Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 101 to 125 of 168
Thread: Another fork of FlexCAN
  1. #101
    I was trying to figure out the version of TD after I had installed it and hunting around I found this file that kinda looked like it might be:
    /Applications/Arduino-1.8.2.app/Contents/Java/hardware/teensy/avr/platform.txt
    # http://www.pjrc.com/teensy/teensyduino.html
    name=Teensyduino
    version=1.6.7
    rewriting=disabled
    I guess that's just one of the many Arduino version numbers - can you tell me how to determine the version of TD after it has been installed?
    I think my next step is to try it on the T3.6 and get to a "known good" milestone and then work backwards until the T3.1 works again.
    I'm sure there will be a simple explanation - just need to find it...
    Regards
    Alex Shepherd
  2. #102
    843
    platform.txt is not the right place (the version number there is junk).
    The build output has the version (IDE Preferences / 'Show verbose output during compilation'):
    Compiling library "FlexCAN"
    ".../arduino-1.8.2-TD1.36/hardware.teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=136 -DARDUINO=10802 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I.../arduino-1.8.2-TD1.36/hardware/teensy/avr/cores/teensy3" "-I.../arduino-1.8.2-TD1.36/hardware/teensy/avr/libraries/FlexCAN" ".../arduino-1.8.2-TD1.36/hardware/teensy/avr/libraries/FlexCAN/FlexCAN.cpp" -o "/tmp/arduino_build_986471/libraries/FlexCAN/FlexCAN.cpp.o"
    and can tell if FlexCAN is picked up from the right location (or possibly from somewhere else).
  3. #103
    Ok, got-it! I can confirm: -DTEENSYDUINO=136 so that part is ok then.
    I'll confirm the behaviour on the T3.6 next.
    Thanks for your help
    Alex
  4. #104
    So i have started to play with this again and i have set up a successful bus using and Arduino with a CAN shield, and a Kvaser Leaf. Im attempting to connect the Teensy and i get ZERO out of it. Can someone confirm that this basic sketch SHOULD send a single message per second at 500K:
    #include <FlexCAN.h>
    static CAN_message_t rxmsg, txmsg;
    Can0.begin(500000);
    Serial.println("Hello Teensy 3.6 CAN Test.");
    txmsg.id = 0xa5;
    txmsg.ext = 0;
    txmsg.len = 2;
    txmsg.timeout = 0;
    txmsg.buf[0] = 0x01;
    txmsg.buf[1] = 0x02;
    txmsg.buf[2] = 0x03;
    txmsg.buf[3] = 0x04;
    txmsg.buf[4] = 0x05;
    txmsg.buf[5] = 0x06;
    txmsg.buf[6] = 0x07;
    txmsg.buf[7] = 0x08;
    Can0.write(txmsg);
    And that this one SHOULD receive a message sent at 500K:
    Can0.begin(500000);
    if (Can0.available()) {
    Can0.read(rxmsg);
    Serial.print("ID ");
    Serial.print(rxmsg.id, HEX);
    Serial.print(" Data ");
    Serial.print(rxmsg.buf[0], HEX);
    Serial.print(" , ");
    Serial.print(rxmsg.buf[1], HEX);
    Serial.print(rxmsg.buf[2], HEX);
    Serial.print(rxmsg.buf[3], HEX);
    Serial.print(rxmsg.buf[4], HEX);
    Serial.print(rxmsg.buf[5], HEX);
    Serial.print(rxmsg.buf[6], HEX);
    Serial.println(rxmsg.buf[7], HEX);
  5. #105
    Quote Originally Posted by TurboStreetCar View Post
    Specifically what model of Teensy? Is it a T3.1 as I'm having issues with that and the latest TD libraries?
    Perhaps it's related to the problem I'm having.
    Alex
  6. #106
    This is on a Teensy 3.6, the arduino and Kvaser leaf communicate just fine, but can't get the teensy working.
  7. #107
    843
    @TurboStreetCar:
    The code from #105 works here (FlexCAN from TD 1.36).
