Page 2 of 2 FirstFirst 1 2
Results 26 to 49 of 49
Thread: Teensyduino 1.32 Beta #2 Available
  1. #26
    17,596
    Ok, here's yet another attempt at the sync problem on Windows.
    If this *still* fails with "Unable find Teensy Loader", can you give me the last several lines from Teensy Loader's verbose info window?
    Attached Files Attached Files
  2. #27
    17,596
    Looks like this where Teensy was low left on the right display - and you can see the VERBOSE window is dropped below that barely showing the title bar::
    Attachment 9064
    Oh, so you're saying Windows is placing most of the Verbose Info window off-screen if you open it while Teensy Loader is near the bottom of the screen? Or is the problem something else?
  3. #28
    3,534
    Here is from T3.6 beta board:
    06:09:18: Teensy Loader 1.32-beta2, begin program
    06:09:18: Listening for remote control on port 3149
    06:09:18: initialized, showing main window
    06:09:19: remote connection opened
    06:09:19: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
    06:09:19: remote cmd: "status"
    06:09:19: status data sent
    06:09:19: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build_109154\"
    06:09:19: remote cmd: "file:Blink.ino.hex"
    06:09:19: File "Blink.ino.hex". 20732 bytes, 2% used
    06:09:19: remote cmd: "auto:on"
    06:09:19: remote connection closed
    06:09:19: HID/win32:  vid:045E pid:07A5 ver:0767
    06:10:04: Verbose Info event
    And from a T3.5
    06:13:23: file changed
    06:13:35: remote connection opened
    06:13:35: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
    06:13:35: remote cmd: "status"
    06:13:35: status data sent
    06:13:35: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build_109154\"
    06:13:35: remote cmd: "file:Blink.ino.hex"
    06:13:35: File "Blink.ino.hex". 20268 bytes, 2% used
    06:13:35: remote connection closed
    06:13:36: remote connection opened
    06:13:36: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
    06:13:36: remote cmd: "status"
    06:13:36: status data sent
    06:13:36: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build_109154\"
    06:13:36: remote cmd: "file:Blink.ino.hex"
    06:13:36: File "Blink.ino.hex". 20268 bytes, 2% used
    06:13:36: remote connection closed
    06:13:43: Verbose Info event
    Don't know if it helps, but if I then press the program button on the T3.5, it does program and Verbose info
    06:15:09: Device came online, code_size = 524288
    06:15:09: Board is: Teensy 3.5 (MK64FX512), version 1.03
    06:15:09: File "Blink.ino.hex". 20268 bytes, 4% used
    06:15:09: set background IMG_ONLINE
    06:15:09: elf size appears to be 524288
    06:15:09: elf binary data matches hex file
    06:15:09: Code size from .elf file = 524288
    06:15:09: begin operation
    06:15:09: flash, block=0, bs=1024, auto=1
    06:15:09: flash, block=1, bs=1024, auto=1
    06:15:09: flash, block=2, bs=1024, auto=1
    06:15:09: flash, block=3, bs=1024, auto=1
    06:15:09: HID/win32: waiting for device
    06:15:09: flash, block=4, bs=1024, auto=1
    06:15:09: flash, block=5, bs=1024, auto=1
    06:15:09: flash, block=6, bs=1024, auto=1
    06:15:09: flash, block=7, bs=1024, auto=1
    06:15:09: flash, block=8, bs=1024, auto=1
    06:15:09: flash, block=9, bs=1024, auto=1
    06:15:09: flash, block=10, bs=1024, auto=1
    06:15:09: flash, block=11, bs=1024, auto=1
    06:15:09: flash, block=12, bs=1024, auto=1
    06:15:09: flash, block=13, bs=1024, auto=1
    06:15:09: flash, block=14, bs=1024, auto=1
    06:15:09: flash, block=15, bs=1024, auto=1
    06:15:09: flash, block=16, bs=1024, auto=1
    06:15:09: flash, block=17, bs=1024, auto=1
    06:15:09: flash, block=18, bs=1024, auto=1
    06:15:09: flash, block=19, bs=1024, auto=1
    06:15:09: sending reboot
    06:15:09: begin wait_until_offline
    06:15:09: offline, waited 3
    06:15:09: end operation
    06:15:09: set background IMG_REBOOT_OK
    06:15:09: redraw timer set, image 14 to show for 1200 ms
    06:15:09: HID/win32:  vid:045E pid:07A5 ver:0767
    06:15:11: redraw, image 9
    06:15:17: Verbose Info event
  4. #29
    1,471
    Quote Originally Posted by Paul View Post
    Changes since Teensyduino 1.32-beta1:
    • attachInterrupt supports uninitialized pins
    Hurrah! In January, 2013 in my very first Teensy post, I whined about having to set the pinMode for interrupt pin.
