Results 1 to 16 of 16
Thread: Teensyduino 1.33 Beta #1 Available
    Administrator Paul's Avatar
    Oct 2012
    272
    Here is a first beta test for Teensyduino 1.33.
    It seems some of the communication sync issues made their way into the 1.32 release. Most computers don't experience any problems, but on those which do, a variety of strange errors can occur after compiling but before or during uploading. If you are seeing these problems, please reply here with the Verbose Info log from Teensy Loader, the "teensy_reboot_log.txt" file from your temporary folder, and a copy of the exact error which appeared in the Arduino window.
    An alternative is to revert to version 1.31. These sync issues are present in 1.31, but not (usually) detected. The result is
    uploads tend to work on affected computers, even though error messages occasionally appear. To revert, you will need to install to a fresh copy of Arduino, because the 1.31 installer does not know how to remove files from 1.32 or 1.33.
    Please allow me to appologize, if you're seeing these issues. They're almost certainly a bug or incompatibility within the Teensyduino software. It's my fault. But I really need your help, since none of my computers are able to reproduce the problem. If your PC or Mac shows this issue, please take a moment to collect up the two log files and post here. This info will really help me to figure out what's going wrong.
    Edit: links removed. Please use 1.33-beta2:
    https://forum.pjrc.com/threads/40798...ta-2-Available
    Changes since Teensyduino 1.32:
    • Teensy Loader GUI toolkit updated (wxWidgets 3.1.0)
    • Teensy Loader Verbose Info now logs time with milliseconds
    • More logging in (tempdir)/teensy_reboot_log.txt
    • Mac version now requires OSX 10.7 (Lion) or later
    • Libraries updated: Audio, Tlc5940
    16,266
    On Windows 10, the default temporary folder is C:\Users\(username)\AppData\Local\Temp, where "AppData" is a hidden folder.
    Dec 2016
    6
    Unhappy
    Hey Paul
    I am one of those guys with a strange error.
    This is what I am working with:
    * Teensy 3.6
    * Macbook Pro with MacOS Sierra (10.12.1) -> same Problem on a Windows 7 PC
    * Arduino 1.6.13 (set to Teensy 3.6), Teensyduino 1.33-beta1
    * Sketch: File -> Examples -> Teensy -> Tutorial01 -> Blink
    The Teensy came preloaded with the LED blink code and gets recognized by the Teensy Loader when I push the button. The USB Cable works fine with my smartphone.
    This is what is visible in the Arduino console:
    /Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/philipp/Documents/Arduino/libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180opt,k eys=de-ch -ide-version=10613 -build-path /var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998 -warnings=default -verbose /Applications/Arduino.app/Contents/Java/examples/Teensy/Tutorial1/Blink/Blink.pde
    /Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/philipp/Documents/Arduino/libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180opt,k eys=de-ch -ide-version=10613 -build-path /var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998 -warnings=default -verbose /Applications/Arduino.app/Contents/Java/examples/Teensy/Tutorial1/Blink/Blink.pde
    Using board 'teensy36' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
    Using core 'teensy3' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
    Detecting libraries used...
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/sketch/Blink.pde.cpp" -o "/dev/null"
    Generating function prototypes...
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/sketch/Blink.pde.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/preproc/ctags_target_for_gcc_minus_e.cpp"
    "/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/preproc/ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/sketch/Blink.pde.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/sketch/Blink.pde.cpp.o"
    Compiling libraries...
    Compiling core...