    @kiwi64ajs:
    Can you post the compiled .elf and .hex? It's in the sketch build directory. The forum allows attachments, if you go to the advanced post view. You need to put the .hex and .elf into a .zip file, the forum doesn't allow raw .hex / .elf files.
  8. #108
    @TurboStreetCar:
    @kiwi64ajs:
    Ok I
    - copied the build output into a file "Build-Output.txt" in the sketch folder
    - copied the whole build folder into the sketch folder
    - ZIPped the Sketch folder including the build folders - so you have everything
    Thanks for looking into this
    Alex
    Attached Files Attached Files
  9. #109
    843
    @kiwi64ajs:
    Your attachment from #109 works here (Teensy 3.2).
  10. #110
    @kiwi64ajs:
    Hmmm... well that is wierd.
    Well the 3.1 and 3.2 have the same chips and I've proven that my hardware works ok with the other library - it must be something else.
    So I'm now guessing that the CAN bus timing must be different in terms of where the bit sampling and the other configurable CAN bit-timing settings are concerned.
    I'll have to take a look in the morning and try and find that. The other nodes on my CAN Bus are AVR AT90CAN128 based as well as a MCP2515 so maybe they have some incompatible bit-timings.
    Alex
  11. #111
    @TurboStreetCar:
    Thanks! What exactly is TD 1.36? I assume thats the version of the FlexCan library? How do i know what version i have?
  12. #112
    843
    Teensyduino. 1.36 is the latest release.
    Post #103.
  13. #113
    Dec 2016
    Detroit, Michigan, USA
    102
    Thanks TNI for pointing out my obvious mistake.
  14. #114
    Verified im using 1.36.
    I have managed to get the code to receive and print a message from the bus to the serial monitor.
    The issue im still having is it will not transmit or ACK a message put into the bus. So I need to have a minimum of three devices on the bus including the Teensy, or else there will be no ACK and I get error frames. The other two devices create a successful transmission and ACK keeping the bus error free and the Teensy can listen in and grab the messages.
    Is the ACK something handled in the code and library by the Teensy? Or should the TI transceiver handle that on its own with no input needed from the teensy?
  15. #115
    843
    Quote Originally Posted by Detroit_Aristo View Post
    So, I had been using the previous version of ColinK's Flexcan very successfully. There was a push done 4 days ago which I just grabbed, assuming that nothing major would break.
    I was wrong.
    #include "FlexCAN_Latest\FlexCAN_Library\FlexCAN.h"
    What are you doing? Your sketch is using the latest header, but from the link error messages it's clear that you have an old FlexCAN version around that gets compiled.
  16. #116
    843
    If you didn't set listen only mode, Teensy should acknowledge messages.
  17. #117
    I don't believe I did. I've pretty much stick to just the read, write, and available commands. Is this something that is set once and continues for future use?
  18. #118
    843
    It is configured at runtime and not persistent. The FlexCAN default is to not use listen only mode and acknowledge (it works for me).
    It sounds like the transmitter of your CAN transceiver isn't working (or you didn't connect the Teensy TX pin properly).
  19. #119
    Dec 2016
    102
    You are probably right. The project is so large, Rather than changing every header include directive, I should probably update my test server, QA the changes, then push into my prod server.
    Terribly sorry about that post. It was late, I was frustrated, and I probably didn't perform due diligence.
    Thanks for pointing that out. I'll go back and make the necessary changes.
  20. #120
    Yes it sounds very possible, just strange that BOTH of the transceivers i have, don't work.
  21. #121
    TNI: Think you could double check my receive code from post #105 and see if it properly sends an ACK?
  22. #122
    843
    I did. Testing ACKs happens automatically. If the receiver can't send an ACK (it monitors the bus for it's own transmission), the receiver will discard the message.
    If I disconnect the receiver TX, the receiver won't receive anything and the sender keeps retrying sending the message indefinitely.
  23. #123
    Well, the new transceivers came in, and it now successfully communicates both ways! Super pumped, thanks for all the help!
  24. #124
    May 2017
    5
    Hi guys, I've been having some trouble setting a filter. I'm sure it's something simple, but I feel like I have tried everything that I can think of and don't really know what else to try.
