Results 1 to 3 of 3
Thread: Teensy Loader GUI doesn't work, but the CLI version does.
    Dec 2016
    2
    I'm running Ubuntu 16.04 (64-bit), and have a Teensy 2.0. Despite having the udev rule installed, and trying several troubleshooting steps, I cannot get the Teensy Loader GUI to work. I says to "Press Button on Teensy to manually enter Program Mode", but doing that does not cause the Teensy Loader to react in any way. I've tried this on a different machine running Windows 10, and the result was the same.
    I then tried compiling teensy_loader_cli from source, and it worked flawlessly, allowing me to both upload one of the precompiled blink examples, and anything I wrote using Teensyduino.
    As a work arround, I thought that I could configure Teensyduino somehow to use the cli version rather than the gui version. Is there any way to do that?
    2,719
    what version of IDE and teensyduino are you using? I have a 64-bit ubuntu 16.04 with IDE 1.6.12 and TD 1.34. It builds and uploads fine to Teensy 2.
    Can you provide Verbose Info from teensy loader Help menu...
    Dec 2016
    2
    I'm running Arduino IDE 1.8.0 with Teensyduino 1.34
    Verbose output of Teensy loader when trying to upload blink_slow:
    17:02:42.067: Teensy Loader 1.34, begin program
    17:02:42.083: File "joystick.ino.hex". 4384 bytes, 7% used
    17:02:42.085: Listening for remote control on port 3149
    17:02:42.085: initialized, showing main window
    17:02:42.119: remote connection opened
    17:02:42.119: remote cmd: "comment: Teensyduino 1.34 - LINUX64 (teensy_post_compile)"
    17:02:42.120: remote cmd: "status"
    17:02:42.120: status data sent
    17:02:42.158: remote cmd: "dir:/tmp/arduino_build_810456/"
    17:02:42.158: remote cmd: "file:blink_slow.ino.hex"
    17:02:42.161: File "blink_slow.ino.hex". 2898 bytes, 4% used
    17:02:42.164: remote cmd: "status"
    17:02:42.164: status data sent
    17:02:42.202: remote cmd: "auto:on"
    17:02:42.213: remote connection closed
    17:02:42.222: remote connection opened
    17:02:42.223: remote cmd: "comment: Teensyduino 1.34 - LINUX64 (teensy_post_compile)"
    17:02:42.223: remote cmd: "status"
    17:02:42.224: status data sent
    17:02:42.272: remote connection closed
    17:02:42.336: HID/linux: bus "008", device "006" vid=16C0, pid=0486, ver=0102
    17:02:42.546: remote connection opened
    17:02:42.547: remote cmd: "comment: Teensyduino 1.34 - LINUX64 (teensy_reboot)"
    17:02:42.547: remote cmd: "status"
    17:02:42.548: status data sent
    17:02:42.588: remote cmd: "status"
    17:02:42.588: status data sent
    17:02:42.726: remote cmd: "status"
    17:02:42.727: status data sent
    17:02:42.827: remote cmd: "status"
    17:02:42.827: status data sent
    17:02:42.928: remote cmd: "status"
    17:02:42.928: status data sent
    17:02:43.028: remote cmd: "status"
    17:02:43.029: status data sent
    17:02:43.129: remote cmd: "status"
    17:02:43.129: status data sent
    17:02:43.229: remote cmd: "status"
    17:02:43.230: status data sent
    17:02:43.330: remote cmd: "status"
    17:02:43.330: status data sent
    17:02:43.430: remote cmd: "status"
    17:02:43.431: status data sent
    17:02:43.531: remote cmd: "status"
    17:02:43.531: status data sent
    17:02:43.632: remote cmd: "status"
    17:02:43.632: status data sent
    17:02:43.733: remote cmd: "status"
    17:02:43.733: status data sent
    17:02:43.833: remote cmd: "status"
    17:02:43.834: status data sent
    17:02:43.934: remote cmd: "status"
    17:02:43.934: status data sent
    17:02:44.035: remote cmd: "status"
    17:02:44.035: status data sent
    17:02:44.135: remote cmd: "status"
    17:02:44.136: status data sent
    17:02:44.236: remote cmd: "status"
    17:02:44.236: status data sent
    17:02:44.337: remote cmd: "status"
    17:02:44.337: status data sent
    17:02:44.437: remote cmd: "status"
    17:02:44.438: status data sent
    17:02:44.538: remote cmd: "status"
    17:02:44.538: status data sent
    17:02:44.639: remote cmd: "status"
    17:02:44.639: status data sent
    17:02:44.739: remote cmd: "status"
    17:02:44.740: status data sent
    17:02:44.840: remote cmd: "status"
    17:02:44.841: status data sent
    17:02:44.941: remote cmd: "status"
    17:02:44.941: status data sent
    17:02:45.042: remote cmd: "status"
    17:02:45.042: status data sent
    17:02:45.142: remote cmd: "status"
    17:02:45.143: status data sent
    17:02:45.243: remote cmd: "status"
    17:02:45.243: status data sent
    17:02:45.344: remote cmd: "status"
    17:02:45.344: status data sent
    17:02:45.444: remote cmd: "status"
    17:02:45.445: status data sent
    17:02:45.545: remote cmd: "status"
    17:02:45.545: status data sent
    17:02:45.646: remote cmd: "status"
    17:02:45.646: status data sent
    17:02:45.746: remote cmd: "status"
    17:02:45.746: status data sent
    17:02:45.847: remote cmd: "status"
    17:02:45.847: status data sent
    17:02:45.947: remote cmd: "status"
    17:02:45.948: status data sent
    17:02:46.048: remote cmd: "status"
    17:02:46.048: status data sent
    17:02:46.149: remote cmd: "status"
    17:02:46.149: status data sent
    17:02:46.249: remote cmd: "status"
    17:02:46.250: status data sent
    17:02:46.350: remote cmd: "status"
    17:02:46.350: status data sent
    17:02:46.451: remote cmd: "status"
    17:02:46.451: status data sent
    17:02:46.551: remote cmd: "status"
    17:02:46.552: status data sent
    17:02:46.652: remote cmd: "status"
    17:02:46.652: status data sent
    17:02:46.753: remote cmd: "status"
    17:02:46.753: status data sent
    17:02:46.853: remote cmd: "status"
    17:02:46.853: status data sent
    17:02:46.954: remote cmd: "status"
    17:02:46.954: status data sent
    17:02:47.055: remote cmd: "status"
    17:02:47.055: status data sent
    17:02:47.155: remote cmd: "status"
    17:02:47.155: status data sent
    17:02:47.256: remote cmd: "status"
    17:02:47.256: status data sent
    17:02:47.356: remote cmd: "status"
    17:02:47.357: status data sent
    17:02:47.457: remote cmd: "status"
    17:02:47.457: status data sent
    17:02:47.558: remote cmd: "status"
    17:02:47.558: status data sent
    17:02:47.669: remote connection closed
    17:02:53.517: Verbose Info event