  5. #30
    17,596
    @KurtE - Does any extra info show up if you turn on verbose info during upload in File > Preferences?
    Those multiple lines of "remote connection opened" aren't normal, but so far I have no idea what's really going wrong. Will try to add logging to the teensy_reboot side and post yet another set of files soon.
    Here's how the verbose info is supposed to look when things go as planned (as they always do on my test machine)
    12:44:45: remote connection opened
    12:44:45: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
    12:44:45: remote cmd: "status"
    12:44:45: status data sent
    12:44:45: remote cmd: "dir:C:\Users\me\AppData\Local\Temp\arduino_build_899015\"
    12:44:45: remote cmd: "file:Blinky.ino.hex"
    12:44:45: File "Blinky.ino.hex". 34812 bytes, 13% used
    12:44:45: remote connection closed
    12:44:45: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_reboot)"
    12:44:45: remote cmd: "auto:on"
    12:44:45: elf size appears to be 262144
    12:44:45: elf binary data matches hex file
    12:44:45: Code size from .elf file = 262144
    12:44:45: begin operation
  6. #31
    3,534
    It is sort of strange. I turned on verbose and the first time I ran it actually programmed properly, turned it off, it failed, turned it back on it succeeded first time, but then failed the next 3 times, then 1 success and then several more failures. Maybe 1 out 10 worked...
    Does not give much more information
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172\core\usb_flightsim.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172\core\usb_inst.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172\core\yield.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481208461 "-TC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3/mk66fx1m0.ld"  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172\sketch\Blink.ino.cpp.o" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/core\core.a" "-LC:\Users\Kurt\AppData\Local\Temp\arduino_build_637172" -larm_cortexM4lf_math -lm
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/Blink.ino.eep"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172/Blink.ino.hex"
    "C:\arduino-1.6.13\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.ino" "-path=C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172" "-tools=C:\arduino-1.6.13\hardware\teensy/../tools/" "-board=TEENSY36"
    Sketch uses 20,584 bytes (1%) of program storage space. Maximum is 1,048,576 bytes.
    Global variables use 3,964 bytes (1%) of dynamic memory, leaving 258,180 bytes for local variables. Maximum is 262,144 bytes.
    C:\arduino-1.6.13\hardware\teensy/../tools/teensy_post_compile -test -file=Blink.ino -path=C:\Users\Kurt\AppData\Local\Temp\arduino_build_637172 -tools=C:\arduino-1.6.13\hardware\teensy/../tools -board=TEENSY36 -reboot
    Opening Teensy Loader...
    Unable find Teensy Loader.  (r)  Is the Teensy Loader application running?
    Is a firewall (eg, ZoneAlarm) blocking localhost communication?
  7. #32
    6,439
    Indeed - said and shown - that only the title bar is barely on the screen when the window is opened. In a recent post you noted you were looking after window open locations - I was following up that this Verbose window is opened all but off screen.
    In this case if I place the TEENSY.exe any lower on the screen ( so I can just see when 'Reboot Ok' flashes by ) then the verbose window is opened fully off screen #2.
    I also tried to fix two other long-standing problems. Teensyduino-1-32-Beta-2-Available
    >The dialog box could be rendered out of view, if Teensy Loader is covered by other windows or minimized to the tray/dock.
    >It could appear somewhere far away from the original Teensy Loader window if you have a large screen or multi-monitor setup.
  8. #33
    Dec 2014
    1
    This is the first release I have tried on a Raspberry Pi. I am unable to program my Teensy 3.1 with this release with basically any combination of cold start (ie power removal and insertion), pressing the reset button, or automatic programming.
    Programming from my Mac works perfectly with the same cable, so I believe the cable is "exonerated."
    Serial console works perfectly, so we know that communications is working at some level on the Pi.
    I don't see any error messages in dmesg during the programming sequence.
    This is a raspberry pi 3 fwiw.
    Any ideas?
    Thanks,
    Chris
  9. #34
  10. #35
    17,596
    Quote Originally Posted by huffine View Post
    Any ideas?
    Look in Help > Verbose Info to find out what Teensy Loader is really seeing.
  11. #36
    3,534
    FYI - I tried installing Arduino... this beta on UP board (http://up-shop.org/up-boards/44-up-b...4-gb-emmc.html) running Windows 10 64 bit, and it works fine...
