JamesCoyle
I'm using the 5V output on the Teensy 2 to power some LEDs. I have the LEDs wired with a resistor all in series between 5V and GND. The problem I have is how they are connected to the Teensy. I'm using a 3.5mm audio jack to allow the LED circuit to be plugged in when needed but this can lead to the 5V rail being shorted to ground for a second or so when the connector is inserted or removed while the Teensy has power. Will it cause damage to the Teensy over time and is there a relatively simple way to solve this issue?
