Results 1 to 3 of 3
Thread: Teensy Midi | Pitch Bend Range
    Nov 2016
    9
    Hi Guys,
    I'm creating a midi controller using a Teensy 3.2. I implemented pitch bending and everything is working fine. However, the pitch bend is over an initially undefined range of semitones. I would like to be able to set the device to a specific pitch bend range like 12 or 24. I found how to do it here: http://www.midikits.net/midi_analyser/pitch_bend.htm
    Only I do not really have a clue how to implement it within Teensyduino. Is there anyone that can help me out?
    Thanks in advance!
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,348
    That reference has some clarity issues.
    You send:
    usbMIDI.sendControlChange(101, 0, channel)
    usbMIDI.sendControlChange(100, 0, channel)
    usbMIDI.sendControlChange(6, semiRange, channel)
    and then to lock:
    usbMIDI.sendControlChange(101, 127, channel)
    usbMIDI.sendControlChange(100, 127, channel)
    NB - untested ... just my reading of this and other references.
    Not sure if you actually need to send the CC=100s as some references seem to suggest you only need those if you're limiting PM to a CENT range; explicit examples, however, seem to send them even if they are just using CC6 and not CC38.
    Feb 2013
    1,348
    Your reference suggests sending:
    usbMIDI.sendControlChange(38, 00, channel);
    after the CC6 message... others omit.
    Some references seem to suggest either 101,00 or 101,00 will lock the RPN while most seem to use both.
