Fritzing components for teensy 3.6
Moo
I've started building a teensy 3.6 fritzing component (for an teensy audio display project);
This is a work-in-progress and its only my second component I've created for fritzing, but I thought I'd share it.
So far I have:
a rough breadboard svg,
a rough schematic svg;
I am creating the pcb svg; then I will need to wire them up in fritzing;
Please feel free to use, modify, share, clone, correct, send pull request, etc...
https://github.com/newdigate/teensy-3.6
So far I have:
I'm looking forward to use this, any ETA on an importable part?
The PCB part is most important for me personally.
I don't think it'll be too long now, perhaps about a week or two.
I've finally finished the PCB svg, and now all I've got to do is wire it all together now as a fritzing component - although this seems to be the hardest part... I am struggling to re-open my saved component in fritzing - Once saved, Im not able to re-load in back into fritzing - it seems there is some manual work to be done.... I think i have finally found the solution;
I've done my best to pay attention to detail in creating the PCB svg graphic; https://github.com/newdigate/teensy-3.6/blob/master/fritzing/svgs/pcb.svg
When I say a week or two - I mean the untested fritzing component;
It will take me a few months to have the pcb printed and tested; As this is my first complete fritzing component there may be some errors which in time I hope will be ironed out;
I am very fond of the little teensy familty of devices and I think having a good fritzing component will help beginners diagram their ideas and make PC boards;
What I like about Fritzing is the breadboard view; It is also the only free PCB editor that I am aware of; Eagle is free but only for a limited size PCB;
There is also DesignSpark. Some people love it, some hate it. I have not tried it yet. I have been using the professional version of Eagle since the early 90's (DOS version 2.6). I needed the pro version because my simple 2 layer PC boards for vacuum tube amps are too big for any other version. I upgraded every year for about $100. When Newark / Farnell bought Eagle they up-revved it and wanted over $600 for me to upgrade. Then they modified the library format such that the old version (5.11) that I am using will not open any library created since then, and now want over $1000 for the upgrade. That is far beyond my budget, so I will probably try DesignSpark when I need to make something that requires a new library footprint.
https://www.rs-online.com/designspark/home
FYI - I use Diptrace. I started using it as I found it far more intuitive than Eagle. They have a freeware version of it that you can use as long as you are not making money from it, but it is limited to 2 layers and 300 pins. I purchased the standard addition, which is limited to 4 layers and 1000 pins.
I also purchased one of the Eagle lite additions (currently 6.6), that I use to look at other designs, plus use it to export data such as libraries in a format that I can then import into Diptrace.
I keep meaning to look into Kicad as well. There was also a recent posting by Seeedstudio about converting Eagle library to Kicad, which I have not tried yet, but: http://seeed.cc/Converting-Seeed-OP...m18&utm_medium=mailchimp&utm_campaign=fu_1229
Awesome! Thats good information... Thanks;
Here is a first version of a Fritzing component for Teensy 3.6:
https://github.com/newdigate/teensy-3.6/tree/master/fritzing
It is completely untested and is likely to contain errors; please feel free to add issues in github if you like. or on this forum...
Once I've done some testing myself I will submit to the Fritzing crowd;
Are there any eagle parts for teensy 3.6? I've not been able to find any; I would be surprised if I was the first person to make pcb footprints for the teensy 3.6 -
I have based my work on the Teensy 3.0 part for Fritzing by Fabian Althaus; Thank you Fabian.
