i am working on getting to know the new lan8720a ethernet module and have been digging through Poul's example https://github.com/PaulStoffregen/k66_ethernet
on page 1458 in the data sheet is a list of the different flags
https://cdn.sparkfun.com/datasheets/Dev/Arduino/Boards/K66P144M180SF5RMV2.pdf
trying to make a nice struct for it i ended up with this:
on github https://github.com/alex-Arc/k66_ethernet
my question is, will the bit fields make this very slow and if so, how to do it differently and still keep the clarity of the 1 bit flags?
Alex
typedef struct {
uint16_t length;
union {
uint16_t all;
struct {
uint16_t TR : 1; //frame must be discarded. Set if the receive frame is truncated (frame length >TRUNC_FL).
uint16_t OV : 1; //This field is valid only if the L field is set. A receive FIFO overrun occurred
uint16_t CR : 1; //This field is valid only if the L field is set. Receive CRC or frame error.
uint16_t Reserved0 : 1; //Reserved
uint16_t NO : 1; //This field is valid only if the L field is set. Receive non-octet aligned frame
uint16_t LG : 1; //This field is valid only if the L field is set. A frame length greater than RCR[MAX_FL] was recognized.
uint16_t MC : 1; //Set if is multicast and not BC.
uint16_t BC : 1; //Set if is broadcast (FFFF_FFFF_FFFF).
uint16_t M : 1; //This field is valid only if the L and PROM bits are set. 0 The frame was received because of an address recognition hit. 1 The frame was received because of promiscuous mode.
uint16_t Reserved1 : 2; //Reserved
uint16_t L : 1; //last frame
uint16_t RO2 : 1;
uint16_t W : 1; //Warp
uint16_t RO1 : 1; //Receive software ownership. This field is reserved for use by software. This read/write field is not modified by hardware, nor does its value affect hardware.
uint16_t E : 1; //0 data in buffer. 1 buffer empty.
}flags;
void *buffer;
union {
uint32_t all;
struct {
uint8_t Reserved0 : 7;
uint8_t INT : 1;
uint8_t UC : 1; //unicast frame
uint8_t CE : 1; //Collision error The frame is invalid. Only valid if the L field is set.
uint8_t PE : 1; //PHY error The frame is invalid. Only valid if the L field is set.
uint8_t Reserved1 : 4;
uint8_t ME : 1; //Erroe in memory or receive FIFO overflow. Only valid if the L field is set.
uint8_t FRAG : 1; //This is a IPv4 fragment frame. Only valid if the L field is set.
uint8_t IPV6 : 1; //IPV6 tag. Only valid if the L field is set.
uint8_t VLAN : 1; //VLAN tag. Only valid if the L field is set.
uint8_t Reserved2 : 1;
uint8_t PCR : 1; //Protocol checksum error. Only valid if the L field is set.
uint8_t ICE : 1; //IP header checksum error. Only valid if the L field is set.
uint8_t Reserved3 : 2;
uint8_t Reserved4 : 5;
uint8_t VPCP : 3; //VLAN priority code 0-7
}moreflags;
uint16_t checksum;
uint8_t header;
uint8_t protocolType :7;
uint32_t dmadone;
uint32_t timestamp;
uint32_t unused1;
uint32_t unused2;
} enetbufferdesc_t;
Alex
