MIDI vs. I2C at a level shifter
vehtoh
Hi Guys,
hope someone can give me a hint, whats runnig in the false direction with my MIDI/Synth Project. I've startet to build an Audio Sythesizer (first with Arduino, but since a few weeks with a Teensy 3.5). I'm realy impressed about the sound quality an possitbilities of the Audio library. Big Thanks to Paul! But at the moment i'm very fucked up.
I've added 2 LED Rotary Pots to the Project, 8 analog Pots + 1 RGB LED for each (maybe for some sequencer stuff later), 2 Neopixel 12er Rings (to help througth the navigation via the Rotary Encoders) and a MIDI input Circuit. Output is via DAC0 and into my Mixer. So far all this works very well.
Last Thing i wanted to add, is a LCD Display (20x4, HD44780 controlled, 5V) witch i connected via I2C. I took a wihle to get the LCD running, because on the arduion i could use it directly and on teensy i have to use a level shifter (5V to 3.3V, bidirectional), but finally also this works pretty nice. (By the way, the Liquid Crystal library and the i2c_3t library seems not work together, getting compiling errors with that, so i use the standard wire.h library and New Liquid Cristal library.)
So far, so good. But now i addead all these things together and discovert a "strange" behaviour. (i have no idea, why this happens). If i connect the LCD on SCL0 + SAD0, PIN19, 18, via the Level Shifter, Teensy didn`t read the MIDI-Inputs (RX1, PIN0) correctly. Sounds like there are some bits comming throught at the startup, (it plays 1-2 Notes) but after that, no further MIDI Data arrives. If I unwire the SDA0 (and it works only while unwiring this, not the SCL0) the MIDI Data comes in as it should. But obviously the LCD isn`t working.
What i´ve tried:
- Other Serial Inputs for MIDI 1-3 -> Same result, 4 -> False MIDI Reading
- Running the MIDI Circuit also on 5V and sending the Signal also througth the Level Shifter -> Same Result
- Other SCL, SDA Ports wanted to try out, ut dit not know how to reach them (is there a description for that anywhere?)
- Tested the single Elements separatly -> they work fine
- thougth about some grounding problems and testet serval connections with the 3.3V and 5V -> on its own, the LCD and MIDI in work without errors, i can only reproduce the problem as described, with the SDA connection on or off
What i´ve also detected:
- the LCD will also work, when i connect the SCL0, SDA0 directly to the teensy and only the Level Shifter is connected to GND, V 3.3+ @ Teensy and GND, 5V from external
- if i plug or unplug the SDA while Sketch is runnig nothing changes. means: if i startet without connected SDA MIDI continous playing as i plug in and if i start with connected SDA and unplug it while running, MIDI stays silent.
As you wanna see my code, here is the complete uncleaned:
const float tune_frequencies2_PGM[128] =
const float velocity2amplitude[127] = {
//AudioSynthWaveform  *Waveforms[] = {&waveform1, &waveform2, &waveform3,
//                                    &waveform4, &waveform5, &waveform6,
//                                    &waveform7, &waveform8, &waveform9,
//                                    &waveform10, &waveform11, &waveform12
AudioEffectEnvelope  *Envelopes[] = {&envelope1, &envelope2, &envelope3,
                                     &envelope4, &envelope5, &envelope6,
                                     &envelope7, &envelope8
AudioFilterStateVariable   *Filters[] = {&filter1, &filter2, &filter3,
                                         &filter4, &filter5, &filter6,
                                         &filter7, &filter8
AudioMixer4   *Mixers1[] = {&mixer4, &mixer9, &mixer14, &mixer19,
                            &mixer25, &mixer30, &mixer35, &mixer40
AudioMixer4   *Mixers2[] = {&mixer5, &mixer10, &mixer15, &mixer20,
                            &mixer26, &mixer31, &mixer36, &mixer41
short wave_type[] = {
  WAVEFORM_SINE,
  WAVEFORM_SINE,
  WAVEFORM_TRIANGLE,
  WAVEFORM_SQUARE,
  WAVEFORM_SAWTOOTH,
  WAVEFORM_SAWTOOTH_REVERSE,
  WAVEFORM_PULSE,
  WAVEFORM_SAMPLE_HOLD
//#include <i2c_t3.h>
#include <LiquidCrystal_I2C.h>
//// set the LCD address to 0x20 for a 20 chars 4 line display
//// Set the pins on the I2C chip used for LCD connections:
////                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
//LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h>
#define NUMRing1      12
#define PIXELPIN            34
#define PIXELPIN2            33
Adafruit_NeoPixel Ring1 = Adafruit_NeoPixel(NUMRing1, PIXELPIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel Ring2 = Adafruit_NeoPixel(NUMRing1, PIXELPIN2, NEO_GRB + NEO_KHZ800);
#include <Bounce.h>
#define ROT1_BUT 8
#define ROT2_BUT 9
const   byte Rot1_R = 7,  Rot1_G = 6, Rot1_B = 5,
             Rot2_R = 4,  Rot2_G = 3, Rot2_B = 2;
Bounce bouncer = Bounce( ROT2_BUT, 16 );
Bounce bouncer2 = Bounce( ROT1_BUT, 16 );
#include <Encoder.h>
#define ROT1_D1 38
#define ROT1_D2 39
#define ROT2_D1 12
#define ROT2_D2 11
////Encoder ROT2_DATA(33, 34);
Encoder ROT1_DATA(ROT1_D1, ROT1_D2);
Encoder ROT2_DATA(ROT2_D1, ROT2_D2);
//Encoder ROT2_DATA(22, 23);
//Encoder ROT1_DATA(ROT1_D1, ROT1_D2);
long positionLeft  = -999;
long positionRight = -999;
int16_t last, value, last2, value2, last3, value3, last4, value4;
#define LED 13
#define SEQ_LED_1 31
#define SEQ_LED_2 30
#define SEQ_LED_3 29
#define SEQ_LED_4 28
#define SEQ_LED_5 27
#define SEQ_LED_6 26
#define SEQ_LED_7 25
#define SEQ_LED_8 24
#define SerialMIDI Serial1
#include <MIDI.h>
//MIDI_CREATE_DEFAULT_INSTANCE();
MIDI_CREATE_INSTANCE(HardwareSerial, SerialMIDI, MIDI);
unsigned long bouncer_millis_last, bouncer2_millis_last, bouncer_millis_now, bouncer2_millis_now, POTs_millis;
byte SEQ_LEDs[] = {SEQ_LED_1, SEQ_LED_2, SEQ_LED_3, SEQ_LED_4, SEQ_LED_5, SEQ_LED_6, SEQ_LED_7, SEQ_LED_8};
const byte  SEQ_LED_G = 35, SEQ_LED_R = 36, SEQ_LED_B = 37;
#include <EEPROM.h>
//short wave_type2[] = {
//  WAVEFORM_TRIANGLE,
//  WAVEFORM_SAWTOOTH_REVERSE,
//  WAVEFORM_SINE,
//  WAVEFORM_SQUARE,
//  WAVEFORM_SAWTOOTH,
//  WAVEFORM_PULSE,
//  WAVEFORM_SAMPLE_HOLD
int POT0, POT1, POT2, POT3, POT4, POT5, POT6, POT7,
    POT0_Last, POT1_Last, POT2_Last, POT3_Last, POT4_Last, POT5_Last, POT6_Last, POT7_Last,
    POT0_Read,   POT1_Read, POT2_Read,   POT3_Read, POT4_Read,   POT5_Read, POT6_Read,   POT7_Read;
byte Wave_Select1 = 0, Wave_Select2 = 3,  Wave_Select3 = 0, Wave_Select4 = 3, Wave_Select5 = 1, Wave_Select6 = 4,
     Wave_Select13, Edit_Count = 1,   Edit_Level = 0, Save_Space = 0, Current_Note, Last_Note, Current_Velocity, Note_On, Array_Nr,
                    Prev_Edit_Count, Prev_Array_Nr, Button_hold, Last_Save_Space, Notes[8], Pitches[8];
int16_t Count1;
int16_t Count2;
int long last_value, last_value2, last_value3, last_value4,     newRight_Speed, newRight2_Speed;
int
Shift_Switch = 0, Option_Select, Prev_Option_Select, Prev_Current_Rot1_Val, Current_Rot1_Val,
Prev_Ring2_Scale,  Ring2_Scale, Voice_Counter,     newRight_Last, First_Random;
float level1 = 1.0, Volume_Split = 0.00, Mixed_Volume = 1.00, level2 = 0.6, level3 = 0.8, level4 = 0.4, level5 = 0.4, level6 = 0.5,
      level13, pitch1, pitch2, pitch3, pitch4, pitch5 , pitch6, pitch13,
      pwm1, pwm2, pwm3,
      mixer2_0, mixer2_1, mixer2_2, mixer2_3, mixer3_0, mixer3_1, mixer3_2, mixer3_3,
      filter1_res, filter2_res,
      del = 0, att = 10, hol = 0, dec = 20, sust = 1.0, rel = 400,
      del2 = 0, att2 = 10, hol2 = 0, dec2 = 20, sust2 = 1.0, rel2 = 400;
long previousMillis = 0, Voices_millis, interval1, LastByte, StartByte, Data_Size, newLeft, newRight, newRight_Raw, Prev_MIDI_Millis, MIDI_Millis;     // will store last time LED was updated
byte MIDI_On = 2, SEQ_Counter = 1, SEQ_Counter_Last, Voices = 6;
boolean Harmonics = 0;
#define      Max_Edit_Count  8
#define POTI_Sum 16
int POT0_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT1_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT2_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT3_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT4_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT5_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT6_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT7_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT8_Array[Max_Edit_Count] = {512, 512, 512, 512, 512, 512, 512, 512};
int POT9_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT10_Array[Max_Edit_Count] = {512, 512, 512, 512, 512, 512, 512, 512};
int POT11_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT12_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT13_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT14_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
int POT15_Array[Max_Edit_Count] =  {512, 512, 512, 512, 512, 512, 512, 512};
//#define WIRE2_PINS   I2C_PINS_3_4
// ============================================ SETUP =================================
//#define USE_SERIAL_PORT         Serial4
//  Serial.begin(115200);
  SerialMIDI.begin(31250);
  //    Wire2.begin(I2C_MASTER, 0x00, WIRE2_PINS, I2C_PULLUP_EXT, 400000);
  lcd.begin(20, 4);        // initialize the lcd for 20 chars 4 lines and turn on backlight
  Serial.println(" Good Morning... ");
  lcd.setCursor(0, 0);
  lcd.print("Good Morning...");
  delay(200);
  //  //  lcd.backlight(); // finish with backlight on
  Ring1.begin();
  Ring2.begin();
  pinMode(ROT2_BUT, INPUT);
  pinMode(ROT1_BUT, INPUT);
  randomSeed(analogRead(2));
  //  lcd.clear();
  // Initiate MIDI communications, listen to all channels
  MIDI.begin(MIDI_CHANNEL_OMNI);
  // Connect the HandleNoteOn function to the library, so it is called upon reception of a NoteOn.
