unicornpower
I'm trying to code a very simple comb filter using Teensy and the Audio Shield. I'm trying to copy something like the Resonator in Ableton. I plan to use it as a guitar effect, so when I play certain notes they ring out more than others. I'm using the delay object included in the audio library, but setting the delay time so that it is tuned to resonate at a certain pitch, using this simple calculation.
I have this setup so that I have both a feed forward, and a feed back comb filter. Only the feed forward one is currently enabled. I have added some simple test tone code. What I would expect to see, is that when the test tone matches the frequency that the comb filter is tuned to, the amplitude would essentially double. But depending on what note it's tuned to, the highest amplitude is often seen one tone up? I am seeing amplitude increase at the expected frequency, but not as much as 1 tone up. I suspect this is down to some error in my understanding of comb filters, but if someone more knowledgeable could point it out I'd be very appreciative! Full code included below for reference..
float calculate_delay_time_ms( float resonant_frequency )
return 1000.0f / resonant_frequency;
#define TEST_TONE
// Use these with the audio adaptor board
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
const int DRY_SIGNAL_CHANNEL( 0 );
const int FEED_FORWARD_CHANNEL( 1 );
const int FEED_BACKWARD_CHANNEL( 2 );
const int RESONANT_FREQ_PIN( 20 );
const int RESONANCE_TIME_PIN( 17 );
const float FREQUENCIES[] = { 65.41, // C2
69.30, // C#2
73.42, // D2
77.78, // D#2
82.41, // E2
87.31, // F2
92.50, // F#2
98.00, // G2
103.83, // G#2
110.00, // A2
116.54, // A#2
123.47, // B2
const float FREQUENCIES[] = { 261.63, // C4
277.18, // C#4
293.66, // D4
311.13, // D#4
329.63, // E4
349.23, // F4
369.99, // F#4
392.00, // G4
415.30, // G#4
440.00, // A4
466.16, // A#4
493.88, // B4
#ifdef TEST_TONE
AudioSynthWaveformSine test_tone;
AudioOutputI2S audio_output;
AudioMixer4 delay_mixer;
AudioEffectDelay feed_forward_delay;
AudioEffectDelay feed_back_delay;
AudioConnection patch_cord_1( test_tone, 0, delay_mixer, DRY_SIGNAL_CHANNEL );
AudioConnection patch_cord_2( delay_mixer, 0, audio_output, 0 );
AudioConnection patch_cord_3( test_tone, 0, feed_forward_delay, 0 );
AudioConnection patch_cord_4( feed_forward_delay, 0, delay_mixer, FEED_FORWARD_CHANNEL );
AudioConnection patch_cord_5( delay_mixer, 0, feed_back_delay, 0 );
AudioConnection patch_cord_6( feed_back_delay, 0, delay_mixer, FEED_BACKWARD_CHANNEL );
#else // !TEST_TONE
AudioInputI2S audio_input;
AudioConnection patch_cord_1( audio_input, 0, delay_mixer, DRY_SIGNAL_CHANNEL );
AudioConnection patch_cord_3( audio_input, 0, feed_forward_delay, 0 );
#endif // !TEST_TONE
float calculate_feedback_multiplier( float delay_time_ms, float resonance_time_ms )
const float p = delay_time_ms / resonance_time_ms;
return powf( 0.001, p );
AudioMemory( 128 );
sgtl5000_1.enable();
sgtl5000_1.volume(0.8f);
sgtl5000_1.lineInLevel( 10 ); // 0.56volts p-p
sgtl5000_1.lineOutLevel( 13 ); // 3.16volts p-p
delay( 1000 );
#ifdef TEST_TONE
test_tone.amplitude( 0.25f );
Serial.print("Setup started!\n");
const float delay_time_ms = calculate_delay_time_ms( FREQUENCIES[2] ); // tuned to D2
const float feedback_mult = calculate_feedback_multiplier( delay_time_ms, 1000.0f );
feed_forward_delay.delay( 0, delay_time_ms );
feed_back_delay.delay( 0, delay_time_ms );
delay_mixer.gain( DRY_SIGNAL_CHANNEL, 0.5f );
delay_mixer.gain( FEED_BACKWARD_CHANNEL, feedback_mult * 0.0f );
delay_mixer.gain( FEED_FORWARD_CHANNEL, feedback_mult * 0.5f );
Serial.print("Delay time ms:");
Serial.print(delay_time_ms);
Serial.print(" feedback mult:");
Serial.print(feedback_mult);
Serial.print("\nSetup finished!\n");
#ifdef TEST_TONE
static int current_tone_index = 0;
test_tone.frequency( FREQUENCIES[current_tone_index] );
Serial.print("Tone index:");
Serial.print( current_tone_index );
Serial.print(" Freq:");
Serial.println( FREQUENCIES[current_tone_index] );
delay( 2000 );
current_tone_index = ( current_tone_index + 1 ) % 12;