    I am trying to listen for a single address, take bytes [4] and [5], and output that value on teensy's DAC. My problem is that no matter what I try, the filter doesn't take, and I am receiving addresses that should be filtered out.
    I can get it to work if I manually include an if (frame.id == 0x70) inside frameHandler, but that kinda defeats the purpose.
    Here is my setup:
    Teensy 3.2 with MCP2561 transceiver
    IntrepidCS ValueCAN3 set up to output the following messages:
    Every 5ms:
    ID: 0x70 ***this is the one I would like to filter for***
    bytes[0][1]: incrementing counter
    bytes[2][3]: 0xDEAD
    bytes[4][5]: uint16_t sine wave of ~2.5Hz ***the value of interest***
    bytes[6][7]: 0xBEEF
    Every 50ms:
    byte[0]: incrementing counter
    byte[1]: 20
    byte[2]: 30
    byte[3]: 40
    bytes[4][5][6][7]: 0xDEADBEEF
    Software:
    Ubuntu 16.04.2
    Arduino 1.8.2
    Teensyduino 1.36
    FlexCAN library from CollinK's github (also tried the version that came with TD 1.36 but that didn't make a difference)
    uint16_t raw;
    class ExampleClass : public CANListener
    public:
       bool frameHandler(CAN_message_t &frame, int mailbox, uint8_t controller); //overrides the parent version so we can actually do something
       //void gotFrame(CAN_message_t &frame, int mailbox); //overrides the parent version so we can actually do something
    //void ExampleClass::gotFrame(CAN_message_t &frame, int mailbox)
    bool ExampleClass::frameHandler(CAN_message_t &frame, int mailbox, uint8_t controller)
        raw = 0;
        raw |= frame.buf[5] << 8;
        raw |= frame.buf[4];
        analogWrite(A14,raw);
      return true;
    ExampleClass exampleClass;
    void setup(void)
      Serial.println(F("CAN variable to Analog Out"));
      //turn LED on
      pinMode(13, OUTPUT);
      digitalWrite(13, HIGH);
      analogWriteResolution(16);
      CAN_filter_t filter;
      filter.id = 0x70;
      filter.flags.extended = 0;
      filter.flags.remote = 0;
      Can0.begin(1000000);
      //Can0.begin(1000000,filter);
      Can0.attachObj(&exampleClass);
      for (uint8_t filterNum=0; filterNum<16; filterNum++)
        Can0.setFilter(filter,filterNum);
        exampleClass.attachMBHandler(filterNum);
      //exampleClass.attachGeneralHandler();
      //exampleClass.detachGeneralHandler();
    void loop(void)
      float eval = (raw - 32768) * 0.0001274;
      Serial.print("Value: ");
      Serial.print(eval);
      Serial.write('\r');
      Serial.write('\n');
    In the attached scope screenshot, you can see that bytes[4][5] from 0x110 are being read when they shouldn't be. Help?
  25. #125
    May 2017
    5
    Some additional info...I added the following to the end of setup() to make sure the mailboxes were successfully getting a filter set.
    CAN_filter_t setfilter;
    for(uint8_t num=0; num<16; num++)
      if(Can0.getFilter(setfilter,num))
        Serial.print("MB ");
        Serial.print(num);
        Serial.print(": ID: ");
        Serial.print(setfilter.id,HEX);
        Serial.write('\r');
        Serial.write('\n');
    The resulting serial window output:
    MB 0: ID: 70
    MB 1: ID: 70
    MB 2: ID: 70
    MB 3: ID: 70
    MB 4: ID: 70
    MB 5: ID: 70
    MB 6: ID: 70
    MB 7: ID: 70
    MB 8: ID: 70
    MB 9: ID: 70
    MB 10: ID: 70
    MB 11: ID: 70
    MB 12: ID: 70
    MB 13: ID: 70
    So it looks as if mailboxes 0 through 13 are correctly getting filters set but not 14 and 15. This seems to be proper behavior since 14 and 15 are reserved for TX only, but it is still reading data from 0x110.
