DD4WH
My longterm plan is to realize a Software Defined Radio which implements different filtering and demodulation strategies: phasing, Weaver demodulation, and Fast Convolution Filtering. The latter was the most challenging for me. With a hint by Alberto, finally today I managed to get audio filtered through a 513 (!!!) tap FIR filter by fast convolution.
Unlike standard filtering techniques, fast convolution works in the frequency domain like this (taken from Lyons 2011: Understanding Digital Signal Processing):
- FFT of the FIR filter coefficients = Filter mask
- fill FFT buffer with audio samples of last time and of now
- perform FFT
- complex multiply the output of the FFT with the filter mask
- perform inverse FFT
- discard half of the output samples and take other half of the output samples of the iFFT as the filtered audio samples
This technique is best done in 32bit integer math or floating point because otherwise precision of the calculations is not sufficient
In order to demonstrate the power of this filter technique I attach here a plot of the implemented filter response of the FIR filter with 512 taps:
This is achieved with a 1024point FFT/iFFT sequence. However, my script also runs with 2048 and 4096 point FFT/iFFTs, thus it should be able to achieve even steeper filter responses. Here is a list of the processor time that I measured for different FFT/iFFT sizes in microseconds:
point FFT/iFFT
To be able to process audio data in realtime at a sample rate of 44118sps, we have 2900 microseconds available for 128 samples, 5800usec for 256 samples etc.
That means this filtering technique needs only about 16% of the processor time to achieve this filtering! And it is the same processor load regardless if I use a 256point FFT/iFFT (equivalent to 129tap FIR filter) or a 4096 point FFT/iFFT (equivalent to a 2049tap FIR filter!!! which really is a brickwall filter . . .).
However, my favourite Filter coefficient program (Iowa Hills FIR Filter designer) only calculates coefficients for a FIR filter of up to 512 taps. I haven´t got a copy of MATLAB, but I have Octave (which I have not used much).
Has anybody got a hint how to calulate FIR filter coefficients with OCTAVE for filter larger than 512 taps? I would really like to push the filtering to the limit, just to try what is possible with the Teensy. [BUT: Maximum number of taps for the FIR filter is FFT_length / 2 +1]
Here is the script for Fast Convolution Filtering (STEREO, because finally I need it to treat both, I & Q):
(It runs ONLY on Teensy 3.5/3.6 AND when using the new version of the CMSIS library, which is really easy to achieve, see the code for the thread link where this is explained.)
Filter_coeffs.h
- perform FFT
point FFT/iFFT
FFT / iFFT points | audio samples processed | Time for processing in usec |
256 | 128 | 472 |
512 | 256 | 839 |
1024 | 512 | 1966 |
2048 | 1024 | 4214 |
4096 | 2048 | 7574 |
* (c) Frank DD4WH 2016_11_23
* FFT Fast Convolution = Digital Convolution
* in floating point 32bit
* tested on Teensy 3.6
* audio queue optimized by Pete El Supremo 2016_10_27, thanks Pete!
* final hint on the implementation came from Alberto I2PHD, thanks for that!
* audio processing in float32_t with the NEW ARM CMSIS lib (see https://forum.pjrc.com/threads/38325-Excellent-results-with-Floating-Point-FFT-IFFT-Processing-and-Teensy-3-6?p=119797&viewfull=1#post119797),
* and see here: https://forum.pjrc.com/threads/38325-Excellent-results-with-Floating-Point-FFT-IFFT-Processing-and-Teensy-3-6?p=120177&viewfull=1#post120177
* MIT license
#include <Metro.h>
#include "font_Arial.h"
#include <ILI9341_t3.h>
#include <arm_math.h>
#include <arm_const_structs.h>
#include "Filter_coeffs.h"
#define BACKLIGHT_PIN 0
#define TFT_DC 20
#define TFT_CS 21
#define TFT_RST 32 // 255 = unused. connect to 3.3V
#define TFT_MOSI 7
#define TFT_SCLK 14
#define TFT_MISO 12
ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
Metro five_sec=Metro(2000); // Set up a Metro
// this audio comes from the codec by I2S2
AudioInputI2S i2s_in;
AudioRecordQueue Q_in_L;
AudioRecordQueue Q_in_R;
AudioPlayQueue Q_out_L;
AudioPlayQueue Q_out_R;
AudioAnalyzeFFT256 myFFT;
AudioOutputI2S i2s_out;
AudioConnection patchCord1(i2s_in, 0, Q_in_L, 0);
AudioConnection patchCord2(i2s_in, 1, Q_in_R, 0);
AudioConnection patchCord5(Q_out_R,0,myFFT,0);
AudioConnection patchCord3(Q_out_L, 0, i2s_out, 1);
AudioConnection patchCord4(Q_out_R, 0, i2s_out, 0);
AudioControlSGTL5000 sgtl5000_1; //xy=265.212
int idx_t = 0;
int idx = 0;
int64_t sum;
float32_t mean;
int n_L;
int n_R;
long int n_clear;
int peak[512];
int barm[512];
ulong samp_ptr = 0;
// bool FFT_state = false;
#define BUFFER_SIZE 128
// complex FFT with the new library CMSIS V4.5
const static arm_cfft_instance_f32 *S;
* Define your FFT_size HERE, possible values below
* change filter coeffs accordingly
//const uint32_t FFT_length = 256;
//const uint32_t FFT_length = 512;
const uint32_t FFT_length = 1024;
//const uint32_t FFT_length = 2048;
//const uint32_t FFT_length = 4096;
const uint32_t N_BLOCKS = FFT_length / 2 / BUFFER_SIZE;
float32_t float_buffer_L [BUFFER_SIZE * N_BLOCKS];
float32_t float_buffer_R [BUFFER_SIZE * N_BLOCKS];
float32_t FFT_buffer [FFT_length * 2] __attribute__ ((aligned (4)));
float32_t last_sample_buffer_L [BUFFER_SIZE * N_BLOCKS];
float32_t last_sample_buffer_R [BUFFER_SIZE * N_BLOCKS];
// complex iFFT with the new library CMSIS V4.5
const static arm_cfft_instance_f32 *iS;
float32_t iFFT_buffer [FFT_length * 2] __attribute__ ((aligned (4)));
// FFT instance for direct calculation of the filter mask
// from the impulse response of the FIR - the coefficients
const static arm_cfft_instance_f32 *maskS;
float32_t FIR_filter_mask [FFT_length * 2] __attribute__ ((aligned (4)));
int8_t first_block = 1;
uint32_t i = 0;
// Audio connections require memory. and the record queue
// for the large FFT sizes we need a lot of buffers
AudioMemory(60);
// Enable the audio shield. select input. and enable output
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
sgtl5000_1.adcHighPassFilterDisable(); // does not help too much!