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/memcpy-armv7m.S" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/memcpy-armv7m.S.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/memset.S" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/memset.S.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/analog.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/eeprom.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/eeprom.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/keylayouts.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/keylayouts.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/math_helper.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/math_helper.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/mk20dx128.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/mk20dx128.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/nonstd.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/nonstd.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/pins_teensy.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/pins_teensy.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/ser_print.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/ser_print.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial1.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial1.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial2.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial2.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial3.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial3.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial4.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial4.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial5.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial5.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial6.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial6.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/serial6_lpuart.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial6_lpuart.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/touch.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/touch.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_desc.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_desc.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_dev.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_dev.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_joystick.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_joystick.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_keyboard.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_keyboard.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_mem.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_mem.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_midi.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_midi.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_mouse.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_mouse.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_mtp.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_mtp.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_rawhid.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_rawhid.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_seremu.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_seremu.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_serial.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_serial.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_touch.c" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_touch.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/AudioStream.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/AudioStream.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/DMAChannel.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/DMAChannel.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial1.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial1.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial2.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial2.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial3.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial3.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial4.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial4.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial5.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial5.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/HardwareSerial6.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial6.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/IPAddress.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/IPAddress.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/IntervalTimer.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/IntervalTimer.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/Print.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/Print.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/Stream.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/Stream.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/Tone.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/Tone.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/WMath.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/WMath.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/WString.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/WString.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/avr_emulation.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/avr_emulation.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/main.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/main.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/new.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/new.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_audio.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_audio.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_flightsim.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_flightsim.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/usb_inst.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_inst.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=133 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_GERMAN_SWISS "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/yield.cpp" -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/yield.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/memcpy-armv7m.S.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/memset.S.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/analog.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/eeprom.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/keylayouts.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/math_helper.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/mk20dx128.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/nonstd.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/pins_teensy.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/ser_print.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial1.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial2.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial3.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial4.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial5.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial6.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/serial6_lpuart.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/touch.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_desc.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_dev.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_joystick.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_keyboard.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_mem.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_midi.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_mouse.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_mtp.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_rawhid.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_seremu.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_serial.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_touch.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/AudioStream.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/DMAChannel.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial1.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial2.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial3.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial4.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial5.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/HardwareSerial6.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/IPAddress.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/IntervalTimer.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/Print.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/Stream.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/Tone.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/WMath.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/WString.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/avr_emulation.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/main.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/new.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_audio.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_flightsim.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/usb_inst.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/yield.cpp.o"
    Linking everything together...
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481566429 "-T/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/mk66fx1m0.ld" -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/Blink.pde.elf" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/sketch/Blink.pde.cpp.o" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "-L/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998" -larm_cortexM4lf_math -lm
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/Blink.pde.elf" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/Blink.pde.eep"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/Blink.pde.elf" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/Blink.pde.hex"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998" "-tools=/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/" "-board=TEENSY36"
    Opening Teensy Loader...
    Error compiling for board Teensy 3.6.
    If I click verify a second time I get:
    [...same as above...]
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481566956 "-T/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/mk66fx1m0.ld" -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/Blink.pde.elf" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/sketch/Blink.pde.cpp.o" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998/core/core.a" "-L/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_234998" -larm_cortexM4lf_math -lm
    Oh no, the compiler quit with an error, but did not print any error messages!
    Your computer may be running out of memory or resources. Try closing other
    windows or programs
    The log is attached.
    Thank you for your help!
    Attached Files Attached Files
    16,266
    Quote Originally Posted by kophi View Post
    Is Teensy Loader still on your screen? If so, please use Help > Verbose Info to capture its log file too. There's 2 log files, one from the Arduino side (the one you posted) and the one from the Teensy Loader side.
    Dec 2016
    6
    I attached the teensy_reboot_log.txt in my last post.
    This is the content of the verbose window:
    18:33:03.624: Teensy Loader 1.33-beta1, begin program
    18:33:03.661: Listening for remote control on port 3149
    18:33:03.663: initialized, showing main window
    18:33:03.715: remote connection opened
    18:33:03.717: remote cmd: "comment: Teensyduino 1.33-beta1 - MACOSX (teensy_post_compile)"
    18:33:03.718: remote cmd: "status"
    18:33:03.719: status data sent
    18:33:03.729: remote cmd: "status"
    18:33:03.730: status data sent
    18:33:03.743: remote cmd: "status"
    18:33:03.744: status data sent
    18:33:03.756: remote cmd: "status"
    18:33:03.757: status data sent
    18:33:03.768: remote connection closed
    18:33:03.911: HID/macos: no devices found
    18:33:07.198: Verbose Info event
    Dec 2016
    7
    Same here w 1.33b1
    Same here w 1.33b1 ...compile sent and four remote cmd: "status" w confirmation. Arduino complains of OOM and errors out.
    Dec 2016
    1
    Same for me too
    Hi!
