Page 2 of 2 FirstFirst 1 2
Results 26 to 35 of 35
Thread: Teensy Hearing Aid
  1. #26
    Nov 2015
    Norway
    70
    Thank you both! That works perfectly =)
  2. #27
    Oct 2015
    Vermont, USA
    178
    I made an enclosure for our device. Enclosures are hard!
    Basically, I had to give up on making something attractive and I simply had to focus on making it functional.
Name:	Enclosed Tympan in Hand.png
    More pictures and a link to CAD files: http://openaudio.blogspot.com/2017/0...ectronics.html
    It sure does take special skills to make something both functional and attractive. Electronics and software is way easier than industrial design. Wow.
    Chip
  3. #28
    Oct 2015
    Vermont, USA
    178
    I tested the Tympan with three different microphones.
    I measured their frequency response and scale factor. It was interesting to see how the microphones performed similarly and how they performed differently.
Name:	Calibration for All Mics.png
    If you want more details on how I did the calibration (including Arduino sketches, spectrograms and whatnot), you can check it out here: http://openaudio.blogspot.com/2017/0...th-tympan.html
    What other kinds of microphones might people find interesting?
    Chip
  4. #29
    9,029
    That PCB mic looks worthy of a test buy, Thanks for the info. Can you show the parts and circuit on the output to get the gain of 20?
  5. #30
    Oct 2015
    Vermont, USA
    178
    The mic is connected directly to our audio codec (TI 3206). The codec has a built-in PGA that you simply command to +20 dB and you're done. Codecs are a pain to setup but, man, they sure do integrate a ton of good functionality.
    The schematic is here: https://github.com/Tympan/Tympan_Lib...are/Tympan_PCB
    Chip
  6. #31
    Oct 2015
    Vermont, USA
    178
    After calibrating the system with different microphones, I turned to look at the output side of things. So, I calibrated the output of the system with a pair of my earbuds (inexpensive Klipsch S4). I used an ANSI-standard 2cc coupler and got the following response:
Name:	Klipsch Earphone Calibration.png
    More details: http://openaudio.blogspot.com/2017/0...th-tympan.html
    Does anyone have any experience calibrating earbuds? What kind of test fixture did you use? 2cc coupler? Artificial ear? Some sort of homebrew thing?
    Chip
  7. #32
    Apr 2018
    11
    In your circuit you have directly connected the mic to the line in pins. I wanted to know if there is a requirement of pre-amplification stage for that or connecting the mic to line in directly gives a good quality output?
  8. #33
    Oct 2015
    Vermont, USA
    178
    I see that my old GitHub link isn't correct anymore. Here are updated links:
    "Rev C", which is the audio board as add-on to Teensy 3.6: https://github.com/Tympan/Tympan_Rev..._Schematic.pdf
    "Rev D", which is the audio board and Teensy 3.6 integrated into one PCB: https://github.com/Tympan/Tympan_Rev...0Schematic.pdf
    Chip
  9. #34
    Oct 2015
    Vermont, USA
    178
    Quote Originally Posted by Kavyashree View Post
    The Texas Instruments AIC3206 has a programmable gain pre-amp. So, yes, you can connect a microphone directly to this chip without any additional amplification. For electret microphones, you do need to be sure that you provide a microphone bias (which can be either from the AIC or from your own bias voltage supply), but no additional amplification is needed.
    Chip
  10. #35
    Dec 2016
    101
    Quote Originally Posted by chipaudette View Post
    Chip
    Hi
    The invensense ICS-40730 has about 9db more SNR than you're PCB mic, but listens from the bottom.
