Results 1 to 11 of 11
Thread: Teensyduino 1.34 Beta #2
    Administrator Paul's Avatar
    Oct 2012
    306
    Here is a second beta test for Teensyduino 1.34.
    Changes since Teensyduino 1.34-beta1:
    • Support for Arduino 1.8.0
    • Revert ARM Toolchain back to gcc 4.8
    Changes since Teensyduino 1.33:
    • Update ARM Toolchain to gcc 5.4 (was gcc 4.8)
    • Add Tools > Optimize menu
    • Fix driver install/update on Windows 7 & 8
    • Prevent "might not have installed correctly" message on Windows
    3,653
    Installed on 1.8.0 Windows 64 bit and so far they work. Still faults at shutdown... But only a minor nit
    Also installed and programmed a T3.2 with blink on: MAC and Linux Arm (Odroid XU4)
    18,355
    I am able to reproduce the fault on Windows shutdown here too. Looks into it now...
    3,653
    I was wondering about some of the features of the 1.8.0 release, which the release notes state:
    ARDUINO 1.8.0 - 2016.12.20
    [ide]
    * Linux: running in command line mode doesn't require an X11 display anymore
    * "Save as" now clears the "modified" status
    * builder: Paths with strange UTF8 chars are now correctly handled
    * builder: .hpp and .hh file extensions are now considered valid sketch extension
    * builder: core.a is not rebuild if not needed (improve build time in particular for big projects)
    * Fixed swapped actions "Copy for Forum" and "Copy as HTML"
    * Linux/osx: If an editor tab is a symbolic link it is no more replaced with a real file when saving (see #5478)
    * Increased the upload timeout to 5 minutes (it was 2 min, but it may be not sufficient when uploading via UART a big sketch)
    [core]
    * Added Arduino.org boards
    * Added Adafruit Circuit Playground board
    * Added "-g" option to linker to keep debug information in the .elf file (see #5539)
    * avrdude: Added fake configuration for EFUSE on atmega8 part. This solves a long standing issue with "Burn bootloader".
    Thanks @rigelinorion, @awatterott
    So I wondered about could I build a teensy program from the command line on Linux (actually ARM linux). So I tried running it from a Putty window on my main machine.
    Found the syntax up at: https://github.com/arduino/Arduino/b...d/manpage.adoc
    odroid@odroid:~/Desktop/arduino-1.8.0$ ./arduino --upload --port /dev/ttyACM0 ./        ./examples/01.Basics/Blink/Blink.ino
    Picked up JAVA_TOOL_OPTIONS:
    Loading configuration...
    Initializing packages...
    Preparing boards...
    Verifying...
    Opening Teensy Loader...
    Unable find Teensy Loader.  (p)  Is the Teensy Loader application running?
    odroid@odroid:~/Desktop/arduino-1.8.0$ ./arduino --upload --port /dev/ttyACM0 ././examples/01.Basics/Blink/Blink.ino
    Preparing boards...
    Verifying...
    So it looks like the compile succeeds, but the Teensy loader fails... Wonder how hard that would be to change?
    Thank You! I am finally able to load a sketch on the 3.6 I've had for months. My computer is a 32 bit athlon and up until arduino 1.8 would not compile anything, get the dreaded
    SIGILL: illegal instruction
    PC=0x8115829
    which is fixed in 1.8 and now teensyduino works as well.
    18,355
    Has anyone noticed the Arduino 1.8.0 font issue on Windows?
    Should I bring in this patch?
    https://github.com/arduino/Arduino/pull/5756
    https://cloud.githubusercontent.com/...dd139dffdd.PNG
    3,653
    Yes please
    Edit: But wonder if this may imply that release 1.8.1 will be coming soon?
    Member dimitre's Avatar
    Aug 2016
    São Paulo
    57
    Thanks for the release. for some reason 1.8.0 and 1.34 beta2 are super fast to compile and upload to teensy
    18,355
    Quote Originally Posted by dimitre View Post
    This is probably part of the reason.
    https://github.com/arduino/arduino-builder/pull/194
    Build core.a seems to be particularly slow on Windows.
    Probably not. For some time they've been bumping the rev number right after each release, so the nightly builds and arduinobot builds don't have the same rev as the current release.
    953
    Yes. I didn't notice it while I was editing the code with the IDE but it is very noticeable in the serial monitor. The font looks thinner than it was before - I'm not sure whether it is a different font or somehow it is being drawn incorrectly (wrong strokewidth?). I can live with it but it would be nice to have it fixed once it is convenient for you to do so.
    Pete
    18,355
    I'm rebuilding the IDE java code with the right right now. Hope to have a 1.34-beta3 installer later today...
