#include "teensydmx.h"
#include "rdm.h"
static constexpr uint32_t BREAKSPEED = 100000;
static constexpr uint32_t RDM_BREAKSPEED = 45500;
static constexpr uint32_t BREAKFORMAT = SERIAL_8E1;
static constexpr uint32_t DMXSPEED = 250000;
static constexpr uint32_t DMXFORMAT = SERIAL_8N2;
static constexpr uint16_t NACK_WAS_ACK = 0xffff; // Send an ACK, not a NACK
// It was an easy job to register a manufacturer id to myself as explained
// on http://tsp.plasa.org/tsp/working_groups/CP/mfctrIDs.php.
// The ID below is designated as a prototyping ID.
static constexpr byte _devID[] = { 0x7f, 0xf0, 0x20, 0x12, 0x00, 0x00 };
// The Device ID for adressing all devices of a manufacturer.
static constexpr byte _devIDGroup[] = { 0x7f, 0xf0, 0xFF, 0xFF, 0xFF, 0xFF };
// The Device ID for adressing all devices: 6 times 0xFF.
static constexpr byte _devIDAll[] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
struct RDMDATA
//byte StartCode; // Start Code 0xCC for RDM (discarded by Recv)
byte SubStartCode; // Start Code 0x01 for RDM
byte Length; // packet length
byte DestID[6];
byte SourceID[6];
byte _TransNo; // transaction number, not checked
byte ResponseType; // ResponseType
byte _unknown; // I don't know, ignore this
uint16_t SubDev; // sub device number (root = 0)
byte CmdClass; // command class
uint16_t Parameter; // parameter ID
byte DataLength; // parameter data length in bytes
byte Data[231]; // data byte field
}; // struct RDMDATA
// the special discovery response message
struct DISCOVERYMSG
byte headerFE[7];
byte headerAA;
byte maskedDevID[12];
byte checksum[4];
}; // struct DISCOVERYMSG
// The DEVICEINFO structure (length = 19) has to be responsed for E120_DEVICE_INFO
// See http://rdm.openlighting.org/pid/display?manufacturer=0&pid=96
struct DEVICEINFO
byte protocolMajor;
byte protocolMinor;
uint16_t deviceModel;
uint16_t productCategory;
uint32_t softwareVersion;
uint16_t footprint;
byte currentPersonality;
byte personalityCount;
uint16_t startAddress;
uint16_t subDeviceCount;
byte sensorCount;
}; // struct DEVICEINFO
// Instance for UART0, UART1, UART2
static TeensyDmx *uartInstances[3] = {0};
static inline void putInt(void* const buffer, const size_t offset, const uint16_t value)
reinterpret_cast<byte*>(buffer)[offset] = value >> 8;
reinterpret_cast<byte*>(buffer)[offset + 1] = value & 0xff;
TeensyDmx::TeensyDmx(HardwareSerial& uart, struct RDMINIT* rdm, uint8_t redePin) :
m_uart(uart),
m_dmxBuffer1{0},
m_dmxBuffer2{0},
m_activeBuffer(m_dmxBuffer1),
m_inactiveBuffer(m_dmxBuffer2),
m_dmxBufferIndex(0),
m_frameCount(0),
m_newFrame(false),
m_rdmChange(false),
m_mode(DMX_OFF),
m_state(State::IDLE),
m_redePin(portOutputRegister(redePin)),
m_rdmMute(false),
m_identifyMode(false),
m_rdm(rdm),
m_deviceLabel{0}
pinMode(redePin, OUTPUT);
*m_redePin = 0;
if (&m_uart == &Serial1) {
uartInstances[0] = this;
} else if (&m_uart == &Serial2) {
uartInstances[1] = this;
} else if (&m_uart == &Serial3) {
uartInstances[2] = this;
TeensyDmx::TeensyDmx(HardwareSerial& uart, uint8_t redePin) :