  MIDI.setHandleNoteOn(HandleNoteOn);  // Put only the name of the function
  MIDI.setHandleNoteOff(HandleNoteOff);
  Save_Space = EEPROM.read(0);
  EEPROM_READ(Save_Space);
  SAVE_SPACE_UPDATE();
  // Initialize processor and memory measurements
  AudioProcessorUsageMaxReset();
  AudioMemoryUsageMaxReset();
  POT0_Last = analogRead(A0);
  POT1_Last = analogRead(A1);
  POT2_Last = analogRead(A2);
  POT3_Last = analogRead(A3);
  //  else {
  //          analogWrite(SEQ_LED_1, 0);
  POT4_Last = analogRead(A4);
  POT5_Last = analogRead(A5);
  POT6_Last = analogRead(A6);
  POT7_Last = analogRead(A7);
  for (int i = 0; i < 4; i++) {
    mixer1.gain(i, 0.3);
    mixer2.gain(i, 0.3);
    mixer3.gain(i, 0.6);
    mixer6.gain(i, 0.3);
    mixer7.gain(i, 0.3);
    mixer8.gain(i, 0.6);
    mixer11.gain(i, 0.3);
    mixer12.gain(i, 0.3);
    mixer13.gain(i, 0.6);
    mixer16.gain(i, 0.3);
    mixer17.gain(i, 0.3);
    mixer18.gain(i, 0.6);
    mixer22.gain(i, 0.3);
    mixer23.gain(i, 0.3);
    mixer24.gain(i, 0.6);
    mixer27.gain(i, 0.3);
    mixer28.gain(i, 0.3);
    mixer29.gain(i, 0.6);
    mixer32.gain(i, 0.3);
    mixer33.gain(i, 0.3);
    mixer34.gain(i, 0.6);
    mixer37.gain(i, 0.3);
    mixer38.gain(i, 0.3);
    mixer39.gain(i, 0.6);
    mixer21.gain(i, 0.4);
    mixer42.gain(i, 0.4);
    mixer43.gain(i, 0.6);
  SOUNDS();
  Serial.print("Ready!");
  lcd.setCursor(0, 2);
  lcd.print("Let´s Rock!");
  delay(200);
  lcd.clear();
  //  lcd.setCursor(0,0);
  //  lcd.print("POT0:");
  MIDI_On = 1;
// ============================== Generating Sounds =======================
void SOUNDS() {
  Harmonics = 0;
  if (MIDI_On == 0) Current_Note = 64;
  pitch1 = tune_frequencies2_PGM[Current_Note];
  pitch3 = tune_frequencies2_PGM[Current_Note];
  if (Harmonics == 1)   pitch2 =  tune_frequencies2_PGM[constrain(Current_Note + (64 - (POT2_Array[0] / 8)), 0, 128)]; //(POT5_Array[1] / 1.1625);
  else pitch2 = constrain(tune_frequencies2_PGM[Current_Note] + (3069 - POT2_Array[0] * 4), 1.00, 13000.00);
  if (Harmonics == 1)   pitch4 =  tune_frequencies2_PGM[constrain(Current_Note + (64 - (POT6_Array[0] / 8)), 0, 128)]; //(POT5_Array[1] / 1.1625);
  else pitch4 = constrain(tune_frequencies2_PGM[Current_Note] + (3069 - POT6_Array[0] * 4), 1.00, 13000.00);
  pitch5 =  (63.00 - POT9_Array[0] * (63.00 / 1023.00)) + (63.00 / 1023.00); //+(Current_Note/10);
  Wave_Select1 = 5 - constrain((POT0_Array[0] / 170), 0, 5);
  Wave_Select2 = 5 - constrain((POT1_Array[0] / 170), 0, 5);
  Wave_Select3 = 5 - constrain((POT4_Array[0] / 170), 0, 5);
  Wave_Select4 = 5 - constrain((POT5_Array[0] / 170), 0, 5);
  Wave_Select5 = 7 - constrain((POT8_Array[0] / 127), 0, 7);
  level1 = 0.8 ;
  level3 = 0.8 ;
  level2 = 0.8 - POT3_Array[0] * (0.8 / 1023.00);
  level4 = 0.8 - POT7_Array[0] * (0.8 / 1023.00);
  level5 =  0.8 - POT10_Array[0] * (0.8 / 1023.00); //+(Current_Note/50);
  if (Wave_Select1 == 0) level1 = 0.0;
  if (Wave_Select2 == 0) level2 = 0.0;
  if (Wave_Select3 == 0) level3 = 0.0;
  if (Wave_Select4 == 0) level4 = 0.0;
  if (Wave_Select5 == 0) level5 = 0.0;
  del = 200 - constrain(POT4_Array[1] / 5, 0, 200);
  att = 100 - constrain(POT0_Array[1] / 10, 0.5, 100);
  hol = 100 - constrain( POT5_Array[1] / 10, 0.5, 100);
  dec = 200 - constrain( POT1_Array[1] / 5, 0, 200);
  sust = 1.0 - POT2_Array[1] * (1.00 / 1023.00);
  rel = 240 - constrain(POT3_Array[1] / 4.26, 2, 240);
  for (int i = 0; i < Voices; i++) {
    Envelopes[i]->delay(del);
    Envelopes[i]->attack(att);
    Envelopes[i]->hold(hol);
    Envelopes[i]->decay(dec);
    Envelopes[i]->sustain(sust);
    Envelopes[i]->release(rel);
  float filter1_freq =  (4400.00 - POT12_Array[0] * (4400.00 / 1023.00)) + (4400.00 / 1023.00);
  float filter1_res = 3.71 - POT13_Array[0] * (3.00 / 1023.00);
  float filter1_oct = 7 - POT14_Array[0] * (7.00 / 1023.00);
  for (int i = 0; i < 8; i++) {
    Filters[i]->resonance(filter1_res);
    Filters[i]->frequency(filter1_freq);
    Filters[i]->octaveControl(filter1_oct);
  float crossmix1 = POT11_Array[0] * (1.0 / 1023.0);
  float crossmix2 = POT15_Array[0] * (1.0 / 1023.0);
    Mixers1[i]->gain(0,  crossmix1);
    Mixers1[i]->gain(1, 1.0 - ((crossmix1 + crossmix2) / 2));
    Mixers1[i]->gain(2,  crossmix2);
  float crossmix3 = POT7_Array[1] * (1.0 / 1023.0);
    Mixers2[i]->gain(0, crossmix3);
    Mixers2[i]->gain(1, 1.0 - crossmix3);
void SETTINGS() {
  //     Setting Harmonics On/Off
  Harmonics = constrain(POT1_Array[7] / 512, 0,  1);
  //       Switching between MIDI only, Pulse Trigger via ADSR-Loop, booth
  MIDI_On = constrain(POT2_Array[7] / 340, 0,  2);
// ================================== MIDI ==================================
byte velocity_last;
void HandleNoteOff(byte channel, byte note, byte velocity) {
  Serial.println(" === HandleNoteOff === ");
  if (MIDI_On == 1 || MIDI_On == 2) {
    // made for a keyboard where noteoff is expressed as velocity==0
    // finds the calling note, shuts it off and sets it to 0, meaning it's available
    if (velocity == 0)
      Prev_MIDI_Millis = millis();
      //      Current_Note = 0;
      Current_Velocity = 0;
      Note_On = 0;
      if (note == Notes[0] && Pitches[0] != 0) {
        Serial.print(" === 1. Note Off === ");
        Serial.print(" Note ");
        Serial.print(note);
        Serial.print(" // Voice_Counter ");
        Serial.println(Voice_Counter);
        AudioNoInterrupts();
        envelope1.noteOff();
        AudioInterrupts();
        Pitches[0] = 0;
        Volume_Split = 0;
        Voice_Counter--;
      else  if (note == Notes[1] && Pitches[1] != 0) {
        Serial.print(" === 2. Note Off === ");
        Serial.print(note);
        envelope2.noteOff();
        AudioInterrupts();
        Pitches[1] = 0;
        Volume_Split = 2;
        Voice_Counter--;
      else  if (note == Notes[2] && Pitches[2] != 0) {
        Serial.print(" === 3. Note Off === ");
        Serial.print(note);
        envelope3.noteOff();
        AudioInterrupts();
        Pitches[2] = 0;
        Volume_Split = 2;
        Voice_Counter--;
      else  if (note == Notes[3] && Pitches[3] != 0) {
        Serial.print(" === 4. Note Off === ");
        Serial.print(note);
        envelope4.noteOff();
        AudioInterrupts();
        Pitches[3] = 0;
        Volume_Split--;
        Voice_Counter--;
      else  if (note == Notes[4] && Pitches[4] != 0) {
        Serial.print(" === 5. Note Off === ");
        Serial.print(note);
        envelope5.noteOff();
        AudioInterrupts();
        Pitches[4] = 0;
        Volume_Split = 0;
        Voice_Counter--;
      else  if (note == Notes[5] && Pitches[5] != 0) {
        Serial.print(" === 6. Note Off === ");
        Serial.print(note);
        envelope6.noteOff();
        AudioInterrupts();
        Pitches[5] = 0;
        Volume_Split = 2;
        Voice_Counter--;
      else  if (note == Notes[6] && Pitches[6] != 0) {
        if (Voices > 6) {
          Serial.print(" === 7. Note Off === ");