    I recently got a computer upgrade and had to reinstall everything. I am using Windows 8 and Arduino 1.6.13 as well as the Teensyduino 1.33Beta. The error message is as below:
    PHP Code:
    Error compiling
    for board Teensy 3.2 3.1
    The Verbose Information is also attached below such that at 13:51:07 I plugged in the Teensy and at 15:51:12 I tried to verify/compile the code but the error message popped up and no COM port was found for the Teensy:
    PHP Code:
    13:51:07.198HID/win32:  vid:16C0 pid:0478 ver:0103
    13
    :51:07.198HID/win32:  usage_page:FF9Cusage:0021
    13
    :51:07.198Device came onlinecode_size 262144
    13
    :51:07.198Board isTeensy 3.2 (MK20DX256), version 1.03
    13
    :51:07.198set background IMG_ONLINE
    13
    :51:07.448HID/win32HidD_GetPreparsedData okdevice still online :-)
    13:51:12.903remote connection opened
    13
    :51:12.904remote cmd"comment: Teensyduino 1.33-beta1 - WINDOWS (teensy_post_compile)"
    13:51:12.904remote cmd"status"
    13:51:12.904status data sent
    13
    :51:12.915remote cmd"status"
    13:51:12.915status data sent
    13
    :51:12.927remote cmd"status"
    13:51:12.927status data sent
    13
    :51:12.938remote cmd"status"
    13:51:12.938status data sent
    13
    :51:12.951remote connection closed
    13
    :52:31.571Verbose Info event
    Dec 2016
    7
    I get the same behavior w 1.32 or 1.33b1 - same output, etc.
    Dec 2016
    4
    Hi Paul,
    I updated to 1.33Beta (Teensy 3.2, Windows 10, Arduino 1.6.13) as you requested in a different thread. Still getting the following error:
    windows or programs
    Error compiling for board Teensy 3.2 / 3.1.
    14:37:27.292: Device came online, code_size = 262144
    14:37:27.294: Board is: Teensy 3.2 (MK20DX256), version 1.03
    14:37:27.295: set background IMG_ONLINE
    14:37:27.540: HID/win32: HidD_GetPreparsedData ok, device still online :-)
    14:39:13.065: remote connection opened
    14:39:13.067: remote cmd: "comment: Teensyduino 1.33-beta1 - WINDOWS (teensy_post_compile)"
    14:39:13.069: remote cmd: "status"
    14:39:13.072: status data sent
    14:39:13.083: remote cmd: "status"
    14:39:13.084: status data sent
    14:39:13.095: remote cmd: "status"
    14:39:13.096: status data sent
    14:39:13.107: remote cmd: "status"
    14:39:13.108: status data sent
    14:39:13.142: remote connection closed
    14:44:21.311: Verbose Info event
    3,232
    Quick FYI - To get to your temp directory, open up any File Explorer window and in the top area that shows the folder you are browsing, type: %temp%
    and it should take you to your temp folder
    16,266
    Quote Originally Posted by glenngineer View Post
    Any chance you could run it again and post both logs? One is in Help > Verbose Info and the other is a file in your temp folder (which is hidden on Winwows... see above). This new beta logs everything with milliseconds, so I can match them up much better, but only if I have both logs (and they're from the same run... the ones above are from different runs).
    I'm going to work on this tonight and tomorrow and hopefully have a fix to try out soon.
    Dec 2016
    7
    I know you're asking Glen here ... but any idea where that temp log gets put on a Mac? I'd love to dig in with you here.
