Strange looking limit checks in Teensy3 Version of Stream.cpp
when looking around how Serial is implemented, I stopped at this piece of code in Stream.cpp
String Stream::readString(size_t max)
String str;
size_t length = str.length();
while (length < max) {
int c = timedRead();
if (c < 0) {
setReadError();
break; // timeout
if (c == 0) break;
str += (char)c;
return str;
If I understand the Arduino reference right then str.length() returns the actual size of the String, which is 0 after initialisation. After that the value of length is not more modified in the loop. So the condition is always while(0 < max).
Do I miss something that is happening in background or is this a bug ?
The same is happening in readStringUntil, too.
Senior Member+
Originally Posted by
Frank2
I haven't looked at the code. However, I would suspect that this line, which adds a single line to the end of the string bumps up the length:
Thanks for your answer,
yes that's exactly what I mean. The String object and its internal length ist growing in this line. But the variable with name "length" isn't, because it's nowhere changed in the loop.
I think
while (str.length() < max) {
is what is realy meant there.
But anyway tho code is Arduino compatible as it is, because the original Arduino libraries don't do any length checks there. So introducing a limit may break some people's code. The only problem is, that not having a limit may cause other trouble.
Yes, I believe you're right. The length check is probably ineffective. A low priority bug which should get tested and fixed if the tests confirm the problem...
- You may not post replies
- You may not edit your posts
Forum Rules