          Serial.print(note);
          envelope7.noteOff();
          AudioInterrupts();
          Pitches[6] = 0;
          Volume_Split = 2;
          Voice_Counter--;
        else  if (note == Notes[7] && Pitches[7] != 0) {
          if (Voices > 7) {
            Serial.print(" === 8. Note Off === ");
            Serial.print(note);
            envelope8.noteOff();
            AudioInterrupts();
            Pitches[7] = 0;
            Volume_Split--;
            Voice_Counter--;
  //Volume_Split = constrain(Volume_Split,0,3);
void HandleNoteOn(byte channel, byte note, byte velocity) {
  Serial.println(" === HandleNoteOn === ");
    if (velocity == 0)
      Note_On = 0;
        Serial.print(note);
        AudioInterrupts();
        Pitches[0] = 0;
        Volume_Split = 0;
        Voice_Counter--;
        Serial.print(note);
        AudioInterrupts();
        Pitches[1] = 0;
        Volume_Split = 2;
        Voice_Counter--;
        Serial.print(note);
        AudioInterrupts();
        Pitches[2] = 0;
        Volume_Split = 2;
        Voice_Counter--;
        Serial.print(note);
        AudioInterrupts();
        Pitches[3] = 0;
        Volume_Split--;
        Voice_Counter--;
        Serial.print(note);
        AudioInterrupts();
        Pitches[4] = 0;
        Volume_Split = 0;
        Voice_Counter--;
        Serial.print(note);
        AudioInterrupts();
        Pitches[5] = 0;
        Volume_Split = 2;
        Voice_Counter--;
        if (Voices > 6) {
          Serial.print(note);
          AudioInterrupts();
          Pitches[6] = 0;
          Volume_Split = 2;
          Voice_Counter--;
          if (Voices > 7) {
            Serial.print(note);
            AudioInterrupts();
            Pitches[7] = 0;
            Volume_Split--;
            Voice_Counter--;
    else {
      MIDI_Millis = millis() - Prev_MIDI_Millis;
      //    Serial.print(" ===== MIDI MILILIS =========== :");
      //    Serial.println(MIDI_Millis);
      Current_Note = note;
      Current_Velocity = velocity;
      Note_On = 1;
      SOUNDS();
      if (Pitches[0] == 0) {
        Notes[0] = note;
        Pitches[0] = velocity;
        Voice_Counter++;
        digitalWrite(LED, HIGH );
        Serial.print(" === 1. Note On ===");
        Serial.print(note);
        //        Serial.print(Notes[0] );
        //        Serial.print(" / ");
        //        Serial.print(pitch1);
        //        Serial.print((int) pitch2);
        velocity_last = velocity;
        //        Current_Note = note;
        Volume_Split++;
        waveform1.begin(level1,  pitch1 , (short) wave_type[Wave_Select1]);
        waveform1.phase(0);
        waveform1.pulseWidth(pwm1);
        waveform2.begin(level2,  pitch2, (short) wave_type[Wave_Select2]);//
        waveform2.phase(0);
        waveform2.pulseWidth(pwm2);
        waveform3.begin(level3,  pitch3, (short) wave_type[Wave_Select3]);
        waveform3.phase(0);
        waveform3.pulseWidth(pwm3);
        waveform4.begin(level4,  pitch4 , (short) wave_type[Wave_Select4]);
        waveform4.phase(0);
        waveform4.pulseWidth(0.5);
        waveform5.begin(level5,  pitch5 , (short) wave_type[Wave_Select5]);
        waveform5.phase(0);
        waveform5.pulseWidth(0.5);
        envelope1.noteOn();
        AudioInterrupts();
      else if (Pitches[1] == 0) {
        Serial.print(" === 2. Note On ===");
        Serial.println(note);
        Volume_Split++;
        //        envelope3.noteOn();
        //        envelope4.noteOn();
        Notes[1] = note;
        Pitches[1] = velocity;
        Voice_Counter++;
        waveform6.begin(level1,  pitch1 , (short) wave_type[Wave_Select1]);
        waveform6.phase(0);
        waveform6.pulseWidth(pwm1);
        waveform7.begin(level2,  pitch2, (short) wave_type[Wave_Select2]);//
        waveform7.phase(0);
        waveform7.pulseWidth(pwm2);
        waveform8.begin(level3,  pitch3, (short) wave_type[Wave_Select3]);
        waveform8.phase(0);
        waveform8.pulseWidth(pwm3);
        waveform9.begin(level4,  pitch4 , (short) wave_type[Wave_Select4]);
        waveform9.phase(0);
        waveform9.pulseWidth(0.5);
        waveform10.begin(level5,  pitch5 , (short) wave_type[Wave_Select5]);
        waveform10.phase(0);
        waveform10.pulseWidth(0.5);
        envelope2.noteOn();
        //        envelope2.noteOn();
        //        drum1.noteOn();
        AudioInterrupts();
      else if (Pitches[2] == 0) {
        Serial.print(" === 3. Note On ===");
        Volume_Split++;
        Notes[2] = note;
        Pitches[2] = velocity;
        Voice_Counter++;
        waveform11.begin(level1,  pitch1 , (short) wave_type[Wave_Select1]);
        waveform11.phase(0);
        waveform11.pulseWidth(pwm1);
        waveform12.begin(level2,  pitch2, (short) wave_type[Wave_Select2]);//
        waveform12.phase(0);
        waveform12.pulseWidth(pwm2);
        waveform13.begin(level3,  pitch3, (short) wave_type[Wave_Select3]);
        waveform13.phase(0);
        waveform13.pulseWidth(pwm3);
        waveform14.begin(level4,  pitch4 , (short) wave_type[Wave_Select4]);
        waveform14.phase(0);
        waveform14.pulseWidth(0.5);
        waveform15.begin(level5,  pitch5 , (short) wave_type[Wave_Select5]);
        waveform15.phase(0);
        waveform15.pulseWidth(0.5);
        envelope3.noteOn();
        //        drum1.noteOn();
        AudioInterrupts();
      else if (Pitches[3] == 0) {
        Serial.println(" === 4. Note On ===");
        Volume_Split++;
        Notes[3] = note;
        Pitches[3] = velocity;
        Voice_Counter++;
        waveform16.begin(level1,  pitch1 , (short) wave_type[Wave_Select1]);
        waveform16.phase(0);
        waveform16.pulseWidth(pwm1);
        waveform17.begin(level2,  pitch2, (short) wave_type[Wave_Select2]);//
        waveform17.phase(0);
        waveform17.pulseWidth(pwm2);
        waveform18.begin(level3,  pitch3, (short) wave_type[Wave_Select3]);
        waveform18.phase(0);
        waveform18.pulseWidth(pwm3);
        waveform19.begin(level4,  pitch4 , (short) wave_type[Wave_Select4]);
        waveform19.phase(0);
        waveform19.pulseWidth(0.5);
        waveform20.begin(level5,  pitch5 , (short) wave_type[Wave_Select5]);
        waveform20.phase(0);
        waveform20.pulseWidth(0.5);
        envelope4.noteOn();
        //        drum1.noteOn();
        AudioInterrupts();
      else if (Pitches[4] == 0) {
        Notes[4] = note;
        Pitches[4] = velocity;
        Voice_Counter++;
        Serial.print(" === 5. Note On ===");
        Volume_Split++;
        waveform21.begin(level1,  pitch1 , (short) wave_type[Wave_Select1]);
        waveform21.phase(0);
        waveform21.pulseWidth(pwm1);
        waveform22.begin(level2,  pitch2, (short) wave_type[Wave_Select2]);//
        waveform22.phase(0);
        waveform22.pulseWidth(pwm2);
        waveform23.begin(level3,  pitch3, (short) wave_type[Wave_Select3]);
