grease_lighting
One of my biggest problems in creating a project is determining what Teensy 3.2 pins to use for a given shield and are any other pins that MAY be needed as well. My background is in electronics and the coding part is trial by fire. I've been doing this for about 3 years now.
An example of this is the WIZ820 ethernet shield. Like others I find thru search of this forum/web or trial and error that I need Teensy pin #9 to be used for the WIZ820 RESET. Also in my searching I find that pin #8 is assigned for the power down function. I understand that for each functional shield used there is software (drivers) and each uses a pre-determined pin set to 'talk' to the module.
So my question is where in the software do I look, (file names, extensions) to find the pins used for a given shield so I may select and connect them without interfering with another shield or home brew electronics used in my project?
