Page 25 of 25 FirstFirst ... 15 23 24 25
Results 601 to 609 of 609
Thread: Teensy Convolution SDR (Software Defined Radio)
  1. #601
    Feb 2021
    2
    gmtii: I followed this method to solder, but I can’t receive the signal. I don’t know why? Can you help me?
  2. #602
    Feb 2021
    2
    I don’t know why I can’t upload pictures. Do you have an email address?
  3. #603
    Oct 2019
    1
    Question audio output
    [QUOTE=DD4WH;261776]Hi Rudolf: no, there is no complete schematic / es gibt keinen kompletten Schaltplan. Its the very nature of the project that the Teensy Convolution SDR can cope with every I & Q input from many different frontends and that builders have their own plan of the hardware. But you can find an incomplete suggestion in:
    Hallo Frank,
    and Frohe Ostern !
    I have teensy 3.6 also the Elektor SDR board.
    Do I need to buy audio teensy board, or I can use audio output from elektor sdr?
    Thank you in advance !
    My best 73, de yo2ldk
  4. #604
    Jun 2020
    Berlin, Germany
    15
    You Need additional the teensy audio board, which is use as ADC for the analog I/Q signals from the Elektor SDR.
  5. #605
    9,345
    ..and from my experience, the Elektor board is not very good, but sufficient for the fist experiments. Just don't expect great results.
  6. #606
    Jun 2020
    Berlin, Germany
    15
    The problem of the Elektor SDR is the noisy op amplifier. An low-noise op as the TS464 or TS974 instead the TS914 gives bettler performance.
  7. #607
    Senior Member Rolfdegen's Avatar
    Sep 2020
    226
    Nice project
  8. #608
    Nov 2020
    7
    Ich habe den Empfänger zusammengestellt und bin sehr zufrieden. Kompiliert #define HARDWARE_DO7JBH mit den Modulen PCM1808 / PCM5102. Die Lautstärke ändert sich jedoch nicht, wenn der Encoder von 0 bis 100 eingestellt wird. Bitte um Hilfe
  9. #609
    Nov 2020
    7
    Hallo Frank
    I have put together the receiver and I am very satisfied. Compiles #define HARDWARE_DO7JBH with PCM1808/PCM5102 modules. However, the volume does not change when the encoder is set from 0 to 100. Ask for help
