Page 1 of 4 1 2 3 ... LastLast
Results 1 to 25 of 84
Thread: Teensyduino 1.34 Beta #1 (ARM Toolchain Update)
    Administrator Paul's Avatar
    Oct 2012
    294
    Here is a first beta test for Teensyduino 1.34.
    This version updates the ARM toolchain used to compile for Teensy LC and 3.x.
    Linux 32 bit:
    http://www.pjrc.com/teensy/td_134-be...nstall.linux32
    Linux 64 bit:
    http://www.pjrc.com/teensy/td_134-be...nstall.linux64
    Linux ARM:
    http://www.pjrc.com/teensy/td_134-be...stall.linuxarm
    Mac OS-X:
    http://www.pjrc.com/teensy/td_134-be...inoInstall.dmg
    Windows:
    http://www.pjrc.com/teensy/td_134-be...inoInstall.exe
    Changes since Teensyduino 1.33:
    • Update ARM Toolchain to gcc 5.4 (was gcc 4.8)
    • Add Tools > Optimize menu
    • Fix driver install/update on Windows 7 & 8
    • Prevent "might not have installed correctly" message on Windows
    Oct 2012
    294
    This beta adds a Tools > Optimize menu, so you can easily experiment with 10 different optimization settings.
    (click for full size)
    LTO is Link Time Optimization. It can really reduce the size and increase the speed of many programs. But it might come with compatibility issues.
    Fastest, Faster and Fast are optimization flags -O3, -O2 and -O. Debug is -Og, and Smallest is -Os plus use of the nano C library.
    Please give these various settings a try. We probably have a couple months before Arduino releases a new version. If this toolchain update or LTO breaks too many programs & libraries, I can always revert to the 4.8 toolchain. But hopefully we can play with this quite a bit in the coming weeks and build enough confidence to use it in a non-beta release.
    3,536
    Quote Originally Posted by Paul View Post
    Linux ARM: (still struggling to build the new toolchain...)
    Now downloading windows version...
    Curious, what are you using to build the Arm version? RPI? If so you would probably get much faster response using something like an Odroid XU4, especially with an EMMC.
    http://ameridroid.com/products/odroid-xu4
    17,628
    Does Odroid XU4 use the same ARM ABI? All the info I've found says RPi is v6 and upwards compatible with v7 or v8, but programs compiled on those boards can't run on v6.
    But if there is a way, I'd love to use faster hardware! So far I've been using the original model B. Ordered a RPi3. It's supposed to arrive early next week.
    2,718
    I believe the Odroid uses Arm in 64-bit mode, and Raspberry Pi uses Arm 32-bit chips. I don't know if you run/build 32-bit binaries on a 64-bit system.
    3,536
    Actually Odroid XU4 and C1 are 32 bit. It is the C2 which is 64 bit.
    6,444
    PURGED - wow <57 MB downloaded! TD_1.33 was 72 MB.
    Question - would it be easy for 'somebody' to make a makefile that would casually build multiple binaries with a single command?
    <edit>: TD_1.34 Installed fine on copy of 1.6.13, first few default compiles of open sketches no problems. Just this one accurate warning I see that may not be new:
    TimedStartBlink_SerEv:55: warning: array subscript has type 'char'
    That added 'optimize' Menu does look nice.
    1,482
    raspberry pi 3 is 64-bit, gcc 4.9.2,debian(jessie)
    I like the "optimize window"
    6,444
    I got a pi 3 months back - unpowered yet - but I understood it was still using 32 bit Jessie for compatibility to all existing code/usage?
    Germany NRW
    4,438
    I'm getting the following errors in some of my sketches:
    - error: 'strncmpi' was not declared in this scope
    - error: 'strcasestr' was not declared in this scope
    (not from libs, but from my own code)
    Edit: They should be in string.h - i've included that lib (and it worked with older teensyduino-versions)
    Germany NRW
    4,438
    string.h:
    #if __GNU_VISIBLE
    char    *_EXFUN(strcasestr,(const char *, const char *));
    I added "#define __GNU_VISIBLE 1" to my Sketch, and now the compiler complains:
    c:\arduino\hardware\tools\arm\arm-none-eabi\include\sys\features.h:256:0: note: this is the location of the previous definition
     #define __GNU_VISIBLE  0
    features.h :
    #ifdef _GNU_SOURCE
    #else
    , so _GNU_SOURCE is not defined.
    Is there a compiler-switch missing ?
    Senior Member duff's Avatar
    Las Vegas
    904
    Audio FFT example doesn't work with any Optimize menu options. I'm using Auduino 1.6.13
    1,482
    you're right, RPI3 jessie is still running in 32 bit mode.
    i tested 1.6.12 with 1.34beta1 on mac os,
    coremark:
    previously T3.2@96mhz -O2 189.4 iterations/sec | with LTO fastest 207.29
    previously T3.6@180mhz -O2 384.0 | with LTO fastest 447.7
    ... so many optimization choices ...
    T3.6@180mhz coremark
            fastest LTO 447.676389
            fastest     463.692033
            faster LTO  437.121360
            faster      434.528617
            fast  LTO   333.619557
            fast        333.032915
            small LTO   323.248789  no float printf
            small       320.692182
    1,482
    is compiler doing hardware floating point? my linpack benchmark with LTO fastest is giving < 1 megaflop, should be 30 megaflops
    is it really using gcc 5.4, if i look at version of /Applications/Arduino.app//Contents/Java/hardware/tools/arm/arm-none-eabi/bin/gcc
    it still says 4.8.4
    maybe i'm looking in wrong place (i don't use mac that much)
    EDIT found it /Applications/Arduino.app//Contents/Java/hardware/tools/arm/bin/arm-none-eabi-gcc-5.4.1
    EDIT 2, restarted IDE floating point seems OK now ... pilot error i guess
    Senior Member brtaylor's Avatar
    Mar 2016
    Portland, OR
    278
    Installed just fine on Fedora 25 and Arduino 1.6.13. I'll let you know if I run into anything as I use it...