pinMode( BACKLIGHT_PIN, OUTPUT );
analogWrite( BACKLIGHT_PIN, 1023 );
tft.begin();
tft.setRotation( 3 );
tft.setCursor(10, 1);
tft.setTextSize(2);
tft.setTextColor(ILI9341_WHITE);
tft.setFont(Arial_14);
tft.print("Floating point audio processing");
* init complex FFT
switch (FFT_length) {
case 16:
S = &arm_cfft_sR_f32_len16;
iS = &arm_cfft_sR_f32_len16;
case 32:
S = &arm_cfft_sR_f32_len32;
iS = &arm_cfft_sR_f32_len32;
case 64:
S = &arm_cfft_sR_f32_len64;
iS = &arm_cfft_sR_f32_len64;
case 128:
S = &arm_cfft_sR_f32_len128;
iS = &arm_cfft_sR_f32_len128;
case 256:
S = &arm_cfft_sR_f32_len256;
iS = &arm_cfft_sR_f32_len256;
maskS = &arm_cfft_sR_f32_len256;
case 512:
S = &arm_cfft_sR_f32_len512;
iS = &arm_cfft_sR_f32_len512;
maskS = &arm_cfft_sR_f32_len512;
case 1024:
S = &arm_cfft_sR_f32_len1024;
iS = &arm_cfft_sR_f32_len1024;
maskS = &arm_cfft_sR_f32_len1024;
case 2048:
S = &arm_cfft_sR_f32_len2048;
iS = &arm_cfft_sR_f32_len2048;
maskS = &arm_cfft_sR_f32_len2048;
case 4096:
S = &arm_cfft_sR_f32_len4096;
iS = &arm_cfft_sR_f32_len4096;
maskS = &arm_cfft_sR_f32_len4096;
* Calculate the FFT of the FIR filter coefficients once to produce the FIR filter mask
// the FIR has (FFT_length / 2) + 1 taps = coefficients, so we have to add (FFT_length / 2) -1 zeros before the FFT
// in order to produce a FFT_length point input buffer for the FFT
// copy coefficients into real values of first part of buffer, rest is zero
for (i = 0; i < (FFT_length / 2) + 1; i+=2)
FIR_filter_mask[i * 2] = FIR1 [i];
FIR_filter_mask[i * 2 + 1] = 0.0;
// FFT of FIR_filter_mask
// perform FFT (in-place), needs only to be done once (or every time the filter coeffs change)
arm_cfft_f32(maskS, FIR_filter_mask, 0, 1);
Serial.print("Filter mask FFT done ");
///////////////////////////////////////////////////////////////77
// PASS-THRU only for TESTING
// hmmm, unclear, whether [1,1] or [1,0] or [0,1] are pass-thru filter-mask-multipliers??
// empirically, [1,0] sounds most natural = pass-thru
for(i = 0; i < FFT_length * 2; i+=2)
FIR_filter_mask [i] = 1.0; // real
FIR_filter_mask [i + 1] = 0.0; // imaginary
* begin to queue the audio from the audio library
Q_in_L.begin();
Q_in_R.begin();
} // END SETUP
int16_t *sp_L;
int16_t *sp_R;
elapsedMicros usec = 0;
* Get samples from queue buffers
// we have to ensure that we have enough audio samples: we need
// N_BLOCKS = fft_length / 2 / BUFFER_SIZE
// FFT1024 point --> n_blocks = 1024 / 2 / 128 = 4
// when these buffers are available, read them in and perform
// the FFT - cmplx-mult - iFFT
// are there at least N_BLOCKS buffers in each channel available ?
if (Q_in_L.available() > N_BLOCKS && Q_in_R.available() > N_BLOCKS)
// get audio samples from the audio buffers and convert them to float
for (i = 0; i < N_BLOCKS; i++)
sp_L = Q_in_L.readBuffer();
sp_R = Q_in_R.readBuffer();
// convert to float one buffer_size
arm_q15_to_float (sp_L, &float_buffer_L[BUFFER_SIZE * i], BUFFER_SIZE); // convert int_buffer to float 32bit
arm_q15_to_float (sp_R, &float_buffer_R[BUFFER_SIZE * i], BUFFER_SIZE); // convert int_buffer to float 32bit
Q_in_L.freeBuffer();
Q_in_R.freeBuffer();
// this is supposed to prevent overfilled queue buffers
// rarely the Teensy audio queue gets a hickup
// in that case this keeps the whole audio chain running smoothly
if (Q_in_L.available() > N_BLOCKS * 4 || Q_in_R.available() > N_BLOCKS * 4)
Q_in_L.clear();
Q_in_R.clear();
n_clear ++; // just for debugging to check how often this occurs [about once in an hour of playing . . .]
* Digital convolution
// basis for this was Lyons, R. (2011): Understanding Digital Processing.
// "Fast FIR Filtering using the FFT", pages 688 - 694
// numbers for the steps taken from that source
// Method used here: overlap-and-save
// 4.) ONLY FOR the VERY FIRST FFT: fill first samples with zeros
if(first_block) // fill real & imaginaries with zeros for the first BLOCKSIZE samples
for(i = 0; i < BUFFER_SIZE * 2 * N_BLOCKS; i++)
FFT_buffer[i] = 0.0;
first_block = 0;
// HERE IT STARTS for all other instances
// 6 a.) fill FFT_buffer with last events audio samples
for(i = 0; i < BUFFER_SIZE * N_BLOCKS; i++)
FFT_buffer[i * 2] = last_sample_buffer_L[i]; // real
FFT_buffer[i * 2 + 1] = last_sample_buffer_R[i]; // imaginary
// copy recent samples to last_sample_buffer for next time!
arm_copy_f32(float_buffer_L, last_sample_buffer_L, BUFFER_SIZE * N_BLOCKS);
arm_copy_f32(float_buffer_R, last_sample_buffer_R, BUFFER_SIZE * N_BLOCKS);
// 6. b) now fill audio samples into FFT_buffer (left channel: re, right channel: im)
FFT_buffer[FFT_length + i * 2] = float_buffer_L[i]; // real
FFT_buffer[FFT_length + i * 2 + 1] = float_buffer_R[i]; // imaginary
// perform complex FFT
// calculation is performed in-place the FFT_buffer [re, im, re, im, re, im . . .]
arm_cfft_f32(S, FFT_buffer, 0, 1);
// complex multiply with filter mask
arm_cmplx_mult_cmplx_f32 (FFT_buffer, FIR_filter_mask, iFFT_buffer, FFT_length);
/* // just for testing: pass-thru !
for(i = 0; i < FFT_length * 2; i++)
iFFT_buffer[i] = FFT_buffer[i];
// perform iFFT (in-place)
arm_cfft_f32(iS, iFFT_buffer, 1, 1);
// our desired output is the real part (left channel) AND the imaginary part (right channel) of the second half of the FFT_buffer
float_buffer_L[i] = iFFT_buffer[FFT_length + (i * 2)];
float_buffer_R[i] = iFFT_buffer[FFT_length + (i * 2) + 1];
// float_buffer_L[i] = iFFT_buffer[(i * 2)];
// float_buffer_R[i] = iFFT_buffer[(i * 2) + 1];
sp_L = Q_out_L.getBuffer();
sp_R = Q_out_R.getBuffer();
arm_float_to_q15 (&float_buffer_L[BUFFER_SIZE * i], sp_L, BUFFER_SIZE);
arm_float_to_q15 (&float_buffer_R[BUFFER_SIZE * i], sp_R, BUFFER_SIZE);
Q_out_L.playBuffer(); // play it !