    Dec 2016
    4
    Hi Paul. Here is the Arduino output, the Verbose Log, followed by the teensy_reboot_log. - Glenn
    Arduino: 1.6.13 (Windows 10), TD: 1.33-beta1, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimize speed (overclock), US English"
    Verbose Information Log:
    20:31:55.639: Teensy Loader 1.33-beta1, begin program
    20:31:55.738: Listening for remote control on port 3149
    20:31:55.738: initialized, showing main window
    20:31:55.966: HID/win32: vid:0483 pid:91D1 ver:0037
    20:31:55.968: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.969: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.970: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.971: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.972: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.973: HID/win32: vid:04F3 pid:300F ver:0008
    20:31:55.974: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.975: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.976: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.977: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.978: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.979: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.980: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.981: HID/win32: vid:045E pid:0000 ver:0000
    20:31:55.982: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:55.983: HID/win32: vid:045E pid:0000 ver:0000
    20:31:56.045: HID/win32: vid:04F3 pid:228A ver:2015
    20:31:56.046: HID/win32: vid:8087 pid:0A1E ver:0200
    20:31:56.047: HID/win32: vid:04F3 pid:228A ver:2015
    20:31:56.110: HID/win32: vid:16C0 pid:0478 ver:0103
    20:31:56.111: HID/win32: usage_page:FF9C, usage:0021
    20:31:56.112: Device came online, code_size = 262144
    20:31:56.113: Board is: Teensy 3.2 (MK20DX256), version 1.03
    20:31:56.114: set background IMG_ONLINE
    20:31:56.123: remote connection opened
    20:31:56.126: remote cmd: "comment: Teensyduino 1.33-beta1 - WINDOWS (teensy_post_compile)"
    20:31:56.128: remote cmd: "status"
    20:31:56.130: status data sent
    20:31:56.141: remote cmd: "status"
    20:31:56.143: status data sent
    20:31:56.155: remote cmd: "status"
    20:31:56.157: status data sent
    20:31:56.168: remote cmd: "status"
    20:31:56.170: status data sent
    20:31:56.203: remote connection closed
    20:31:56.205: HID/win32: HidD_GetPreparsedData ok, device still online :-)
    20:32:43.610: Verbose Info event
    teensy_reboot_log.txt Contents:
    20:31:54.284 post_compile: Begin
    20:31:54.285 post_compile: Connect attempt to port 3149
    20:31:55.504 post_compile: Connect attempt to port 3149
    20:31:56.005 post_compile: Connected to port 3149
    20:31:56.124 post_compile: Sending command: comment: Teensyduino 1.33-beta1 - WINDOWS (teensy_post_compile)
    20:31:56.127 post_compile: Sending status request
    20:31:56.129 post_compile: Receive status readable = 0
    20:31:56.130 post_compile: Receive status auto = 0
    20:31:56.130 post_compile: Receive status online = 1
    20:31:56.130 post_compile: Receive status online_count = 1
    20:31:56.130 post_compile: Receive status offline_count = 1
    20:31:56.130 post_compile: Receive status state = 0
    20:31:56.130 post_compile: Receive status EOT
    20:31:56.141 post_compile: Sending status request
    20:31:56.143 post_compile: Receive status readable = 0
    20:31:56.143 post_compile: Receive status auto = 0
    20:31:56.143 post_compile: Receive status online = 1
    20:31:56.143 post_compile: Receive status online_count = 1
    20:31:56.143 post_compile: Receive status offline_count = 1
    20:31:56.143 post_compile: Receive status state = 0
    20:31:56.143 post_compile: Receive status EOT
    20:31:56.155 post_compile: Sending status request
    20:31:56.157 post_compile: Receive status readable = 0
    20:31:56.157 post_compile: Receive status auto = 0
    20:31:56.157 post_compile: Receive status online = 1
    20:31:56.157 post_compile: Receive status online_count = 1
    20:31:56.157 post_compile: Receive status offline_count = 1
    20:31:56.157 post_compile: Receive status state = 0
    20:31:56.157 post_compile: Receive status EOT
    20:31:56.168 post_compile: Sending status request
    20:31:56.170 post_compile: Receive status readable = 0
    20:31:56.170 post_compile: Receive status auto = 0
    20:31:56.170 post_compile: Receive status online = 1
    20:31:56.170 post_compile: Receive status online_count = 1
    20:31:56.170 post_compile: Receive status offline_count = 1
    20:31:56.170 post_compile: Receive status state = 0
    20:31:56.170 post_compile: Receive status EOT
    Dec 2016
    6
    Quote Originally Posted by znevans View Post
    The temp folder on Mac and Linux might be /tmp
    Dec 2016
    6
    My previous logs were out of sync. Here is a full set of new logs.
