Page 2 of 2 FirstFirst 1 2
Results 26 to 28 of 28
Thread: Time signal LF Receiver Teensy DCF77 with minimal hardware effort
  1. #26
    Jan 2020
    6
    Another issue: I wanted to try some cross correlation to try to detect weaker signal. I added an IntervalTimer to call my very small interrupt routine every 10ms so I could sample the current signal strength. The thing went kind of crazy. Parts of the display were messed up and I think maybe it affected the sound card(?)
    Is there some other interrupt driven timer I could use?
  2. #27
    10,566
    Is 'current signal strength' an analogRead?
    See if the ADC library works with DMA to read it without interrupts?
    Or depending on how fast loop() cycles just start an elapsedMillis var and sample it every 10 ms
  3. #28
    Jan 2020
    6
    First Rule of Programming: It is probably your own fault.
    I was writing off the end of my sample array.
    Once I sorted that out everything was good with the display.
    IntervalTimer is exonerated.