Q_out_R.playBuffer(); // play it !
* PRINT ROUTINE FOR ELAPSED MICROSECONDS
sum = sum + usec;
idx_t++;
if (idx_t > 1000) {
tft.fillRect(240,50,90,20,ILI9341_BLACK);
tft.setCursor(240, 50);
mean = sum / idx_t;
tft.print (mean);
Serial.print (mean);
Serial.print (" microsec for 2 stereo blocks ");
Serial.print (" n_clear ");
Serial.println(n_clear);
idx_t = 0;
sum = 0;
* PRINT ROUTINE FOR AUDIO LIBRARY PROCESSOR AND MEMORY USAGE
if (five_sec.check() == 1)
Serial.print("Proc = ");
Serial.print(AudioProcessorUsage());
Serial.print(" (");
Serial.print(AudioProcessorUsageMax());
Serial.print("), Mem = ");
Serial.print(AudioMemoryUsage());
Serial.print(" (");
Serial.print(AudioMemoryUsageMax());
Serial.println(")");
/* tft.fillRect(100,120,200,80,ILI9341_BLACK);
tft.setCursor(10, 120);
tft.setTextSize(2);
tft.print ("Proc = ");
tft.setCursor(100, 120);
tft.print (AudioProcessorUsage());
tft.setCursor(180, 120);
tft.print (AudioProcessorUsageMax());
tft.setCursor(10, 150);
tft.print ("Mem = ");
tft.setCursor(100, 150);
tft.print (AudioMemoryUsage());
tft.setCursor(180, 150);
tft.print (AudioMemoryUsageMax());
AudioProcessorUsageMaxReset();
AudioMemoryUsageMaxReset();
spectrum();
void spectrum() { // spectrum analyser code by rheslip - modified
if (myFFT.available()) {
int scale;
scale = 2;
for (int16_t x=2; x < 100; x+=2) {
int bar = (abs(myFFT.output[x]) * scale);
if (bar >180) bar=180;
// this is a very simple IIR filter to smooth the reaction of the bars
bar = 0.2 * bar + 0.8 * barm[x];
if (bar > peak[x]) peak[x]=bar;
// tft.drawFastVLine(x, 210-bar,bar, ILI9341_PURPLE);
tft.drawFastVLine(x*2+10, 210-bar,bar, ILI9341_PINK);
tft.drawFastVLine(x*2+10, 20, 210-bar-20, ILI9341_BLACK);
tft.drawPixel(x*2+10,209-peak[x], ILI9341_YELLOW);
if(peak[x]>0) peak[x]-=1;
barm[x] = bar;
} //end if
} // end void spectrum
Filter_coeffs.h
// LOWPASS, Fs = 44118sps, Fc = 4.65kHz, Raised Cos, Kaiser Window, KaiserBeta = 6.6, 513 taps, 80dB stopband attenuation
float32_t FIR1 [513] = {6.871453131273526080E-6, 3.445208686058514050E-6,-2.267576792967956220E-6,-7.919106902676396050E-6,-10.78330803716723630E-6,-9.023454130073321980E-6,-2.727716424898928960E-6, 5.830806219449149450E-6, 12.95263921038207760E-6, 15.07004322439275690E-6, 10.46645638312625340E-6, 352.9895673672170920E-9,-11.30136043391740590E-6,-19.27117070103877340E-6,-19.36773512201770590E-6,-10.53810844057831630E-6, 4.246565645390340650E-6, 18.88131923910259150E-6, 26.59255574530914860E-6, 23.00867797048227100E-6, 8.469591168820601370E-6,-11.59072016534943120E-6,-28.58389907785851850E-6,-34.38412012066380900E-6,-25.12542511874780260E-6,-3.438442404986254970E-6, 22.07369790699343070E-6, 40.16548142864498060E-6, 41.83631164663676570E-6, 24.68029431209209430E-6,-5.356921369655561090E-6,-35.87676946745603600E-6,-53.06496452714677050E-6,-47.85805435255078780E-6,-20.52159581641252470E-6, 18.60301812321676710E-6, 52.87758953002247610E-6, 66.35847481556579910E-6, 51.09982205584921640E-6, 11.46773656911063460E-6,-36.76187456915871370E-6,-72.56446574739206310E-6,-78.73777304608509550E-6,-50.00909485652042010E-6, 3.582085651938113460E-6, 59.95323217943641220E-6, 93.96507511644892930E-6, 88.52025560782911380E-6, 42.92080484068521430E-6,-25.51467591852549430E-6,-87.83752761919105010E-6,-115.5998385779402470E-6,-93.69719863854982120E-6,-28.18268580960215530E-6, 54.85414729897830450E-6, 119.5106512276131810E-6, 135.4700545070515430E-6, 92.02479796172386270E-6, 4.312256142316567060E-6,-91.60761750746233640E-6,-153.4226992285940700E-6,-151.0898538008062530E-6,-81.15967262677578730E-6, 29.82131007206200830E-6, 135.1176733260618620E-6, 187.3332849135738910E-6, 159.5690163151246280E-6, 58.83695341793738720E-6,-74.80066892174815510E-6,-183.9358373761230610E-6,-218.3152940660573900E-6,-157.7507032381709560E-6,-23.08507710114890090E-6, 130.4626205385996510E-6, 235.7322319962519830E-6, 242.8171610526223670E-6, 142.4043234780449440E-6,-27.53277196456661000E-6,-195.7153542023962700E-6,-287.2564798196244170E-6,-256.7907900508363350E-6,-110.4692644381636340E-6, 93.66466053090076120E-6, 268.3884569597703380E-6, 334.3634604657972890E-6, 255.8882334451354270E-6, 59.34036139065401730E-6,-174.9209539475816650E-6,-345.1340708370582890E-6,-372.1147967561435620E-6,-235.7253504313817700E-6, 12.81889441169864520E-6, 269.6506718361622460E-6, 421.3967525005456310E-6, 394.9629158680992300E-6, 192.2051845858361500E-6,-106.7539047042511700E-6,-374.7648593146286660E-6,-491.4672567532300600E-6,-397.0193777286223170E-6,-121.8880852669094990E-6, 221.8094711193295150E-6, 485.6286529121493340E-6, 548.6316252709169700E-6, 372.4031540954385950E-6, 22.39008286279281280E-6,-355.6579784851013530E-6,-596.0420324019763710E-6,-585.4217320307434420E-6,-315.6580489304485010E-6, 107.2138253653659630E-6, 504.0909578730086200E-6, 698.3258335996976030E-6, 593.9670621475752340E-6, 222.2219282155563180E-6,-266.0085519273678190E-6,-660.8989251159424610E-6,-783.5245170801475750E-6,-566.4403476402001160E-6,-88.92438393084313480E-6, 450.9092143633432100E-6, 817.8616459956699600E-6, 841.7306498093511210E-6, 495.5822225788455740E-6,-85.51557986657856250E-6,-656.4123945110995920E-6,-964.8662924347729590E-6,-862.5284067179455860E-6,-375.2828393541101950E-6, 300.0237739563860370E-6, 874.4560667028388250E-6, 0.001090164472359596, 835.5451098502492190E-6, 201.1919988203605380E-6,-550.7704621765309410E-6,-0.001094411832878682,-0.001180771142940600,-751.0914695446640510E-6, 28.67561545477996530E-6, 