Results 1 to 20 of 20
Thread: Just noise with Teensy 3.6 and Audio Adaptor Board
    Dec 2016
    18
    Dear forum members,
    I have attached the audio adaptor board to the teensy 3.6. The "SdCardTest" sketch and the "Part_1_03_Playing_Music" sketch both works (based on the output of the serial monitor), but I just hear noise. I have recorded the output of the headphone with my mobile: https://dl.dropboxusercontent.com/u/...audioboard.m4a
    Does anybody has an idea what's wrong?
    Peter
    1,080
    Exactly how did you do this? A photo would be good.
    Pete
    Dec 2016
    18
    Here it is:
    Germany NRW
    5,586
    Quote Originally Posted by Frickelpiet View Post
    Here it is:
    You might want to check every single connection.
    Would have been much easier to stack the boards..
    Dec 2016
    18
    I have checked and double checked every single connection.
    + 3,3 V is connected to a pololu regulator (3,3 V)
    GND is connected with GND of the regulator and the teensy
    All other connections are as follows:
    LRCLK pin 23
    TX    pin 22
    SCL   pin 19
    SDA   pin 18
    VOL   pin 15
    SCLK  pin 14
    RX    pin 13
    MISO  pin 12
    MCLK  pin 11
    SDCS  pin 10
    BCLK  pin 9
    MOSI  pin 7
    MEMCS pin 6
    2,187
    deleted, was wrong info
    Dec 2016
    18
    I have figured out that the wires are the problem. I think they are too long. Sometimes the board plays the test files until I touch the wires.
    Peter
    1,080
    Or perhaps one or more of those wires has a bad solder joint?
    Pete
    Feb 2014
    Colmar, France
    2,415
    What about pull up resistors for the I2C bus to stabilize the signals?
    Jun 2016
    rural West Virginia
    53
    I had a similar problem with a T3.2 and an audio adaptor connected by wires that were about 3 inches long. It seems that there can be some clock skew and cross coupling in those wires, especially without a good low inductance ground between the two boards. This causes the clock and data to get out of sync, resulting in noise. Adding some copper foil under the wires and separating each one cured the random rude sounds. Kapton tape holds the wires to the copper foil, which is grounded in multiple places. Other sound anomalies were cured by replacing the cheap SD card with a true Class 10 card. The project has worked perfectly ever since. Pictures are before and after the added ground. Click image for larger version.
ID:	9267Click image for larger version.
    Dec 2016
    18
    I have added the pullup resistors as recommended, and with them the audio board works better. But sometimes I still get the noise. I think I will solder the audio board on the top of the teensy.
    20,064
    Maybe small series resistors on the MCLK and BCLK outputs could also help?
    Same sort of trouble we've seen many times with OctoWS2811... before PJRC started selling the board with 100 ohm resistors and connectors for using CAT5 or CAT6 cable. The fast edges of the clocks and long wires can cause a lot of crosstalk.
    25
    Fighting with the same Issues at the moment.
    https://forum.pjrc.com/threads/40903...-Audio-Adaptor
    Seems to be the I2S Signal.
    No problems with a T3.1 with the same setup.
    I'll try the hint with the resistors when i'm back in office.
    20,064
    Please post photos of how you've actually connected the wires. Show (don't tell) how you've really connected everything.
    25
    So this is the actual Setup:
    Problem seems to be Pin 11 - MCLK.
    Adding a 1K Resistor improved the stability a lot. (chaos when touching the resistor pins - same as before)
    Im sorry I could not find the 10K Resistors. It stopped working with a 130K Resistor.
    then I bridged Pin 11 from Teensy and Audio Board with a piece of a Guinness can....
    (ok... in fact, i used one of the wires of a resistor.... i'm still not in office, so i have to improvise)
    problems were gone then.
    Dec 2016
    18
    Since I have soldered the Audio Adaptor Board on top of the teensy everything works flawless.
    Jun 2018
    1
    MCLK Fixed for me
    Quote Originally Posted by nemation View Post
    Made an account just to say that the MCLK fix worked for me. Sounded raspy and like the sample rate was constantly changing. Adding the 1K on MCLK fixed it entirely. I also have pull ups (1K) on the I2C bus as well, but I'm not sure if they are doing anything at the moment.
    Jan 2017
    16
    I struggled with this too. I used 300mm jumper wires that I had laying around with a teensy 3.2. and an audio adaptor perfectly fine for ages. As I was now testing a Teensy 3.6 I got very odd crackling, and general noise as well. I could faintly hear the actual audio in the background though.
    Adding the 1K on MCLK totally fixed it.
    Feb 2014
    Colmar, France
    2,415
    The BCLK and MCLK signals are RF @ 2.82 and 11.29MHz. It should be self-understanding to treat such signals in an appropriate way, keeping the wiring as short as possible to prevent parasitic inductance and to reduce the EM stray field. 300mm jumper wire is definitively not state of the art, and though a series resistor might cure several symptoms by damping the inductive effects of this wild wiring, it is not the optimal way to go since other problems like phase jitter might arise. Even when only prototyping a project, one should always do it already with a CE and/or FCC certification of the final commercial product in mind.
    20,064
    Using short wires is the best way.
    But I can tell you, PJRC will soon make a revision to the audio shield to add a 100 ohm resistor to the MCLK signal.