        waveform23.phase(0);
        waveform23.pulseWidth(pwm3);
        waveform24.begin(level4,  pitch4 , (short) wave_type[Wave_Select4]);
        waveform24.phase(0);
        waveform24.pulseWidth(0.5);
        waveform25.begin(level5,  pitch5 , (short) wave_type[Wave_Select5]);
        waveform25.phase(0);
        waveform25.pulseWidth(0.5);
        envelope5.noteOn();
        //        drum1.noteOn();
        AudioInterrupts();
      else if (Pitches[5] == 0) {
        if (Voices > 6) {
          Notes[5] = note;
          Pitches[5] = velocity;
          Voice_Counter++;
          Serial.print(" === 6. Note On ===");
          Volume_Split++;
          waveform26.begin(level1,  pitch1 , (short) wave_type[Wave_Select1]);
          waveform26.phase(0);
          waveform26.pulseWidth(pwm1);
          waveform27.begin(level2,  pitch2, (short) wave_type[Wave_Select2]);//
          waveform27.phase(0);
          waveform27.pulseWidth(pwm2);
          waveform28.begin(level3,  pitch3, (short) wave_type[Wave_Select3]);
          waveform28.phase(0);
          waveform28.pulseWidth(pwm3);
          waveform29.begin(level4,  pitch4 , (short) wave_type[Wave_Select4]);
          waveform29.phase(0);
          waveform29.pulseWidth(0.5);
          waveform30.begin(level5,  pitch5 , (short) wave_type[Wave_Select5]);
          waveform30.phase(0);
          waveform30.pulseWidth(0.5);
          envelope6.noteOn();
          //        drum1.noteOn();
          AudioInterrupts();
        else if (Pitches[6] == 0) {
          if (Voices > 7) {
            Notes[6] = note;
            Pitches[6] = velocity;
            Voice_Counter++;
            Serial.print(" === 7. Note On ===");
            Volume_Split++;
            waveform31.begin(level1,  pitch1 , (short) wave_type[Wave_Select1]);
            waveform31.phase(0);
            waveform31.pulseWidth(pwm1);
            waveform32.begin(level2,  pitch2, (short) wave_type[Wave_Select2]);//
            waveform32.phase(0);
            waveform32.pulseWidth(pwm2);
            waveform33.begin(level3,  pitch3, (short) wave_type[Wave_Select3]);
            waveform33.phase(0);
            waveform33.pulseWidth(pwm3);
            waveform34.begin(level4,  pitch4 , (short) wave_type[Wave_Select4]);
            waveform34.phase(0);
            waveform34.pulseWidth(0.5);
            waveform35.begin(level5,  pitch5 , (short) wave_type[Wave_Select5]);
            waveform35.phase(0);
            waveform35.pulseWidth(0.5);
            envelope7.noteOn();
            //        drum1.noteOn();
            AudioInterrupts();
      else if (Pitches[7] == 0) {
        Notes[7] = note;
        Pitches[7] = velocity;
        Voice_Counter++;
        Serial.print(" === 8. Note On ===");
        Volume_Split++;
        waveform36.begin(level1,  pitch1 , (short) wave_type[Wave_Select1]);
        waveform36.phase(0);
        waveform36.pulseWidth(pwm1);
        waveform37.begin(level2,  pitch2, (short) wave_type[Wave_Select2]);//
        waveform37.phase(0);
        waveform37.pulseWidth(pwm2);
        waveform38.begin(level3,  pitch3, (short) wave_type[Wave_Select3]);
        waveform38.phase(0);
        waveform38.pulseWidth(pwm3);
        waveform39.begin(level4,  pitch4 , (short) wave_type[Wave_Select4]);
        waveform39.phase(0);
        waveform39.pulseWidth(0.5);
        waveform40.begin(level5,  pitch5 , (short) wave_type[Wave_Select5]);
        waveform40.phase(0);
        waveform40.pulseWidth(0.5);
        envelope8.noteOn();
        //        drum1.noteOn();
        AudioInterrupts();
      else {
        Notes[0] = 0;
        Pitches[0] = 0;
      if (Pitches[0] != 0 && Pitches[1] != 0 && Pitches[2] != 0 && Pitches[3] != 0
          && Pitches[4] != 0 && Pitches[5] != 0 && Pitches[6] != 0 && Pitches[7] != 0) {
        AudioInterrupts();
        Notes[0] = 0;
        Pitches[0] = 0;
      if (Pitches[0] == 0 && Pitches[1] == 0 && Pitches[2] == 0 && Pitches[3] == 0
          && Pitches[4] == 0 && Pitches[5] == 0 && Pitches[6] == 0 && Pitches[7] == 0 ) {
        Volume_Split = 0;
        Current_Note = 0;
  Volume_Split = constrain(Volume_Split, 0, 3);
// ===================== EEPROM ================================
int EEPROM_WRITE(byte SAVE_PLACE) {
  Serial.println("Saving... ");
  Data_Size = POTI_Sum * Max_Edit_Count * 2; //Data_Size = POTI_Sum *sizeof(POT0_Array); //
  EEPROM.put(0, SAVE_PLACE);
  int NextByte = (SAVE_PLACE * Data_Size) + 2;
  StartByte = NextByte;
  for (int i = 0; i < Max_Edit_Count; i++) {
    EEPROM.put(NextByte, highByte(POT0_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT0_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT1_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT1_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT2_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT2_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT3_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT3_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT4_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT4_Array[i]));
    NextByte++;
    LastByte = NextByte;
    EEPROM.put(NextByte, highByte(POT5_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT5_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT6_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT6_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT7_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT7_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT8_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT8_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT9_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT9_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT10_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT10_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT11_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT11_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT12_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT12_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT13_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT13_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT14_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT14_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, highByte(POT15_Array[i]));
    NextByte++;
    EEPROM.put(NextByte, lowByte(POT15_Array[i]));
    NextByte++;
    //    if (LastByte == StartByte + Data_Size+2) break;
  Serial.print(" Data_Size ");
  Serial.print(Data_Size);
  Serial.print(" / SB ");
  Serial.print(StartByte);
  Serial.print(" / LB ");
  Serial.println(LastByte);
  Serial.println("Done. ");
int EEPROM_READ(byte SAVE_PLACE) {
    int tmp_high = EEPROM.read(NextByte);
    NextByte++;
    int tmp_low = EEPROM.read(NextByte);
    NextByte++;
