()'
    main.cpp:(.text._ZN14AudioPlaySdRawD2Ev[_ZN14AudioPlaySdRawD5Ev]+0x14): undefined reference to `vtable for AudioPlaySdRaw'
    .pioenvs\teensy36\src\main.cpp.o: In function `AudioMixer4::AudioMixer4()':
    main.cpp:(.text._ZN11AudioMixer4C2Ev[_ZN11AudioMixer4C5Ev]+0x24): undefined reference to `vtable for AudioMixer4'
    .pioenvs\teensy36\src\main.cpp.o: In function `set_mic_gain(signed char)':
    main.cpp:(.text._Z12set_mic_gaina+0xc): undefined reference to `AudioControlSGTL5000::micGain(unsigned int)'
    .pioenvs\teensy36\src\main.cpp.o: In function `spectrum()':
    main.cpp:(.text._Z8spectrumv+0x22): undefined reference to `AudioPlaySdRaw::positionMillis()'
    main.cpp:(.text._Z8spectrumv+0x2a): undefined reference to `AudioPlaySdRaw::lengthMillis()'
    main.cpp:(.text._Z8spectrumv+0x4e): undefined reference to `AudioPlaySdRaw::positionMillis()'
    main.cpp:(.text._Z8spectrumv+0x56): undefined reference to `AudioPlaySdRaw::lengthMillis()'
    main.cpp:(.text._Z8spectrumv+0x7a): undefined reference to `AudioPlaySdRaw::positionMillis()'
    main.cpp:(.text._Z8spectrumv+0x82): undefined reference to `AudioPlaySdRaw::lengthMillis()'
    main.cpp:(.text._Z8spectrumv+0xa2): undefined reference to `AudioPlaySdRaw::positionMillis()'
    main.cpp:(.text._Z8spectrumv+0xaa): undefined reference to `AudioPlaySdRaw::lengthMillis()'
    .pioenvs\teensy36\src\main.cpp.o: In function `startRecording()':
    main.cpp:(.text._Z14startRecordingv+0x10): undefined reference to `f_close'
    main.cpp:(.text._Z14startRecordingv+0x3c): undefined reference to `char2tchar'
    main.cpp:(.text._Z14startRecordingv+0x5c): undefined reference to `f_stat'
    main.cpp:(.text._Z14startRecordingv+0x68): undefined reference to `f_open'
    main.cpp:(.text._Z14startRecordingv+0x74): undefined reference to `f_close'
    main.cpp:(.text._Z14startRecordingv+0x80): undefined reference to `f_unlink'
    main.cpp:(.text._Z14startRecordingv+0x8c): undefined reference to `f_open'
    main.cpp:(.text._Z14startRecordingv+0xf6): undefined reference to `AudioRecordQueue::clear()'
    .pioenvs\teensy36\src\main.cpp.o: In function `continueRecording()':
    main.cpp:(.text._Z17continueRecordingv+0x4): undefined reference to `AudioRecordQueue::available()'
    main.cpp:(.text._Z17continueRecordingv+0x18): undefined reference to `AudioRecordQueue::readBuffer()'
    main.cpp:(.text._Z17continueRecordingv+0x2a): undefined reference to `AudioRecordQueue::freeBuffer()'
    main.cpp:(.text._Z17continueRecordingv+0x3a): undefined reference to `AudioRecordQueue::readBuffer()'
    main.cpp:(.text._Z17continueRecordingv+0x4c): undefined reference to `AudioRecordQueue::freeBuffer()'
    main.cpp:(.text._Z17continueRecordingv+0x6a): undefined reference to `f_write'
    .pioenvs\teensy36\src\main.cpp.o: In function `stopRecording()':
    main.cpp:(.text._Z13stopRecordingv+0x18): undefined reference to `AudioRecordQueue::available()'
    main.cpp:(.text._Z13stopRecordingv+0x22): undefined reference to `AudioRecordQueue::readBuffer()'
    main.cpp:(.text._Z13stopRecordingv+0x30): undefined reference to `f_write'
    main.cpp:(.text._Z13stopRecordingv+0x38): undefined reference to `AudioRecordQueue::freeBuffer()'
    main.cpp:(.text._Z13stopRecordingv+0x40): undefined reference to `f_close'
    .pioenvs\teensy36\src\main.cpp.o: In function `startPlaying(int)':
    main.cpp:(.text._Z12startPlayingi+0x9e): undefined reference to `AudioPlaySdRaw::play(char const*)'
    .pioenvs\teensy36\src\main.cpp.o: In function `stopPlaying()':
    main.cpp:(.text._Z11stopPlayingv+0xe): undefined reference to `AudioPlaySdRaw::stop()'
    .pioenvs\teensy36\src\main.cpp.o: In function `updateEncoder(unsigned char)':
    main.cpp:(.text._Z13updateEncoderh+0xaa): undefined reference to `AudioControlSGTL5000::volumeInteger(unsigned int)'
    .pioenvs\teensy36\src\main.cpp.o: In function `updateButtons()':
    main.cpp:(.text._Z13updateButtonsv+0xc): undefined reference to `Bounce::update()'
    main.cpp:(.text._Z13updateButtonsv+0x12): undefined reference to `Bounce::risingEdge()'
    main.cpp:(.text._Z13updateButtonsv+0x28): undefined reference to `Bounce::update()'
    main.cpp:(.text._Z13updateButtonsv+0x2e): undefined reference to `Bounce::update()'
    main.cpp:(.text._Z13updateButtonsv+0x34): undefined reference to `Bounce::update()'
    main.cpp:(.text._Z13updateButtonsv+0x3a): undefined reference to `Bounce::update()'
    main.cpp:(.text._Z13updateButtonsv+0x40): undefined reference to `Bounce::risingEdge()'
    main.cpp:(.text._Z13updateButtonsv+0x5e): undefined reference to `Bounce::risingEdge()'