  12. #37
    17,596
    I'm working right now to add a logging layer into the post compile and reboot programs. By tomorrow I'll have another test that'll give us a *lot* more info about what's going wrong on your system. I *really* want to get this figured out and hopefully make these more robust for the upcoming 1.32 release.
  13. #38
    17,596
    Here is yet another attempt. These will create a log file named teensy_reboot_log.txt. Hopefully together with the Verbose Info from Teensy Loader it will shine some light on what's really happening here.
    On Windows, it will be created in the default temp folder, which defaults to C:\Users\username\AppData\Local\Temp. The AppData may be hidden, but can be accessed from the command line or other tools.
  14. #39
    6,439
    Hit: Start Key + R :: to get RUN, enter %appdata% and you open to C:\Users\user\AppData\Roaming ... navigate to ..\local
    Question- @KurtE - is any/all Teensy doing this for you on this Win_10 machine? Has it worked before until a new build?
    And it seems to work using tyqt - so hardware seems to be fine? Any of the machine's USB ports? Using a hub?
  15. #40
    17,596
    This sync issue appears to be only related to the communication between Teensy Loader and Arduino (teensy_post_compile & teensy_reboot).
    I'm not completely ruling out USB overhead or other issues somehow playing a factor. But I'm trying to focus on the sync problem between these two without getting distracted by other stuff.
    So far Kurt has the only machine reproducing the problem, of anyone willing to reply here with test results. If anyone else has a Windows machine doing this, please please please speak up. I can't get it to happen here, and I *REALLY* want to get to the bottom of this problem. I could really use all the help I can get with running these tests on problematic Windows machines.
  16. #41
    6,439
    Understood ... loader HID - but it plugs in to the USB port right? - just trying to make sure going to other machines to test I was set up knowing the repro scenario. On that machine it is any Teensy on any port with or without a hub with IDE 1.6.13 and 1.32b2?
  17. #42
    17,596
    Good questions. Most of Kurt's tests look like a Teensy was plugged in and running a previously uploaded sketch. Which USB Type is was, and whether plugged in directly to a USB2 or USB3 port or through a hub is unknown.
    But the problems seen are happening before teensy_reboot can send the request to auto reboot. They're inter-process communication issues between programs running entirely on the PC, which happens before any USB communication takes place.
    I really wish I knew a way to reproduce the problem here. But I don't...
  18. #43
    6,439
    Two other Win_10 Pro x64 desktops (i5/i7) to 1.6.13 w/ TD_1.32vb2 and programmed T_3.1's a few times each no issue. Did fresh directory unzip of IDE on both, then TeensyInstaller.
    Kurt has noted intermittent ability to program, once after TD_1.32b1, and again once each time after hitting Verbose (p#31)?
  19. #44
    3,534
    Just started computer up and getting ready to download latest.
    But some more info: again windows 10 64 bit. Trying to program blink to teensys that already have been programmed, USB Serial, USB2 directly connected to computer (which of course has it's own HUB).
    Above shows the USB connections...
    I can try other connections if desired, like USB3 or the 2nd USB2 controller 1C26...
    The same connections/setup works with TyQt. Also works fine with Teensyduino 31 and 32b1.
    Now to download and see what I get.
  20. #45
    3,534
    Here is the log file:
    .152 post_compile: Begin
    .153 post_compile: Connect attempt to port 3149
    .320 post_compile: Connect attempt to port 3149
    .472 post_compile: Connect attempt to port 3149
    .622 post_compile: Connect attempt to port 3149
    .625 post_compile: Connected to port 3149
    .629 post_compile: Sending command: comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)
    .630 post_compile: Sending status request
    .631 post_compile: Receive status dir = C:\Users\Kurt\AppData\Local\Temp\arduino_build_100474\
    .631 post_compile: Receive status file = Blink.ino.hex
    .631 post_compile: Receive status readable = 0
    .631 post_compile: Receive status auto = 0
    .631 post_compile: Receive status online = 0
    .631 post_compile: Receive status online_count = 0
    .631 post_compile: Receive status offline_count = 0
    .631 post_compile: Receive status state = 0
    .631 post_compile: Receive status EOT
    .631 post_compile: Sending command: dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\
    .632 post_compile: Sending command: file:Blink.ino.hex
    .646 post_compile: Sending status request
    .648 post_compile: Receive status dir = C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\
    .648 post_compile: Receive status file = Blink.ino.hex