830.8681654758361220E-6, 0.001303226870386641, 0.001222999403169315, 600.8634212405887640E-6,-313.3764878151378070E-6,-0.001130197118226046,-0.001485724826421536,-0.001203115683866600,-378.6719410188165970E-6, 648.5525101941651660E-6, 0.001435382003559500, 0.001625065164448771, 0.001108090582798773, 81.16264269073093370E-6,-0.001026057991404070,-0.001729935230903342,-0.001703349699989170,-926.4122571275300970E-6, 291.5150652380575020E-6, 0.001433728599806572, 0.001994571378751822, 0.001702353869617076, 648.9226260857874420E-6,-735.1283955788730960E-6,-0.001855312749965784,-0.002207684835071205,-0.001604349313729314,-269.6323687549075880E-6, 0.001240905613202777, 0.002270573976250003, 0.002345968474751946, 0.001392974246376057,-213.5305137380872220E-6,-0.001795230168128267,-0.002655557437678700,-0.002385135660152189,-0.001054099336284485, 798.0813615715164820E-6, 0.002379496857325687, 0.002982994513348000, 0.002300690858936965, 576.6296833914587980E-6,-0.001476484847955344,-0.002970123506655021,-0.003222795508393209,-0.002068674975946207, 46.82224341581670050E-6, 0.002235830760167846, 0.003538685683553156, 0.003342549504198230, 0.001666287960147844,-819.4630819009767040E-6,-0.003057686303493348,-0.004052105369877611,-0.003307907326939082,-0.001072258550084767, 0.001740121893785564, 0.003918105633284077, 0.004472770064543100, 0.003082657772322536, 266.7788691729235780E-6,-0.002803421498178969,-0.004787738231008889,-0.004758370868813245,-0.002628195722905225, 769.2719925567854490E-6, 0.004000439690934184, 0.005631914927179969, 0.004861092447298931, 0.001901873229013341,-0.002056274728030315,-0.005320052262134744,-0.006410479055585143,-0.004725485495793865,-853.3044223474688580E-6, 0.003619832446757073, 0.006751311278615875, 0.007076909840564227, 0.004283710631210142,-583.2260378596162130E-6,-0.005498466619796607,-0.008287597049579185,-0.007575796990001497,-0.003445350620907208, 0.002504300176841653, 0.007758897336365033, 0.009934258644397245, 0.007836513216583964, 0.002075147714846438,-0.005070705639957433,-0.010528539554898025,-0.011724185678847697,-0.007757512119751574, 59.16993475261030260E-6, 0.008585873029180020, 0.014072760273724966, 0.013754502383653571, 0.007164384929012854,-0.003425237154328352,-0.013709030445404981,-0.019011254332136619,-0.016291757581157761,-0.005678473688921063, 0.009173391211196489, 0.022179432200976727, 0.027096212934009833, 0.020173702289179009, 0.002167007193506445,-0.021164172207011101,-0.040435286753901352,-0.045576331708279419,-0.029395106851093578, 0.009478483248810876, 0.065374553209471109, 0.126649403304741365, 0.178813587395760448, 0.208766865575148675, 0.208766865575148675, 0.178813587395760448, 0.126649403304741365, 0.065374553209471109, 0.009478483248810876,-0.029395106851093578,-0.045576331708279419,-0.040435286753901352,-0.021164172207011101, 0.002167007193506445, 0.020173702289179009, 0.027096212934009833, 0.022179432200976727, 0.009173391211196489,-0.005678473688921063,-0.016291757581157761,-0.019011254332136619,-0.013709030445404981,-0.003425237154328352, 0.007164384929012854, 0.013754502383653571, 0.014072760273724966, 0.008585873029180020, 59.16993475261030260E-6,-0.007757512119751574,-0.011724185678847697,-0.010528539554898025,-0.005070705639957433, 0.002075147714846438, 0.007836513216583964, 0.009934258644397245, 0.007758897336365033, 0.002504300176841653,-0.003445350620907208,-0.007575796990001497,-0.008287597049579185,-0.005498466619796607,-583.2260378596162130E-6, 0.004283710631210142, 0.007076909840564227, 0.006751311278615875, 0.003619832446757073,-853.3044223474688580E-6,-0.004725485495793865,-0.006410479055585143,-0.005320052262134744,-0.002056274728030315, 0.001901873229013341, 0.004861092447298931, 0.005631914927179969, 0.004000439690934184, 769.2719925567854490E-6,-0.002628195722905225,-0.004758370868813245,-0.004787738231008889,-0.002803421498178969, 266.7788691729235780E-6, 0.003082657772322536, 0.004472770064543100, 0.003918105633284077, 0.001740121893785564,-0.001072258550084767,-0.003307907326939082,-0.004052105369877611,-0.003057686303493348,-819.4630819009767040E-6, 0.001666287960147844, 0.003342549504198230, 0.003538685683553156, 0.002235830760167846, 46.82224341581670050E-6,-0.002068674975946207,-0.003222795508393209,-0.002970123506655021,-0.001476484847955344, 576.6296833914587980E-6, 0.002300690858936965, 0.002982994513348000, 0.002379496857325687, 798.0813615715164820E-6,-0.001054099336284485,-0.002385135660152189,-0.002655557437678700,-0.001795230168128267,-213.5305137380872220E-6, 0.001392974246376057, 0.002345968474751946, 0.002270573976250003, 0.001240905613202777,-269.6323687549075880E-6,-0.001604349313729314,-0.002207684835071205,-0.001855312749965784,-735.1283955788730960E-6, 648.9226260857874420E-6, 0.001702353869617076, 0.001994571378751822, 0.001433728599806572, 291.5150652380575020E-6,-926.4122571275300970E-6,-0.001703349699989170,-0.001729935230903342,-0.001026057991404070, 81.16264269073093370E-6, 0.001108090582798773, 0.001625065164448771, 0.001435382003559500, 648.5525101941651660E-6,-378.6719410188165970E-6,-0.001203115683866600,-0.001485724826421536,-0.001130197118226046,-313.3764878151378070E-6, 600.8634212405887640E-6, 0.001222999403169315, 0.001303226870386641, 830.8681654758361220E-6, 28.67561545477996530E-6,-751.0914695446640510E-6,-0.001180771142940600,-0.001094411832878682,-550.7704621765309410E-6, 201.1919988203605380E-6, 835.5451098502492190E-6, 