    main.cpp:(.text._Z13updateButtonsv+0x64): undefined reference to `Bounce::risingEdge()'
    main.cpp:(.text._Z13updateButtonsv+0xde): undefined reference to `Bounce::risingEdge()'
    .pioenvs\teensy36\src\main.cpp.o: In function `setup':
    main.cpp:(.text.setup+0x4e): undefined reference to `AudioControlSGTL5000::enable()'
    main.cpp:(.text.setup+0x5a): undefined reference to `AudioControlSGTL5000::write(unsigned int, unsigned int)'
    main.cpp:(.text.setup+0x66): undefined reference to `AudioControlSGTL5000::write(unsigned int, unsigned int)'
    main.cpp:(.text.setup+0x76): undefined reference to `AudioControlSGTL5000::write(unsigned int, unsigned int)'
    main.cpp:(.text.setup+0x82): undefined reference to `AudioControlSGTL5000::volumeInteger(unsigned int)'
    main.cpp:(.text.setup+0x8e): undefined reference to `AudioControlSGTL5000::micGain(unsigned int)'
    main.cpp:(.text.setup+0x98): undefined reference to `AudioControlSGTL5000::lineInLevel(unsigned char, unsigned char)'
    main.cpp:(.text.setup+0xe6): undefined reference to `seconds2tm'
    main.cpp:(.text.setup+0x112): undefined reference to `SDClass::begin(unsigned char)'
    main.cpp:(.text.setup+0x152): undefined reference to `SDClass::open(char const*, unsigned char)'
    main.cpp:(.text.setup+0x184): undefined reference to `File::~File()'
    main.cpp:(.text.setup+0x194): undefined reference to `File::openNextFile(unsigned char)'
    main.cpp:(.text.setup+0x19a): undefined reference to `File::operator bool()'
    main.cpp:(.text.setup+0x1b4): undefined reference to `File::~File()'
    main.cpp:(.text.setup+0x1bc): undefined reference to `File::isDirectory()'
    main.cpp:(.text.setup+0x1cc): undefined reference to `File::name()'
    main.cpp:(.text.setup+0x1da): undefined reference to `File::name()'
    main.cpp:(.text.setup+0x208): undefined reference to `File::close()'
    main.cpp:(.text.setup+0x20e): undefined reference to `File::~File()'
    main.cpp:(.text.setup+0x21e): undefined reference to `f_mount'
    main.cpp:(.text.setup+0x2a8): undefined reference to `SD'
    .pioenvs\teensy36\src\main.cpp.o: In function `_GLOBAL__sub_I_root':
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x20): undefined reference to `File::File()'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x58): undefined reference to `AudioInputI2S::begin()'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0xf2): undefined reference to `File::File()'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0xf8): undefined reference to `AudioPlaySdRaw::begin()'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x140): undefined reference to `AudioOutputI2S::begin()'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x360): undefined reference to `File::~File()'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x36c): undefined reference to `vtable for AudioInputI2S'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x370): undefined reference to `vtable for AudioRecordQueue'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x378): undefined reference to `vtable for AudioSynthWaveformSineHires'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x380): undefined reference to `vtable for AudioEffectMultiply'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x384): undefined reference to `vtable for AudioAnalyzeFFT256'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x388): undefined reference to `AudioWindowHanning256'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x38c): undefined reference to `vtable for AudioPlaySdRaw'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x3a4): undefined reference to `vtable for AudioOutputI2S'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x3d0): undefined reference to `vtable for AudioControlSGTL5000'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x42c): undefined reference to `Bounce::Bounce(unsigned char, unsigned long)'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x436): undefined reference to `Bounce::Bounce(unsigned char, unsigned long)'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x44a): undefined reference to `Bounce::Bounce(unsigned char, unsigned long)'
    main.cpp:(.text.startup._GLOBAL__sub_I_root+0x454): undefined reference to `Bounce::Bounce(unsigned char, unsigned long)'
    *** [.pioenvs\teensy36\firmware.elf] Error 1
    =============================================================================================== [ERROR] Took 4.24 seconds ===============================================================================================
    The terminal process terminated with exit code: 1
    If anyone can give a hint I'd be grateful.