TeensyDmx(uart, nullptr, redePin)
const volatile uint8_t* TeensyDmx::getBuffer() const
return m_inactiveBuffer;
bool TeensyDmx::isIdentify() const
return m_identifyMode;
const char* TeensyDmx::getLabel() const
return m_deviceLabel;
void TeensyDmx::setMode(TeensyDmx::Mode mode)
switch (m_mode)
case DMX_IN:
stopReceive();
case DMX_OUT:
stopTransmit();
default:
// No action
m_mode = mode;
switch (m_mode)
case DMX_IN:
startReceive();
case DMX_OUT:
startTransmit();
default:
*m_redePin = 0; // Off puts in receive state so as to be passive
void TeensyDmx::setChannel(const uint16_t address, const uint8_t value)
if (address < DMX_BUFFER_SIZE) {
m_activeBuffer[address] = value;
void TeensyDmx::setChannels(
const uint16_t startAddress,
const uint8_t* values,
const uint16_t length)
uint16_t currentAddress = 0;
while (currentAddress < startAddress && currentAddress < DMX_BUFFER_SIZE) {
m_activeBuffer[currentAddress] = 0;
++currentAddress;
for (uint16_t i = 0; i < length && currentAddress < DMX_BUFFER_SIZE; ++i) {
m_activeBuffer[currentAddress] = values[i];
++currentAddress;
while (currentAddress < DMX_BUFFER_SIZE) {
++currentAddress;
void TeensyDmx::nextTx()
if (m_state == State::BREAK) {
m_state = DMX_TX;
m_uart.begin(DMXSPEED, DMXFORMAT);
m_uart.write(0);
} else if (m_state == State::DMX_TX) {
// Check if we're at the end of the packet
if (m_dmxBufferIndex == DMX_BUFFER_SIZE) {
// Send BREAK
m_state = State::BREAK;
m_uart.begin(BREAKSPEED, BREAKFORMAT);
m_uart.write(0);
m_dmxBufferIndex = 0;
m_uart.write(m_activeBuffer[m_dmxBufferIndex]);
++m_dmxBufferIndex;
void uart0_status_isr(); // Back reference to serial1.c
void UART0TxStatus()
if ((UART0_C2 & UART_C2_TCIE) && (UART0_S1 & UART_S1_TC)) {
// TX complete
uartInstances[0]->nextTx();
// Call standard ISR too
uart0_status_isr();
void uart1_status_isr(); // Back reference to serial2.c
void UART1TxStatus()
if ((UART1_C2 & UART_C2_TCIE) && (UART1_S1 & UART_S1_TC)) {
// TX complete
uartInstances[1]->nextTx();
uart1_status_isr();
void uart2_status_isr(); // Back reference to serial3.c
void UART2TxStatus()
if ((UART2_C2 & UART_C2_TCIE) && (UART2_S1 & UART_S1_TC)) {
// TX complete
uartInstances[2]->nextTx();
uart2_status_isr();
void TeensyDmx::startTransmit()
*m_redePin = 1;
// Change interrupt vector to mine to monitor TX complete
attachInterruptVector(IRQ_UART0_STATUS, UART0TxStatus);
attachInterruptVector(IRQ_UART1_STATUS, UART1TxStatus);
attachInterruptVector(IRQ_UART2_STATUS, UART2TxStatus);
// Send BREAK
m_uart.write(0);
void TeensyDmx::stopTransmit()
m_uart.end();
attachInterruptVector(IRQ_UART0_STATUS, uart0_status_isr);
attachInterruptVector(IRQ_UART1_STATUS, uart1_status_isr);
attachInterruptVector(IRQ_UART2_STATUS, uart2_status_isr);
bool TeensyDmx::newFrame(void)
if (m_newFrame) {
m_newFrame = false;
return true;
return false;
bool TeensyDmx::rdmChanged(void)
if (m_rdmChange) {
m_rdmChange = false;
return true;
return false;
void TeensyDmx::completeFrame()
// Ensure we've processed all the data that may still be sitting
// in software buffers.
