Page 24 of 25 FirstFirst ... 14 22 23 24 25 LastLast
Results 576 to 600 of 606
Thread: Teensy Convolution SDR (Software Defined Radio)
  1. #576
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    654
    Quote Originally Posted by f6duk View Post
    Almost everything looks ok now, could copy first signals, just looking for getting preselector switching to work
    Sounds good!
    Have a look at the function switch_RF_filters() in the code and alter it according to your needs and pin selections! Do not forget to define the Band1, Band2 etc. pins to your specific needs in the setup
  2. #577
    Nov 2020
    5
    Guten Abend.
    Gibt es ein komplettes Schema?
    73!
  3. #578
    Nov 2020
    New Haven, Indiana
    5
    I am trying to compile Teensy Convolution SDR (Windows 10, Arduino 1.8.13, Teensy 1.53, HARDWARE_DD4WH uncommented using Teensy_Convolution_SDR.ino dated 2020_09_08). After installing the required libraries, I am still getting errors when I compile. On first compile I get "'EEPROM_LOAD' was not declared in this scope". If I comment out EEPROM_LOAD(); on line 3069 and try to compile again, I get "'prepare_spectrum_display' was not declared in this scope (line 3217).
    I have tried compiling the same file on a different Windows 10 machine with Arduino 1.8.12 and Teensy 1.52, and the errors are the same. Any suggestions?
  4. #579
    Oct 2015
    Central Europe
    654
    Hi Rudolf: no, there is no complete schematic / es gibt keinen kompletten Schaltplan. Its the very nature of the project that the Teensy Convolution SDR can cope with every I & Q input from many different frontends and that builders have their own plan of the hardware. But you can find an incomplete suggestion in:
    https://github.com/DD4WH/Teensy-Conv...%20english.pdf
    and a pin connection diagram (for Teensy 4 !) in:
    https://github.com/DD4WH/Teensy-Conv...ion%20SDR.xlsx
    Others have even used the Teensy Convolution SDR successfully with the highly advanced Msi001 receiver chip!
    Hi Forest (KD9JCD): which Teensy do you plan to use? And which hardware are you using? Compile time switches (#define . . .) are dependent on your hardware. Of course, the software should compile with your settings, but I think you should try to compile with the exact configuration that is approproiate for your hardware.
    73 DD4WH
  5. #580
    Nov 2020
    New Haven, Indiana
    5
    I have tried to compile with the exact configuration that is appropriate for my hardware. I am trying to compile for a Teensy 3.6 with the #define HARDWARE_DD4WH uncommented. I've tried compiling for other hardware (HARDWARE_DO7JBH, HARDWARE_FRANKB, etc.) but get similar errors. The only other default define I changed (for the DD4WH hardware) was #define Si_5351_crystal 25000000 for using an Adafruit Si5351 board for frequency generation. It's almost as if there is a missing #endif in the code. My hardware is not yet assembled, since I wanted to make sure I could compile the code before I started wiring things up.
  6. #581
    Oct 2020
    1
    When I rebuild, I hear clicks from the main encoder, How to get rid of them who will tell,
  7. #582
    Oct 2015
    Central Europe
    654
    @KD9JCD: sorry for the late answer: I will have to look at the new Teensyduino version, which could potentially make problems because of the SD lib change. So I still need some time to dive deeper into that.
    @kyrillic letters: are you using the Si5351 that is mentioned in the Teensy script? Or are you using a different lib? What do you mean by "rebuild". Are you compiling a second time? Not quite sure what you mean. Could you clarify?
  8. #583
    Apr 2017
    10
    Hallo ,please help again ;)
    I have downloaded:
    Teensy_Convolution_SDR_Msi001_v3_5_2020_07_24.rar > TEENSY 4.0 Msi001 + Menu
    DDc) Frank DD4WH 2020_05_8
    When compiling I get the following error message:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\Ri ngBufferDMA.cpp:33:19: error: 'ADC0_RA' was not declared in this scope
    , ADC_RA(&ADC0_RA + (uint32_t)0x20000*ADC_number) ^
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\Ri ngBufferDMA.cpp: In member function 'void RingBufferDMA::start(void (*)())':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ADC\Ri ngBufferDMA.cpp:64:30: error: 'DMAMUX_SOURCE_ADC0' was not declared in this scope
    uint8_t DMAMUX_SOURCE_ADC = DMAMUX_SOURCE_ADC0; ^
    Henk - PA0HAH
  9. #584
    Jan 2019
    14
    Hi Frank, and the other enthusiasts!
    In 2018 I built my first Teensy Convolution Receiver with a Teensy3.6, was very happy with it and it's possibilities.
    Now I brought the actual software in an error free compilable status. (Some functions were not declared before their using, some CMSIS files had to be included and so on.)
    But one problem remains: RAM overflow (45404 bytes).
    For the Teensy4.0/4.1 no problem...
    My question is: Where can I get the latest version of Teensy Convolution Receiver- software, which is running on a Teensy3.6 ??
    Or would it be better to upgrade to Teensy4.0 ?
    Best regards, and a Happy New Year, may it be a better one!