0.001090164472359596, 874.4560667028388250E-6, 300.0237739563860370E-6,-375.2828393541101950E-6,-862.5284067179455860E-6,-964.8662924347729590E-6,-656.4123945110995920E-6,-85.51557986657856250E-6, 495.5822225788455740E-6, 841.7306498093511210E-6, 817.8616459956699600E-6, 450.9092143633432100E-6,-88.92438393084313480E-6,-566.4403476402001160E-6,-783.5245170801475750E-6,-660.8989251159424610E-6,-266.0085519273678190E-6, 222.2219282155563180E-6, 593.9670621475752340E-6, 698.3258335996976030E-6, 504.0909578730086200E-6, 107.2138253653659630E-6,-315.6580489304485010E-6,-585.4217320307434420E-6,-596.0420324019763710E-6,-355.6579784851013530E-6, 22.39008286279281280E-6, 372.4031540954385950E-6, 548.6316252709169700E-6, 485.6286529121493340E-6, 221.8094711193295150E-6,-121.8880852669094990E-6,-397.0193777286223170E-6,-491.4672567532300600E-6,-374.7648593146286660E-6,-106.7539047042511700E-6, 192.2051845858361500E-6, 394.9629158680992300E-6, 421.3967525005456310E-6, 269.6506718361622460E-6, 12.81889441169864520E-6,-235.7253504313817700E-6,-372.1147967561435620E-6,-345.1340708370582890E-6,-174.9209539475816650E-6, 59.34036139065401730E-6, 255.8882334451354270E-6, 334.3634604657972890E-6, 268.3884569597703380E-6, 93.66466053090076120E-6,-110.4692644381636340E-6,-256.7907900508363350E-6,-287.2564798196244170E-6,-195.7153542023962700E-6,-27.53277196456661000E-6, 142.4043234780449440E-6, 242.8171610526223670E-6, 235.7322319962519830E-6, 130.4626205385996510E-6,-23.08507710114890090E-6,-157.7507032381709560E-6,-218.3152940660573900E-6,-183.9358373761230610E-6,-74.80066892174815510E-6, 58.83695341793738720E-6, 159.5690163151246280E-6, 187.3332849135738910E-6, 135.1176733260618620E-6, 29.82131007206200830E-6,-81.15967262677578730E-6,-151.0898538008062530E-6,-153.4226992285940700E-6,-91.60761750746233640E-6, 4.312256142316567060E-6, 92.02479796172386270E-6, 135.4700545070515430E-6, 119.5106512276131810E-6, 54.85414729897830450E-6,-28.18268580960215530E-6,-93.69719863854982120E-6,-115.5998385779402470E-6,-87.83752761919105010E-6,-25.51467591852549430E-6, 42.92080484068521430E-6, 88.52025560782911380E-6, 93.96507511644892930E-6, 59.95323217943641220E-6, 3.582085651938113460E-6,-50.00909485652042010E-6,-78.73777304608509550E-6,-72.56446574739206310E-6,-36.76187456915871370E-6, 11.46773656911063460E-6, 51.09982205584921640E-6, 66.35847481556579910E-6, 52.87758953002247610E-6, 18.60301812321676710E-6,-20.52159581641252470E-6,-47.85805435255078780E-6,-53.06496452714677050E-6,-35.87676946745603600E-6,-5.356921369655561090E-6, 24.68029431209209430E-6, 41.83631164663676570E-6, 40.16548142864498060E-6, 22.07369790699343070E-6,-3.438442404986254970E-6,-25.12542511874780260E-6,-34.38412012066380900E-6,-28.58389907785851850E-6,-11.59072016534943120E-6, 8.469591168820601370E-6, 23.00867797048227100E-6, 26.59255574530914860E-6, 18.88131923910259150E-6, 4.246565645390340650E-6,-10.53810844057831630E-6,-19.36773512201770590E-6,-19.27117070103877340E-6,-11.30136043391740590E-6, 352.9895673672170920E-9, 10.46645638312625340E-6, 15.07004322439275690E-6, 12.95263921038207760E-6, 5.830806219449149450E-6,-2.727716424898928960E-6,-9.023454130073321980E-6,-10.78330803716723630E-6,-7.919106902676396050E-6,-2.267576792967956220E-6, 3.445208686058514050E-6, 6.871453131273526080E-6, 0.0f};
// LOWPASS, Fs = 44118sps, Fc = 4.4kHz, Kaiser Window, KaiserBeta = 7.6, 257 taps, 80dB stopband attenuation
// Iowa Hills FIR Filter Designer
//float32_t FIR1 [257] = { 7.328762614559201970E-6, 1.699530910501760860E-6,-7.475206154865301040E-6,-16.58864707313134800E-6,-20.71725038234058400E-6,-15.89322634590453380E-6,-1.546623827977725350E-6, 18.15229207888054930E-6, 35.05906151777181630E-6, 40.08343621023521310E-6, 27.49895263826912740E-6,-1.338406569559799310E-6,-36.87236974177827160E-6,-63.99381985769387170E-6,-68.00815642169322930E-6,-41.74761656253530620E-6, 9.365463746343056780E-6, 67.16686132592890600E-6, 106.5897713856251840E-6, 105.9269752259186110E-6, 57.54588018547838150E-6,-25.87661803103766900E-6,-113.3408031635732270E-6,-166.3106155289682140E-6,-154.8903042568662730E-6,-72.89559803429361300E-6, 55.27165709883256990E-6, 180.4567630373264820E-6, 246.7312913678270830E-6, 215.3307374164887450E-6, 84.68164945983102140E-6,-103.1082426170837890E-6,-274.2770110461190140E-6,-351.3425059712318440E-6,-286.8093405666396620E-6,-88.46579759213780390E-6, 176.1727105475958690E-6, 401.1666294078363540E-6, 483.3235639121454600E-6, 367.7504095060265290E-6, 78.29232257440359890E-6,-282.5230317340425470E-6,-567.9662444819534810E-6,-645.2953634062116630E-6,-455.1735661234249620E-6,-46.50593910926322390E-6, 431.5134058566782190E-6, 781.8503636979066870E-6, 839.0685661736512200E-6, 544.4290076521535870E-6,-16.42621160044870620E-6,-633.8211595687887440E-6,-0.001050196222342095,-0.001065404193656754,-628.9352480453173940E-6, 122.1103596179346910E-6, 901.5124886093840360E-6, 0.001380499415738101, 0.001323804968983299, 699.9072083139226380E-6,-284.4827416383485570E-6,-0.001248206918152512,-0.001780388256273617,-0.001612355412927966,-746.0432374336776320E-6, 520.2037805257599530E-6, 0.001689436729121183, 0.002257812645409072, 0.001927626922710254, 753.1072482572329820E-6,-849.3225009519289870E-6,-0.002243358362155522,-0.002821523408162229,-0.002264660848988334,-703.2857940274367370E-6, 0.001296442617129755, 0.002932081798002042, 0.003482031752368026, 0.002617038102056222, 