readBytes();
if (m_state == State::DMX_RECV || m_state == State::DMX_COMPLETE) {
// Update frame count and swap buffers
++m_frameCount;
if (m_activeBuffer == m_dmxBuffer1) {
m_activeBuffer = m_dmxBuffer2;
m_inactiveBuffer = m_dmxBuffer1;
m_activeBuffer = m_dmxBuffer1;
m_inactiveBuffer = m_dmxBuffer2;
m_newFrame = true;
} else if (m_state == State::RDM_RECV) {
// Check if we need to reply to this RDM message
m_state = State::IDLE; // Stop the ISR messing up things
processRDM();
void TeensyDmx::rdmUniqueBranch(const unsigned long timingStart, struct RDMDATA* rdm)
if (m_rdmMute) return;
if (rdm->Length != 36) return;
if (rdm->DataLength != 12) return;
if (memcmp(rdm->Data, _devID, sizeof(_devID)) <= 0 &&
memcmp(_devID, rdm->Data+6, sizeof(_devID)) <= 0) {
// I'm in range - say hello to the lovely controller
// respond a special discovery message !
struct DISCOVERYMSG *disc = (struct DISCOVERYMSG*)(m_activeBuffer);
uint16_t checksum = 6 * 0xFF;
// fill in the _rdm.discovery response structure
for (byte i = 0; i < 7; i++) {
disc->headerFE[i] = 0xFE;
disc->headerAA = 0xAA;
for (byte i = 0; i < 6; i++) {
disc->maskedDevID[i+i] = _devID[i] | 0xAA;
disc->maskedDevID[i+i+1] = _devID[i] | 0x55;
checksum += _devID[i];
disc->checksum[0] = (checksum >> 8) | 0xAA;
disc->checksum[1] = (checksum >> 8) | 0x55;
disc->checksum[2] = (checksum & 0xFF) | 0xAA;
disc->checksum[3] = (checksum & 0xFF) | 0x55;
// Send reply
stopReceive();
*m_redePin = 1;
m_uart.begin(RDM_BREAKSPEED, BREAKFORMAT);
m_uart.write(0);
m_uart.flush();
for (uint16_t i = 0; i < sizeof(struct DISCOVERYMSG); ++i) {
m_uart.write(m_activeBuffer[i]);
m_uart.flush();
startReceive();
void TeensyDmx::rdmUnmute(const unsigned long timingStart, struct RDMDATA* rdm)
if (rdm->DataLength == 0) {
m_rdmMute = false;
// Control field
rdm->Data[0] = 0;
rdm->Data[1] = 0;
rdm->DataLength = 2;
respondMessage(timingStart, NACK_WAS_ACK);
void TeensyDmx::rdmMute(const unsigned long timingStart, struct RDMDATA* rdm)
m_rdmMute = true;
// Control field
rdm->Data[0] = 0;
rdm->Data[1] = 0;
void TeensyDmx::rdmSetIdentify(const unsigned long timingStart, struct RDMDATA* rdm)
if (rdm->DataLength != 1) {
// Oversized data
respondMessage(timingStart, E120_NR_FORMAT_ERROR);
} else if ((rdm->Data[0] != 0) && (rdm->Data[0] != 1)) {
// Out of range data
respondMessage(timingStart, E120_NR_DATA_OUT_OF_RANGE);
m_identifyMode = rdm->Data[0] != 0;
m_rdmChange = true;
rdm->DataLength = 0;
void TeensyDmx::rdmSetDeviceLabel(const unsigned long timingStart, struct RDMDATA* rdm)
if (rdm->DataLength > sizeof(m_deviceLabel)) {
// Oversized data
memcpy(m_deviceLabel, rdm->Data, rdm->DataLength);
m_deviceLabel[rdm->DataLength] = '\0';
m_rdmChange = true;
void TeensyDmx::rdmSetStartAddress(const unsigned long timingStart, struct RDMDATA* rdm)
if (rdm->DataLength != 2) {
// Oversized data
uint16_t newStartAddress = (rdm->Data[0] << 8) | (rdm->Data[1]);
if ((newStartAddress <= 0) || (newStartAddress > DMX_BUFFER_SIZE)) {
// Out of range start address
} else if (m_rdm == nullptr) {
respondMessage(timingStart, E120_NR_HARDWARE_FAULT);
m_rdm->startAddress = newStartAddress;
m_rdmChange = true;
void TeensyDmx::rdmSetParameters(const unsigned long timingStart, struct RDMDATA* rdm)
respondMessage(timingStart, E120_NR_UNSUPPORTED_COMMAND_CLASS);
void TeensyDmx::rdmGetIdentify(const unsigned long timingStart, struct RDMDATA* rdm)
if (rdm->DataLength > 0) {
// Unexpected data
} else if (rdm->SubDev != 0) {
// No sub-devices supported
respondMessage(timingStart, E120_NR_SUB_DEVICE_OUT_OF_RANGE);
rdm->Data[0] = m_identifyMode;
rdm->DataLength = 1;
void TeensyDmx::rdmGetDeviceInfo(const unsigned long timingStart, struct RDMDATA* rdm)
// Unexpected data
// return all device info data
// The data has to be responsed in the Data buffer.