    6,444
    One simple sketch: TD_1.34 beats TD_1.33, and using LTO on TD_1.34 makes a real difference
    I created a sketch watching pin 3 with FreqMeasure.countToFrequency().
    Then in the sketch under test with pin 12 as output in loop() I do :: #define q12() {GPIOC_PTOR=128;} // Toggle pin 12
    That pin 12 feeds the first T_3.6 pin 3 and shows the cycle rate each sec.
    So far that - with a not quite empty loop() on a T_3.6 at 240 MHz shows:
    TD_1.33 [ using an empty yield() ]:: == 1,153,846.13
    TD_1.33 [ using PJRC yield() ]:: == 451,127.81
    TD_1.34 Without LTO [ using an empty yield() ]:: FASTER == FASTEST == 1,304,347.88 Hz
    TD_1.34 With LTO [ using an empty yield() ]::
    FASTER = 1,935,483.88 Hz
    FASTEST = 1,818,181.88 Hz
    TD_1.34 With LTO [ using PJRC yield() ]::
    FASTER = 857,142.88
    FASTEST = 800,000.00
    17,628
    Raspberry Pi 3 is up and running here, after a few false starts with weaker power supplies. It really does draw over 2 amps when running at full load! (edit: or maybe not... could have been just crappy wall wart power supplies...) Building the toolchain now. Seems to be going a *lot* faster. The Broadcom chip gets scorching hot. I've got a 120mm fan cooling the whole thing.
    Edit: "vcgencmd measure_temp" says "temp=51.0'C", and that's with a big 120mm fan blowing down.
    3,536
    Hi Paul,
    That sounds HOT! It is interesting that last week I purchased a RPI3 as it looks like Trossen Robotics will be using them in some of their products... Mine came with two small heat sinks to stick on the two chips and with the package I purchased from Amazon a 2.5 amp power supply.
    For the fun of it, I pulled my spare Odroid Xu3-lite out from my cabinet (my 2 XU4's are mounted in two robots) and I downloaded that latest Ubuntu 16.04 image and updated the 32gb EMMC...
    I saw a project up in your github: https://github.com/PaulStoffregen/AR..._2016q3_Source And it looked like maybe it was the one you are trying to build?
    So I downloaded it to Odroid and tried to follow your steps. I did not create virtual memory yet, but went through some of the steps.
    It looked like it completed: ./build-prerequisites.sh
    But it died somewhere in: ./build-toolchain.sh
    If this is what you are building, it will be interesting to see the differences in time building between using this and RPI3. But some of this may depend on if the build process can use more of the cores of the 8 cores of the processor...
    If it works, I could probably loan it to you.
    17,628
    Yup, that's the new toolchain.
    I almost got through ./build-toolchain.sh, until the USB hub I was using for power died. It ran for approx 5 hours to get into 2nd gcc compile stage.
    On the old Pi (original version 1) running wheezy (from 2014), it complains about a gcc bug after about a day compiling.
    This one is the old toolchain. It builds in approx 47 hours on the old Pi running wheezy.
    https://github.com/PaulStoffregen/AR..._2014q3_Source
    I'm restarting the new toolchain build again on the Pi3 with jessie. This time I've added a small heatsink on the chip and a lab bench power supply capable of 10 amps.
    3,536
    I have restarted the build on the Odroid 3 times now, as it failed with missing some different things I need to apt-get install... It is using one of their 4amp power supplies. And I don't think it is overheating too badly as the automatic fan is only on part of the time. So I don't think the automatic throttling of the Cores down to 900mhz is happening due to heat... Could be wrong.
    It was good I added 2GB of virtual memory using the information in: https://www.digitalocean.com/communi...n-ubuntu-14-04
    As the htop command has shown all 8 cores doing something and at times the SWP being used.
    Not sure how long this one will run.
    It does run reasonably warm by looking at:
    odroid@odroid:~$ cat /sys/devices/10060000.tmu/temp
    sensor0 : 77000
    sensor1 : 69000
    sensor2 : 83000
    sensor3 : 77000
    sensor4 : 65000
    I think it throttles when it gets to 100C so here shows maybe 83C high
    Germany NRW
    4,438
    Can you add something like the defs.h solution ? It really makes life easier...
    17,628
    I've completed building the new toolchain for Raspberry Pi and (hopefully) other ARM-based machines.
    Edited the first post. The installer for linuxarm is now available.
    If anyone tests on non-RPI boards, or anything other than Raspberry Pi 3, please let me know if it worked?
    17,628
    Has anyone tried other stuff depending on the arm_math.h? Does it work with and/or without LTO?
    My guess is the library probably needs to be rebuilt for LTO. Earlier this year I started this work, in anticipation of someday needing to be able to rebuild it....
    https://github.com/PaulStoffregen/arm_math
    6,444
    Talkie compiles and runs and sounds right with PJRC PROP on T_3.6 @240 MHz Faster and Fastest +/- LTO : no warnings or errors. Same at 180 Fastest and Smallest with LTO.
    <edit>: Verify compiled for T_3.2 - no warn/err - but not uploaded tested.
    Germany NRW
    4,438
    Do you have plans to use a newer version ? arm_math is from 2012
