TelephoneBill
The objective of this thread is raise awareness of the multiple signal timing capability of the Flexible Timer Module (FTM). I recently discovered that FTM0 can be configured to compare up to eight signals simultaneously with a resolution of around 8 nanoSeconds.
For anyone not familiar with the FTM timers there are three such devices generally available in the Teensy 3 boards (FTM0, FTM1 and FTM2). My recent experiments use a T3.6 board but the same principles apply to other boards.
An FTM timer is basically a 16 bit counter (0 to 65535) that can be driven by either an internal or an external clock signal. The counter value can be read at any moment by the rising or falling edge of an external signal using what is known as a “Channel”. One “flexible aspect” of these channels is that they can be configured to be associated with various external Teensy Pins, such that the rising/falling edge of an external signal can “instantly freeze” the count value into a variable. That variable can then be used in a computation at some later time. (By the way, these variables are pre-defined in the Teensyduino environment.)
The “freezing” of a “read value” of the 16 bit counter is done in hardware by the FTM module, so it is not subject to any software delays or variability in timing caused by interrupts. The standard internal clock frequency is 60 MHz which means the timing resolution of the counter is 16.7 nanoSeconds – but this may be overclocked (with caveats) to 120 MHz, giving a resolution of 8.3 nanoSeconds.
My experiments have shown that each of these eight channels operates independently, which means that the accuracy in a “read value” is not affected by the actions of other channels. This then allows the timing of up to eight external signals to be compared simultaneously with good consistent precision.
If you use a precision external signal on one channel, such as a 1 pulse per second from a frequency standard (perhaps a cheap GPS module), then you can make a series of counter read values of known interval accuracy. By then using one of the other channels to also make a series of readings, you can write some internal software to compare these readings against the 1 PPS – and thereby compute the frequency or timing of the second external signal. This could be computed over many seconds, and this would increase the resolution of the measurement even beyond 8 nanoSeconds. The benefit of this technique is that it is independent of the accuracy of the 120 MHz internal bus peripheral clock. Any variability of the 120 MHz due to, say - ambient temperature, is the same for both sets of channel readings.
Using Teensy 3.6 and the FTM0 timer, the eight simultaneous external channels can be configured as follows:
CH0 = Port PTC1 (ALT4) = External Pin 22
CH1 = Port PTC2 (ALT4) = External Pin 23
CH2 = Port PTC3 (ALT4) = External Pin 9
CH3 = Port PTC4 (ALT4) = External Pin 10
CH4 = Port PTD4 (ALT4) = External Pin 6
CH5 = Port PTD5 (ALT4) = External Pin 20
CH6 = Port PTD6 (ALT4) = External Pin 21
CH7 = Port PTD7 (ALT4) = External Pin 5
(For more details, see Table “Signal Multiplexing” in para 11.3.1, page 184 of the K66 Reference Manual).
I will include some sample coding shortly in another post to this thread.