    .648 post_compile: Receive status readable = 1
    .648 post_compile: Receive status auto = 0
    .648 post_compile: Receive status online = 0
    .648 post_compile: Receive status online_count = 0
    .648 post_compile: Receive status offline_count = 0
    .648 post_compile: Receive status state = 0
    .648 post_compile: Receive status EOT
    .648 post_compile: Sending command: auto:on
    .649 post_compile: Disconnect
    .857 post_compile: Begin
    .859 post_compile: Connect attempt to port 3149
    .012 post_compile: Connect attempt to port 3149
    .162 post_compile: Connect attempt to port 3149
    .313 post_compile: Connect attempt to port 3149
    .313 post_compile: Connected to port 3149
    .314 post_compile: Sending command: comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)
    .314 post_compile: Sending status request
    .315 post_compile: Receive status dir = C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\
    .315 post_compile: Receive status file = Blink.ino.hex
    .315 post_compile: Receive status readable = 1
    .315 post_compile: Receive status auto = 1
    .315 post_compile: Receive status online = 0
    .315 post_compile: Receive status online_count = 0
    .315 post_compile: Receive status offline_count = 0
    .315 post_compile: Receive status state = 0
    .315 post_compile: Receive status EOT
    .315 post_compile: Sending command: dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\
    .315 post_compile: Sending command: file:Blink.ino.hex
    .325 post_compile: Sending status request
    .327 post_compile: Receive status dir = C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\
    .327 post_compile: Receive status file = Blink.ino.hex
    .327 post_compile: Receive status readable = 1
    .327 post_compile: Receive status auto = 1
    .327 post_compile: Receive status online = 0
    .327 post_compile: Receive status online_count = 0
    .327 post_compile: Receive status offline_count = 0
    .327 post_compile: Receive status state = 0
    .328 post_compile: Receive status EOT
    .328 post_compile: Disconnect
    .339 post_compile: Running teensy_reboot
    .390 reboot: Begin
    .400 reboot: Device Instance: 1
    .400 reboot:   PortName: "COM12"
    .400 reboot:   pathname: \\.\COM12
    .400 reboot: add_serial_name, \\.\COM12
    .402 reboot: Connect attempt to port 3149
    The verbose information:
    06:35:10: Teensy Loader 1.32-beta2, begin program
    06:35:10: Listening for remote control on port 3149
    06:35:10: initialized, showing main window
    06:35:10: remote connection opened
    06:35:10: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
    06:35:10: remote cmd: "status"
    06:35:10: status data sent
    06:35:10: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\"
    06:35:10: remote cmd: "file:Blink.ino.hex"
    06:35:10: File "Blink.ino.hex". 20732 bytes, 2% used
    06:35:10: remote cmd: "auto:on"
    06:35:10: HID/win32:  vid:045E pid:07A5 ver:0767
    06:35:10: remote connection closed
    06:35:11: remote connection opened
    06:35:11: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
    06:35:11: remote cmd: "status"
    06:35:11: status data sent
    06:35:11: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\"
    06:35:11: remote cmd: "file:Blink.ino.hex"
    06:35:11: File "Blink.ino.hex". 20732 bytes, 2% used
    06:35:11: remote connection closed
    06:38:50: Verbose Info event
    Output from verbose compile:
    C:\arduino-1.6.13\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-1.6.13\hardware -hardware C:\Users\Kurt\AppData\Local\Arduino15\packages -hardware C:\Users\Kurt\Documents\Arduino\hardware -tools C:\arduino-1.6.13\tools-builder -tools C:\arduino-1.6.13\hardware\tools\avr -tools C:\Users\Kurt\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.6.13\libraries -libraries C:\Users\Kurt\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180opt,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10613 -build-path C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528 -warnings=all -verbose C:\arduino-1.6.13\examples\01.Basics\Blink\Blink.ino
    C:\arduino-1.6.13\arduino-builder -compile -logger=machine -hardware C:\arduino-1.6.13\hardware -hardware C:\Users\Kurt\AppData\Local\Arduino15\packages -hardware C:\Users\Kurt\Documents\Arduino\hardware -tools C:\arduino-1.6.13\tools-builder -tools C:\arduino-1.6.13\hardware\tools\avr -tools C:\Users\Kurt\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.6.13\libraries -libraries C:\Users\Kurt\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180opt,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10613 -build-path C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528 -warnings=all -verbose C:\arduino-1.6.13\examples\01.Basics\Blink\Blink.ino
    Using board 'teensy36' from platform in folder: C:\arduino-1.6.13\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\arduino-1.6.13\hardware\teensy\avr
    Detecting libraries used...
