Results 1 to 8 of 8
Thread: Getting +/-5v audio signals into the Teensy 3.x analog inputs
    Hi all
    I'd like to get modular synth audio signals into a Teensy for processing (pitch detection) but I'm green when it comes to electronics. Currently thinking I need to offset the +/-5v to 0-10v, then voltage divide that down to 0-3.3v. Is this correct, and is there a way of doing this without a -5v reference?
    I'm looking at this schematic from the Ornament and Crime module for its CV inputs, however that seems to be using a -5v reference from the eurorack power source, and I am trying to avoid that at this stage - I am powering the Teensy from USB and if its not too complicated I want to keep it that way whilst prototyping the code.
    Does anyone have an example of such an offset circuit, or how to calculate one? I have some of the MCP6004 op-amps as used in the O&C module.
    Thanks in advance !
    20,574
    Yep, that opamp circiut is the good way to do it, especially if the offset is a highly stable & accurate reference voltage.
    This would be the not-as-good way...
    https://www.dorkbotpdx.org/blog/paul...alog_input_pin
    More detailed discussion is here:
    https://forum.pjrc.com/threads/28423...late-cv-signal
    Thanks Paul, that not-as-good way you linked to looks like a good starting point. Note in this instance I want to get audio input in rather than CV, if that makes a difference.
    I was just looking at this schematic for an offset circuit:
    (from endolith's answer at http://electronics.stackexchange.com...sing-atmega328)
    ...and starting to learn how to use Circuits Cloud to try things out.
    I've attempted to combine your not-so-good offset and scaling schematic with a 16hz high-pass filter:
Name:	Screen Shot 2017-01-08 at 00.26.17.jpg
    Feb 2013
    563
    Quote Originally Posted by adamski View Post
    Hi all
    if you want to omit the +/- 12 V bus, you'd have to bias the op-amp* differently, like so:
    that's the circuit used at the O&C outputs, rather than inputs. in that case, V_out = - (R2/R1)*V_in + (1+R2/R1)*V_bias. R1 is typically/conventionally 100k ("high" impedance), so for a 10V input range, you'd pick R2=33k. the trick then is to come up with V_bias, which needs to be ~ 1.24V (= (1 + 33k/100k)*1.24V = 1.65V). in this case, a simple voltage divider should do: e.g., using the 3.3V supply, 49k9 and 30k would get you fairly close (= 30/(30+49.9)*3.3).
    *you'll need a rail-to-rail one, so MCP6004 is fine; you'd power it off 3.3v so the teensy is protected from over-voltage.
    Quote Originally Posted by mxxx View Post
    Thank you, that is super helpful. Much appreciated.
    I will be powering it off the 12v bus eventually, when I get round to installing the AD7367 I'm planning to try out for the CV inputs which needs 11-15v power.. (Need to get my SMT soldering skills up to scratch first!!)
    Feb 2013
    563
    note the schematic doesn't show the low pass / capacitor in the feedback path (it's value will depend on the sampling frequency; in case of OC: 560p ~ 8.6kHz cut-off / 16.7kHz Fs); also that's the kind of (DC-coupled) circuit you'd use for CV inputs rather than audio; i guess it'll do for testing purposes, but unless you actually intend to DC couple the inputs (choosing AD7367 suggests so?), eventually it might be preferable to AC-couple the inputs. the DLD schematic posted in the other thread has an example for AC-coupled inputs (see INA-1, INB-1).
    I am planning to have 4 DC-coupled CV inputs (possibly via the AD7367), and 1 audio input. I'll have a look at the DLD schematic for the AC-coupling, cheers.
