George Pillsbury
New member
I'm building a project using the APA102 LED strip (60 LED), and I want to power the strip from the right hand end with the GRD, LED_CLK, LED_DAT, 5v and supply the other end with a ADA Fruit LiPo power supply at 5v and GRD. I know the ADA fruit can put out at least 1000 mA, and the APA102 can draw a it more then that at full brightness. Will the prop shield safely carry the current through the 5v and Grd power rails, or should I run bypass wires end to end?
I'm loving the Teensy boards, they have so much more horse power then the Arduinos and are easy to work with.