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\sketch\Blink.ino.cpp" -o "nul"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\sketch\Blink.ino.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\preproc\ctags_target_for_gcc_minus_e.cpp"
    "C:\arduino-1.6.13\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\preproc\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\sketch\Blink.ino.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\sketch\Blink.ino.cpp.o"
    Compiling libraries...
    Compiling core...
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\memcpy-armv7m.S.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\memset.S" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\memset.S.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\analog.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\analog.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\eeprom.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\eeprom.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\keylayouts.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\keylayouts.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\math_helper.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\math_helper.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\mk20dx128.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\mk20dx128.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\nonstd.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\nonstd.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\pins_teensy.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\pins_teensy.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\ser_print.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\ser_print.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial1.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial1.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial2.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial2.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial3.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial3.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial4.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial4.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial5.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial5.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial6.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial6.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial6_lpuart.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial6_lpuart.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\touch.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\touch.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_desc.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_desc.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_dev.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_dev.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_joystick.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_joystick.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_keyboard.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_keyboard.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_mem.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_mem.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_midi.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_midi.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_mouse.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_mouse.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_mtp.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_mtp.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_rawhid.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_rawhid.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_seremu.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_seremu.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_serial.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_serial.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_touch.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_touch.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\AudioStream.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\AudioStream.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\DMAChannel.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\DMAChannel.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareSerial1.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial1.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareSerial2.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial2.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareSerial3.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial3.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareSerial4.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial4.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareSerial5.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial5.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareSerial6.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial6.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\IPAddress.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\IPAddress.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\IntervalTimer.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\IntervalTimer.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\Print.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\Print.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\Stream.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\Stream.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\Tone.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\Tone.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\WMath.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\WMath.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\WString.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\WString.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\avr_emulation.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\avr_emulation.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\main.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\main.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\new.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\new.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_audio.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_audio.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_flightsim.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_flightsim.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_inst.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_inst.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\yield.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\yield.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\memcpy-armv7m.S.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\memset.S.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\analog.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\eeprom.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\keylayouts.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\math_helper.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\mk20dx128.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\nonstd.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\pins_teensy.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\ser_print.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial1.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial2.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial3.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial4.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial5.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial6.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\serial6_lpuart.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\touch.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_desc.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_dev.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_joystick.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_keyboard.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_mem.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_midi.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_mouse.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_mtp.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_rawhid.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_seremu.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_serial.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_touch.c.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\AudioStream.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\DMAChannel.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial1.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial2.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial3.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial4.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial5.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\HardwareSerial6.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\IPAddress.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\IntervalTimer.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\Print.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\Stream.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\Tone.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\WMath.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\WString.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\avr_emulation.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\main.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\new.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_audio.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_flightsim.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\usb_inst.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\core\yield.cpp.o"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481265297 "-TC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3/mk66fx1m0.ld"  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528\sketch\Blink.ino.cpp.o" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/core\core.a" "-LC:\Users\Kurt\AppData\Local\Temp\arduino_build_756528" -larm_cortexM4lf_math -lm
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/Blink.ino.eep"
    "C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528/Blink.ino.hex"
    "C:\arduino-1.6.13\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.ino" "-path=C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528" "-tools=C:\arduino-1.6.13\hardware\teensy/../tools/" "-board=TEENSY36"
    Sketch uses 20,728 bytes (1%) of program storage space. Maximum is 1,048,576 bytes.
    C:\arduino-1.6.13\hardware\teensy/../tools/teensy_post_compile -test -file=Blink.ino -path=C:\Users\Kurt\AppData\Local\Temp\arduino_build_756528 -tools=C:\arduino-1.6.13\hardware\teensy/../tools -board=TEENSY36 -reboot
    Strange: If I do a sleep operation on my computer and right after I awake the computer, do an upload, it worked twice in a row. But if I wait a little while then it fails again...
    Weird!
  21. #46
    17,596
    Thanks Kurt. I know it doesn't seem like progress, but that actually helps quite a lot.
    Here's another attempt, which might fix this problem, and if it doesn't it has even more info that might help.
    Attached Files Attached Files
  22. #47
    3,534
    - I thought it failed the first time, but then I tried it many different ways, With T3.2, T3.5 and a couple of T3.6s and it is working fine every time. I tried with Teensyduino already loaded, or without it already open. I tried with and without Verbose.
  23. #48
    17,596
    Whew, glad it's *finally* resolved!
    I'm going disable the excessive logging and start packaging up 1.32 now.
  24. #49
    Administrator Paul's Avatar
    Oct 2012
    294
    Teensyduino 1.32 has been released.
    http://www.pjrc.com/teensy/td_download.html