    POT0_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT1_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT2_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT3_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT4_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT5_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT6_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT7_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT8_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT9_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT10_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT11_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT12_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT13_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT14_Array[i] = word(tmp_high, tmp_low);
    NextByte++;
    NextByte++;
    POT15_Array[i] = word(tmp_high, tmp_low);
//   for (int i = 0; i < OSC1_Size; i++) {
//    // First Byte to Store Values After Setting
//    int tmp_high = EEPROM.read(NextByte);
//    NextByte++;
//    int tmp_low = EEPROM.read(NextByte);
//    NextByte++;
//    OSC1_Array[i] = word(tmp_high, tmp_low) ;
// =============================================== DISPLAY FUNCTIONS ============================
// Printing a max 6 Letter Number, COL = last Colum, ARRAY_NR = 255 to switch between Array Values and single Values
int PRINT_VALUE(byte COL, byte ROW, long  ARRAY_NR, bool ARRAY_TRUE = true, int* ARRAY = POT0_Array) {
  int value_to_set;
  if (ARRAY_TRUE == true)   value_to_set = ARRAY[ARRAY_NR];
  else  value_to_set =   ARRAY_NR;
  bool err = false;
  //  lcd.setCursor(COL, ROW);
  if (value_to_set >= 0 && value_to_set < 10)   {
    lcd.setCursor(COL - 1, ROW);
    lcd.print(" ");
  else if (value_to_set >= 10 && value_to_set < 100 || value_to_set <= -1 && value_to_set > -10)  {
    lcd.setCursor(constrain(COL - 2, 0, 19), ROW);
    lcd.print(" ");
  else if (value_to_set >= 100 && value_to_set < 1000 || value_to_set <= -10 && value_to_set > -100)  {
    lcd.setCursor(constrain(COL - 3, 0, 19), ROW);
    lcd.print(" ");
  else if (value_to_set >= 1000 && value_to_set < 10000 || value_to_set <= -100 && value_to_set > -1000)  {
    lcd.setCursor(constrain(COL - 4, 0, 19), ROW);
    lcd.print(" ");
  else if (value_to_set >= 10000 && value_to_set < 100000 || value_to_set <= -1000 && value_to_set > -10000)  {
    lcd.setCursor(constrain(COL - 5, 0, 19), ROW);
    lcd.print(" ");
  else if (value_to_set >= 100000 && value_to_set < 1000000 || value_to_set <= -10000 && value_to_set > -100000)  {
    lcd.setCursor(constrain(COL - 6, 0, 19), ROW);
    lcd.print(" ");
  else if (value_to_set >= 1000000  || value_to_set <= -100000 )  {
    err = true;
  if (err == false)  lcd.print(value_to_set);
  if (err == true)  {
    lcd.print("!LARGE!");
    err = false;
// ================================================ NeoPixel Function ==================================
int CLEAR_RING(byte RINGNUMBER) {
  if (RINGNUMBER == 1) {
    for (int i = 1; i <= NUMRing1; i++) {
      Ring1.setPixelColor(i, Ring1.Color(0, 0, 0));
  else if (RINGNUMBER == 2) {
      Ring2.setPixelColor(i, Ring2.Color(0, 0, 0));
byte Option_Select_Last;
// ================================================ L O O P ==================================
unsigned long last_time = millis();
//  Serial4.read();
  MIDI.read();
  //  delay(20);
  //  SOUNDS();
  //  SETTINGS();
  if (1) {
    if (millis() - last_time >= 1000) {
      Serial.print("Proc = ");
      Serial.print(AudioProcessorUsage());
      Serial.print(" (");
      Serial.print(AudioProcessorUsageMax());
      Serial.print("),  Mem = ");
      Serial.print(AudioMemoryUsage());
      Serial.print(" (");
      Serial.print(AudioMemoryUsageMax());
      Serial.println(")");
      Serial.print("pitch3: ");
      Serial.println(pitch3);
  // Should prevent MIDI Input Overkill at fast Speed & End eventually "unOffed" Notes
  if (Voice_Counter > Voices - 1) {
    Voice_Counter--;
    if (millis() - Voices_millis < 20) {
      Voice_Counter--;
      Voice_Counter--;
      Voice_Counter--;
      Voice_Counter--;
      Voice_Counter--;
      Voice_Counter--;
      Voice_Counter--;
    Voices_millis = millis();
  // Button 1
  bouncer.update ( );
  int value = bouncer.read();
  // button not pressed
  if (value == HIGH) {
    Button_hold = 1;
    // at the moment button ist pressed
    if (bouncer.risingEdge()) {
      Shift_Switch = !Shift_Switch;
      Serial.print("Button push - ");
      Serial.println(Shift_Switch);
  //while pressing button
  else    {
    Button_hold = 0;
  // Rot1 Button
  int bouncer2_Press_Delay = 400;
  bouncer2.update ( );
  int value2 = bouncer2.read();
  if (value2 == HIGH) {
    if (bouncer2.risingEdge()) {
      bouncer2_millis_last = millis();
      Serial.print("Rot1 push - ");
      Edit_Level++;
      if (Edit_Level > 2) Edit_Level = 0;
    if (millis() - bouncer2_millis_last > bouncer2_Press_Delay) {
      if (Edit_Count == 8 ) {
        if (Save_Space != Last_Save_Space) {
          Last_Save_Space = Save_Space;
      else {
        Edit_Level--;
        int Blink1_Delay = 100;
        Serial.print("Saving...");
        analogWrite(SEQ_LED_1, 255);
        delay(Blink1_Delay);
        EEPROM_WRITE(Save_Space);
  //  newLeft = ROT2_DATA.read() / 4;
  //  newRight = ROT1_DATA.read() / 4;
  //  if (newRight != newRight_Last) {
  //    newRight_Speed = micros();
  //    newRight_Last = newRight;
  //      newRight2_Speed = micros();
  //      int newRight_Accel = 200;
  //      if (newRight2_Speed - newRight_Speed < newRight_Accel) {
  //        newRight = ROT1_DATA.read();
  //      else newRight = ROT1_DATA.read() / 4;
  if (Edit_Level == 0) {
    analogWrite(Rot1_R, 255);
    analogWrite(Rot1_G, 255);
    analogWrite(Rot1_B, 0);
    if (newRight != last) {
      last = newRight;
      last2 = newRight ;
      last3 = newRight ;
      if (last_value > newRight) {
        Prev_Edit_Count = Edit_Count;
        Prev_Array_Nr = Array_Nr;
        Edit_Count--;
        if (Edit_Count < 1 ) Edit_Count = Max_Edit_Count;
      if (last_value < newRight)  {
        Edit_Count++;
        if (Edit_Count > Max_Edit_Count) Edit_Count = 1;
    Array_Nr = Edit_Count - 1;
  //  newLeft2 = ROT2_DATA.read() / 4;
  //  newRight2 = ROT1_DATA.read() / 4;
  int Col_Val_B;
  if (Edit_Level == 1) {
    analogWrite(Rot1_R, 0);
    analogWrite(Rot1_B, 255);
    if (newRight != last2) {
      last = newRight;
      last2 = newRight ;
      last3 = newRight ;
      if (last_value2 > newRight) {
        Prev_Option_Select = Option_Select;
        Option_Select--;
        Current_Rot1_Val = 0;
        if (Option_Select < 0 ) Option_Select = POTI_Sum - 1;
        CLEAR_RING(2);
      if (last_value2 < newRight)  {
        Option_Select++;
        if (Option_Select > POTI_Sum - 1) Option_Select = 0;
        CLEAR_RING(2);
    for (int i = -1; i <= Ring2_Scale - 1; i++) {
      Col_Val_B = i * 8;
      Ring2.setPixelColor(i, Ring2.Color( 255, 96 - Col_Val_B, 0)); // Moderately bright green color.
