Results 1 to 4 of 4
Thread: Strange looking limit checks in Teensy3 Version of Stream.cpp
    Jan 2017
    17
    when looking around how Serial is implemented, I stopped at this piece of code in Stream.cpp
    String Stream::readString(size_t max)
    	String str;
    	size_t length = str.length();
    	while (length < max) {
    		int c = timedRead();
    		if (c < 0) {
    			setReadError();
    			break;	// timeout
    		if (c == 0) break;
    		str += (char)c;
    	return str;
    If I understand the Arduino reference right then str.length() returns the actual size of the String, which is 0 after initialisation. After that the value of length is not more modified in the loop. So the condition is always while(0 < max).
    Do I miss something that is happening in background or is this a bug ?
    The same is happening in readStringUntil, too.
    4,029
    Quote Originally Posted by Frank2 View Post
    I haven't looked at the code. However, I would suspect that this line, which adds a single line to the end of the string bumps up the length:
    		str += (char)c;
    Jan 2017
    17
    Thanks for your answer,
    yes that's exactly what I mean. The String object and its internal length ist growing in this line. But the variable with name "length" isn't, because it's nowhere changed in the loop.
    I think
    while (str.length() < max) {
    is what is realy meant there.
    But anyway tho code is Arduino compatible as it is, because the original Arduino libraries don't do any length checks there. So introducing a limit may break some people's code. The only problem is, that not having a limit may cause other trouble.
    24,076
    Yes, I believe you're right. The length check is probably ineffective. A low priority bug which should get tested and fixed if the tests confirm the problem...