DEVICEINFO *devInfo = (DEVICEINFO *)(rdm->Data);
devInfo->protocolMajor = 1;
devInfo->protocolMinor = 0;
putInt(&devInfo->productCategory, 0, E120_PRODUCT_CATEGORY_DIMMER_CS_LED);
devInfo->softwareVersion = 0x00000010; // Endian swapped
devInfo->currentPersonality = 1;
devInfo->personalityCount = 1;
devInfo->subDeviceCount = 0;
devInfo->sensorCount = 0;
devInfo->deviceModel = 0;
devInfo->startAddress = 0;
devInfo->footprint = 0;
putInt(&devInfo->deviceModel, 0, m_rdm->deviceModelId);
putInt(&devInfo->startAddress, 0, m_rdm->startAddress);
putInt(&devInfo->footprint, 0, m_rdm->footprint);
rdm->DataLength = sizeof(DEVICEINFO);
void TeensyDmx::rdmGetManufacturerLabel(
// Unexpected data
// return the manufacturer label
rdm->DataLength = strlen(m_rdm->manufacturerLabel);
memcpy(rdm->Data, m_rdm->manufacturerLabel, rdm->DataLength);
void TeensyDmx::rdmGetModelDescription(
// Unexpected data
// return the DEVICE MODEL DESCRIPTION
rdm->DataLength = strlen(m_rdm->deviceModel);
memcpy(rdm->Data, m_rdm->deviceModel, rdm->DataLength);
void TeensyDmx::rdmGetDeviceLabel(const unsigned long timingStart, struct RDMDATA* rdm)
// Unexpected data
rdm->DataLength = strlen(m_deviceLabel);
memcpy(rdm->Data, m_deviceLabel, rdm->DataLength);
void TeensyDmx::rdmGetSoftwareVersion(
// Unexpected data
// return the SOFTWARE_VERSION_LABEL
rdm->DataLength = strlen(m_rdm->softwareLabel);
memcpy(rdm->Data, m_rdm->softwareLabel, rdm->DataLength);
void TeensyDmx::rdmGetStartAddress(const unsigned long timingStart, struct RDMDATA* rdm)
// Unexpected data
putInt(rdm->Data, 0, 0);
putInt(rdm->Data, 0, m_rdm->startAddress);
void TeensyDmx::rdmGetParameters(const unsigned long timingStart, struct RDMDATA* rdm)
// Unexpected data
rdm->DataLength = 6;
rdm->DataLength = 2 * (3 + m_rdm->additionalCommandsLength);
for (int n = 0; n < m_rdm->additionalCommandsLength; ++n) {
putInt(rdm->Data, 6+n+n, m_rdm->additionalCommands[n]);
putInt(rdm->Data, 0, E120_MANUFACTURER_LABEL);
putInt(rdm->Data, 2, E120_DEVICE_MODEL_DESCRIPTION);
putInt(rdm->Data, 4, E120_DEVICE_LABEL);
void TeensyDmx::processRDM()
unsigned long timingStart = micros();
struct RDMDATA* rdm = (struct RDMDATA*)(m_activeBuffer);
bool isForMe = (memcmp(rdm->DestID, _devID, sizeof(_devID)) == 0);
if (isForMe ||
memcmp(rdm->DestID, _devIDAll, sizeof(_devIDAll)) == 0 ||
memcmp(rdm->DestID, _devIDGroup, sizeof(_devIDGroup)) == 0) {
uint16_t parameter = (rdm->Parameter << 8) | ((rdm->Parameter >> 8) & 0xff);
switch (rdm->CmdClass)
case E120_DISCOVERY_COMMAND:
switch (parameter)
case E120_DISC_UNIQUE_BRANCH:
rdmUniqueBranch(timingStart, rdm);
case E120_DISC_UN_MUTE:
if (isForMe)
rdmUnmute(timingStart, rdm);
case E120_DISC_MUTE:
if (isForMe)
rdmMute(timingStart, rdm);
default:
respondMessage(timingStart, E120_NR_UNKNOWN_PID);
case E120_SET_COMMAND:
switch (parameter)
case E120_IDENTIFY_DEVICE:
rdmSetIdentify(timingStart, rdm);
case E120_DEVICE_LABEL:
rdmSetDeviceLabel(timingStart, rdm);
case E120_DMX_START_ADDRESS:
rdmSetStartAddress(timingStart, rdm);
case E120_SUPPORTED_PARAMETERS:
rdmSetParameters(timingStart, rdm);
default:
case E120_GET_COMMAND:
switch (parameter)
rdmGetIdentify(timingStart, rdm);
case E120_DEVICE_INFO:
rdmGetDeviceInfo(timingStart, rdm);
case E120_MANUFACTURER_LABEL:
rdmGetManufacturerLabel(timingStart, rdm);
case E120_DEVICE_MODEL_DESCRIPTION:
rdmGetModelDescription(timingStart, rdm);
rdmGetDeviceLabel(timingStart, rdm);
case E120_SOFTWARE_VERSION_LABEL:
rdmGetSoftwareVersion(timingStart, rdm);
rdmGetStartAddress(timingStart, rdm);
rdmGetParameters(timingStart, rdm);
default:
default:
void TeensyDmx::respondMessage(unsigned long timingStart, uint16_t nackReason)
uint16_t i;
uint16_t checkSum = 0;
// TIMING: don't send too fast, min: 176 microseconds
timingStart = micros() - timingStart;
if (timingStart < 176) {
delayMicroseconds(176 - timingStart);
// no need to set these data fields:
// StartCode, SubStartCode
if (nackReason == NACK_WAS_ACK) {
rdm->ResponseType = E120_RESPONSE_TYPE_ACK;
rdm->ResponseType = E120_RESPONSE_TYPE_NACK_REASON;
rdm->Data[0] = (nackReason >> 8) & 0xFF;
rdm->Data[1] = nackReason & 0xFF;
rdm->Length = rdm->DataLength + 24; // total packet length
// swap SrcID into DestID for sending back.
memcpy(rdm->DestID, rdm->SourceID, sizeof(rdm->SourceID));
memcpy(rdm->SourceID, _devID, sizeof(_devID));
++(rdm->CmdClass);
// Parameter
// prepare buffer and Checksum
checkSum += E120_SC_RDM;
for (i = 0; i < rdm->Length; i++) {
checkSum += m_activeBuffer[i];
// Send reply
stopReceive();
*m_redePin = 1;
m_uart.write(0);
m_uart.flush();
m_uart.write(E120_SC_RDM);
m_uart.flush();
for (uint16_t i = 0; i < rdm->Length; ++i) {
m_uart.flush();
m_uart.write(checkSum >> 8);
m_uart.flush();
m_uart.write(checkSum & 0xff);
m_uart.flush();
// Restart receive
startReceive();
void uart0_error_isr(); // Back reference to serial1.c
// UART0 will throw a frame error on the DMX break pulse. That's our
// cue to switch buffers and reset the index to zero
void UART0RxError(void)
// On break, uart0_status_isr() will probably have already
// fired and read the data buffer, clearing the framing error.