574.0963347876687520E-6,-0.001892807564106649,-0.003784093355115586,-0.004253383954450271,-0.002977038347256079,-336.4193933759605670E-6, 0.002680096306067828, 0.004838678364053398, 0.005156393049966772, 0.003335885777371288,-49.20399049568850810E-6,-0.003717534447192724,-0.006154204345667625,-0.006224663422812675,-0.003684072232652828, 639.8623649234300500E-6, 0.005095841740168318, 0.007824422768965554, 0.007516452924108570, 0.004011742566743573,-0.001525533556200337,-0.006966531592685411,-0.010013078932329953,-0.009140093724559383,-0.004309122109956730, 0.002863960302125023, 0.009609845644003705, 0.013035802144374114, 0.011315405143426487, 0.004566962290015101,-0.004971252790332698,-0.013616299025791751,-0.017586400829978907,-0.014549640096248489,-0.004776978274764704, 0.008607429932232010, 0.020487455293014531, 0.025528436622625647, 0.020292174349273998, 0.004932252120862281,-0.016214726742582217,-0.035489595022107710,-0.044077991770366636,-0.034860358428049180,-0.005027576424117068, 0.042444580267464491, 0.099042763400386813, 0.152722135412216936, 0.191126786440214774, 0.205059716796875013, 0.191126786440214774, 0.152722135412216936, 0.099042763400386813, 0.042444580267464491,-0.005027576424117068,-0.034860358428049180,-0.044077991770366636,-0.035489595022107710,-0.016214726742582217, 0.004932252120862281, 0.020292174349273998, 0.025528436622625647, 0.020487455293014531, 0.008607429932232010,-0.004776978274764704,-0.014549640096248489,-0.017586400829978907,-0.013616299025791751,-0.004971252790332698, 0.004566962290015101, 0.011315405143426487, 0.013035802144374114, 0.009609845644003705, 0.002863960302125023,-0.004309122109956730,-0.009140093724559383,-0.010013078932329953,-0.006966531592685411,-0.001525533556200337, 0.004011742566743573, 0.007516452924108570, 0.007824422768965554, 0.005095841740168318, 639.8623649234300500E-6,-0.003684072232652828,-0.006224663422812675,-0.006154204345667625,-0.003717534447192724,-49.20399049568850810E-6, 0.003335885777371288, 0.005156393049966772, 0.004838678364053398, 0.002680096306067828,-336.4193933759605670E-6,-0.002977038347256079,-0.004253383954450271,-0.003784093355115586,-0.001892807564106649, 574.0963347876687520E-6, 0.002617038102056222, 0.003482031752368026, 0.002932081798002042, 0.001296442617129755,-703.2857940274367370E-6,-0.002264660848988334,-0.002821523408162229,-0.002243358362155522,-849.3225009519289870E-6, 753.1072482572329820E-6, 0.001927626922710254, 0.002257812645409072, 0.001689436729121183, 520.2037805257599530E-6,-746.0432374336776320E-6,-0.001612355412927966,-0.001780388256273617,-0.001248206918152512,-284.4827416383485570E-6, 699.9072083139226380E-6, 0.001323804968983299, 0.001380499415738101, 901.5124886093840360E-6, 122.1103596179346910E-6,-628.9352480453173940E-6,-0.001065404193656754,-0.001050196222342095,-633.8211595687887440E-6,-16.42621160044870620E-6, 544.4290076521535870E-6, 839.0685661736512200E-6, 781.8503636979066870E-6, 431.5134058566782190E-6,-46.50593910926322390E-6,-455.1735661234249620E-6,-645.2953634062116630E-6,-567.9662444819534810E-6,-282.5230317340425470E-6, 78.29232257440359890E-6, 367.7504095060265290E-6, 483.3235639121454600E-6, 401.1666294078363540E-6, 176.1727105475958690E-6,-88.46579759213780390E-6,-286.8093405666396620E-6,-351.3425059712318440E-6,-274.2770110461190140E-6,-103.1082426170837890E-6, 84.68164945983102140E-6, 215.3307374164887450E-6, 246.7312913678270830E-6, 180.4567630373264820E-6, 55.27165709883256990E-6,-72.89559803429361300E-6,-154.8903042568662730E-6,-166.3106155289682140E-6,-113.3408031635732270E-6,-25.87661803103766900E-6, 57.54588018547838150E-6, 105.9269752259186110E-6, 106.5897713856251840E-6, 67.16686132592890600E-6, 9.365463746343056780E-6,-41.74761656253530620E-6,-68.00815642169322930E-6,-63.99381985769387170E-6,-36.87236974177827160E-6,-1.338406569559799310E-6, 27.49895263826912740E-6, 40.08343621023521310E-6, 35.05906151777181630E-6, 18.15229207888054930E-6,-1.546623827977725350E-6,-15.89322634590453380E-6,-20.71725038234058400E-6,-16.58864707313134800E-6,-7.475206154865301040E-6, 1.699530910501760860E-6, 7.328762614559201970E-6};
// dto., LOWPASS, but Fstop = 2.4kHz
//float32_t FIR1 [257] = { 9.478463659369410270E-6, 12.70714431137183450E-6, 14.68103429127791950E-6, 14.49479956796871960E-6, 11.41776493385259000E-6, 5.089908387289337810E-6,-4.309783664626112730E-6,-15.96101513067834610E-6,-28.39919448816325340E-6,-39.63275865624029850E-6,-47.38350090008037800E-6,-49.43060901359754670E-6,-44.01681098337634520E-6,-30.25633471196833570E-6,-8.473212210829382580E-6, 19.60204134783623790E-6, 50.83739644240948510E-6, 80.94167884055040930E-6, 104.9457640360280950E-6, 117.8839462069065290E-6, 115.5969258699817460E-6, 95.54485687295468210E-6, 57.49932403509221500E-6, 3.982199741563685610E-6,-59.66009953683904850E-6,-125.6166648245185230E-6,-184.4170010490886970E-6,-226.1219357052953000E-6,-241.7718032967744650E-6,-224.9039573656878590E-6,-172.9139623166668120E-6,-88.02747811810078820E-6, 22.32198221733446530E-6, 145.8503861051778760E-6, 266.5624313454762840E-6, 366.6059349745512460E-6, 428.6566860210803040E-6, 438.5445607213444530E-6, 387.7582441874295110E-6, 275.4385174216719180E-6, 109.4984246530900410E-6,-93.40500699602969800E-6,-309.1847879979926570E-6,-508.8861885377647810E-6,-662.2701068971941820E-6,-742.0130864527443460E-6,-727.9819761102048690E-6,-610.9685330377087670E-6,-395.2792265263719860E-6,-99.67553074565914530E-6, 243.6550989706558430E-6, 592.1658834020230420E-6, 897.8352547039144160E-6, 