Page 23 of 24 FirstFirst ... 13 21 22 23 24 LastLast
Results 551 to 575 of 593
Thread: Teensy Convolution SDR (Software Defined Radio)
  1. #551
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    691
    Bob Larkin provided very nice code for an Audio Equalizer (https://forum.pjrc.com/threads/60928...udio+equalizer), which I implemented as a 9-band graphical EQ in the latest version of the Teensy Convolution SDR.
    I was always a little unhappy with the built-in five-band-EQ of the SGTL5000 codec, because my impression was, it did not accurately separate the frequencies (Adjusting Bass also impacted Mids etc.). This seems much better now with the FIR-based EQ by Bob. But it also takes a lot more CPU power.
    We have to experiment with several parametres:
    * menu: adjustable dB response for 9 bands (separate responses for wideband FM and the other modes) --> a nice feature is the graphical display of the frequency response, I tried to scale the frequency-axis logarithmically
    * hardcoded (see lines 1918ff): 60dB stopband attenuation
    * hardcoded: centre frequencies for the nine bands
    * hardcoded: number of FIR coefficients: at the moment 199 taps for the T4 and 69 taps for the T3.6
    Please feel free to test and report any bugs.
  2. #552
    Apr 2017
    10
    version (c) Frank DD4WH 2020_09_08
    Please help
    I got an error in version (c) Frank DD4WH 2020_09_08
    The version (c) Frank DD4WH 2019_10_15 is ok
    in line 6814: max_gain = powf (10.0, (float32_t)bands[current_band].AGC_thresh / 20.0);
    error code :'struct band' has no member named 'AGC_thresh'
    inline 7865ixelnew[x] = displayScale[currentScale].baseOffset + bands[current_band].pixel_offset + (int16_t)(displayScale[currentScale].dBScale * log10f_fast(FFT_spec[x]));
    error code : 'struct band' has no member named 'pixel_offset'
    73 ,PA0HAH Henk
  3. #553
    Oct 2015
    Central Europe
    691
    Hi Henk,
    you have to keep an eye on which #define you uncomment/comment at the beginning of the .ino-file.
    Probably you have too many #define uncommented, so that the program initializes a very old version of the "band" struct.
    Have a close look on which version of the band struct you are using.
    73 de Frank
  4. #554
    Apr 2017
    10
    Hi Henk,
    73 de Frank
    Hallo Frank,
    I do not understand it. The "band "struct is a part of the *.INO file which I have downloaded ? Or is this not right ?
  5. #555
    Oct 2015
    Central Europe
    691
    Quote Originally Posted by xhenk01 View Post
    Yes! But it is defined in different ways, depending on which hardware you have defined at the beginning of your sketch!
    Which Hardware did you define in the very first lines of the sketch?
  6. #556
    Apr 2017
    10
    /* If you use the hardware made by Frank DD4WH uncomment the next line */
    //#define HARDWARE_DD4WH
    /* If you use the hardware made by Frank DD4WH & the T4 uncomment the next line */
    #define HARDWARE_DD4WH_T4
    //#define HARDWARE_AD8331
    /* If you use the hardware made by FrankB uncomment the next line */
    //#define HARDWARE_FRANKB
    //#define HARDWARE_FRANKB2
    /* If you use the hardware made by Dante DO7JBH [https://github.com/do7jbh/SSR-2], uncomment the next line */
    //#define HARDWARE_DO7JBH
    /* If you use the hardware made by Dante DO7JBH with a Teensy 4.1 adapter [https://github.com/do7jbh/SSR-2], uncomment the next line */
    //#define HARDWARE_DO7JBH_T41
    /* only for debugging */
    //#define DEBUG
    /* this prints out the ADC and DAC levels when NOT in SAM mode, primarily for debugging hardware
    recommendation: leave this commented */
    //#define USE_ADC_DAC_display
    /* only for support of the hardware RF frontend filters designed by Bob Larkin, W7PUA
    http://www.janbob.com/electron/FilterBP1/FiltBP1.html
    adjust cutoff frequencies according to your needs in function setfreq */
    //#define USE_BOBS_FILTER
    /* flag to indicate to use the changes introduced by Bob Larkin, W7PUA
    recommendation: leave this uncommented */
    //#define USE_W7PUA
    /* use faster log calculations
    #define USE_LOG10FAST
    /* use faster atan2f calculation
    #define USE_ATAN2FAST
    // #define MP3 //<<++++++++++++++++++++++++++++++++++++++++++++++
  7. #557
    Sep 2020
    3
    Greetings from a newbie very attracted to this project.
    I am also following some others like QRP Labs, QCX, uSDX...
    I have tried to find info about it in the forum but I have not found it: I would like to know if it is in the roadmap to cover bands above 30 MHz - 6 m, 4 m, 2 m, 70 cm...air bands, full band - and if the receiver could be operated as say a "AM/NBFM police scanner" with its usual functions and features.
    Thanks so much for this amazing project. Chapeau !!
    73 Iņigo; EA2AYO
  8. #558
    Oct 2015
    Central Europe
    691
    Henk, try to uncomment:
    #define USE_W7PUA
  9. #559
    Oct 2015
    Central Europe
    691
    Iņigo,
    it is already possible with the Msi001 chip! Ask tisho and Esteban! I do not have working hardware with the Msi001, so I cannot contribute to that part of the software (yet).
