Results 1 to 18 of 18
Thread: 3D Cad for Teensy 3.5 and 3.6
    Dec 2016
    3
    Does anyone have a link to 3D Cad for teensy 3.5 and or 3.6
    Rendered model
    3D CAD model for Teensy 3.6
    https://github.com/BasicAirData/AirD...port/teensy3.6
    Mar 2017
    10
    Looks nice! Any chance that you could post the 3D files in a more universal format like STEP or parasolid .X_t so folks w/o Inventor could benefit too?
    3,638
    My version is not half as nice as that one, but I have used it in my 3d renderings in Diptrace.
    If you want to play with the Step file, I have included it here...
    Again this is not half as nice as the version above, but at least I could verify how things would look in diptrace...
    Attached Files Attached Files
    Thank you.
    Look at this new folder
    https://github.com/BasicAirData/AirD...teensy3.6/STEP
    It is somewhat raw, more development is needed.
    Regarding the file format, you are right, it is more comfortable to use a neutral file format. But is not trivial.
    We've an open issue on Github
    https://github.com/BasicAirData/AirD...uter/issues/40
    @KurtE It seems we posted at the same time.
    Thank you for sharing!
    In my humble opinion your release seem to be more appropriate for development purposes than ours; and it is nice. In fact ours is render oriented.
    Anyway.
    For development, we use Kicad. Once the PCB is completed we export the wrlm 3D model and then we use it with our enclosure/case 3D model.
    Mar 2017
    10
    Kurt and JLJ, thanks for the prompt responses. Kurt any idea what the weird artifacts are near the SD Card socket?
Name:	Strange artifacts with SD Card socket.jpg
    Apr 2017
    1
    I have created an Altium 3D Model for anyone looking to use it - Teensy 3.5/6 - it will also be up on my 3D Content Central portfolio in due course - search for tag 'Teensy'
ID:	10181Click image for larger version.
    @ZS6HG Thank you for sharing!
    Mar 2017
    10
    Very nice, thanks!
    18,191
    I've added links to these 3D models from the dimensions page. Hopefully that will help everyone to find them.
    https://www.pjrc.com/teensy/dimensions.html
    If there are any others I've missed, please let me know?
    Many Thanks ZS6HG,
    My model was 90% finished, so your post inspired me to complete it. I have stolen some of your model - I didn't have all the passive components on mine.
    My K66 and Reset-button are quite a bit taller than yours, and the Micro-SD a little further out, and while your SD Slot is much more accurate, it didn't import as solid into my package so I have left mine as-is.
    Unless someone is like me, packaging with sub-millimeter tolerances and clearances, it will never worry them!
    I will upload mine here after I have run it through a few MCAD packages at work to check it is robust (STEP, even though a standard exchange format for 30~40 years, is never read or written exactly the same on any two CAD systems)
    18,191
    @Darcy - Are your files published somewhere?
    for those who want a sketchup file of the teensy 3.6 (not 100% accurate)
    teensy 3.6.skp.zip
    render:
    My file as per my above post is here:
    Oh, and another version with headers for those that don't like soldering!
    and finally a HOOPS stream format and a VRML format here:
    Mar 2017
    10
    Darcy: Any chance that you can export your Teensy 3.6 model in parasolid or maybe IGES(?) format. The Step format seems to lose most (but not all) the color when it get imported into Solidworks. Parasolid usually preserves it. Figured I ask. Thanks!
    Feb 2018
    1
    Quote Originally Posted by @ZS6HG View Post
    ZS6HG, Do you mind if I use this as the model for a Circuitmaker component?
    (The resulting part is publicly visible and usable).