    Wolfgang, DH1AKF
  10. #585
    Mar 2018
    Cincinnati, OH, USA
    5
    Hi Frank,
    Just finished a prototype SDR receiver using your code. I am interested in expanding the project to a full transceiver. I sent you a private message with more details, but your inbox is full. Look forward to hearing from you
    Regards,
    Al
    AC8GY
Name:	SDR Protoype.jpg
  11. #586
    Nov 2020
    New Haven, Indiana
    5
    @DD4WH: I could never get any of the options for the Teensy 3.6 to compile correctly, so I have ordered a Teensy 4.0. I was able to compile successfully for Teensy 4.0, but I have been away from the project for a few weeks while I awaited the arrival of the Teensy 4.0. I'll be getting back to the project soon.
  12. #587
    Mar 2018
    Cincinnati, OH, USA
    5
    KD9JCD: Try the Teensy 4.1 instead. Lots more memory and pins. You may have to be sure you have the correct Arm_Math library modifications - search here for info.
  13. #588
    Nov 2020
    New Haven, Indiana
    5
    Quote Originally Posted by AC8GY View Post
    AC8GY: I haven't seen anything in the forum for modifying the Arm_Math library for the Teensy 4.0., and most of the postings I've seen for modifying the library for Teensy 3.6 are several years old.
  14. #589
    Mar 2018
    Cincinnati, OH, USA
    5
    KD9JCD: I believe it still applies. I modified the libraries as suggested and that solved at least part of my problems getting it to compile. the pic you see in my post above is with the T4.1 and the modified AR_Math libraries. I also had problems with the SPI speed with the ILI9341. Had to reduce it 1/2 the values in the code. The T4.1 also heated up at 600MHz try 300MHz and the move up to the point where it becomes unstable and back off a bit. At those rates and setting the sample rate up to 192KHz it uses about 38% of the CPU and the temp is at 52 deg C. Runs very stable now. At 96KHz sample rate it uses about 19% CPU.
  15. #590
    Nov 2020
    New Haven, Indiana
    5
    AC8GY: Can you give me a link to the modifications you used? The only modifications to the math libraries that I have found affect only the Teensy 3.X. In your message above you said "search here for info" -- and I assumed that the "here" meant this forum, since there was no embedded link. I have searched the forum and found no information on updating the math libraries for the Teensy 4.X.
  16. #591
    Mar 2018
    Cincinnati, OH, USA
    5
    KD9JCD: Search for "Canoe:" then scroll down in Convolution SDR to his post on 01-02-2017. I just followed the directions and it worked.
  17. #592
    Oct 2015
    Central Europe
    654
    @AC8GY, @KD9JCD, @DH1AKF: I will try to answer your questions below:
    Sorry for my late reply!
    Teensy Convolution SDR & T3.6:
    * I am afraid I ruined the T3.6 support in one of my last additions to the software
    * that is also the reason for the memory overflow
    * the new wideband FM demodulation procedure is too heavy for the T3.6, so probably it should be commented out for the T3.6
    * I am not sure when/if I will be able to repair that . . . sorry Wolfgang ! (it was not intended, my fault)
    That all means: FOR THE MOMENT, the current software obviously only supports T4.0 and T4.1
    CMSIS lib:
    * for T4.0 or T4.1, there is no need to do anything with the library, Teensyduino already has a newer version of CMSIS included and it works without altering that lib
    * for T3.6, there is the need to install a newer version and the mentioned post by Canoe is the right hint to do this
    SPI speed ILI9341:
    * I do not have extensive experience with different displays, but it seems that displays of different brand and sizes react differently to SPI speed, so this seems a matter of trial and error to alter the SPI speed
    Heat production of T4 processor:
    * my recommendation is using a heatsink: I use one with a heavy copper base and copper blades on it attached to the processor with thermal glue. This keeps the processor temperature below 45 degrees Celsius even at full speed.
    * but I also speed down the processor to 300MHz often if possible in order to lower power supply drain (processor speed is a menu entry in T4.x)
    * overclocking (above 600MHz) is not recommended, the software becomes unreliable and often crashes above 600MHz
    Expansion to TRX:
    * yes, please!
    * go ahead!
    * why not share your plans on this forum?
    @Henk: please contact the Msi001 specialists for details of the software addressing the Msi001 (Esteban and tisho).
  18. #593
    Mar 2018
    Cincinnati, OH, USA
    5
    @DD4WH
    Frank, I just sent you a message with more detail.
    Al
    AC8GY
  19. #594
    Nov 2020
    5
    I compiled the sketch #define HARDWARE_FRANKB but I don't have the buttons working what else should I do. Please help me
  20. #595
    8,551
    You for sure don't have my Hardware (Yes, it is confusing with all the Franks here.. -use the default setting!
  21. #596
    Nov 2020
    5
    I have a board with a PCF8574 chip
  22. #597
    8,551
    Ah..OK
    Does the I2C scanner (from Teensyduino-examples) find the PCF8547? Which address? It should be the same as in the SDR.
  23. #598
    Nov 2020
    5
    yes it sees the address 0*20
  24. #599
    Nov 2020
    5
    you can send me a compiled sketch #define HARDWARE_FRANKB. On my e-mail.I will be very grateful
  25. #600
    8,551
    Quote Originally Posted by rudolf0351 View Post
    Sorry, at the moment I don't have a compiled version myself. I can't test anything either, because my hardware is disassembled in the basement.
    I don't use the program anymore.
    Is the interrupt PIN of the PCF connected? Default would be a connection with PIN 22 of the Teensy.
    If I remember correctly the interrupt pin is needed it does not work without.