  10. #560
    Sep 2020
    3
    Hi Frank,
    Thanks.
    I see.. it seems there is a say "hidden" roadmap.
    73 Iņigo; EA2AYO
  11. #561
    Oct 2015
    Central Europe
    691
    Quote Originally Posted by Nacho View Post
    No, it seems you completely misunderstood me! There is NO roadmap, not even a hidden one.
    And there already is existing code for the Msi001 which allows for the VHF/UHF bands you are looking for :-). It has been developed by tisho and Esteban, have a look into this thread and read their posts.
  12. #562
    Apr 2017
    10
    Hello Frank this was the solution.
    The problems are solved.
    Thank you for your fast help.
    Henk
  13. #563
    Sep 2020
    3
    Thanks Frank,
    I was just joking. Irony does not work well for me when writing.
  14. #564
    Oct 2015
    Central Europe
    691
    Thanks Frank,
    Perfectly OK :-).
    Its just that I cannot help you with the Msi001 version of the Teensy Convolution SDR!
  15. #565
    Oct 2015
    Central Europe
    691
    Henk
    Very good to hear! Have fun with your SDR!
  16. #566
    Oct 2020
    11
    Dear all, As amn old analog guy I took the opportunity to go on this project. I use a Teensy4 did uncomment #define HARDWARE_DD4WH_T4
    could compile Software and frontend are OK but cannot igure out how preselector switching works in this configuration.
    Any clue would be appreciated best 73,s Hubert F6DUK
  17. #567
    Oct 2015
    Central Europe
    691
    hi Hubert,
    please let us know what you are using, how your hardware looks like, what kind of preselector you would like to switch etc.
    otherwise it is difficult to answer your questions.
  18. #568
    Oct 2020
    11
    Dear Frank thank you for your patience you may wonder that I am not (yet) an expert but I feel that time has come to do something else than tayloring crystal filters!
    I start from the previous thread
    DD4WH said:
    Hi!
    The Teensy Convolution SDR code works with many hardware configurations including different I2S codecs, I have built and tested a few of those types:
    * T4.1 & audio shield rev D
    * T4 & PCM5102 & PCM1808
    * T3.6 & audio shield rev B
    * T3.6 & PCM5102 & PCM1808
    I am not able to understand what your problem is here . . .
    * which software switches (#defines) did you comment out during compile?
    * Do you have working audio? Which demodulation type are you using?
    * the sample rate is adjustable in the menu, which sample rate did you choose?
    * what is your hardware frontend setup? Do you use a Tayloe type (QSD) frontend?
    * please give us some more information :-)
    So I am using as frontend exatly what you describes in the paper in mai 2017 with 74cbtlv3253 it delivers a nice IQ with correct phase to the Audio board RevD unter the Teensy 4.0
    So software runs and give the correct info to the SI5351. As I did not see any response in the Spectrum I started to check the signals going to the Codec and have
    on pin 23MCLK Clock I have 45.157 Mhz I have the 11.289 for a couple of milliseconds after booting
    on pin 20LRCLK I have 176Khz
    on pin 21BCLK I have 11.289Mhz
    This looked strange and try to understand what I have done wrong
    //#define DEBUG
    #define USE_W7PUA
    With many thanks in advance
    Hubert F6DUK
  19. #569
    Oct 2020
    11
    Dear Frank
    Some new facts
    Problem seems not to be where I thought. If I decrease sample rate I get the correct frequencies but the only pulse encoder that works correctly is the frequency encoder.
    I use Bournes from Farnell not from Ebay signals are as they should be in either directions just scratching my head!
    When I turn it reacts randomlyI use the correct bounce library (debounced Version of Paul Stoffregens)
    73,s
    Hubert
  20. #570
    Oct 2020
    11
    Last news: encoders work, I changed encoderbounce against encoder we come closer...
  21. #571
    Oct 2015
    Central Europe
    691
    Hi Hubert,
    the software switches seem correct. But you configured it as "No Teensy audio board", because my T4 hardware has no audio board, but external ADC and DAC.
    if you use the #define HARDWARE_DD4WH_T4, the only thing you are missing, I think, is the configuration of the SGTL5000 control code for the audio lib
    * line 1189: delete the #ifdef and #endif
    * delete line 3070 and line 3087
    BTW, do you have working audio? You did not answer that question.
    Try the two deletions above and please report back.
  22. #572
    Oct 2020
    11
    Hi Frank
    Of course no audio and that could be a serous reason thanks or the clue will try it and keep you informed.
  23. #573
    Oct 2020
    11
    I Commented some other !defined(HARDWARE_DD4WH_T4) lines 10148 10214 12251 13631 they ar still some uncommented ones but and do not clearly understand the consequence. But now I have audio. Still some wierd things Enc2 changes the color and button of enc 2 pushes the frequency down I will have to investigate on that. I ordered ADC and DAC maybe easier to do hands on on a proven configuration.
    Do we have a automatic preselector switching in this setup?
    Thanks and best 73,s
    Hubert
  24. #574
    Oct 2020
    11
    Dear Frank
    A little progress report, could fix the Encoder issue, When I plugged the T4 in the Audio board, 1 side from Enc2 was pulled to ground by Audio board , I cut these pins and it starts to behave. Remaining other !Define uncomment or comment and Presel switching.73,s Hubert
  25. #575
    Oct 2020
    11
    Almost everything looks ok now, could copy first signals, just looking for getting preselector switching to work
