Hi there,
I'm trying to get a sketch running that uses both the FastLED library over SPI with the Prop Shield and also an atwink1500 adafruit module with WiFi101 at the same time.
I've got both working separately and I understand that when using multiple SPI slaves I have to manage CS(chip-select) pins. The issue I'm having is figuring out how the WiFi101 library uses the CS pin, I've looked over the source and it's not apparent to me.
If anyone could give me some clues that would be incredibly helpful as I've hit a brick wall on this one.