      //      Ring2.setPixelColor(i + 1, Ring2.Color(0, 0, 0));
    Ring2.show();
    //     if (newRight != newRight) Edit_Count++;
    POT0_Last = POT0_Read;
    POT1_Last = POT1_Read;
    POT2_Last = POT2_Read;
    POT3_Last = POT3_Read;
    POT4_Last = POT4_Read;
    POT5_Last = POT5_Read;
    POT6_Last = POT6_Read;
    POT7_Last = POT7_Read;
  if (Edit_Level == 2) {
    analogWrite(Rot1_G, 0);
    //newLeft3 = ROT2_DATA.read() / 4;
    //  newRight3 = ROT1_DATA.read() / 4;
    if (newRight != last3) {
      last = newRight;
      last2 = newRight ;
      last3 = newRight ;
      if (last_value3 > newRight) {
        Prev_Current_Rot1_Val = Current_Rot1_Val;
        if (Button_hold == 1)
          Current_Rot1_Val++;//
        else Current_Rot1_Val =  Current_Rot1_Val + 48;
      if (last_value3 < newRight)  {
        if (Button_hold == 1)  Current_Rot1_Val--; //
        else Current_Rot1_Val =  Current_Rot1_Val - 48;
      Current_Rot1_Val = constrain(Current_Rot1_Val, -1023, 1023);
    // Ring2 Array Value Scale
      Col_Val_B = i * 8;
    Ring2.show();
  last_value = newRight;
  last_value3 = newRight ;
  last_value2 = newRight ;
  // =============== playing constant tone depending on ADSR Values ========================
  if (MIDI_On == 0 || MIDI_On == 2) {
    unsigned long currentMillis = millis();
    if (currentMillis - previousMillis > interval1) {
      // save the last time you blinked the LED
      previousMillis = currentMillis;
      if (Note_On == 1) {
        //        drum1.noteOn();
        Note_On = 0;
        interval1 = (att + hol + dec   + att2 + hol2 + dec2);
        SOUNDS();
        waveform1.phase(0);
        waveform2.phase(0);
        waveform3.phase(0);
        waveform4.phase(0);
        waveform5.phase(0);
        envelope1.noteOn();
        envelope2.noteOn();
        envelope3.noteOn();
        envelope4.noteOn();
        envelope5.noteOn();
        AudioInterrupts();
        //    return;
      else {
        //          delay(att + hol + dec + att2 + hol2 + dec2);
        //            delay(del + rel);
        digitalWrite(LED, LOW );
        Note_On = 1;
        interval1 = (del + rel + del2 + rel2);
  // ===============================EDIT COUNT =======================
  switch (Edit_Count) {
    // =====OSC1 =====
    case 1: {
        RING1_BLUE();
        lcd.print("OSCILLATORS");
    // =====OSC2 =====
    case 2: {
        RING1_BLUE();
    // =====FILTER OSC 1=====
    case 3: {
        RING1_BLUE();
    // =====FILTER OSC 2=====
    case 4: {
        RING1_BLUE();
    // =====Drum/Pink Noise =====
    case 5: {
        RING1_BLUE();
    // =====Other Envelope OSC 1 & OSC 2 =====
    case 6: {
        RING1_BLUE();
    // =====unused=====
    case 7: {
        RING1_BLUE();
    // =====Options & Saving=====
    case 8: {
        Ring1.setPixelColor(Array_Nr, Ring1.Color(255, 128, 0)); // Moderately bright green color.
        Ring1.setPixelColor(Prev_Array_Nr, Ring1.Color(0, 0, 0));
        Ring1.show();
        byte Max_Save_Spaces = 16;
          //        Setting Current Memory Place
          Save_Space = constrain(POT0_Array[Array_Nr] / (1023 / (Max_Save_Spaces - 1)), 0, Max_Save_Spaces - 1);
  //  if (Save_Space != Save_Space) {
  // ===============================OPTION SELECT =======================
  switch (Option_Select) {
    // =====POT0 =====
    case 0: {
        RING1_RED();
        Ring2_Scale = (1023 - POT0_Array[Array_Nr]) / 73, Prev_Ring2_Scale, Col_Val_B;
        if (Edit_Level == 2 ) {
          if (Current_Rot1_Val != Prev_Current_Rot1_Val) {
            POT0_Array[Array_Nr] +=  Current_Rot1_Val;
            POT0_Array[Array_Nr] = constrain(POT0_Array[Array_Nr], 0, 1023);
    // =====POT1 =====
    case 1: {
        RING1_RED();
        Ring2_Scale = (1023 - POT1_Array[Array_Nr]) / 73, Prev_Ring2_Scale, Col_Val_B;
            POT1_Array[Array_Nr] +=  Current_Rot1_Val;
            POT1_Array[Array_Nr] = constrain(POT1_Array[Array_Nr], 0, 1023);
      break;   //
    // =====POT2 =====
    case 2: {
        RING1_RED();
        Ring2_Scale = (1023 - POT2_Array[Array_Nr]) / 73, Prev_Ring2_Scale, Col_Val_B;
            POT2_Array[Array_Nr] +=  Current_Rot1_Val;
            POT2_Array[Array_Nr] = constrain(POT2_Array[Array_Nr], 0, 1023);
      break;   //
    // =====POT3 =====
    case 3: {
        RING1_RED();
        Ring2_Scale = (1023 - POT3_Array[Array_Nr]) / 73, Prev_Ring2_Scale, Col_Val_B;
            POT3_Array[Array_Nr] +=  Current_Rot1_Val;
            POT3_Array[Array_Nr] = constrain(POT3_Array[Array_Nr], 0, 1023);
      break;   //
    // =====POT4 =====
    case 4: {
        RING1_RED();
        Ring2_Scale = (1023 - POT4_Array[Array_Nr]) / 73, Prev_Ring2_Scale, Col_Val_B;
            POT4_Array[Array_Nr] +=  Current_Rot1_Val;
            POT4_Array[Array_Nr] = constrain(POT4_Array[Array_Nr], 0, 1023);
    // =====POT5 =====
    case 5: {
        RING1_RED();
        Ring2_Scale = (1023 - POT5_Array[Array_Nr]) / 73, Prev_Ring2_Scale, Col_Val_B;
            POT5_Array[Array_Nr] +=  Current_Rot1_Val;
            POT5_Array[Array_Nr] = constrain(POT5_Array[Array_Nr], 0, 1023);
      break;   //
    // =====POT6 =====
    case 6: {
        RING1_RED();
        Ring2_Scale = (1023 - POT6_Array[Array_Nr]) / 73, Prev_Ring2_Scale, Col_Val_B;
            POT6_Array[Array_Nr] +=  Current_Rot1_Val;
            POT6_Array[Array_Nr] = constrain(POT6_Array[Array_Nr], 0, 1023);
      break;   //
    // =====POT7 =====
    case 7: {
        RING1_RED();
        Ring2_Scale = (1023 - POT7_Array[Array_Nr]) / 73, Prev_Ring2_Scale, Col_Val_B;
            POT7_Array[Array_Nr] +=  Current_Rot1_Val;
            POT7_Array[Array_Nr] = constrain(POT7_Array[Array_Nr], 0, 1023);
  //  pitch1 = tune_frequencies2_PGM[Current_Note];
  //  pitch3 = tune_frequencies2_PGM[Current_Note + 12];
  //  if (Shift_Switch == 1) {
  //          analogWrite(SEQ_LED_1, 255);
  POT0_Read = analogRead(A0);
  POT1_Read = analogRead(A1);
  POT2_Read = analogRead(A2);
  POT3_Read = analogRead(A3);
  //  else {
  POT4_Read = analogRead(A6);
  POT5_Read = analogRead(A7);
  POT6_Read = analogRead(A8);
  POT7_Read = analogRead(A9);
  //  if (Button_hold == 1) {
  unsigned long current_POTs_Millis = millis();
  byte voices = 2;
  if (current_POTs_Millis - POTs_millis > 20) {
    POTs_millis = current_POTs_Millis;
    // not that time critical tasks
    First_Random = random(0, 1024);
    //    SOUNDS();
    SETTINGS();
    byte Tolerance = 12;
    switch (Shift_Switch) {
      case 0: {
          analogWrite(Rot2_R, 0);
          analogWrite(Rot2_G, 255);
          analogWrite(Rot2_B, 255);
          lcd.setCursor(14, 0);
          lcd.print("Tab 1");