    Arduino last lines (full log attached):
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481622344 "-T/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/mk66fx1m0.ld" -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482/Blink.pde.elf" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482/sketch/Blink.pde.cpp.o" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482/core/core.a" "-L/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482" -larm_cortexM4lf_math -lm
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482/Blink.pde.elf" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482/Blink.pde.eep"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482/Blink.pde.elf" "/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482/Blink.pde.hex"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=/var/folders/sd/c85sk5296ml9661crj5fqw880000gn/T/arduino_build_298482" "-tools=/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/" "-board=TEENSY36"
    Teensy loader verbose:
    09:45:53.386: Teensy Loader 1.33-beta1, begin program
    09:45:53.436: Listening for remote control on port 3149
    09:45:53.437: initialized, showing main window
    09:45:53.525: remote connection opened
    09:45:53.527: remote cmd: "comment: Teensyduino 1.33-beta1 - MACOSX (teensy_post_compile)"
    09:45:53.529: remote cmd: "status"
    09:45:53.529: status data sent
    09:45:53.541: remote cmd: "status"
    09:45:53.543: status data sent
    09:45:53.556: remote cmd: "status"
    09:45:53.557: status data sent
    09:45:53.569: remote cmd: "status"
    09:45:53.571: status data sent
    09:45:53.584: remote connection closed
    09:45:53.701: HID/macos: no devices found
    09:46:32.363: Verbose Info event
    teensy_reboot_log.txt:
    09:45:52.901 post_compile: Begin
    09:45:52.902 post_compile: Connect attempt to port 3149
    09:45:52.903 post_compile: Connect attempt to port 3149
    09:45:53.006 post_compile: Connect attempt to port 3149
    09:45:53.108 post_compile: Connect attempt to port 3149
    09:45:53.213 post_compile: Connect attempt to port 3149
    09:45:53.316 post_compile: Connect attempt to port 3149
    09:45:53.420 post_compile: Connect attempt to port 3149
    09:45:53.524 post_compile: Connect attempt to port 3149
    09:45:53.524 post_compile: Connected to port 3149
    09:45:53.526 post_compile: Sending command: comment: Teensyduino 1.33-beta1 - MACOSX (teensy_post_compile)
    09:45:53.529 post_compile: Sending status request
    09:45:53.529 post_compile: Receive status readable = 0
    09:45:53.529 post_compile: Receive status auto = 0
    09:45:53.529 post_compile: Receive status online = 0
    09:45:53.529 post_compile: Receive status online_count = 0
    09:45:53.529 post_compile: Receive status offline_count = 0
    09:45:53.529 post_compile: Receive status state = 0
    09:45:53.529 post_compile: Receive status EOT
    09:45:53.541 post_compile: Sending status request
    09:45:53.543 post_compile: Receive status readable = 0
    09:45:53.543 post_compile: Receive status auto = 0
    09:45:53.543 post_compile: Receive status online = 0
    09:45:53.543 post_compile: Receive status online_count = 0
    09:45:53.543 post_compile: Receive status offline_count = 0
    09:45:53.543 post_compile: Receive status state = 0
    09:45:53.543 post_compile: Receive status EOT
    09:45:53.556 post_compile: Sending status request
    09:45:53.557 post_compile: Receive status readable = 0
    09:45:53.557 post_compile: Receive status auto = 0
    09:45:53.557 post_compile: Receive status online = 0
    09:45:53.557 post_compile: Receive status online_count = 0
    09:45:53.557 post_compile: Receive status offline_count = 0
    09:45:53.557 post_compile: Receive status state = 0
    09:45:53.557 post_compile: Receive status EOT
    09:45:53.569 post_compile: Sending status request
    09:45:53.570 post_compile: Receive status readable = 0
    09:45:53.570 post_compile: Receive status auto = 0
    09:45:53.570 post_compile: Receive status online = 0
    09:45:53.570 post_compile: Receive status online_count = 0
    09:45:53.571 post_compile: Receive status offline_count = 0
    09:45:53.571 post_compile: Receive status state = 0
    09:45:53.571 post_compile: Receive status EOT
    Hope that helps.
    Administrator Paul's Avatar
    Oct 2012
    272
    I believe I've found and fixed the bug. Please use this new beta:
    https://forum.pjrc.com/threads/40798...ta-2-Available
    The error involves a bug in teensy_post_compile where an empty filename is treated as a parse error. After 4 tries, it gives up trying to inform Teensy Loader of your freshly-compiled code. This problem escaped detection during the 1.32 beta testing because (apparently) all machines I and others used for testing already had uploaded once, and had a filename configured in Teensy Loader.
    This beta2 version should fix the problem.
    Please let me know how it works for you (please reply on the new 1.32-beta2 thread). If all looks good, I'll quickly publish 1.33 to replace the flawed 1.32 release.
    Update: 1.33 has been officially released, to fix these problems.
    http://www.pjrc.com/teensy/td_download.html