// If for some reason it hasn't, make sure we consume the 0x00
// byte that was received.
if (UART0_S1 & UART_S1_FE)
(void) UART0_D;
uartInstances[0]->completeFrame();
void uart1_error_isr(); // Back reference to serial2.c
// UART1 will throw a frame error on the DMX break pulse. That's our
void UART1RxError(void)
// On break, uart1_status_isr() will probably have already
if (UART1_S1 & UART_S1_FE)
(void) UART1_D;
uartInstances[1]->completeFrame();
void uart2_error_isr(); // Back reference to serial3.c
// UART2 will throw a frame error on the DMX break pulse. That's our
void UART2RxError(void)
// On break, uart2_status_isr() will probably have already
if (UART2_S1 & UART_S1_FE)
(void) UART2_D;
uartInstances[2]->completeFrame();
void TeensyDmx::startReceive()
*m_redePin = 0;
// UART Initialisation
m_uart.begin(250000);
// Fire UART0 receive interrupt immediately after each byte received
UART0_RWFIFO = 1;
// Set error IRQ priority lower than that of the status IRQ,
// so that the status IRQ receives any leftover bytes before
// we detect and trigger a new frame.
NVIC_SET_PRIORITY(IRQ_UART0_ERROR,
NVIC_GET_PRIORITY(IRQ_UART0_STATUS) + 1);
// Enable UART0 interrupt on frame error and enable IRQ
UART0_C3 |= UART_C3_FEIE;
NVIC_ENABLE_IRQ(IRQ_UART0_ERROR);
attachInterruptVector(IRQ_UART0_ERROR, UART0RxError);
// Fire UART1 receive interrupt immediately after each byte received
UART1_RWFIFO = 1;
NVIC_SET_PRIORITY(IRQ_UART1_ERROR,
NVIC_GET_PRIORITY(IRQ_UART1_STATUS) + 1);
// Enable UART1 interrupt on frame error and enable IRQ
UART1_C3 |= UART_C3_FEIE;
NVIC_ENABLE_IRQ(IRQ_UART1_ERROR);
attachInterruptVector(IRQ_UART1_ERROR, UART1RxError);
// Fire UART2 receive interrupt immediately after each byte received
UART2_RWFIFO = 1;
NVIC_SET_PRIORITY(IRQ_UART2_ERROR,
NVIC_GET_PRIORITY(IRQ_UART2_STATUS) + 1);
// Enable UART2 interrupt on frame error and enable IRQ
UART2_C3 |= UART_C3_FEIE;
NVIC_ENABLE_IRQ(IRQ_UART2_ERROR);
attachInterruptVector(IRQ_UART2_ERROR, UART2RxError);
void TeensyDmx::stopReceive()
m_uart.end();
UART0_RWFIFO = 0;
UART0_C3 &= ~UART_C3_FEIE;
NVIC_DISABLE_IRQ(IRQ_UART0_ERROR);
attachInterruptVector(IRQ_UART0_ERROR, uart0_error_isr);
UART1_RWFIFO = 0;
UART1_C3 &= ~UART_C3_FEIE;
NVIC_DISABLE_IRQ(IRQ_UART1_ERROR);
attachInterruptVector(IRQ_UART1_ERROR, uart1_error_isr);
UART2_RWFIFO = 0;
UART2_C3 &= ~UART_C3_FEIE;
NVIC_DISABLE_IRQ(IRQ_UART2_ERROR);
attachInterruptVector(IRQ_UART2_ERROR, uart2_error_isr);
void TeensyDmx::readBytes()
__disable_irq(); // Prevents conflicts with the error ISR
int available = m_uart.available();
while (available--)
switch (m_state)
case State::BREAK:
switch (m_uart.read())
case 0:
m_state = State::DMX_RECV;
case E120_SC_RDM:
m_state = State::RDM_RECV;
default:
case State::RDM_RECV:
case State::DMX_RECV:
++m_dmxBufferIndex;
m_activeBuffer[m_dmxBufferIndex] = m_uart.read();
if (m_dmxBufferIndex >= DMX_BUFFER_SIZE) {
if (m_state == State::DMX_RECV) {
m_state = State::DMX_COMPLETE;
m_state = State::IDLE; // Buffer full
default:
// Discarding bytes
m_uart.read();
__enable_irq();
void TeensyDmx::loop()
if (m_mode == DMX_IN) {
readBytes();
/* TeensyDmx - DMX Sender/Receiver with RDM for Teensy 3.2
Copyright (c) 2017 Peter Newman, Dan Large, http://daniellarge.co.uk
Copyright (c) 2017 Chris Staite
Copyright (c) 2014 Jim Paris
Copyright (c) 2014 Ward
Copyright (c) 2008-2009 Peter Knight, Tinker.it! All rights reserved.