          //          lcd.setCursor(1,1);
          PRINT_VALUE(4, 1, Array_Nr, true, POT0_Array);
          //  lcd.print(POT0_Array[Array_Nr]);
          // lcd.setCursor(4,1);
          PRINT_VALUE(9, 1, Array_Nr, true, POT1_Array);
          //  lcd.print(POT1_Array[Array_Nr]);
          // lcd.setCursor(9,1);
          PRINT_VALUE(14, 1, Array_Nr, true, POT2_Array);
          //lcd.print(POT2_Array[Array_Nr]);
          // lcd.setCursor(14,1);
          PRINT_VALUE(19, 1, Array_Nr, true, POT3_Array);
          //lcd.print(POT3_Array[Array_Nr]);
          //   lcd.setCursor(1,2);
          PRINT_VALUE(4, 2, Array_Nr, true, POT4_Array);
          //lcd.print(POT4_Array[Array_Nr]);
          // lcd.setCursor(4,2);
          PRINT_VALUE(9, 2, Array_Nr, true, POT5_Array);
          //lcd.print(POT5_Array[Array_Nr]);
          // lcd.setCursor(9,2);
          PRINT_VALUE(14, 2, Array_Nr, true, POT6_Array);
          // lcd.print(POT6_Array[Array_Nr]);
          // lcd.setCursor(14,2);
          PRINT_VALUE(19, 2, Array_Nr, true, POT7_Array);
          //lcd.print(POT7_Array[Array_Nr]);
          //    if (Edit_Level == 2 ) {
          if (POT0_Read > POT0_Last + Tolerance || POT0_Read < POT0_Last - Tolerance) {
            POT0_Array[Array_Nr] = POT0_Read;
          else       POT0_Array[Array_Nr] = POT0_Array[Array_Nr];
          if (POT1_Read > POT1_Last + Tolerance || POT1_Read < POT1_Last - Tolerance) {
            POT1_Array[Array_Nr]  = POT1_Read;
          else       POT1_Array[Array_Nr] = POT1_Array[Array_Nr];
          if (POT2_Read > POT2_Last + Tolerance || POT2_Read < POT2_Last - Tolerance) {
            POT2_Array[Array_Nr] = POT2_Read;
          else       POT2_Array[Array_Nr] = POT2_Array[Array_Nr];
          if (POT3_Read > POT3_Last + Tolerance || POT3_Read < POT3_Last - Tolerance) {
            POT3_Array[Array_Nr] = POT3_Read;
          else       POT3_Array[Array_Nr] = POT3_Array[Array_Nr];
          if (POT4_Read > POT4_Last + Tolerance || POT4_Read < POT4_Last - Tolerance) {
            POT4_Array[Array_Nr] = POT4_Read;
          else       POT4_Array[Array_Nr] = POT4_Array[Array_Nr];
          if (POT5_Read > POT5_Last + Tolerance || POT5_Read < POT5_Last - Tolerance) {
            POT5_Array[Array_Nr] = POT5_Read;
          else       POT5_Array[Array_Nr] = POT5_Array[Array_Nr];
          if (POT6_Read > POT6_Last + Tolerance || POT6_Read < POT6_Last - Tolerance) {
            POT6_Array[Array_Nr] = POT6_Read;
          else       POT6_Array[Array_Nr] = POT6_Array[Array_Nr];
          if (POT7_Read > POT7_Last + Tolerance || POT7_Read < POT7_Last - Tolerance) {
            POT7_Array[Array_Nr] = POT7_Read;
          else       POT7_Array[Array_Nr] = POT7_Array[Array_Nr];
      case 1: {
          analogWrite(Rot2_R, 255);
          analogWrite(Rot2_G, 0);
          lcd.print("Tab 2");
          PRINT_VALUE(4, 1, Array_Nr, true, POT8_Array);
          PRINT_VALUE(9, 1, Array_Nr, true, POT9_Array);
          PRINT_VALUE(14, 1, Array_Nr, true, POT10_Array);
          PRINT_VALUE(19, 1, Array_Nr, true, POT11_Array);
          PRINT_VALUE(4, 2, Array_Nr, true, POT12_Array);
          PRINT_VALUE(9, 2, Array_Nr, true, POT13_Array);
          PRINT_VALUE(14, 2, Array_Nr, true, POT14_Array);
          PRINT_VALUE(19, 2, Array_Nr, true, POT15_Array);
            POT8_Array[Array_Nr] = POT0_Read;
          else       POT8_Array[Array_Nr] = POT8_Array[Array_Nr];
            POT9_Array[Array_Nr]  = POT1_Read;
          else       POT9_Array[Array_Nr] = POT9_Array[Array_Nr];
            POT10_Array[Array_Nr] = POT2_Read;
          else       POT10_Array[Array_Nr] = POT10_Array[Array_Nr];
            POT11_Array[Array_Nr] = POT3_Read;
          else       POT11_Array[Array_Nr] = POT11_Array[Array_Nr];
            POT12_Array[Array_Nr] = POT4_Read;
          else       POT12_Array[Array_Nr] = POT12_Array[Array_Nr];
            POT13_Array[Array_Nr] = POT5_Read;
          else       POT13_Array[Array_Nr] = POT13_Array[Array_Nr];
            POT14_Array[Array_Nr] = POT6_Read;
          else       POT14_Array[Array_Nr] = POT14_Array[Array_Nr];
            POT15_Array[Array_Nr] = POT7_Read;
          else       POT15_Array[Array_Nr] = POT15_Array[Array_Nr];
} // LOOP End
void RING1_BLUE() {
  Ring1.setPixelColor(Array_Nr, Ring1.Color(0, 0, 255)); // Moderately bright green color.
  Ring1.show();
void RING1_RED() {
  Ring1.setPixelColor(Prev_Option_Select, Ring1.Color(0, 0, 0));
  Ring1.setPixelColor(Option_Select, Ring1.Color(255, 0, 0)); // Moderately bright green color.
  Ring1.show();
void SAVE_SPACE_UPDATE() {
  byte Ring_Save_Step = Save_Space % 4;
  if (Save_Space < 4) {
      Ring1.setPixelColor(NUMRing1 - 1 - i, Ring1.Color(5, 5, 5)); // Moderately bright green color.
    Ring1.setPixelColor(NUMRing1 - 1 - Ring_Save_Step, Ring1.Color(255, 255,  255)); // Moderately bright green color.
  else if (Save_Space < 8) {
      Ring1.setPixelColor(NUMRing1 - 1 - i, Ring1.Color(8, 4, 0)); // Moderately bright green color.
    Ring1.setPixelColor(NUMRing1 - 1 - Ring_Save_Step, Ring1.Color(255, 128,  0)); // Moderately bright green color.
  else if (Save_Space < 12) {
      Ring1.setPixelColor(NUMRing1 - 1 - i, Ring1.Color(8, 0, 0)); // Moderately bright green color.
    Ring1.setPixelColor(NUMRing1 - 1 - Ring_Save_Step, Ring1.Color(255, 0,  0)); // Moderately bright green color.
  else {
      Ring1.setPixelColor(NUMRing1 - 1 - i, Ring1.Color(0, 0, 8)); // Moderately bright green color.
    Ring1.setPixelColor(NUMRing1 - 1 - Ring_Save_Step, Ring1.Color(0, 0,  255)); // Moderately bright green color.
  Ring1.show();
I realy hope someonehast a clue, whats going on there and can say; hey! you simply have to edit line xy and everything will work fine!
Thx
Ok. Maybe i have to simplify my problem/question. Should it be possible to run a 5V Lcd via a level shifter at the SDL0/SDA0 pins and simoultaniously use Serial port Pin 0 for MIDI input?
Certainly should be. Trouble is working through your explantation and code is non trivial. Only advice I can offer at the moment is to try and produce a test program with just a one per second midi message and a basic LCD update and try to confirm there really is nothing interacting.
You are not using the audio board are you?
For some info on i2c usage this thread might help; New-I2C-library-for-Teensy3
I see that "//#include <i2c_t3.h>" for that thread commented out - but it would let you move to alternate pins with Wire1 on SCL1/SDA1. It also has an interface to alter the bus speed.
Thank you two for your awnsers.
@Gremlin ok, so i think a have to recomplex and slow down things and try to get a working or non working version witch is more easily to understand.