0.001113363272414600, 0.001198931500159666, 0.001128619044471772, 895.5235359829191570E-6, 514.7245801221930610E-6, 23.44875125042007370E-6,-521.8695534083930170E-6,-0.001051525485351555,-0.001490937302885498,-0.001770553565044442,-0.001836027031766926,-0.001657252324891159,-0.001234892469535187,-603.2442372959892510E-6, 171.3004493121681830E-6, 996.3912453261834800E-6, 0.001764023560227131, 0.002363959489187634, 0.002698687062332011, 0.002697985676222414, 0.002331050101614698, 0.001614284387375592, 613.3111436446814650E-6,-561.5863128156847780E-6,-0.001766535064740374,-0.002840704319673461,-0.003626702778115438,-0.003992281005830110,-0.003850494531688887,-0.003175456564540999,-0.002011170915866102,-471.6670509964064310E-6, 0.001268310404008350, 0.002991592296925078, 0.004464144275072356, 0.005465069441068737, 0.005817406532078847, 0.005415676565785563, 0.004246239431140068, 0.002397161183427105, 55.41698862280428270E-6,-0.002509249355730281,-0.004972790417330560,-0.006994933531054830,-0.008262695927882365,-0.008534126892031858,-0.007676629965273138,-0.005694473397163862,-0.002741058487521368, 886.8925359691697850E-6, 0.004774005560083403, 0.008428254993829033, 0.011336501373060305, 0.013027821672442942, 0.013137516758874564, 0.011464091607285475, 0.008011814198809461, 0.003012680456452188,-0.003076353975003412,-0.009602371789443273,-0.015770253315109159,-0.020716778313256249,-0.023598066990079193,-0.023681458694612422,-0.020431966058645848,-0.013583568141761258,-0.003186844116896969, 0.010373305309214511, 0.026393073960790544, 0.043898042774577158, 0.061720528009800393, 0.078598932800310356, 0.093289519444314517, 0.104679489125996686, 0.111889913052296328, 0.114357958984375008, 0.111889913052296328, 0.104679489125996686, 0.093289519444314517, 0.078598932800310356, 0.061720528009800393, 0.043898042774577158, 0.026393073960790544, 0.010373305309214511,-0.003186844116896969,-0.013583568141761258,-0.020431966058645848,-0.023681458694612422,-0.023598066990079193,-0.020716778313256249,-0.015770253315109159,-0.009602371789443273,-0.003076353975003412, 0.003012680456452188, 0.008011814198809461, 0.011464091607285475, 0.013137516758874564, 0.013027821672442942, 0.011336501373060305, 0.008428254993829033, 0.004774005560083403, 886.8925359691697850E-6,-0.002741058487521368,-0.005694473397163862,-0.007676629965273138,-0.008534126892031858,-0.008262695927882365,-0.006994933531054830,-0.004972790417330560,-0.002509249355730281, 55.41698862280428270E-6, 0.002397161183427105, 0.004246239431140068, 0.005415676565785563, 0.005817406532078847, 0.005465069441068737, 0.004464144275072356, 0.002991592296925078, 0.001268310404008350,-471.6670509964064310E-6,-0.002011170915866102,-0.003175456564540999,-0.003850494531688887,-0.003992281005830110,-0.003626702778115438,-0.002840704319673461,-0.001766535064740374,-561.5863128156847780E-6, 613.3111436446814650E-6, 0.001614284387375592, 0.002331050101614698, 0.002697985676222414, 0.002698687062332011, 0.002363959489187634, 0.001764023560227131, 996.3912453261834800E-6, 171.3004493121681830E-6,-603.2442372959892510E-6,-0.001234892469535187,-0.001657252324891159,-0.001836027031766926,-0.001770553565044442,-0.001490937302885498,-0.001051525485351555,-521.8695534083930170E-6, 23.44875125042007370E-6, 514.7245801221930610E-6, 895.5235359829191570E-6, 0.001128619044471772, 0.001198931500159666, 0.001113363272414600, 897.8352547039144160E-6, 592.1658834020230420E-6, 243.6550989706558430E-6,-99.67553074565914530E-6,-395.2792265263719860E-6,-610.9685330377087670E-6,-727.9819761102048690E-6,-742.0130864527443460E-6,-662.2701068971941820E-6,-508.8861885377647810E-6,-309.1847879979926570E-6,-93.40500699602969800E-6, 109.4984246530900410E-6, 275.4385174216719180E-6, 387.7582441874295110E-6, 438.5445607213444530E-6, 428.6566860210803040E-6, 366.6059349745512460E-6, 266.5624313454762840E-6, 145.8503861051778760E-6, 22.32198221733446530E-6,-88.02747811810078820E-6,-172.9139623166668120E-6,-224.9039573656878590E-6,-241.7718032967744650E-6,-226.1219357052953000E-6,-184.4170010490886970E-6,-125.6166648245185230E-6,-59.66009953683904850E-6, 3.982199741563685610E-6, 57.49932403509221500E-6, 95.54485687295468210E-6, 115.5969258699817460E-6, 117.8839462069065290E-6, 104.9457640360280950E-6, 80.94167884055040930E-6, 50.83739644240948510E-6, 19.60204134783623790E-6,-8.473212210829382580E-6,-30.25633471196833570E-6,-44.01681098337634520E-6,-49.43060901359754670E-6,-47.38350090008037800E-6,-39.63275865624029850E-6,-28.39919448816325340E-6,-15.96101513067834610E-6,-4.309783664626112730E-6, 5.089908387289337810E-6, 11.41776493385259000E-6, 14.49479956796871960E-6, 14.68103429127791950E-6, 12.70714431137183450E-6, 9.478463659369410270E-6 };
// BANDPASS Fs = 44118sps, Fc = 2.0kHz, bandwidth = 1.324kHz Kaiser Window, KaiserBeta = 7.6, 257 taps, 80dB stopband attenuation