  20. #170
    Nov 2018
    Netherlands
    28
    So I just hijacked my wifes computer to test.
    Installed Arduino 1.8.7
    Installed teensyduino
    Downloaded https://github.com/WMXZ-EU/uSDFS
    Extracted the library to C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries
    Downloaded the zip here https://github.com/CorBer/teensy_batdetector
    Extracted both lil.... files here C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ILI934 1_t3
    Extracted both granular..... files here C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
    Chose the Teensy 3.6 board in Arduino IDE
    Cut and paste the code from post #159 and compiled
    I do not know what is special about the ili library, for audio I can imagine the custom bitrates.
    I just replaced the files to prevent conflicts.
  21. #171
    Germany NRW
    5,268
    ILI9341_t3: agreed, if there are changed/edited libraries in the wild, they *really* should have a new, different name.. it's annoying that there are copies of well-known libraries with different features, but having the same name.
  22. #172
    Nov 2018
    5
    Ok. A quick update. I had a tidy up of old copies of files and deleted everything not useful, rather than archiving it. Started a new Arduino session created a new project and it complied! Just uploaded it and it seems to working (more or less). The clock is frozen, I can only use spectrum and I have a cheap mic and a dodgy screen but it works with the keyring test. Not much time to play with it now but I need to get a better hardware set up first (I might try one of those boards, Edwin)
  23. #173
    Nov 2018
    Netherlands
    28
    Glad to see you finally got something compiled.
    If you want a board, just contact me by email.
    Displays are a real problem, more then half the displays I ordered arrived broken.
    Somehow the sellers refuse to pack these properly.
  24. #174
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    339
    Hi Edwin, hi CorBee,
    thanks again for your efforts to improve the software and providing a nice PCB!
    I managed to build the detector, but I have problems with using it :-). I probably need a user manual ;-).
    I do not understand the difference between the functions of the two encoders and the meaning of the white and yellow colour of the menu options . . .
    When I try to record (by setting the menu option to record with the left encoder, then pressing the left encoder then pressing again the right encoder), a sign appears "RECORDING", but nothing happens when I try to leave this mode. The detector remains entirely locked (heterodyne sound is still hearable).
    I am totally lost now and I do not know how to further proceed.
    Maybe you can help me to understand how to use the menu?
    All the best,
    Frank DD4WH
  25. #175
    Nov 2018
    Netherlands
    28
    Hi Frank,
    You got it all together quite quickly.
    I guess this question can best be answered by Cor but I did play around with it so I think I know how it works.
    I also made a video and put it on Youtube hoping to make more people enthusiastic.
    I guess you will probably see me struggling pressing the wrong button.
    First of all the left push button does not have a function assigned yet.
    Both encoders seem to have almost the same functions, you can set either for volume, gain, frequency or other function.
    The white text means turning the encoder makes you choose the function.
    If you press it it turns yellow and you can change the value of that function bu turning the same encoder.
    If you have set the left encoder to record you need to push the richt for record, the display will show recording.
    Seems a bit weid, pushing the left will change color between white and yellow but probably does nothing.
    I did notice at some point my recordings did not show in the files list when I selected Play. Somehow hey appeared after cycling the power. I was not able to reproduce that but I also had some strange ,raw files in my list at the time.
    The working of the buttons could use some fine-tuning I guess but maybe Cor ad an explenation and a manual.
    I am sure you will get things going, maybe the youtube video will help, around 6:30 you can see me recording.
    Kind regards,
    Edwin