Copyright (c) 2011-2013 by Matthias Hertel, http://www.mathertel.de
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
#ifndef _TEENSYDMX_H
#define _TEENSYDMX_H
#include "Arduino.h"
#ifndef UART_C3_FEIE
#define UART_C3_FEIE (uint8_t)0x02 // Framing Error Interrupt Enable
struct RDMINIT
const char *softwareLabel;
const char *manufacturerLabel;
const uint16_t deviceModelId;
const char *deviceModel;
uint16_t footprint;
const uint16_t additionalCommandsLength;
const uint16_t *additionalCommands;
}; // struct RDMINIT
class TeensyDmx
public:
enum Mode { DMX_OFF, DMX_IN, DMX_OUT };
TeensyDmx(HardwareSerial& uart, struct RDMINIT* rdm, uint8_t redePin);
TeensyDmx(HardwareSerial& uart, uint8_t redePin);
void setMode(TeensyDmx::Mode mode);
void loop();
// Returns true if a new frame has been received since the this was last called
bool newFrame();
// Use for receive
const volatile uint8_t* getBuffer() const;
// Returns true if RDM has changed since this was last called
bool rdmChanged();
// Returns true if the device should be in identify mode
bool isIdentify() const;
// Returns the user-set label of the device
const char* getLabel() const;
// Use for transmit with addresses from 0-511
// Will keep all other values as they were previously
void setChannel(const uint16_t address, const uint8_t value);
// Use for transmit with addresses from 1-512
void setDmxChannel(const uint16_t address, const uint8_t value)
setChannel(address - 1, value);
// Use for transmit with channels from 0-511
// Will set all other channels to 0
void setChannels(const uint16_t startAddress, const uint8_t* values, const uint16_t length);
// Use for transmit with channels from 1-512
void setDmxChannels(const uint16_t startAddress, const uint8_t* values, const uint16_t length)
setChannels(startAddress - 1, values, length);
private:
TeensyDmx(const TeensyDmx&);
TeensyDmx& operator=(const TeensyDmx&);
enum State { IDLE, BREAK, DMX_TX, DMX_RECV, DMX_COMPLETE, RDM_RECV };
enum { DMX_BUFFER_SIZE = 512 };
void startTransmit();
void stopTransmit();
void startReceive();
void stopReceive();
void completeFrame(); // Called at error ISR during recv
void processRDM();
void respondMessage(unsigned long timingStart, uint16_t nackReason);
void readBytes(); // Recv handler
void nextTx();
// RDM handler functions
void rdmUniqueBranch(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmUnmute(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmMute(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmSetIdentify(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmSetDeviceLabel(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmSetStartAddress(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmSetParameters(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmGetIdentify(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmGetDeviceInfo(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmGetManufacturerLabel(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmGetModelDescription(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmGetDeviceLabel(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmGetSoftwareVersion(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmGetStartAddress(const unsigned long timingStart, struct RDMDATA* rdm);
void rdmGetParameters(const unsigned long timingStart, struct RDMDATA* rdm);
HardwareSerial& m_uart;
volatile uint8_t m_dmxBuffer1[DMX_BUFFER_SIZE];
volatile uint8_t m_dmxBuffer2[DMX_BUFFER_SIZE];
volatile uint8_t *m_activeBuffer;
volatile uint8_t *m_inactiveBuffer;
volatile uint16_t m_dmxBufferIndex;
volatile unsigned int m_frameCount;
volatile bool m_newFrame;
volatile bool m_rdmChange;
Mode m_mode;
State m_state;
volatile uint8_t* m_redePin;
bool m_rdmMute;
bool m_identifyMode;
struct RDMINIT *m_rdm;
char m_deviceLabel[32];
friend void UART0TxStatus(void);
friend void UART1TxStatus(void);
friend void UART2TxStatus(void);
friend void UART0RxError(void);
friend void UART1RxError(void);
friend void UART2RxError(void);
#endif // _TEENSYDMX_H
This library is undergoing massive changes at the moment and I am (currently) unable to test any of them. Still, I am posting the updates here in the code snippets as they come in.