//float32_t FIR1 [257] = {16.61866773479811950E-6, 19.94613337054439480E-6, 21.29563655473358710E-6, 20.12425300443531740E-6, 16.39366853431405600E-6, 10.68919544786741230E-6, 4.215411625141377350E-6,-1.356969432477939330E-6,-4.190108410209962390E-6,-2.688138188638207640E-6, 4.050701286956446270E-6, 15.82862741394291280E-6, 31.08717219851485680E-6, 46.87678423399312780E-6, 59.11256947541127000E-6, 63.12360636272744330E-6, 54.44533420394996880E-6, 29.74661243139744120E-6,-12.26326443768168950E-6,-70.12601713393657120E-6,-139.2955894056957220E-6,-212.2990212746223050E-6,-279.4539930704328300E-6,-330.1048511403636210E-6,-354.2362782939503060E-6,-344.2320430481552190E-6,-296.4843303376538300E-6,-212.5428895255537900E-6,-99.53208858067959850E-6, 30.34164237528758080E-6, 161.2294257459753060E-6, 275.8979513215931550E-6, 358.5120995029542430E-6, 397.5145321226719940E-6, 388.1004940400010240E-6, 333.7928218129888480E-6, 246.7188501340256150E-6, 146.3714441825771080E-6, 56.87879371166833660E-6, 3.076130405200208530E-6, 5.922469021692320370E-6, 77.99015280909182480E-6, 219.8338842995363790E-6, 417.9925918761219350E-6, 645.1858098218745000E-6, 862.9538006704217420E-6, 0.001026598160733021, 0.001091866377316668, 0.001022459116078967, 797.1913328353425640E-6, 415.5630802610967290E-6,-99.37538268467884000E-6,-701.6472414193301570E-6,-0.001326744086469984,-0.001899473896474262,-0.002344334452274706,-0.002596969281511279,-0.002614938474580782,-0.002385976109729689,-0.001932145511897164,-0.001308831760545092,-598.2665719417420860E-6, 101.8413126900205160E-6, 693.1323229161806690E-6, 0.001092735110396656, 0.001248160232496881, 0.001148362674464450, 828.7863730957278680E-6, 369.0014935166746000E-6,-117.3551478836799050E-6,-499.3795146741921370E-6,-650.2818931890610660E-6,-470.2397434546688260E-6, 92.91611279438340890E-6, 0.001028797943446396, 0.002258341478397023, 0.003638313919204863, 0.004976735440146872, 0.006057761326623174, 0.006672919004720886, 0.006654301372932098, 0.005904622972425995, 0.004419108933794485, 0.002295059200475405,-273.4627786303617540E-6,-0.003016225235905580,-0.005620736386853022,-0.007775238832768322,-0.009214796723312999,-0.009763522764877863,-0.009366052136621639,-0.008102517647962031,-0.006183416855904221,-0.003923627103313620,-0.001698025785265647, 115.7623982397020510E-6, 0.001199526967000850, 0.001352179986100310, 533.5872473138101670E-6,-0.001113521893048559,-0.003268896033113763,-0.005468953566903118,-0.007167168560789308,-0.007813818712157576,-0.006944797857711526,-0.004267004042541636, 272.6938139379725500E-6, 0.006446547135154211, 0.013741563508818224, 0.021395580618215986, 0.028472210640447422, 0.033967491028566665, 0.036936136606129023, 0.036621739315567302, 0.032573680133572355, 0.024734224764116537, 0.013482284145852581,-374.6769295480607980E-6,-0.015662705314293146,-0.030952551858455212,-0.044708524900117598,-0.055458180159149446,-0.061962686197633114,-0.063366899796061693,-0.059310088680181249,-0.049982663161841835,-0.036120691753600054,-0.018937569349441633, 0.000000000000000000, 0.018937569349441633, 0.036120691753600054, 0.049982663161841835, 0.059310088680181249, 0.063366899796061693, 0.061962686197633114, 0.055458180159149446, 0.044708524900117598, 0.030952551858455212, 0.015662705314293146, 374.6769295480607980E-6,-0.013482284145852581,-0.024734224764116537,-0.032573680133572355,-0.036621739315567302,-0.036936136606129023,-0.033967491028566665,-0.028472210640447422,-0.021395580618215986,-0.013741563508818224,-0.006446547135154211,-272.6938139379725500E-6, 0.004267004042541636, 0.006944797857711526, 0.007813818712157576, 0.007167168560789308, 0.005468953566903118, 0.003268896033113763, 0.001113521893048559,-533.5872473138101670E-6,-0.001352179986100310,-0.001199526967000850,-115.7623982397020510E-6, 0.001698025785265647, 0.003923627103313620, 0.006183416855904221, 0.008102517647962031, 0.009366052136621639, 0.009763522764877863, 0.009214796723312999, 0.007775238832768322, 0.005620736386853022, 0.003016225235905580, 273.4627786303617540E-6,-0.002295059200475405,-0.004419108933794485,-0.005904622972425995,-0.006654301372932098,-0.006672919004720886,-0.006057761326623174,-0.004976735440146872,-0.003638313919204863,-0.002258341478397023,-0.001028797943446396,-92.91611279438340890E-6, 470.2397434546688260E-6, 650.2818931890610660E-6, 499.3795146741921370E-6, 117.3551478836799050E-6,-369.0014935166746000E-6,-828.7863730957278680E-6,-0.001148362674464450,-0.001248160232496881,-0.001092735110396656,-693.1323229161806690E-6,-101.8413126900205160E-6, 598.2665719417420860E-6, 0.001308831760545092, 0.001932145511897164, 0.002385976109729689, 0.002614938474580782, 0.002596969281511279, 0.002344334452274706, 0.001899473896474262, 0.001326744086469984, 701.6472414193301570E-6, 99.37538268467884000E-6,-415.5630802610967290E-6,-797.1913328353425640E-6,-0.001022459116078967,-0.001091866377316668,-0.001026598160733021,-862.9538006704217420E-6,-645.1858098218745000E-6,-417.9925918761219350E-6,-219.8338842995363790E-6,-77.99015280909182480E-6,-5.922469021692320370E-6,-3.076130405200208530E-6,-56.87879371166833660E-6,-146.3714441825771080E-6,-246.7188501340256150E-6,-333.7928218129888480E-6,-388.1004940400010240E-6,-397.5145321226719940E-6,-358.5120995029542430E-6,-275.8979513215931550E-6,-161.2294257459753060E-6,-30.34164237528758080E-6, 99.53208858067959850E-6, 212.5428895255537900E-6, 296.4843303376538300E-6, 344.2320430481552190E-6, 354.2362782939503060E-6, 330.1048511403636210E-6, 279.4539930704328300E-6, 212.2990212746223050E-6, 139.2955894056957220E-6, 70.12601713393657120E-6, 12.26326443768168950E-6,-29.74661243139744120E-6,-54.44533420394996880E-6,-63.12360636272744330E-6,-59.11256947541127000E-6,-46.87678423399312780E-6,-31.08717219851485680E-6,-15.82862741394291280E-6,-4.050701286956446270E-6, 2.688138188638207640E-6, 4.190108410209962390E-6, 1.356969432477939330E-6,-4.215411625141377350E-6,-10.68919544786741230E-6,-16.39366853431405600E-6,-20.12425300443531740E-6,-21.29563655473358710E-6,-19.94613337054439480E-6,-16.61866773479811950E-6};