@defragster i read the link in your post before, but as i wrote, i couln´d get the i2c_3t library work with the any of the liquid cristal versions due to compiling errors, so i couln´d use other SCL/SDA Ports. In my first Schematics i wanted to use Pins 3/4 SCL/A 2
Edit:
Compiling the code with uncomment Wire.h, but the library folder in the teensy folder and "include <i2c_t3.h>" produces this Errors:
"C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1482168544 "-TC:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\cores\teensy3/mk64fx512.ld"  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp/Teensy35_2Rot_Pot_MIDIin_ars_rings_sav16_lcd_4osc_8v_008.ino.elf" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\sketch\Teensy35_2Rot_Pot_MIDIin_ars_rings_sav16_lcd_4osc_8v_008.ino.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\memcpy_audio.S.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\data_ulaw.c.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\data_waveforms.c.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\data_windows.c.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\analyze_fft1024.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\analyze_fft256.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\analyze_notefreq.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\analyze_peak.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\analyze_print.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\analyze_rms.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\analyze_tonedetect.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\control_ak4558.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\control_cs4272.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\control_sgtl5000.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\control_wm8731.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_bitcrusher.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_chorus.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_delay.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_delay_ext.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_envelope.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_fade.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_flange.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_midside.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_multiply.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\effect_reverb.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\filter_biquad.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\filter_fir.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\filter_variable.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\input_adc.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\input_adcs.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\input_i2s.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\input_i2s_quad.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\mixer.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\output_dac.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\output_dacs.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\output_i2s.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\output_i2s_quad.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\output_pt8211.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\output_pwm.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\output_spdif.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\play_memory.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\play_queue.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\play_sd_raw.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\play_sd_wav.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\play_serialflash_raw.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\record_queue.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\spi_interrupt.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\synth_dc.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\synth_karplusstrong.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\synth_pinknoise.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\synth_simple_drum.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\synth_sine.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\synth_tonesweep.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\synth_waveform.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\synth_whitenoise.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Audio\utility\sqrt_integer.c.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SPI\SPI.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\File.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\SD.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\cache_t3.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\card_t3.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\dir_t3.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\fat_t3.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\file_t3.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\init_t3.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\utility\KinetisSDHC.c.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\utility\Sd2Card.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\utility\SdFile.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SD\utility\SdVolume.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SerialFlash\SerialFlashChip.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\SerialFlash\SerialFlashDirectory.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\i2c_t3\i2c_t3.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\FastIO.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\I2CIO.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LCD.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LiquidCrystal.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LiquidCrystal_I2C.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LiquidCrystal_I2C_ByVac.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LiquidCrystal_SI2C.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LiquidCrystal_SR.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LiquidCrystal_SR1W.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LiquidCrystal_SR2W.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\LiquidCrystal_SR3W.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\new_liquidcrystal\SI2CIO.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Adafruit_NeoPixel\esp8266.c.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Bounce\Bounce.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Encoder\Encoder.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\arduino_midi_library-master\MIDI.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\EEPROM\EEPROM.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Wire\Wire.cpp.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Wire\utility\twi.c.o" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp/core\core.a" "-LC:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp" -larm_cortexM4lf_math -lm
C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Wire\Wire.cpp.o: In function `i2c0_isr':
C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\Wire/Wire.cpp:376: multiple definition of `i2c0_isr'
C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\i2c_t3\i2c_t3.cpp.o:C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\i2c_t3/i2c_t3.cpp:1387: first defined here
c:/users/xmg p304 pro/desktop/apps/tools/elektronik/arduino/arduino-1.6.9/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Wire\Wire.cpp.o: In function `TwoWire::flush()':
C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\Wire/Wire.cpp:507: multiple definition of `Wire'
C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\i2c_t3\i2c_t3.cpp.o:C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\i2c_t3/i2c_t3.h:911: first defined here
c:/users/xmg p304 pro/desktop/apps/tools/elektronik/arduino/arduino-1.6.9/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld.exe: Warning: size of symbol `Wire' changed from 20 in C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\i2c_t3\i2c_t3.cpp.o to 16 in C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\libraries\Wire\Wire.cpp.o
Bibliothek Audio in Version 1.3 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\Audio  wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\SPI  wird verwendet
Bibliothek SD in Version 1.0.8 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\SD  wird verwendet
Bibliothek SerialFlash in Version 0.4 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\SerialFlash  wird verwendet
Bibliothek i2c_t3 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\i2c_t3 (legacy) wird verwendet
Bibliothek new_liquidcrystal im Ordner: C:\Users\XMG P304 PRO\Documents\Arduino\libraries\new_liquidcrystal (legacy) wird verwendet
Bibliothek Adafruit_NeoPixel in Version 1.0.4 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\Adafruit_NeoPixel  wird verwendet
Bibliothek Bounce im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\Bounce (legacy) wird verwendet
Bibliothek Encoder in Version 1.4.1 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\Encoder  wird verwendet
Bibliothek arduino_midi_library-master in Version 4.3.1 im Ordner: C:\Users\XMG P304 PRO\Documents\Arduino\libraries\arduino_midi_library-master  wird verwendet
Bibliothek EEPROM in Version 2.0 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\EEPROM  wird verwendet
Bibliothek Wire in Version 1.0 im Ordner: C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\Wire  wird verwendet
Fehler beim Kompilieren für das Board Teensy 3.5.
without the wire.h folder and "include <i2c_t3.h>" this:
"C:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=131 -DARDUINO=10609 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\cores\teensy3" "-IC:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\Audio" "-IC:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\SPI" "-IC:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\SD" "-IC:\Users\XMG P304 PRO\Desktop\APPS\TOOLS\ELEKTRONIK\ARDUINO\arduino-1.6.9\hardware\teensy\avr\libraries\SerialFlash" "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\sketch\Teensy35_2Rot_Pot_MIDIin_ars_rings_sav16_lcd_4osc_8v_008.ino.cpp" -o "C:\Users\XMGP30~1\AppData\Local\Temp\buildaa2c6b69b7418271ed873194bc48bb5d.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\XMGP30~1\AppData\Local\Temp\arduino_modified_sketch_514725\Teensy35_2Rot_Pot_MIDIin_ars_rings_sav16_lcd_4osc_8v_008.ino:376:18: fatal error: Wire.h: No such file or directory
compilation terminated.
Sorry, I have not looked very closely at your code.
FYI when you do code tags: You current have <code>, but you should instead use [ and ] instead of < >
As for using i2c_t3.h instead of wire.h. At times this can run into some issues, where some libraries include wire.h and other include the i2c_t3.h as they both produce some of the same objects like the WIRE object and the underlying interrupt handler...
if you are wanting to use i2c_t3.h in order to use the WIRE1 or WIRE2 objects, then yes currently you need i2c_t3. But if you simply wish to use alternate pins for WIRE then you can do this with the wire library. Maybe sometime soon someone (maybe me) will add WIRE1 and WIRE2 to the main wire library.
I know there has been discussions about how to trick the other libraries that include <wire.h> to play along with I2C_t3.h. Not sure if there was a complete resolution for it. I was thinking of trying to create a dummy wire.h in my <user docuements>/Arduino/libraries/Wire directory, which simply included i2c_t3.h and see if that worked or not... Again I have not tried that yet. The main issue if that trick works is if those libraries that are included use some of the methods of WIRE that are defined in wire.h such as setSCL but are not part of I2C_t3.h.
Kurt
thx Kurt.
also for confirm, that it is not as easy as it should. so i don´t have to be only in doubt with my programmig skills ;)
Is there a simple way to tell the std wire.h to use only wire1 or wire2 instead of wire? (simple means changing some portnumbers or so) or has this other unwanted effects?
@GermlinWrangler sry, i forgot. No, no Audio Board.
This is a bit hard to interpret:
with the SDA connected
* are midi data received
* are the sound processed
* is it not output
* is the display responding
With SDA disconnected
* do you disconect the whole display subsystem, or I would assume that I2C writes would complain or hang
There are several levels where things can go wrong, not simply on MIDI serial input vs I2C output
thx Kurt.
Sorry as far as I know wire.h has not yet been extended to Wire1 and Wire2, it only works with wire. Hopefully at some point in the near future it will also do these two nets as well. (and maybe Wire3...)
@mlu
when i upload the code and teensy rebboots, with sda connected:
- there is some MIDI Data recieved, cause the MIDINoteOn gets triggered, but not in the speed or accurancy as usual, after 2,3 Notes played no further MIDI Triggering works
- the sound always plays fine
- the display works as it should
with sda only disconnected:
- MIDI triggers NoteOn/NoteOff etc as wanted (also with the whole LCD disconnected)
- the 12c adapter is soldered to the display, so i cant disconnect the display only
At one point, I thought about hacking up i2c_t3, to include a #define like #define I2CT3_DONT_DEFINE_WIRE, which when defined,
I2C_T3.H would not define anything that is specific to WIRE object (the object, the interrupt handler(s)...) and as such that then the WIRE stuff would be handled by WIRE library and only WIRE1, WIRE2, WIRE3 would be handled by I2C_t3...
But so far I have not had a need nor am I the owner/developer of either library...
Thx for the input Kurt, but thats far from, what i`m able to do at the moment. It´s disapointing at the moment for me, comming from arduino level to teensy potential, running througth hours of stuff i thougth would be easy to convert ,but turns out much more tricky to realize and now, some last steps before the finishline, i cloudn`t get such a simple thing like an lcd display to work with such an old thing like MIDI. especially because the hardware specs of the teensy 3.5 sound so much more flexible than on any arduino.
i think thats it for the moment. i will start some tests on a simpler level and report if i find a solution. Thx for the inputs/ideas form you.
of course, if anyone hat as running a teensy 3.5 system with an lcd via I2C (with or without i2c_3t) and a level shifter connected and gets propper DIN MIDI Signals, it would be very nice to share some code an scematics.
Your code is quite busy, quite a number of analog reads, neopixel ring updates, Serial writes and display writes and then the sound generation running in the loop. If it really is that lcd via I2C through a level shifter refuses to run with MIDI input on Serial1 then you should try a simple sketch that only uses the MIDI input and the lcd to display incoming MIDI data, and perhaps a loop counter. No audio engine running, no neopixel writes and no analog reads.
