Hi Frank ,
Thanks for answer ...
Tennesy 3.6
Arduino :1.8.12
Teensyduino : last version 1.51
Did you follow the given instruction to manually install ALL the CMSIS files to the right places?
OOOOOOOOOOhhhhhhhhhhhh I am not quite sure ..... May be forgot last ( F ) line ....
I'll verify .
Thanks !!
Hi All
Again me ...
Did all vérifs ..
All seems to be OK , but can't compile ...
Get this error :
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1587740528 "-TC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3/mk66fx1m0.ld" -lstdc++ -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546/Cricri_Convolution_SDR.ino.elf" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\sketch\\font_Arial.c.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\sketch\\Cricri_Convolution_SDR.ino.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\sketch\\ILI9341_t3.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\memcpy_audio.S.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\data_spdif.c.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\data_ulaw.c.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\data_waveforms.c.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\data_windows.c.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\analyze_fft1024.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\analyze_fft256.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\analyze_notefreq.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\analyze_peak.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\analyze_print.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\analyze_rms.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\analyze_tonedetect.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\control_ak4558.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\control_cs42448.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\control_cs4272.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\control_sgtl5000.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\control_tlv320aic3206.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\control_wm8731.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_bitcrusher.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_chorus.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_combine.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_delay.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_delay_ext.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_envelope.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_fade.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_flange.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_freeverb.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_granular.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_midside.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_multiply.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_reverb.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\effect_waveshaper.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\filter_biquad.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\filter_fir.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\filter_variable.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\input_adc.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\input_adcs.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\input_i2s.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\input_i2s2.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\input_i2s_quad.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\input_pdm.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\input_tdm.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\input_tdm2.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\mixer.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_adat.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_dac.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_dacs.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_i2s.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_i2s2.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_i2s_quad.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_mqs.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_pt8211.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_pt8211_2.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_pwm.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_spdif.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_spdif2.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_spdif3.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_tdm.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\output_tdm2.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\play_memory.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\play_queue.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\play_sd_raw.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\play_sd_wav.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\play_serialflash_raw.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\record_queue.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\spi_interrupt.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_dc.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_karplusstrong.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_pinknoise.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_pwm.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_simple_drum.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_sine.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_tonesweep.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_waveform.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_wavetable.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\synth_whitenoise.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\utility\\sqrt_integer.c.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Audio\\utility\\imxrt_hw.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\SD\\File.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\SD\\SD.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\SD\\utility\\Sd2Card.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\SD\\utility\\SdFile.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\SD\\utility\\SdVolume.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\SerialFlash\\SerialFlashChip.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\SerialFlash\\SerialFlashDirectory.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Time\\DateStrings.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Time\\Time.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Wire\\WireIMXRT.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Wire\\WireKinetis.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Metro\\Metro.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Bounce\\Bounce.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Si5351\\si5351.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\Encoder\\Encoder.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546\\libraries\\EEPROM\\EEPROM.cpp.o" "C:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546/core\\core.a" "-LC:\\Users\\cricr\\AppData\\Local\\Temp\\arduino_build_881546" -larm_cortexM4lf_math -lm
C:\Users\cricr\AppData\Local\Temp\arduino_build_881546\sketch\ILI9341_t3.cpp.o: In function `SPIClass::endTransaction()':
C:\Users\cricr\AppData\Local\Temp\arduino_build_881546\sketch/ILI9341_t3.cpp:1373: undefined reference to `glcdfont'
C:\Users\cricr\AppData\Local\Temp\arduino_build_881546\sketch\ILI9341_t3.cpp.o: In function `ILI9341_t3::waitTransmitComplete(unsigned long)':
C:\Users\cricr\AppData\Local\Temp\arduino_build_881546\sketch/ILI9341_t3.h:470: undefined reference to `glcdfont'
So, One question : In which Directory install the software before compiling ??
Tried : C:/Arduino and C: /user/__ /Documents /Arduino ......... With bad results ..
I come from hardware world , not software as you see ....
Regards Xtian
